path: root/include/asm-mips/processor.h
2008-02-08aout: move STACK_TOP[_MAX] to asm/processor.hDavid Howells
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: rework TASK_SIZE macrosDave Hansen
The following replaces the earlier patches sent. It should address David Rientjes's comments, and has been compile tested on all the architectures that it touches, save for parisc. For the /proc/<pid>/pagemap code[1], we need to able to query how much virtual address space a particular task has. The trick is that we do it through /proc and can't use TASK_SIZE since it references "current" on some arches. The process opening the /proc file might be a 32-bit process opening a 64-bit process's pagemap file. x86_64 already has a TASK_SIZE_OF() macro: #define TASK_SIZE_OF(child) ((test_tsk_thread_flag(child, TIF_IA32)) ? IA32_PAGE_OFFSET : TASK_SIZE64) I'd like to have that for other architectures. So, add it for all the architectures that actually use "current" in their TASK_SIZE. For the others, just add a quick #define in sched.h to use plain old TASK_SIZE. 1. http://www.linuxworld.com/news/2007/042407-kernel.html - MIPS portion from Ralf Baechle <ralf@linux-mips.org> [akpm@linux-foundation.org: fix mips build] Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31[MIPS] Fixup secure computing stuff.Ralf Baechle
2007-07-10[MIPS] Convert init_thread initialization to ISO C initializers.Ralf Baechle
2007-07-10[MIPS] "extern inline" -> "static inline"Adrian Bunk
"extern inline" will have different semantics with gcc 4.3, and "static inline" is correct here. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-20Merge git://git.infradead.org/hdrcleanup-2.6Linus Torvalds
* git://git.infradead.org/hdrcleanup-2.6: (63 commits) [S390] __FD_foo definitions. Switch to __s32 types in joystick.h instead of C99 types for consistency. Add <sys/types.h> to headers included for userspace in <linux/input.h> Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h Remove struct fddi_statistics from user view in <linux/if_fddi.h> Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390 Revert include/media changes: Mauro says those ioctls are only used in-kernel(!) Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h> Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too Remove private struct dx_hash_info from public view in <linux/ext3_fs.h> Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h> Use __uXX types in <linux/divert.h> for struct divert_blk et al. Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible. Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely Use __uXX types in user-visible structures in <linux/nbd.h> Don't use 'u32' in user-visible struct ip_conntrack_old_tuple. Use __uXX types for S390 DASD volume label definitions which are user-visible S390 BIODASDREADCMB ioctl should use __u64 not u64 type. Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h> Fix private integer types used in V4L2 ioctls. ... Manually resolve conflict in include/linux/mtd/physmap.h
2006-06-19[MIPS] Unify mips_fpu_soft_struct and mips_fpu_hard_structs.Atsushi Nemoto
The struct mips_fpu_soft_struct and mips_fpu_hard_struct are completely same now and the kernel fpu emulator assumes that. This patch unifies them to mips_fpu_struct and get rid of mips_fpu_union. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-19[MIPS] FPU affinity for MT ASE.Ralf Baechle
2006-04-19[MIPS] MT: Improved multithreading support.Ralf Baechle
2006-01-12[PATCH] mips: task_stack_page()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] mips: task_pt_regs()Al Viro
2006-01-10MIPS: DSP: eleminate used_dsp.Ralf Baechle
used_dsp was meant to be used like used_math - but since the FPU context is small and lazy context switching is a stupid idea on multiprocessors this idea only got halfway implemented and those bits are were now breaking ptrace. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Support the MIPS32 / MIPS64 DSP ASE.Ralf Baechle
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
