path: root/include/asm-mips/time.h
2008-03-12[MIPS] Clocksource: Only install r4k counter as clocksource if present.Ralf Baechle
2008-01-29[MIPS] time: remove unused mips_timer_state()Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-26[MIPS] Only build r4k clocksource for systems that work ok with it.Ralf Baechle
In particular as-is it's not suited for multicore and mutiprocessors systems where there is on guarantee that the counter are synchronized or running from the same clock at all. This broke Sibyte and probably others since the "[MIPS] Handle R4000/R4400 mfc0 from count register." commit. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-26[MIPS] Handle R4000/R4400 mfc0 from count register.Ralf Baechle
The R4000 and R4400 have an errata where if the cp0 count register is read in the exact moment when it matches the compare register no interrupt will be generated. This bug may be triggered if the cp0 count register is being used as clocksource and the compare interrupt as clockevent. So a simple workaround is to avoid using the compare for both facilities on the affected CPUs. This is different from the workaround suggested in the old errata documents; at some opportunity probably the official version should be implemented and tested. Another thing to find out is which processor versions exactly are affected. I only have errata documents upto R4400 V3.0 available so for the moment the code treats all R4000 and R4400 as broken. This is potencially a problem for some machines that have no other decent clocksource available; this workaround will cause them to fall back to another clocksource, worst case the "jiffies" source.
2007-11-02[MIPS] time: Code cleanupsAtsushi Nemoto
* Do not include unnecessary headers. * Do not mention time.README. * Do not mention mips_timer_ack. * Make clocksource_mips static. It is now dedicated to c0_timer. * Initialize clocksource_mips.read statically. * Remove null_hpt_read. * Remove an argument of plat_timer_setup. It is just a placeholder. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-02[MIPS] time: Remove now unused local_timer_interrupt.Ralf Baechle
2007-10-29[MIPS] time: Replace plat_timer_setup with modern APIs.Ralf Baechle
plat_timer_setup is no longer getting called. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] time: Remove declaration of plat_timer_setup, there is no caller.Ralf Baechle
2007-10-19[MIPS] time: Helpers to compute clocksource/event shift and mult values.Ralf Baechle
2007-10-18[MIPS] time: Move R4000 clockevent device code to separate configurable fileRalf Baechle
2007-10-18[MIPS] time: Delete dead cycles_per_jiffy, mips_timer_ack and null_timer_ackRalf Baechle
cycles_per_jiffy was only ever getting assigned and the function pointer not being called anymore and mips_timer_ack had gotten similarly stale. I leave the remaining assignments unfixed as a lighthouse pointing platform maintainers to what needs a rewrite. These changes make null_timer_ack() unreferenced, so delete that too. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Implement clockevents for R4000-style cp0 count/compare interruptRalf Baechle
2007-10-11[MIPS] Consolidate all variants of MIPS cp0 timer interrupt handlers.Ralf Baechle
2007-10-11[MIPS] Switch from to_tm to rtc_time_to_tmRalf Baechle
This replaces the MIPS-specific to_tm function with the generic rtc_time_to_tm function. The big difference between the two functions is that rtc_time_to_tm uses epoch 70 while to_tm uses 1970, so the result of rtc_time_to_tm needs to be fixed up. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] mips HPT cleanup: make clocksource_mips publicAtsushi Nemoto
Make clocksource_mips public and get rid of mips_hpt_read, mips_hpt_mask. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] mips hpt cleanup: get rid of mips_hpt_initAtsushi Nemoto
Currently nobody outside time.c require mips_hpt_init(). Remove it and call c0_hpt_timer_init() directly if R4k counter was used for timer interrupt. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-31[MIPS] Fixup migration to GENERIC_TIMEAtsushi Nemoto
Since we already moved to GENERIC_TIME, we should implement alternatives of old do_gettimeoffset routines to get sub-jiffies resolution from gettimeofday(). This patch includes: * MIPS clocksource support (based on works by Manish Lachwani). * remove unused gettimeoffset routines and related codes. * remove unised 64bit do_div64_32(). * simplify mips_hpt_init. (no argument needed, __init tag) * simplify c0_hpt_timer_init. (no need to write to c0_count) * remove some hpt_init routines. * mips_hpt_mask variable to specify bitmask of hpt value. * convert jmr3927_do_gettimeoffset to jmr3927_hpt_read. * convert ip27_do_gettimeoffset to ip27_hpt_read. * convert bcm1480_do_gettimeoffset to bcm1480_hpt_read. * simplify sb1250 hpt functions. (no need to subtract and shift) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-03-27[PATCH] mips: fixed collision of rtc function nameYoichi Yuasa
Fix the collision of rtc function name. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07Use rtc_lock to protect RTC operationsAtsushi Nemoto
Many RTC routines were not protected against each other, so there are potential races, for example, ntp-update against /dev/rtc. This patch fixes them using rtc_lock. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
