path: root/include/asm-mips
2008-06-05[MIPS] Fix typo in header guardVegard Nossum
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-05[MIPS] Add accessors for random register.Ralf Baechle
2008-06-05[MIPS] Add missing braces to pte_mkyoungIlpo Järvinen
Only the version pte_mkyoung for 36-bit pagetables on 32-bit hw was affected and with this bug being around since November 29, 2004 there is evidence to suport the assumption it was benign ;-) Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-05[MIPS] Alchemy: dbdma: add API to delete custom DDMA device ids.Manuel Lauss
Add API to delete custom DDMA device ids create with au1xxx_ddma_device_add(). Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-24fix parenthesis in include/asm-mips/mach-au1x00/au1000.hMariusz Kozlowski
Parenthesis fix in include/asm-mips/mach-au1x00/au1000.h Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24fix parenthesis in include/asm-mips/gic.hMariusz Kozlowski
Parenthesis fix in include/asm-mips/gic.h Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-12[MIPS] Get rid of __ilog2Ralf Baechle
56a6b1eb7bfb5ace0b5cb9c149f502fbd101b8ab was a bit too conservative and left __ilog2 around which is only used as an internal function for other bitops. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Fix __fls for non-MIPS32/MIPS64 cpusThomas Bogendoerfer
Only MIPS32 and MIPS64 CPUs implement clz/dclz. Therefore don't export __ilog2() for non MIPS32/MIPS64 cpus and use generic __fls bitop code for these cpus. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1200/DBAu1200 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - initialization of a 'static' variable to 0; - space after opening and before closing parentheses; - missing space between 'for' and opening parenthesis; - macros with complex values not enclosed in parentheses; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used; - line over 80 characters. In addition to these changes, also do the following: - mention DBAu1200 board in the Makefile; - replace the group of #include/#ifdef directives by a single #include <au1xxx.h> since this header contains the needed stuff; - properly indent the blocks; - insert spaces between operator and its operands, remove excess spaces there; - remove needless parentheses and add some for clarity; - replace numeric literals/expressions with the matching macros; - remove space after the type cast's closing parenthesis; - reduce pb1200_setup_cascade() to the single 'return' statement; - reduce the number of printed empty lines in the so-called CPLD workaround; - remove #undef AU1X00_EXTERNAL_INT since that macro is not defined anywhere; - replace spaces after the macro name with tabs in the #define directives; - remove excess tabs after the macro name in the #define directives; - fix typo in the BCSR_RESETS_PWMR1mUX macro's name; - group all Pb1200 PCMCIA definitions together; - put the function's result type and name/parameters on the same line; - insert missing and remove excess new lines; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space/asterisk on their left side; - fix typos/errors, capitalize acronyms, etc. in the comments; - combine some comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1550 code style cleanupSergei Shtylyov
Fix a few errors and warnings given by checkpatch.pl: - macros with complex values not enclosed in parentheses; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - replace numeric literals with the matching macros; - properly indent the code and the array initializers; - insert spaces between operator and its operands, also remove excess spaces there; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives, also sometimes insert space there for better looks; - remove excess tabs after the macro name in the #define directives; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1500 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - replace numeric literals/expressions with the matching macros; - insert spaces between operator and its operands; - properly indent the code and the array initializers; - remove useless #if dirctive from board_setup(); - remove needless parentheses; - remove unneeded type casts; - remove excess new lines; - make hexadecimal literals all lower case; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives, also sometimes insert space there for better looks; - fix typos/errors, capitalize acronyms, etc. in the comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1100 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - space between asterisk and variable name; - use of C99 // comments; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - properly indent the code; - remove space after the type cast's closing parenthesis; - replace numeric literals/expressions with the matching macros; - replace spaces after the macro name with tabs in the #define directives, and sometimes insert spaces there; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1000 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - brace not on the same line with condition in the 'switch' statement; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - properly indent the 'switch' statement; - remove needless parentheses; - insert spaces between operator and its operands; - replace numeric literals/expressions with the matching macros; - remove useless #if dirctive from board_setup(); - remove unneeded numeric literal type casts; - remove space after the type cast's closing parenthesis; - replace spaces after the macro name with tabs in the #define directives, and sometimes insert spaces there; - remove excess new lines; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first/last line; - combine some comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] DBAu1xx0 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - macros with complex values not enclosed in parentheses; - leading spaces instead of tabs; - printk() without KERN_* facility level; - using simple_strtol() where strict_strtol() could be used; - line over 80 characters. In addition to these changes, also do the following: - initialize variable instead of assigning value later where it makes sense; - insert spaces between operator and its operands, also remove excess spaces there; - remove unneeded numeric literal type casts; - remove needless parentheses; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives; - remove excess tabs after the macro name in the #define directives; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first/last line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Alchemy common headers style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - space after opening and before closing parentheses; - opening brace following 'struct' not on the same line; - leading spaces instead of tabs; - use of C99 // comments; - macros with complex values not enclosed in parentheses; - missing space between the type and asterisk in a variable declaration; - space between asterisk and function name; - including <asm/io.h> instead of <linux/io.h> and <asm/irq.h> instead of <linux/irq.h>; - use of '__inline__' instead of 'inline'; - space between function name and opening parenthesis; - line over 80 characters. In addition to these changes, also do the following: - remove needless parentheses; - insert spaces between operator and its operands; - replace spaces after the macro name with tabs in the #define directives and after the type in the structure field declarations; - remove excess tabs after the macro name in the #define directives and in the 'extern' variable declarations; - remove excess spaces between # and define for the SSI_*_MASK macros to align with other such macros; - put '||' operator on the same line with its first operand; - properly indent multi-line function prototypes; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space/asterisk on their left side; - make two-line comments that only have one line of text one-line; - convert the large multi-line comment in au1xxx_ide.h into several one-liners, replace spaces with tabs there; - fix typos/errors, capitalize acronyms, etc. in the comments; - insert missing and remove excess new lines; - update MontaVista copyright; - remove Pete Popov's and Steve Longerbeam's old email addresses... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Add empty argument parenthesis to GCC_IMM_ASMRalf Baechle
This is to clarify that GCC_IMM_ASM does not take an argument as the context of the macro's invocation seems to imply. As suggested by Maciej W. Rozycki (macro@linux-mips.org). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] MT: Functional fixes and a little reformatting of APRP supportKevin D. Kissell
Signed-off-by: Kevin D. Kissell <kevink@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-04fix asm-mips/types.h syntax errorAdrian Bunk
This patch fixes the following compile error caused by commit 23cf11ddb5099f8c7f7cb3eb154bff0faf31cae9 (mips: types: use <asm-generic/int-*.h> for the mips architecture): <-- snip --> ... CC kernel/bounds.s In file included from /home/bunk/linux/kernel-2.6/git/linux-2.6/include/linux/types.h:12, from /home/bunk/linux/kernel-2.6/git/linux-2.6/include/linux/page-flags.h:8, from /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/bounds.c:9: include2/asm/types.h:56:2: error: #endif without #if make[2]: *** [kernel/bounds.s] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-05-02mips: types: use <asm-generic/int-*.h> for the mips architectureH. Peter Anvin
This modifies <asm-mips/types.h> to use the <asm-generic/int-*.h> generic include files. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30asm-*/futex.h should include linux/uaccess.hJeff Dike
Lots of asm-*/futex.h call pagefault_enable and pagefault_disable, which are declared in linux/uaccess.h, without including linux/uaccess.h. They all include asm/uaccess.h, so this patch replaces asm/uaccess.h with linux/uaccess.h. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: Move arches to use common unaligned accessHarvey Harrison
Unaligned access is ok for the following arches: cris, m68k, mn10300, powerpc, s390, x86 Arches that use the memmove implementation for native endian, and the byteshifting for the opposite endianness. h8300, m32r, xtensa Packed struct for native endian, byteshifting for other endian: alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh m86knommu is generic_be for Coldfire, otherwise unaligned access is ok. frv, arm chooses endianness based on compiler settings, uses the byteshifting versions. Remove the unaligned trap handler from frv as it is now unused. v850 is le, uses the byteshifting versions for both be and le. Remove the now unused asm-generic implementation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (45 commits) [MIPS] Pb1200/DBAu1200: move platform code to its proper place [MIPS] Fix handling of trap and breakpoint instructions [MIPS] Pb1200: do register SMC 91C111 [MIPS] DBAu1200: fix bad SMC 91C111 resource size [NET] Kconfig: Rename MIKROTIK_RB500 -> MIKROTIK_RB532 [MIPS] IP27: Fix build bug due to missing include [MIPS] Fix some sparse warnings on traps.c and irq-msc01.c [MIPS] cevt-gt641xx: Kill unnecessary include [MIPS] DS1287: Add clockevent driver [MIPS] add DECstation I/O ASIC clocksource [MIPS] rbtx4938: minor cleanup [MIPS] Alchemy: kill unused PCI_IRQ_TABLE_LOOKUP macro [MIPS] rbtx4938: misc cleanups [MIPS] jmr3927: use generic txx9 gpio [MIPS] rbhma4500: use generic txx9 gpio [MIPS] generic txx9 gpio support [MIPS] make fallback gpio.h gpiolib-friendly [MIPS] unexport null_perf_irq() and make it static [MIPS] unexport rtc_mips_set_time() [MIPS] unexport copy_from_user_page() ...
2008-04-28[MIPS] Pb1200/DBAu1200: move platform code to its proper placeSergei Shtylyov
Since both the IDE interface and SMC 91C111 Ethernet chip are on-board devices, not SOC devices, move the platform device registration form the common to the board specific code. While at it, remove semicolon (which didn't break compilation only by chance) from the AU1XXX_ATA_DDMA_REQ macro and do some renaming: - change 'au1200_ide0_' variable name prefix to the mere 'ide_'; - change 'smc91x_' variable name prefix to 'smc91c111_' since that's the name of the chip used on the boards; - drop 'AU1XXX_' prefix from the names of macros describing IDE and Ethernet on-board devices; - change 'SMC91111_' to 'SMC91C111_', change 'IRQ' to 'INT' in the names of the macros describing the Ethernet chip for consistency with the IDE macros; - change 'ATA_' to 'IDE_' and 'OFFSET' to 'SHIFT' (since this value is indeed a shift count) in the names of the macros describing the IDE interface. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] IP27: Fix build bug due to missing includeAdrian Bunk
asm-mips/mach-ip27/topology.h must #include <asm-generic/topology.h> This fixes the following compile error: ... CC kernel/sched.o /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c: In function 'find_next_best_node': /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7015: error: implicit declaration of function 'node_to_cpumask_ptr' /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7015: error: '__tmp__' undeclared (first use in this function) /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7015: error: (Each undeclared identifier is reported only once /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7015: error: for each function it appears in.) /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c: In function 'sched_domain_node_span': /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7047: error: 'nodemask' undeclared (first use in this function) /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7048: warning: ISO C90 forbids mixed declarations and code /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7059: error: implicit declaration of function 'node_to_cpumask_ptr_next' /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c: In function '__build_sched_domains': /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7605: error: 'pnodemask' undeclared (first use in this function) make[2]: *** [kernel/sched.o] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Fix some sparse warnings on traps.c and irq-msc01.cAtsushi Nemoto
* Declare board_bind_eic_interrupt, board_watchpoint_handler in traps.h * Make msc_bind_eic_interrupt static and fix its argument types. * Make msc_levelirq_type, msc_edgeirq_type static. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] DS1287: Add clockevent driverYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] add DECstation I/O ASIC clocksourceYoichi Yuasa
Add DECstation I/O ASIC clocksource Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill unused PCI_IRQ_TABLE_LOOKUP macroSergei Shtylyov
2008-04-28[MIPS] rbtx4938: misc cleanupsAtsushi Nemoto
* Do not use non-standard I/O accessors, such as reg_rd08, etc. * Kill unnecessary wbflush() * Kill tx4938_mips.h * Kill unnecessary includes Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] jmr3927: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for JMR3927 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] rbhma4500: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for RBHMA4500 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] generic txx9 gpio supportAtsushi Nemoto
This is a board-independent TXx9 gpio API implementation using gpiolib. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] make fallback gpio.h gpiolib-friendlyAtsushi Nemoto
If gpiolib was selected, asm-generic/gpio.h provides some prototypes for gpio API and implementation helpers. With this patch, platform code can implement its GPIO API using gpiolib without custom gpio.h file. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: don't unmask timer IRQ earlySergei Shtylyov
Defer the unmasking of the count/compare interrupt (IRQ5) till the clockevent driver initialization: - only enable the cascaded IRQs 0 thru 4 in arch_init_irq(); kill the ALLINTS macro -- this change is blessed by AMD as I saw it in their own patch; :-) - do not force IRQ5 enabled in plat_time_init() if PM is enabled and there's no 32 KHz crystal. Update the copyrights (taking into account my prior changes), also removing Pete Popov's old email... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Move arch/mips/philips to arch/mips/nxpDaniel Laird
Signed-off-by: daniel.j.laird <daniel.j.laird@nxp.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Add support for MIPS CMP platform.Ralf Baechle
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Add CoreFPGA5 support; distinguish between SOCit/ROCitChris Dearman
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Allow setting of the cache attribute at run time.Chris Dearman
Slightly tacky, but there is a precedent in the sparc archirecture code. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Tidy up cache attributesChris Dearman
2008-04-28[MIPS] All MIPS32 processors support64-bit physical addresses.Chris Dearman
Still, only the 4K may actually implement it. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28serial: add VR41xx SIU setup for serial consoleYoichi Yuasa
Add VR41xx SIU setup for serial console. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-generic-bitops-v3 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-generic-bitops-v3: x86, bitops: select the generic bitmap search functions x86: include/asm-x86/pgalloc.h/bitops.h: checkpatch cleanups - formatting only x86: finalize bitops unification x86, UML: remove x86-specific implementations of find_first_bit x86: optimize find_first_bit for small bitmaps x86: switch 64-bit to generic find_first_bit x86: generic versions of find_first_(zero_)bit, convert i386 bitops: use __fls for fls64 on 64-bit archs generic: implement __fls on all 64-bit archs generic: introduce a generic __fls implementation x86: merge the simple bitops and move them to bitops.h x86, generic: optimize find_next_(zero_)bit for small constant-size bitmaps x86, uml: fix uml with generic find_next_bit for x86 x86: change x86 to use generic find_next_bit uml: Kconfig cleanup uml: fix build error
2008-04-26au1xxx-ide: fix MWDMA supportBartlomiej Zolnierkiewicz
Always use "fast" MWDMA support and remove dma_{black,white}_list (they were based on completely bogus ->ide_dma_check implementation which didn't set neither the host controller timings nor the device for the desired transfer mode). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26generic: implement __fls on all 64-bit archsAlexander van Heukelum
Implement __fls on all 64-bit archs: alpha has an implementation of fls64. Added __fls(x) = fls64(x) - 1. ia64 has fls, but not __fls. Added __fls based on code of fls. mips and powerpc have __ilog2, which is the same as __fls. Added __fls = __ilog2. parisc, s390, sh and sparc64: Include generic __fls. x86_64 already has __fls. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (58 commits) ide: remove ide_init_default_irq() macro ide: move default IDE ports setup to ide_generic host driver ide: remove obsoleted "idex=noprobe" kernel parameter (take 2) ide: remove needless hwif->irq check from ide_hwif_configure() ide: init hwif->{io_ports,irq} explicitly in legacy VLB host drivers ide: limit legacy VLB host drivers to alpha, x86 and mips cmd640: init hwif->{io_ports,irq} explicitly cmd640: cleanup setup_device_ptrs() ide: add ide-4drives host driver (take 3) ide: remove ppc ifdef from init_ide_data() ide: remove ide_default_io_ctl() macro ide: remove CONFIG_IDE_ARCH_OBSOLETE_INIT ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2) ppc/pmac: remove no longer needed IDE quirk ppc: don't include <linux/ide.h> ppc: remove ppc_ide_md ppc/pplus: remove ppc_ide_md.ide_init_hwif hook ppc/sandpoint: remove ppc_ide_md hooks ppc/lopec: remove ppc_ide_md hooks ppc/mpc8xx: remove ppc_ide_md hooks ...
2008-04-18ide: remove ide_init_default_irq() macroBartlomiej Zolnierkiewicz
* Use ide_default_irq() instead of ide_init_default_irq() in ide_generic host driver (so the correct IRQ is always set regardless of CONFIG_PCI / CONFIG_BLK_DEV_IDEPCI). * Remove no longer needed ide_init_default_irq() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove ide_default_io_ctl() macroBartlomiej Zolnierkiewicz
It is always == '((base) + 0x206)' if CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=y and it is not needed otherwise (arm, blackfin, parisc, ppc64, sh, sparc[64]). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2)Bartlomiej Zolnierkiewicz
* Add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_DEFAULTS in <arch/ide.h>. v2: * Define ide_default_irq() in ide-probe.c/ns87415.c if not already defined and drop defining ide_default_irq() for CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=n. [ Thanks to Stephen Rothwell and David Miller for noticing the problem. ] Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Miller <davem@davemloft.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
