path: root/include/asm-mn10300
2008-05-08MN10300: Make cpu_relax() invoke barrier()David Howells
Make cpu_relax() invoke barrier() to be the same as other arches. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-02mn10300: types: use <asm-generic/int-*.h> for the mn10300 architectureH. Peter Anvin
This modifies <asm-mn10300/types.h> to use the <asm-generic/int-*.h> generic include files. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: Move arches to use common unaligned accessHarvey Harrison
Unaligned access is ok for the following arches: cris, m68k, mn10300, powerpc, s390, x86 Arches that use the memmove implementation for native endian, and the byteshifting for the opposite endianness. h8300, m32r, xtensa Packed struct for native endian, byteshifting for other endian: alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh m86knommu is generic_be for Coldfire, otherwise unaligned access is ok. frv, arm chooses endianness based on compiler settings, uses the byteshifting versions. Remove the unaligned trap handler from frv as it is now unused. v850 is le, uses the byteshifting versions for both be and le. Remove the now unused asm-generic implementation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-06Really unexport asm/page.hDavid Woodhouse
Commit ed7b1889da256977574663689b598d88950bbd23 removed page.h from include/asm-generic/Kbuild so that it shouldn't get exported. However, it was redundantly listed in asm-mn10300/Kbuild and asm-x86/Kbuild too. Remove those as well, so it really stops being exported on those architectures. Also remove the redundant listing of ptrace.h and termios.h from mn10300. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23MN10300: define SO_MARKDavid Howells
Define SO_MARK for MN10300. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23MN10300: define HZ as a config optionDavid Howells
Define HZ as a config option. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Final removal of FASTCALL()/fastcallHarvey Harrison
All users are gone, remove definitions and comments referring to them. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mn10300: add the MN10300/AM33 architecture to the kernelDavid Howells
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the kernel. This patch also adds board support for the ASB2303 with the ASB2308 daughter board, and the ASB2305. The only processor supported is the MN103E010, which is an AM33v2 core plus on-chip devices. [akpm@linux-foundation.org: nuke cvs control strings] Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com> Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
