path: root/include/asm-parisc
2008-05-15parisc: use conditional macro for 64-bit wide opsKyle McMartin
This work enables us to remove -traditional from $AFLAGS on parisc. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: Remove ioctl.h content picked up from <asm-generic/ioctl.h>.Robert P. J. Day
Now that <asm-generic/ioctl.h> allows overriding of the most commonly changed macro values, take advantage of that. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: new termios definitionsAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-02parisc: types: use <asm-generic/int-*.h> for the parisc architectureH. Peter Anvin
This modifies <asm-parisc/types.h> to use the <asm-generic/int-*.h> generic include files. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org>
2008-04-30asm-*/futex.h should include linux/uaccess.hJeff Dike
Lots of asm-*/futex.h call pagefault_enable and pagefault_disable, which are declared in linux/uaccess.h, without including linux/uaccess.h. They all include asm/uaccess.h, so this patch replaces asm/uaccess.h with linux/uaccess.h. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: Move arches to use common unaligned accessHarvey Harrison
Unaligned access is ok for the following arches: cris, m68k, mn10300, powerpc, s390, x86 Arches that use the memmove implementation for native endian, and the byteshifting for the opposite endianness. h8300, m32r, xtensa Packed struct for native endian, byteshifting for other endian: alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh m86knommu is generic_be for Coldfire, otherwise unaligned access is ok. frv, arm chooses endianness based on compiler settings, uses the byteshifting versions. Remove the unaligned trap handler from frv as it is now unused. v850 is le, uses the byteshifting versions for both be and le. Remove the now unused asm-generic implementation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26generic: implement __fls on all 64-bit archsAlexander van Heukelum
Implement __fls on all 64-bit archs: alpha has an implementation of fls64. Added __fls(x) = fls64(x) - 1. ia64 has fls, but not __fls. Added __fls based on code of fls. mips and powerpc have __ilog2, which is the same as __fls. Added __fls = __ilog2. parisc, s390, sh and sparc64: Include generic __fls. x86_64 already has __fls. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (58 commits) ide: remove ide_init_default_irq() macro ide: move default IDE ports setup to ide_generic host driver ide: remove obsoleted "idex=noprobe" kernel parameter (take 2) ide: remove needless hwif->irq check from ide_hwif_configure() ide: init hwif->{io_ports,irq} explicitly in legacy VLB host drivers ide: limit legacy VLB host drivers to alpha, x86 and mips cmd640: init hwif->{io_ports,irq} explicitly cmd640: cleanup setup_device_ptrs() ide: add ide-4drives host driver (take 3) ide: remove ppc ifdef from init_ide_data() ide: remove ide_default_io_ctl() macro ide: remove CONFIG_IDE_ARCH_OBSOLETE_INIT ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2) ppc/pmac: remove no longer needed IDE quirk ppc: don't include <linux/ide.h> ppc: remove ppc_ide_md ppc/pplus: remove ppc_ide_md.ide_init_hwif hook ppc/sandpoint: remove ppc_ide_md hooks ppc/lopec: remove ppc_ide_md hooks ppc/mpc8xx: remove ppc_ide_md hooks ...
2008-04-18ide: remove ide_default_io_ctl() macroBartlomiej Zolnierkiewicz
It is always == '((base) + 0x206)' if CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=y and it is not needed otherwise (arm, blackfin, parisc, ppc64, sh, sparc[64]). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-15[PARISC] futex: special case cmpxchg NULL in kernel spaceKyle McMartin
Commit a0c1e9073ef7428a14309cba010633a6cd6719ea added code to futex.c to detect whether futex_atomic_cmpxchg_inatomic was implemented at run time: + curval = cmpxchg_futex_value_locked(NULL, 0, 0); + if (curval == -EFAULT) + futex_cmpxchg_enabled = 1; This is bogus on parisc, since page zero in kernel virtual space is the gateway page for syscall entry, and should not be read from the kernel. (That, and we really don't like the kernel faulting on its own address space...) Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-03-15[PARISC] clean up include/asm-parisc/elf.hRandolph Chung
Cleanup some cruft. No functionality changes. Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-03-15[PARISC] pdc_console: fix bizarre panic on bootKyle McMartin
Commit 721fdf34167580ff98263c74cead8871d76936e6 introduced a subtle bug by accidently removing the "static" from iodc_dbuf. This resulted in, what appeared to be, a trap without *current set to a task. Probably the result of a trap in real mode while calling firmware. Also do other misc clean ups. Since the only input from firmware is non blocking, share iodc_dbuf between input and output, and spinlock the only callers. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-15[PARISC] remove unused pdc_iodc_printf functionKyle McMartin
2008-03-15[PARISC] bump __NR_syscallsKyle McMartin
oops, forgot this in the previous commit. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-15[PARISC] unbreak pgalloc.hKyle McMartin
Commit 2f569afd9ced9ebec9a6eb3dbf6f83429be0a7b4 broke the compile rather spectacularly. Fix code errors. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-15[PARISC] move VMALLOC_* definitions to fixmap.hKyle McMartin
They make way more sense here, really... Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-15[PARISC] wire up timerfd syscallsKyle McMartin
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08asm-*/posix_types.h: scrub __GLIBC__Mike Frysinger
Some arches (like alpha and ia64) already have a clean posix_types.h header. This brings all the others in line by removing all references to __GLIBC__ (and some undocumented __USE_ALL). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: move STACK_TOP[_MAX] to asm/processor.hDavid Howells
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Add cmpxchg_local to pariscMathieu Desnoyers
Use the new generic cmpxchg_local (disables interrupt). Also use the generic cmpxchg as fallback if SMP is not set. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Cleanup asm/{elf,page,user}.h: #ifdef __KERNEL__ is no longer neededKirill A. Shutemov
asm/elf.h, asm/page.h and asm/user.h don't export to userspace now, so we can drop #ifdef __KERNEL__ for them. [k.shutemov@gmail.com: remove #ifdef __KERNEL_] Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: rework TASK_SIZE macrosDave Hansen
The following replaces the earlier patches sent. It should address David Rientjes's comments, and has been compile tested on all the architectures that it touches, save for parisc. For the /proc/<pid>/pagemap code[1], we need to able to query how much virtual address space a particular task has. The trick is that we do it through /proc and can't use TASK_SIZE since it references "current" on some arches. The process opening the /proc file might be a 32-bit process opening a 64-bit process's pagemap file. x86_64 already has a TASK_SIZE_OF() macro: #define TASK_SIZE_OF(child) ((test_tsk_thread_flag(child, TIF_IA32)) ? IA32_PAGE_OFFSET : TASK_SIZE64) I'd like to have that for other architectures. So, add it for all the architectures that actually use "current" in their TASK_SIZE. For the others, just add a quick #define in sched.h to use plain old TASK_SIZE. 1. http://www.linuxworld.com/news/2007/042407-kernel.html - MIPS portion from Ralf Baechle <ralf@linux-mips.org> [akpm@linux-foundation.org: fix mips build] Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03include/asm-parisc/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03asm-*/compat.h: fix typo in commentMarcin Ślusarz
Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03vga.h: Fix prepocessor warningFrank Lichtenheld
Mark comment as comment, fixes: include/asm/vga.h:6:8: warning: extra tokens at end of #endif directive Signed-off-by: Frank Lichtenheld <frank@lichtenheld.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-31[NET]: Introducing socket mark socket option.Laszlo Attila Toth
A userspace program may wish to set the mark for each packets its send without using the netfilter MARK target. Changing the mark can be used for mark based routing without netfilter or for packet filtering. It requires CAP_NET_ADMIN capability. Signed-off-by: Laszlo Attila Toth <panther@balabit.hu> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-30x86: remove flush_agp_mappings()Ingo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-06[PARISC] print more than one character at a time for pdc consoleKyle McMartin
There's really no reason not to print more than one character at a time to the PDC console... Booting is measurably speedier, and now I don't have to watch individual characters get drawn. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-23parisc: fix sg_page() falloutFUJITA Tomonori
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_map_sg': arch/parisc/kernel/pci-dma.c:487: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_unmap_sg': arch/parisc/kernel/pci-dma.c:508: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c:508: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_cpu': arch/parisc/kernel/pci-dma.c:535: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c:535: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_device': arch/parisc/kernel/pci-dma.c:545: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c:545: error: 'struct scatterlist' has no member named 'page' Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Add CONFIG_DEBUG_SG sg validationJens Axboe
Add a Kconfig entry which will toggle some sanity checks on the sg entry and tables. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Change table chaining layoutJens Axboe
Change the page member of the scatterlist structure to be an unsigned long, and encode more stuff in the lower bits: - Bits 0 and 1 zero: this is a normal sg entry. Next sg entry is located at sg + 1. - Bit 0 set: this is a chain entry, the next real entry is at ->page_link with the two low bits masked off. - Bit 1 set: this is the final entry in the sg entry. sg_next() will return NULL when passed such an entry. It's thus important that sg table users use the proper accessors to get and set the page member. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-20Merge branch 'master' of ↵Linus Torvalds
hera.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6 * 'master' of hera.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (29 commits) [PARISC] fix uninitialized variable warning in asm/rtc.h [PARISC] Port checkstack.pl to parisc [PARISC] Make palo target work when $obj != $src [PARISC] Zap unused variable warnings in pci.c [PARISC] Fix tests in palo target [PARISC] Fix palo target [PARISC] Restore palo target [PARISC] Attempt to clean up parisc/Makefile [PARISC] Fix infinite loop in /proc/iomem [PARISC] Quiet sysfs_create_link __must_check warnings in pdc_stable [PARISC] Squelch pci_enable_device __must_check warning in superio [PARISC] Kill off broken irqstack code [PARISC] Remove hardcoded uses of PAGE_SIZE [PARISC] Clean up pointless ASM_PAGE_SIZE_DIV use [PARISC] Kill off the last vestiges of ASM_PAGE_SIZE [PARISC] Kill off ASM_PAGE_SIZE use [PARISC] Beautify parisc vmlinux.lds.S [PARISC] Clean up a resource_size_t warning in sba_iommu [PARISC] Kill incorrect cast warning in unwinder [PARISC] Kill zone_to_nid printk warning ... Fixed trivial conflict in include/asm-parisc/tlbflush.h manually
2007-10-20[PARISC] fix uninitialized variable warning in asm/rtc.hKyle McMartin
get_rtc_time, in the case that PDC returns that the battery is bad, returns an unmodified rtc_time arg to the caller, which then uses uninitialized values. Fix this by memset-ing the arg with zeroes, so it will at least be cleared if we return failure. Spotted by John David Anglin. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-20ide: add CONFIG_IDE_ARCH_OBSOLETE_INITBartlomiej Zolnierkiewicz
Add CONFIG_IDE_ARCH_OBSOLETE_INIT to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_INIT in <arch/ide.h>. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19forbid asm/bitops.h direct inclusionJiri Slaby
forbid asm/bitops.h direct inclusion Because of compile errors that may occur after bit changes if asm/bitops.h is included directly without e.g. linux/kernel.h which includes linux/bitops.h, forbid direct inclusion of asm/bitops.h. Thanks to Adrian Bunk. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove unused flush_tlb_pgtablesBenjamin Herrenschmidt
Nobody uses flush_tlb_pgtables anymore, this patch removes all remaining traces of it from all archs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18bitops: introduce lock opsNick Piggin
Introduce test_and_set_bit_lock / clear_bit_unlock bitops with lock semantics. Convert all architectures to use the generic implementation. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-By: David Howells <dhowells@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Andi Kleen <ak@muc.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18[PARISC] Kill off broken irqstack codeKyle McMartin
It's been unfinished and broken long enough, and I have some ideas on how to do it more cleanly. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Kill off ASM_PAGE_SIZE useSam Ravnborg
We have the macro _AC() generally available now so the calculation of PAGE_SIZE can be made assembler compatible. Introduce use of _AC() and kill all users of ASM_PAGE_SIZE. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] parisc: "extern inline" -> "static inline"Adrian Bunk
"extern inline" will have different semantics with gcc 4.3, and "static inline" is correct here. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Clean up asm-parisc/pdc.hKyle McMartin
If we're going to export the header, at least let's organize it sensibly and not have a mishmash of userspace, assembly, and kernel visible defines. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Export pdc.h for paloJeff Bailey
Signed-off-by: Jeff Bailey <jbailey@raspberryginger.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Wire up sys_fallocate (and compat_sys_fallocate)Kyle McMartin
2007-10-17Remove dma_cache_(wback|inv|wback_inv) functionsRalf Baechle
dma_cache_(wback|inv|wback_inv) were the earliest attempt on a generalized cache managment API for I/O purposes. Originally it was basically the raw MIPS low level cache API exported to the entire world. The API has suffered from a lack of documentation, was not very widely used unlike it's more modern brothers and can easily be replaced by dma_cache_sync. So remove it rsp. turn the surviving bits back into an arch private API, as discussed on linux-arch. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
