path: root/include/asm-powerpc/oprofile_impl.h
2006-03-29[PATCH] powerpc: Remove oprofile spinlock backtrace codeAnton Blanchard
Remove oprofile spinlock backtrace code now we have proper calltrace support. Also make MMCRA sihv and sipr bits a variable since they may change in future cpus. Finally, MMCRA should be a 64bit quantity. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-29[PATCH] powerpc: Add oprofile calltrace supportBrian Rogan
Add oprofile calltrace support to powerpc. Disable spinlock backtracing now we can use calltrace info. (Updated to work on both 32bit and 64bit by me). Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-28[PATCH] powerpc: Remove some ifdefs in oprofile_impl.hAnton Blanchard
- No one uses op_counter_config.valid, so remove it - No need to ifdef around function protypes. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: sanitize header files for user space includesArnd Bergmann
include/asm-ppc/ had #ifdef __KERNEL__ in all header files that are not meant for use by user space, include/asm-powerpc does not have this yet. This patch gets us a lot closer there. There are a few cases where I was not sure, so I left them out. I have verified that no CONFIG_* symbols are used outside of __KERNEL__ any more and that there are no obvious compile errors when including any of the headers in user space libraries. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: G4+ oprofile supportAndy Fleming
This patch adds oprofile support for the 7450 and all its multitudinous derivatives. * Added 7450 (and derivatives) support for oprofile * Changed e500 cputable to have oprofile model and cpu_type fields * Added support for classic 32-bit performance monitor interrupt * Cleaned up common powerpc oprofile code to be as common as possible * Cleaned up oprofile_impl.h to reflect 32 bit classic code * Added 32-bit MMCRx bitfield definitions and SPR numbers Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-21[PATCH] powerpc: merge oprofile headersStephen Rothwell
Merge include/asm-ppc64/oprofile_ipml.h and arch/ppc/oprofile/op_impl.h into include/asm-powerpc/oprofile_ipml.h Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
