machine_is() was always returning 0 when used in a module, because
we weren't exporting the machine definitions. This was why sound
wasn't working on powermacs when CONFIG_SND_POWERMAC=m. Original
fix from Ben Herrenschmidt, further fixed by me.
Some devices don't support full 32-bit DMA address space, which we currently
assume. Add the required mask-passing to the IOMMU allocators.
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-merge:
powerpc: Use correct sequence for putting CPU into nap mode
[PATCH] spufs: fix context-switch decrementer code
[PATCH] powerpc32: Set cpu explicitly in kernel compiles
[PATCH] powerpc/pseries: bugfix: balance calls to pci_device_put
[PATCH] powerpc: Fix machine detection in prom_init.c
[PATCH] ppc32: Fix string comparing in platform_notify_map
[PATCH] powerpc: Avoid __initcall warnings
[PATCH] powerpc: Ensure runlatch is off in the idle loop
powerpc: Fix CHRP booting - needs a define_machine call
powerpc: iSeries has only 256 IRQs
We weren't using the recommended sequence for putting the CPU into
nap mode. When I changed the idle loop, for some reason 7447A cpus
started hanging when we put them into nap mode. Changing to the
recommended sequence fixes that.
The complexity here is that the recommended sequence is a loop that
keeps putting the cpu back into nap mode. Clearly we need some way
to break out of the loop when an interrupt (external interrupt,
decrementer, performance monitor) occurs. Here we use a bit in
the thread_info struct to indicate that we need this, and the exception
entry code notices this and arranges for the exception to return
to the value in the link register, thus breaking out of the loop.
We use a new `local_flags' field in the thread_info which we can
alter without needing to use an atomic update sequence.
The PPC970 has the same recommended sequence, so we do the same thing
there too.
This also fixes a bug in the kernel stack overflow handling code on
32-bit, since it was causing a value that we needed in a register to
get trashed.
Basically an in-kernel implementation of tee, which uses splice and the
pipe buffers as an intelligent way to pass data around by reference.
Where the user space tee consumes the input and produces a stdout and
file output, this syscall merely duplicates the data inside a pipe to
another pipe. No data is copied, the output just grabs a reference to the
input pipe data.
Signed-off-by: Jens Axboe <axboe@suse.de>
Current implementations define NODES_SHIFT in include/asm-xxx/numnodes.h for
each arch. Its definition is sometimes configurable. Indeed, ia64 defines 5
NODES_SHIFT values in the current git tree. But it looks a bit messy.
SGI-SN2(ia64) system requires 1024 nodes, and the number of nodes already has
been changeable by config. Suitable node's number may be changed in the
future even if it is other architecture. So, I wrote configurable node's
number.
This patch set defines just default value for each arch which needs multi
nodes except ia64. But, it is easy to change to configurable if necessary.
On ia64 the number of nodes can be already configured in generic ia64 and SN2
config. But, NODES_SHIFT is defined for DIG64 and HP'S machine too. So, I
changed it so that all platforms can be configured via CONFIG_NODES_SHIFT. It
would be simpler.
See also: http://marc.theaimsgroup.com/?l=linux-kernel&m=114358010523896&w=2
Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jack Steiner <steiner@sgi.com>
The iSeries Hypervisor only allows us to specify IRQ numbers up to 255 (it
has a u8 field to pass it in). This patch allows platforms to specify a
maximum to the virtual IRQ numbers we will use and has iSeries set that
to 255. If not set, the maximum is NR_IRQS - 1 (as before).
This patch removes unnecessary exports, marks functions as static when
possible, and simplifies some list-related code.
Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com>
Signed-off-by: Linas Vepstas <linas@austin.ibm.com>
This extends the HCALL interface for InfiniBand usage. I've
made the patch against the linux-2.6 git tree and Segher's patch:
[PATCH] Change H_StudlyCaps to H_SHOUTING_CAPS
We moved this into the common powerpc code based on comments we
got after posting the first eHCA InfiniBand device driver patch.
Signed-off-by: Heiko j Schick <schickhj@de.ibm.com>
Also cleans up some nearby whitespace problems.
Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[NET]: Allow skb headroom to be overridden
[TCP]: Kill unused extern decl for tcp_v4_hash_connecting()
[NET]: add SO_RCVBUF comment
[NET]: Deinline some larger functions from netdevice.h
[DCCP]: Use NULL for pointers, comfort sparse.
[DECNET]: Fix refcount
Previously we added NET_IP_ALIGN so an architecture can override the
padding done to align headers. The next step is to allow the skb
headroom to be overridden.
We currently always reserve 16 bytes to grow into, meaning all DMAs
start 16 bytes into a cacheline. On ppc64 we really want DMA writes to
start on a cacheline boundary, so we increase that headroom to one
cacheline.
This adds support for the sys_splice system call. Using a pipe as a
transport, it can connect to files or sockets (latter as output only).
From the splice.c comments:
"splice": joining two ropes together by interweaving their strands.
This is the "extended pipe" functionality, where a pipe is used as
an arbitrary in-memory buffer. Think of a pipe as a small kernel
buffer that you can use to transfer data from one end to the other.
The traditional unix read/write is extended with a "splice()" operation
that transfers data buffers to or from a pipe buffer.
Named by Larry McVoy, original implementation from Linus, extended by
Jens to support splicing to files and fixing the initial implementation
bugs.
Remove oprofile spinlock backtrace code now we have proper calltrace
support. Also make MMCRA sihv and sipr bits a variable since they may
change in future cpus. Finally, MMCRA should be a 64bit quantity.
Add oprofile calltrace support to powerpc. Disable spinlock backtracing
now we can use calltrace info.
(Updated to work on both 32bit and 64bit by me).
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes
in the past where people were using for_each_cpu() where they should have been
iterating across only online or present CPUs. This is inefficient and
possibly buggy.
We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the
future.
This patch replaces for_each_cpu with for_each_possible_cpu.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
This removes statically assigned platform numbers and reworks the
powerpc platform probe code to use a better mechanism. With this,
board support files can simply declare a new machine type with a
macro, and implement a probe() function that uses the flattened
device-tree to detect if they apply for a given machine.
We now have a machine_is() macro that replaces the comparisons of
_machine with the various PLATFORM_* constants. This commit also
changes various drivers to use the new macro instead of looking at
_machine.
There are at least 14 different implementations of WARN() in the tree already.
The build fails all over the place.
Cc: Michael Ellerman <michael@ellerman.id.au>
We used to assume that a DMA mapping request with a NULL dev was for
ISA DMA. This assumption was broken at some point. Now we explicitly
pass the detected ISA PCI device in the floppy setup.
These are some updates from both Ryan and Arnd for the hvc_console
driver:
The main point is to enable the inclusion of a console driver
for rtas, which is currrently needed for the cell platform.
Also shuffle around some data-type declarations and moves some
functions out of include/asm-ppc64/hvconsole.h and into a new
drivers/char/hvc_console.h file.
Signed-off-by: "Ryan S. Arnold" <rsa@us.ibm.com>
Signed-off-by: Arnd Bergmann <abergman@de.ibm.com>
We need to export ppc64_firmware_features for modules. Before we do that
I think we should probably rename it to powerpc_firmware_features.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Export validate_sp so we can use it in the oprofile calltrace code.
- No one uses op_counter_config.valid, so remove it
- No need to ifdef around function protypes.
32-bit CHRP machines are now supported only in arch/powerpc, as are
all 64-bit PowerPC processors. This means that we don't use
Open Firmware on any platform in arch/ppc any more.
This makes PReP support a single-platform option like every other
platform support option in arch/ppc now, thus CONFIG_PPC_MULTIPLATFORM
is gone from arch/ppc. CONFIG_PPC_PREP is the option that selects
PReP support and is generally what has replaced
CONFIG_PPC_MULTIPLATFORM within arch/ppc.
_machine is all but dead now, being #defined to 0.
Updated Makefiles, comments and Kconfig options generally to reflect
these changes.
The kernel's implementation of notifier chains is unsafe. There is no
protection against entries being added to or removed from a chain while the
chain is in use. The issues were discussed in this thread:
http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2
We noticed that notifier chains in the kernel fall into two basic usage
classes:
"Blocking" chains are always called from a process context
and the callout routines are allowed to sleep;
"Atomic" chains can be called from an atomic context and
the callout routines are not allowed to sleep.
We decided to codify this distinction and make it part of the API. Therefore
this set of patches introduces three new, parallel APIs: one for blocking
notifiers, one for atomic notifiers, and one for "raw" notifiers (which is
really just the old API under a new name). New kinds of data structures are
used for the heads of the chains, and new routines are defined for
registration, unregistration, and calling a chain. The three APIs are
explained in include/linux/notifier.h and their implementation is in
kernel/sys.c.
With atomic and blocking chains, the implementation guarantees that the chain
links will not be corrupted and that chain callers will not get messed up by
entries being added or removed. For raw chains the implementation provides no
guarantees at all; users of this API must provide their own protections. (The
idea was that situations may come up where the assumptions of the atomic and
blocking APIs are not appropriate, so it should be possible for users to
handle these things in their own way.)
There are some limitations, which should not be too hard to live with. For
atomic/blocking chains, registration and unregistration must always be done in
a process context since the chain is protected by a mutex/rwsem. Also, a
callout routine for a non-raw chain must not try to register or unregister
entries on its own chain. (This did happen in a couple of places and the code
had to be changed to avoid it.)
Since atomic chains may be called from within an NMI handler, they cannot use
spinlocks for synchronization. Instead we use RCU. The overhead falls almost
entirely in the unregister routine, which is okay since unregistration is much
less frequent that calling a chain.
Here is the list of chains that we adjusted and their classifications. None
of them use the raw API, so for the moment it is only a placeholder.
ATOMIC CHAINS
arch/i386/kernel/traps.c: i386die_chain
arch/ia64/kernel/traps.c: ia64die_chain
arch/powerpc/kernel/traps.c: powerpc_die_chain
arch/sparc64/kernel/traps.c: sparc64die_chain
arch/x86_64/kernel/traps.c: die_chain
drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list
kernel/panic.c: panic_notifier_list
kernel/profile.c: task_free_notifier
net/bluetooth/hci_core.c: hci_notifier
net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain
net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain
net/ipv6/addrconf.c: inet6addr_chain
net/netfilter/nf_conntrack_core.c: nf_conntrack_chain
net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain
net/netlink/af_netlink.c: netlink_chain
BLOCKING CHAINS
arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain
arch/s390/kernel/process.c: idle_chain
arch/x86_64/kernel/process.c idle_notifier
drivers/base/memory.c: memory_chain
drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list
drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list
drivers/macintosh/adb.c: adb_client_list
drivers/macintosh/via-pmu.c sleep_notifier_list
drivers/macintosh/via-pmu68k.c sleep_notifier_list
drivers/macintosh/windfarm_core.c wf_client_list
drivers/usb/core/notify.c usb_notifier_list
drivers/video/fbmem.c fb_notifier_list
kernel/cpu.c cpu_chain
kernel/module.c module_notify_list
kernel/profile.c munmap_notifier
kernel/profile.c task_exit_notifier
kernel/sys.c reboot_notifier_list
net/core/dev.c netdev_chain
net/decnet/dn_dev.c: dnaddr_chain
net/ipv4/devinet.c: inetaddr_chain
It's possible that some of these classifications are wrong. If they are,
please let us know or submit a patch to fix them. Note that any chain that
gets called very frequently should be atomic, because the rwsem read-locking
used for blocking chains is very likely to incur cache misses on SMP systems.
(However, if the chain's callout routines may sleep then the chain cannot be
atomic.)
The patch set was written by Alan Stern and Chandra Seetharaman, incorporating
material written by Keith Owens and suggestions from Paul McKenney and Andrew
Morton.
[jes@sgi.com: restructure the notifier chain initialization macros]
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Signed-off-by: Jes Sorensen <jes@sgi.com>
- fix: initialize the robust list(s) to NULL in copy_process.
- doc update
- cleanup: rename _inuser to _inatomic
- __user cleanups and other small cleanups
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Ulrich Drepper <drepper@redhat.com>
This patchset provides a new (written from scratch) implementation of robust
futexes, called "lightweight robust futexes". We believe this new
implementation is faster and simpler than the vma-based robust futex solutions
presented before, and we'd like this patchset to be adopted in the upstream
kernel. This is version 1 of the patchset.
Background
What are robust futexes? To answer that, we first need to understand what
futexes are: normal futexes are special types of locks that in the
noncontended case can be acquired/released from userspace without having to
enter the kernel.
A futex is in essence a user-space address, e.g. a 32-bit lock variable
field. If userspace notices contention (the lock is already owned and someone
else wants to grab it too) then the lock is marked with a value that says
"there's a waiter pending", and the sys_futex(FUTEX_WAIT) syscall is used to
wait for the other guy to release it. The kernel creates a 'futex queue'
internally, so that it can later on match up the waiter with the waker -
without them having to know about each other. When the owner thread releases
the futex, it notices (via the variable value) that there were waiter(s)
pending, and does the sys_futex(FUTEX_WAKE) syscall to wake them up. Once all
waiters have taken and released the lock, the futex is again back to
'uncontended' state, and there's no in-kernel state associated with it. The
kernel completely forgets that there ever was a futex at that address. This
method makes futexes very lightweight and scalable.
"Robustness" is about dealing with crashes while holding a lock: if a process
exits prematurely while holding a pthread_mutex_t lock that is also shared
with some other process (e.g. yum segfaults while holding a pthread_mutex_t,
or yum is kill -9-ed), then waiters for that lock need to be notified that the
last owner of the lock exited in some irregular way.
To solve such types of problems, "robust mutex" userspace APIs were created:
pthread_mutex_lock() returns an error value if the owner exits prematurely -
and the new owner can decide whether the data protected by the lock can be
recovered safely.
There is a big conceptual problem with futex based mutexes though: it is the
kernel that destroys the owner task (e.g. due to a SEGFAULT), but the kernel
cannot help with the cleanup: if there is no 'futex queue' (and in most cases
there is none, futexes being fast lightweight locks) then the kernel has no
information to clean up after the held lock! Userspace has no chance to clean
up after the lock either - userspace is the one that crashes, so it has no
opportunity to clean up. Catch-22.
In practice, when e.g. yum is kill -9-ed (or segfaults), a system reboot is
needed to release that futex based lock. This is one of the leading
bugreports against yum.
To solve this problem, 'Robust Futex' patches were created and presented on
lkml: the one written by Todd Kneisel and David Singleton is the most advanced
at the moment. These patches all tried to extend the futex abstraction by
registering futex-based locks in the kernel - and thus give the kernel a
chance to clean up.
E.g. in David Singleton's robust-futex-6.patch, there are 3 new syscall
variants to sys_futex(): FUTEX_REGISTER, FUTEX_DEREGISTER and FUTEX_RECOVER.
The kernel attaches such robust futexes to vmas (via
vma->vm_file->f_mapping->robust_head), and at do_exit() time, all vmas are
searched to see whether they have a robust_head set.
Lots of work went into the vma-based robust-futex patch, and recently it has
improved significantly, but unfortunately it still has two fundamental
problems left:
- they have quite complex locking and race scenarios. The vma-based
patches had been pending for years, but they are still not completely
reliable.
- they have to scan _every_ vma at sys_exit() time, per thread!
The second disadvantage is a real killer: pthread_exit() takes around 1
microsecond on Linux, but with thousands (or tens of thousands) of vmas every
pthread_exit() takes a millisecond or more, also totally destroying the CPU's
L1 and L2 caches!
This is very much noticeable even for normal process sys_exit_group() calls:
the kernel has to do the vma scanning unconditionally! (this is because the
kernel has no knowledge about how many robust futexes there are to be cleaned
up, because a robust futex might have been registered in another task, and the
futex variable might have been simply mmap()-ed into this process's address
space).
This huge overhead forced the creation of CONFIG_FUTEX_ROBUST, but worse than
that: the overhead makes robust futexes impractical for any type of generic
Linux distribution.
So it became clear to us, something had to be done. Last week, when Thomas
Gleixner tried to fix up the vma-based robust futex patch in the -rt tree, he
found a handful of new races and we were talking about it and were analyzing
the situation. At that point a fundamentally different solution occured to
me. This patchset (written in the past couple of days) implements that new
solution. Be warned though - the patchset does things we normally dont do in
Linux, so some might find the approach disturbing. Parental advice
recommended ;-)
New approach to robust futexes
At the heart of this new approach there is a per-thread private list of robust
locks that userspace is holding (maintained by glibc) - which userspace list
is registered with the kernel via a new syscall [this registration happens at
most once per thread lifetime]. At do_exit() time, the kernel checks this
user-space list: are there any robust futex locks to be cleaned up?
In the common case, at do_exit() time, there is no list registered, so the
cost of robust futexes is just a simple current->robust_list != NULL
comparison. If the thread has registered a list, then normally the list is
empty. If the thread/process crashed or terminated in some incorrect way then
the list might be non-empty: in this case the kernel carefully walks the list
[not trusting it], and marks all locks that are owned by this thread with the
FUTEX_OWNER_DEAD bit, and wakes up one waiter (if any).
The list is guaranteed to be private and per-thread, so it's lockless. There
is one race possible though: since adding to and removing from the list is
done after the futex is acquired by glibc, there is a few instructions window
for the thread (or process) to die there, leaving the futex hung. To protect
against this possibility, userspace (glibc) also maintains a simple per-thread
'list_op_pending' field, to allow the kernel to clean up if the thread dies
after acquiring the lock, but just before it could have added itself to the
list. Glibc sets this list_op_pending field before it tries to acquire the
futex, and clears it after the list-add (or list-remove) has finished.
That's all that is needed - all the rest of robust-futex cleanup is done in
userspace [just like with the previous patches].
Ulrich Drepper has implemented the necessary glibc support for this new
mechanism, which fully enables robust mutexes. (Ulrich plans to commit these
changes to glibc-HEAD later today.)
Key differences of this userspace-list based approach, compared to the vma
based method:
- it's much, much faster: at thread exit time, there's no need to loop
over every vma (!), which the VM-based method has to do. Only a very
simple 'is the list empty' op is done.
- no VM changes are needed - 'struct address_space' is left alone.
- no registration of individual locks is needed: robust mutexes dont need
any extra per-lock syscalls. Robust mutexes thus become a very lightweight
primitive - so they dont force the application designer to do a hard choice
between performance and robustness - robust mutexes are just as fast.
- no per-lock kernel allocation happens.
- no resource limits are needed.
- no kernel-space recovery call (FUTEX_RECOVER) is needed.
- the implementation and the locking is "obvious", and there are no
interactions with the VM.
Performance
I have benchmarked the time needed for the kernel to process a list of 1
million (!) held locks, using the new method [on a 2GHz CPU]:
- with FUTEX_WAIT set [contended mutex]: 130 msecs
- without FUTEX_WAIT set [uncontended mutex]: 30 msecs
I have also measured an approach where glibc does the lock notification [which
it currently does for !pshared robust mutexes], and that took 256 msecs -
clearly slower, due to the 1 million FUTEX_WAKE syscalls userspace had to do.
(1 million held locks are unheard of - we expect at most a handful of locks to
be held at a time. Nevertheless it's nice to know that this approach scales
nicely.)
Implementation details
The patch adds two new syscalls: one to register the userspace list, and one
to query the registered list pointer:
asmlinkage long
sys_set_robust_list(struct robust_list_head __user *head,
size_t len);
asmlinkage long
sys_get_robust_list(int pid, struct robust_list_head __user **head_ptr,
size_t __user *len_ptr);
List registration is very fast: the pointer is simply stored in
current->robust_list. [Note that in the future, if robust futexes become
widespread, we could extend sys_clone() to register a robust-list head for new
threads, without the need of another syscall.]
So there is virtually zero overhead for tasks not using robust futexes, and
even for robust futex users, there is only one extra syscall per thread
lifetime, and the cleanup operation, if it happens, is fast and
straightforward. The kernel doesnt have any internal distinction between
robust and normal futexes.
If a futex is found to be held at exit time, the kernel sets the highest bit
of the futex word:
#define FUTEX_OWNER_DIED 0x40000000
and wakes up the next futex waiter (if any). User-space does the rest of
the cleanup.
Otherwise, robust futexes are acquired by glibc by putting the TID into the
futex field atomically. Waiters set the FUTEX_WAITERS bit:
#define FUTEX_WAITERS 0x80000000
and the remaining bits are for the TID.
Testing, architecture support
I've tested the new syscalls on x86 and x86_64, and have made sure the parsing
of the userspace list is robust [ ;-) ] even if the list is deliberately
corrupted.
i386 and x86_64 syscalls are wired up at the moment, and Ulrich has tested the
new glibc code (on x86_64 and i386), and it works for his robust-mutex
testcases.
All other architectures should build just fine too - but they wont have the
new syscalls yet.
Architectures need to implement the new futex_atomic_cmpxchg_inuser() inline
function before writing up the syscalls (that function returns -ENOSYS right
now).
This patch:
Add placeholder futex_atomic_cmpxchg_inuser() implementations to every
architecture that supports futexes. It returns -ENOSYS.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Acked-by: Ulrich Drepper <drepper@redhat.com>
PowerPC can use generic ones.
On CHRP machines we are supposed to call into firmware (RTAS)
periodically, to give it a chance to check for errors and other
events. Under ppc we had some special code in timer_interrupt
to do this, but that didn't get transferred over to arch/powerpc.
Instead, we use an array of timer_list structs, one per CPU,
and use add_timer_on to make sure each one gets called on the
appropriate CPU.
With this we can remove the heartbeat_* elements of the ppc_md
struct.
Since pSeries only wants to do something different in the idle loop when
there is no work to do, we can simplify the code by implementing
ppc_md.power_save functions instead of complete idle loops. There are
two versions: one for shared-processor partitions and one for dedicated-
processor partitions.
With this we also do a cede_processor() call on dedicated processor
partitions if the poll_pending() call indicates that the hypervisor
has work it wants to do.
This unifies the 32-bit (ARCH=ppc and ARCH=powerpc) and 64-bit idle
loops. It brings over the concept of having a ppc_md.power_save
function from 32-bit to ARCH=powerpc, which lets us get rid of
native_idle(). With this we will also be able to simplify the idle
handling for pSeries and cell.
We currently have a hack to flip the boot cpu and its secondary thread
to logical cpuid 0 and 1. This means the logical - physical mapping will
differ depending on which cpu is boot cpu. This is most apparent on
kexec, where we might kexec on any cpu and therefore change the mapping
from boot to boot.
The patch below does a first pass early on to work out the logical cpuid
of the boot thread. We then fix up some paca structures to match.
Ive also removed the boot_cpuid_phys variable for ppc64, to be
consistent we use get_hard_smp_processor_id(boot_cpuid) everywhere.
This patch is layered on top of CONFIG_SPARSEMEM
and is patterned after direct mapping of LS.
This patch allows mmap() of the following regions:
"mfc", which represents the area from [0x3000 - 0x3fff];
"cntl", which represents the area from [0x4000 - 0x4fff];
"signal1" which begins at offset 0x14000; "signal2" which
begins at offset 0x1c000.
The signal1 & signal2 files may be mmap()'d by regular user
processes. The cntl and mfc file, on the other hand, may
only be accessed if the owning process has CAP_SYS_RAWIO,
because they have the potential to confuse the kernel
with regard to parallel access to the same files with
regular file operations: the kernel always holds a spinlock
when accessing registers in these areas to serialize them,
which can not be guaranteed with user mmaps,
Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
This patch adds a new file called 'mfc' to each spufs directory.
The file accepts DMA commands that are a subset of what would
be legal DMA commands for problem state register access. Upon
reading the file, a bitmask is returned with the completed
tag groups set.
The file is meant to be used from an abstraction in libspe
that is added by a different patch.
From the kernel perspective, this means a process can now
offload a memory copy from or into an SPE local store
without having to run code on the SPE itself.
The transfer will only be performed while the SPE is owned
by one thread that is waiting in the spu_run system call
and the data will be transferred into that thread's
address space, independent of which thread started the
transfer.
An SPU does not have a way to implement system calls
itself, but it can create intercepts to the kernel.
This patch uses the method defined by the JSRE interface
for C99 host library calls from an SPU to implement
Linux system calls. It uses the reserved SPU stop code
0x2104 for this, using the structure layout and syscall
numbers for ppc64-linux.
I'm still undecided wether it is better to have a list
of allowed syscalls or a list of forbidden syscalls,
since we can't allow an SPU to call all syscalls that
are defined for ppc64-linux.
This patch implements the easier choice of them, with a
blacklist that only prevents an SPU from calling anything
that interacts with its own execution, e.g fork, execve,
clone, vfork, exit, spu_run and spu_create and everything
that deals with signals.
powerpc currently declares some of its own system calls
in <asm/unistd.h>, but not all of them. That place also
contains remainders of the now almost unused kernel syscall
hack.
- Add a new <asm/syscalls.h> with clean declarations
- Include that file from every source that implements one
of these
- Get rid of old declarations in <asm/unistd.h>
This patch is required as a base for implementing system
calls from an SPU, but also makes sense as a general
cleanup.
So that we can use firmware_has_feature() in a BUG_ON() and have the compiler
elide the code entirely if the feature can never be set, change
firmware_has_feature to a macro. Unfortunate, but necessary at least until
GCC bug #26724 is fixed.
Change BUG_ON and WARN_ON to give the compiler a chance to perform
compile-time optimsations. Depending on the complexity of the condition,
the compiler may not do this very well, so if it's important check the
object code.
Current GCC's (4.x) produce good code as long as the condition does not
include a function call, including a static inline.
Christoph noticed that sparse warned about all the enum tags in cuptable.h
that had values that required them to be type log. (enum tags are ints
according to the standard.)
This patch attempts to fix them in the least intrusive way possible by
turning them all into #defines except for the 32 bit CPU_FTRS_POSSIBLE and
CPU_FTRS_ALWAYS which are hard to construct that way. This works because
these last two contain no bits above 2^31.
- remove __{,test_and_}{set,clear,change}_bit() and test_bit()
- remove generic_fls64()
- remove generic_hweight{64,32,16,8}()
- remove sched_find_first_bit()
Signed-off-by: Akinobu Mita <mita@miraclelinux.com>
Add blkcnt_t as the type of inode.i_blocks. This enables you to make the size
of blkcnt_t either 4 bytes or 8 bytes on 32 bits architecture with CONFIG_LSF.
- CONFIG_LSF
Add new configuration parameter.
- blkcnt_t
On h8300, i386, mips, powerpc, s390 and sh that define sector_t,
blkcnt_t is defined as u64 if CONFIG_LSF is enabled; otherwise it is
defined as unsigned long.
On other architectures, it is defined as unsigned long.
- inode.i_blocks
Change the type from sector_t to blkcnt_t.
Signed-off-by: Takashi Sato <sho@tnes.nec.co.jp>
It takes a size_t, not an int, as its third argument.
Implement the half-closed devices notifiation, by adding a new POLLRDHUP
(and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the
existing POLLHUP handling, that does not report correctly half-closed
devices, was feared to be changed, this implementation leaves the current
POLLHUP reporting unchanged and simply add a new bit that is set in the few
places where it makes sense. The same thing was discussed and conceptually
agreed quite some time ago:
http://lkml.org/lkml/2003/7/12/116
Since this new event bit is added to the existing Linux poll infrastruture,
even the existing poll/select system calls will be able to use it. As far
as the existing POLLHUP handling, the patch leaves it as is. The
pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing
archs and sets the bit in the six relevant files. The other attached diff
is the simple change required to sys/epoll.h to add the EPOLLRDHUP
definition.
There is "a stupid program" to test POLLRDHUP delivery here:
http://www.xmailserver.org/pollrdhup-test.c
It tests poll(2), but since the delivery is same epoll(2) will work equally.
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
When we stop allocating percpu memory for not-possible CPUs we must not touch
the percpu data for not-possible CPUs at all. The correct way of doing this
is to test cpu_possible() or to use for_each_cpu().
This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very
few instances of this bug, if any. But the patch converts lots of open-coded
test to use the preferred helper macros.
Cc: Mikael Starvik <starvik@axis.com>
Acked-by: Kyle McMartin <kyle@parisc-linux.org>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Christian Zankel <chris@zankel.net>
Cc: Philippe Elie <phil.el@wanadoo.fr>
Cc: Nathan Scott <nathans@sgi.com>
Cc: Jens Axboe <axboe@suse.de>
Cc: Eric Dumazet <dada1@cosmosbay.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (78 commits)
[PATCH] powerpc: Add FSL SEC node to documentation
[PATCH] macintosh: tidy-up driver_register() return values
[PATCH] powerpc: tidy-up of_register_driver()/driver_register() return values
[PATCH] powerpc: via-pmu warning fix
[PATCH] macintosh: cleanup the use of i2c headers
[PATCH] powerpc: dont allow old RTC to be selected
[PATCH] powerpc: make powerbook_sleep_grackle static
[PATCH] powerpc: Fix warning in add_memory
[PATCH] powerpc: update mailing list addresses
[PATCH] powerpc: Remove calculation of io hole
[PATCH] powerpc: iseries: Add bootargs to /chosen
[PATCH] powerpc: iseries: Add /system-id, /model and /compatible
[PATCH] powerpc: Add strne2a() to convert a string from EBCDIC to ASCII
[PATCH] powerpc: iseries: Make more stuff static in platforms/iseries/mf.c
[PATCH] powerpc: iseries: Remove pointless iSeries_(restart|power_off|halt)
[PATCH] powerpc: iseries: mf related cleanups
[PATCH] powerpc: Replace platform_is_lpar() with a firmware feature
[PATCH] powerpc: trivial: Cleanup whitespace in cputable.h
[PATCH] powerpc: Remove unused iommu_off logic from pSeries_init_early()
[PATCH] powerpc: Unconfuse htab_bolt_mapping() callers
free_pgtables() has special logic to call hugetlb_free_pgd_range() instead
of the normal free_pgd_range() on hugepage VMAs. However, the test it uses
to do so is incorrect: it calls is_hugepage_only_range on a hugepage sized
range at the start of the vma. is_hugepage_only_range() will return true
if the given range has any intersection with a hugepage address region, and
in this case the given region need not be hugepage aligned. So, for
example, this test can return true if called on, say, a 4k VMA immediately
preceding a (nicely aligned) hugepage VMA.
At present we get away with this because the powerpc version of
hugetlb_free_pgd_range() is just a call to free_pgd_range(). On ia64 (the
only other arch with a non-trivial is_hugepage_only_range()) we get away
with it for a different reason; the hugepage area is not contiguous with
the rest of the user address space, and VMAs are not permitted in between,
so the test can't return a false positive there.
Nonetheless this should be fixed. We do that in the patch below by
replacing the is_hugepage_only_range() test with an explicit test of the
VMA using is_vm_hugetlb_page().
This in turn changes behaviour for platforms where is_hugepage_only_range()
returns false always (everything except powerpc and ia64). We address this
by ensuring that hugetlb_free_pgd_range() is defined to be identical to
free_pgd_range() (instead of a no-op) on everything except ia64. Even so,
it will prevent some otherwise possible coalescing of calls down to
free_pgd_range(). Since this only happens for hugepage VMAs, removing this
small optimization seems unlikely to cause any trouble.
This patch causes no regressions on the libhugetlbfs testsuite - ppc64
POWER5 (8-way), ppc64 G5 (2-way) and i386 Pentium M (UP).
Signed-off-by: David Gibson <dwg@au1.ibm.com>
Acked-by: Hugh Dickins <hugh@veritas.com>
In mm_init_ppc64() we calculate the location of the "IO hole", but then
no one ever looks at the value. So don't bother.
That's actually all mm_init_ppc64() does, so get rid of it too.
Add strne2a() which converts a string from EBCDIC to ASCII.
