path: root/include/asm-s390
2006-03-06[PATCH] s390: fix compile with VIRT_CPU_ACCOUNTING=nJan Blunck
When CONFIG_VIRT_CPU_ACCOUNTING is not defined compiling fails with an undefined reference to account_vtime(). Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] s390: revert dasd eer moduleHeiko Carstens
Revert dasd eer module until we have a common understanding of how the interface should be. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] s390: additional_cpus parameterHeiko Carstens
Introduce additional_cpus command line option. By default no additional cpu can be attached to the system anymore. Only the cpus present at IPL time can be switched on/off. If it is desired that additional cpus can be attached to the system the maximum number of additional cpus needs to be specified with this option. This change is necessary in order to limit the waste of per_cpu data structures. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[PATCH] add asm-generic/mman.hMichael S. Tsirkin
Make new MADV_REMOVE, MADV_DONTFORK, MADV_DOFORK consistent across all arches. The idea is to make it possible to use them portably even before distros include them in libc headers. Move common flags to asm-generic/mman.h Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] madvise MADV_DONTFORK/MADV_DOFORKMichael S. Tsirkin
Currently, copy-on-write may change the physical address of a page even if the user requested that the page is pinned in memory (either by mlock or by get_user_pages). This happens if the process forks meanwhile, and the parent writes to that page. As a result, the page is orphaned: in case of get_user_pages, the application will never see any data hardware DMA's into this page after the COW. In case of mlock'd memory, the parent is not getting the realtime/security benefits of mlock. In particular, this affects the Infiniband modules which do DMA from and into user pages all the time. This patch adds madvise options to control whether memory range is inherited across fork. Useful e.g. for when hardware is doing DMA from/into these pages. Could also be useful to an application wanting to speed up its forks by cutting large areas out of consideration. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-12[PATCH] s390: fstatat64 supportHeiko Carstens
Add fstatat64 support to s390 in order to follow changes with commit cff2b760096d1e6feaa31948e7af4abbefe47822 . Also fixes compilation for 31 bit. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] s390: remove one set of brackets in __constant_test_bit()Eric Paris
Right now in __constant_test_bit for the s390 there is an extra set of () surrounding the calculation. This patch simply removes one set of () that is surrounding the whole clause. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] s390: add #ifdef __KERNEL__ to asm-s390/setup.hHeiko Carstens
Based on a patch from Maximilian Attems <maks@sternwelten.at> . Nothing in asm-s390/setup.h is of interest for user space. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] s390: add support for unshare system callHeiko Carstens
Add support for unshare system call. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] s390: fix non smp build of kexecHeiko Carstens
Add missing smp_cpu_not_running define to avoid build warnings in the non smp case. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-08[PATCH] s390 __get_user() bogus warnings removalAl Viro
2006-02-08[PATCH] s390 misc __user annotationsAl Viro
2006-02-03[PATCH] s390: compile fix: missing defines in asm-s390/io.hHeiko Carstens
Compile fix: add missing __raw_read* and __raw_write* defines to include/asm-s390/io.h. These are mandatory since patch c27a0d75b33c030965cc97d3d7f571107a673fb4 was merged. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] s390: timer interface visibilityJan Glauber
Avoid visibility of kernel internal interface to user space. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] s390: dasd extended error reporting moduleStefan Weinhuber
The DASD extended error reporting is a facility that allows to get detailed information about certain problems in the DASD I/O. This information can be used to implement fail-over applications that can recover these problems. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] s390: Add support for new syscalls/TIF_RESTORE_SIGMASKHeiko Carstens
Add support for the new *at, pselect6 and ppoll system calls. This includes adding required support for TIF_RESTORE_SIGMASK. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] s390: Remove CVS generated informationHeiko Carstens
- Remove all CVS generated information like e.g. revision IDs from drivers/s390 and include/asm-s390 (none present in arch/s390). - Add newline at end of arch/s390/lib/Makefile to avoid diff message. Acked-by: Andreas Herrmann <aherrman@de.ibm.com> Acked-by: Frank Pavlic <pavlic@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] s390: email-address changeCornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] s390: cputime misaccountingMartin Schwidefsky
finish_arch_switch needs to update the user cpu time as well, not just the system cpu time. Otherwise the partial user cpu time of a process that is stored in the lowcore will be (mis-)accounted to the next process. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] s390: sigcontext.h vs __userMartin Schwidefsky
Add an include of linux/compiler.h in sigcontext.h to avoid compiler errors in user space apps because of a missing definition for __user. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] death of get_thread_info/put_thread_infoAl Viro
{get,put}_thread_info() were introduced in 2.5.4 and never had been called by anything in the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] s390: task_stack_page()Al Viro
2006-01-12[PATCH] s390: task_pt_regs()Al Viro
2006-01-12[PATCH] sched: add cacheflush() asmIngo Molnar
Add per-arch sched_cacheflush() which is a write-back cacheflush used by the migration-cost calibration code at bootup time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Generic ioctl.hBrian Gerst
Most arches copied the i386 ioctl.h. Combine them into a generic header. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Kdump: powerpc and s390 build failure fixakpm@osdl.org
) From: Vivek Goyal <vgoyal@in.ibm.com> crash_setup_regs() is an architecture dependent function which is called in architecture independent section. So every architecture supporting kexec should at least provide a dummy definition of crash_setup_regs() even if crash dumping is not implemented yet, to avoid build failures. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: dynamic per cpu allocation of memory for saving cpu registersVivek Goyal
- In case of system crash, current state of cpu registers is saved in memory in elf note format. So far memory for storing elf notes was being allocated statically for NR_CPUS. - This patch introduces dynamic allocation of memory for storing elf notes. It uses alloc_percpu() interface. This should lead to better memory usage. - Introduced based on Andi Kleen's and Eric W. Biederman's suggestions. - This patch also moves memory allocation for elf notes from architecture dependent portion to architecture independent portion. Now crash_notes is architecture independent. The whole idea is that size of memory to be allocated per cpu (MAX_NOTE_BYTES) can be architecture dependent and allocation of this memory can be architecture independent. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, add default include/asm-*/mutex.h filesArjan van de Ven
add the per-arch mutex.h files for the remaining architectures. We default to asm-generic/mutex-dec.h, because that performs quite well on most arches. Arches that do not have atomic decrement/increment instructions should switch to mutex-xchg.h instead. Arches can also provide their own implementation for the mutex fastpath primitives. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, add atomic_xchg() to all archesIngo Molnar
add atomic_xchg() to all the architectures. Needed by the new mutex code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-08[PATCH] consolidate asm/futex.hJeff Dike
Most of the architectures have the same asm/futex.h. This consolidates them into asm-generic, with the arches including it from their own asm/futex.h. In the case of UML, this reverts the old broken futex.h and goes back to using the same one as almost everyone else. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Kill L1_CACHE_SHIFT_MAXRavikiran G Thirumalai
Kill L1_CACHE_SHIFT from all arches. Since L1_CACHE_SHIFT_MAX is not used anymore with the introduction of INTERNODE_CACHE, kill L1_CACHE_SHIFT_MAX. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: qdio V=V pass-throughFrank Pavlic
New feature V=V qdio pass-through. QDIO and HiperSockets processing in z/VM V=V guest environments (as well as V=R with z/VM running in LPAR mode) requires shadowing of all QDIO architecture queue elements. Especially the shadowing of SBALs and SLSBs structures in the hypervisor, and the need to issue SIGA SYNC operations to observe state changes, eventually causes significant CPU processing overhead in the hypervisor. The QDIO pass-through support for V=V guests avoids the shadowing of SBALs and SLSBs. This significantly reduces the hypervisor overhead for QDIO based I/O. Signed-off-by: Frank Pavlic <pavlic@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: move s390_root_dev_* out of the cio layerCarsten Otte
Extract the s390_root_dev_* functions from the common I/O layer as they are also used by non-ccw device drivers. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: uaccess warningsMartin Schwidefsky
Convert __access_ok to an inline C function and change __get_user primitive to avoid uaccess compiler warnings. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: cms volume label definitionsPeter Oberparleiter
Moved definition of CMS volume label to vtoc.h and modify partitions/ibm.c to use this volume label definition instead of anonymous array. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: atomic primitivesMartin Schwidefsky
Hugh Dickins <hugh@veritas.com> Fix the broken atomic_cmpxchg primitive. Add atomic_sub_and_test, atomic64_sub_return, atomic64_sub_and_test, atomic64_cmpxchg, atomic64_add_unless and atomic64_inc_not_zero. Replace old style atomic_compare_and_swap by atomic_cmpxchg. Shorten the whole header by defining most primitives with the two inline functions atomic_add_return and atomic_sub_return. In addition this patch contains the s390 related fixes of Hugh's "mm: fill arch atomic64 gaps" patch. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] atomic_long_t & include/asm-generic/atomic.h V2Christoph Lameter
Several counters already have the need to use 64 atomic variables on 64 bit platforms (see mm_counter_t in sched.h). We have to do ugly ifdefs to fall back to 32 bit atomic on 32 bit platforms. The VM statistics patch that I am working on will also make more extensive use of atomic64. This patch introduces a new type atomic_long_t by providing definitions in asm-generic/atomic.h that works similar to the c "long" type. Its 32 bits on 32 bit platforms and 64 bits on 64 bit platforms. Also cleans up the determination of the mm_counter_t in sched.h. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] madvise(MADV_REMOVE): remove pages from tmpfs shm backing storeBadari Pulavarty
Here is the patch to implement madvise(MADV_REMOVE) - which frees up a given range of pages & its associated backing store. Current implementation supports only shmfs/tmpfs and other filesystems return -ENOSYS. "Some app allocates large tmpfs files, then when some task quits and some client disconnect, some memory can be released. However the only way to release tmpfs-swap is to MADV_REMOVE". - Andrea Arcangeli Databases want to use this feature to drop a section of their bufferpool (shared memory segments) - without writing back to disk/swap space. This feature is also useful for supporting hot-plug memory on UML. Concerns raised by Andrew Morton: - "We have no plan for holepunching! If we _do_ have such a plan (or might in the future) then what would the API look like? I think sys_holepunch(fd, start, len), so we should start out with that." - Using madvise is very weird, because people will ask "why do I need to mmap my file before I can stick a hole in it?" - None of the other madvise operations call into the filesystem in this manner. A broad question is: is this capability an MM operation or a filesytem operation? truncate, for example, is a filesystem operation which sometimes has MM side-effects. madvise is an mm operation and with this patch, it gains FS side-effects, only they're really, really significant ones." Comments: - Andrea suggested the fs operation too but then it's more efficient to have it as a mm operation with fs side effects, because they don't immediatly know fd and physical offset of the range. It's possible to fixup in userland and to use the fs operation but it's more expensive, the vmas are already in the kernel and we can use them. Short term plan & Future Direction: - We seem to need this interface only for shmfs/tmpfs files in the short term. We have to add hooks into the filesystem for correctness and completeness. This is what this patch does. - In the future, plan is to support both fs and mmap apis also. This also involves (other) filesystem specific functions to be implemented. - Current patch doesn't support VM_NONLINEAR - which can be addressed in the future. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Andrea Arcangeli <andrea@suse.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-13[PATCH] atomic: inc_not_zeroNick Piggin
Introduce an atomic_inc_not_zero operation. Make this a special case of atomic_add_unless because lockless pagecache actually wants atomic_inc_not_negativeone due to its offset refcount. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] atomic: cmpxchgNick Piggin
Introduce an atomic_cmpxchg operation. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] s390: "extern inline" -> "static inline"Adrian Bunk
"extern inline" -> "static inline" Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] s390: const pointer uaccessMartin Schwidefsky
Using __typeof__(*ptr) on a pointer to const makes the __x variable in __get_user const as well. The latest gcc will refuse to write to it. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] s390: cleanup of include/asm-s390/vtoc.hPeter Oberparleiter
2005-11-07[PATCH] s390: test_bit return valueChristian Borntraeger
The test_bit function returns a non-boolean value, it returns 0,1,2,4,... instead of only 0 or 1. This causes wrongs results in the mincore system call. Check against 0 to get a proper boolean value. Signed-off-by: Christian Borntraeger <cborntra@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] semaphore: Remove __MUTEX_INITIALIZER()Arthur Othieno
__MUTEX_INITIALIZER() has no users, and equates to the more commonly used DECLARE_MUTEX(), thus making it pretty much redundant. Remove it for good. Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] unify sys_ptrace prototypeChristoph Hellwig
Make sure we always return, as all syscalls should. Also move the common prototype to <linux/syscalls.h> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
