path: root/include/asm-sh/dma.h
2008-07-29sh: migrate to arch/sh/include/Paul Mundt
This follows the sparc changes a439fe51a1f8eb087c22dd24d69cebae4a3addac. Most of the moving about was done with Sam's directions at: http://marc.info/?l=linux-sh&m=121724823706062&w=2 with subsequent hacking and fixups entirely my fault. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: dma: Fix CONFIG_SYSFS=n build.Paul Mundt
Trivial build fix for when sysfs is disabled. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-24sh: Fix Dreamcast DMA issues.Adrian McMenamin
The current SH DMA API is somewhat broken, not correctly matching virtual channel to the correct SH DMAC. This wasn't noticeable when using g2 DMA for the sound driver - one channel 0 is as good as any other! - but caused the pvr2 driver to fail. This patch fixes the pvr2 problem and consequently fixes the sound driver to ensure it continues to function. Signed-off by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-31sh: trivial build cleanups.Evgeniy Polyakov
Several errors were spotted during building for custom config (SMP included). Although SMP still does not compile (no ipi and __smp_call_function) and does not work, this looks a bit cleaner. Some other errors obtained via gcc-4.1.0 build. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: dma-api channel capability extensions.Mark Glaisher
This extends the SH DMA API for allowing handling of DMA channels based off of their respective capabilities. A couple of functions are added to the existing API, the core bits are register_chan_caps() for registering channel capabilities, and request_dma_bycap() for fetching a channel dynamically based off of a capability set. Signed-off-by: Mark Glaisher <mark.glaisher@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-27sh: More cosmetic cleanups and trivial fixes.Paul Mundt
Nothing exciting here, just trivial fixes.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-16[PATCH] sh: DMA updatesPaul Mundt
This extends the current SH DMA API somewhat to support a proper virtual channel abstraction, and also works to represent this through the driver model by giving each DMAC its own platform device. There's also a few other minor changes to support a few new CPU subtypes, and make TEI generation for the SH DMAC configurable. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
