path: root/include/asm-sh/hw_irq.h
2008-05-08sh: add interrupt ack code to sh3Magnus Damm
This patch adds interrupt acknowledge code for external interrupt sources on sh3 processors. Only really required for edge triggered interrupts, but we ack regardless of sense configuration. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: unify external irq pin code for sh3Magnus Damm
This patch unifies the sh3 external irq pin code. It buys us some savings with reduced code redundancy, but the main feature with this change is irq sense selection support for all sh3 processors. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: intc - remove default interrupt priority tablesMagnus Damm
This patch removes interrupt priority tables from the intc code. Optimal priority assignment varies with embedded application anyway, so keeping the interrupt priority tables together with cpu-specific code doesn't make sense. The function intc_set_priority() should be used instead to set the desired interrupt priority level. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - initial SMP support.Magnus Damm
This implements initial support for the SMP INTC (particularly INTC2) controllers. These are largely implemented as conventional blocks, with register sets grouped together at fixed strides relative to the CPU id. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - irl mode update for sh7780 and sh7785Magnus Damm
This patch contains the following fixes and improvements: - Fix address typo for INTMSK2 / INTMSKCLR2 registers on sh7780. - Adds IRQ_MODE_IRLnnnn_MASK using intc controller for IRL masking. - Good old IRQ_MODE_IRLnnnn should not register any intc controller. - plat_irq_setup_pins() now selects IRL or IRQ mode. - the holding function is now disabled using ICR0. By default all external pin interrupts are disabled. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - primary priority masking fixesMagnus Damm
This patch contains various intc fixes for problems reported by Markus Brunner on the linuxsh-dev mailing list: http://marc.info/?l=linuxsh-dev&m=118701948224991&w=1 Apart from added comments, the fixes are: - add intc_set_priority() function prototype to hw_irq.h - fix off-by-one error in intc_set_priority() - make sure _INTC_WIDTH() is set for primary priority masking Big thanks to Markus for finding these problems. Version two fixes a compile error and an inverted primary check. Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Markus Brunner <super.firetwister@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - mark data structures as __initdataMagnus Damm
With the intc core improved it is now possible to put the intc data structures in the initdata section. Version two of this patch puts the __initdata inside DECLARE_INTC_DESC() and removes the __initdata included in the board specific r2d code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - rework core codeMagnus Damm
This patch reworks the intc core, implementing the following features: - Support dual priority registers - one set and one clear register - All 8/16/32 bit register combinations are now supported - Both single mask and single enable bitmap register are supported - Add code to set interrupt priority - Speedup sense and priority configuration code - Allocate data using bootmem, allows intc data structures to be __initdata - Save memory - allocated memory footprint is smaller than intc structures Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - add a clear register to struct intc_prio_regMagnus Damm
We need a secondary register member in struct intc_prio_reg to support dual priority registers used by ipi on x3. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: remove intc2 codeMagnus Damm
There is no point in keeping around the now unused intc2 code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - add single bitmap register supportMagnus Damm
This patch adds single bitmap register support to intc. The current code only handles 16 and 32 bit registers where a set bit means interrupt enabled, but this is easy to extend in the future. The INTC_IRQ() macro is also added to provide a way to hook in interrupt controllers for FPGAs in boards or companion chips. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - remove redundant irq code for sh03, snapgear and titanMagnus Damm
This patch removes redundant board specific interrupt code for boards using sh775x processors and 4 IRQ lines in "Individual Interrupt Mode" aka IRLM. Three boards are affected: sh03, snapgear and titan. The right way to do this is to use cpu specific code provided by intc. A nice side effect is that sh03 now compiles, board not BROKEN any more. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - add support for SH7785Magnus Damm
This patch converts the cpu specific interrupt setup code for sh7785 from intc2 to intc. New vectors are also added to match the information provided by the datasheet. No IRQ/IRL pin vectors are enabled by default. Use plat_irq_setup_pins() to select between IRL and IRQ mode. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-20sh: intc - add support for SH7750 and its variantsMagnus Damm
This patch converts the cpu specific 7750 setup code to use the new intc controller. Many new vectors are added and multiple processor variants including 7091, 7750, 7750s, 7750r, 7751 and 7751r should all have the correct vectors hooked up. IRLM interrupts can be enabled using ipr_irq_enable_irlm() which now is marked as __init. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-20sh: intc - add support for 7780Magnus Damm
This patch converts the cpu specific 7780 setup code to use the new intc controller. Many new vectors are added and also support for external interrupt sense configuration. So with this patch it is now possible to configure external interrupt pins as edge or level triggered using set_irq_type(). No external interrupts are registered by default. Use plat_irq_setup_pins() to select between IRQ or IRL mode. This patch also fixes the Alarm IRQ for the RTC. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-20sh: IPR/INTC2 IRQ setup consolidation.Magnus Damm
This patch unifies the cpu specific interrupt setup functions for interrupt controller blocks such as ipr, intc2 and intc. There is no point in having separate functions for each interrupt controller, so let's clean this up. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-20sh: intc - add support for 7722 processorMagnus Damm
This patch converts the cpu specific 7722 setup code to use the new intc controller. Many new vectors are added and also support for external interrupt sense configuration. So with this patch it is now possible to configure external interrupt pins as edge or level triggered using set_irq_type(). Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-20sh: intc - shared IPR and INTC2 controllerMagnus Damm
This is the second version of the shared interrupt controller patch for the sh architecture, fixing up handling of intc_reg_fns[]. The three main advantages with this controller over the existing ones are: - Both priority (ipr) and bitmap (intc2) registers are supported - External pin sense configuration is supported, ie edge vs level triggered - CPU/Board specific code maps 1:1 with datasheet for easy verification This controller can easily coexist with the current IPR and INTC2 controllers, but the idea is that CPUs/Boards should be moved over to this controller over time so we have a single code base to maintain. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-06-15sh: rework ipr codeMagnus Damm
This patch reworks the ipr code by grouping the offset array together with the ipr_data structure in a new data structure called ipr_desc. This new structure also contains the name of the controller in struct irq_chip. The idea behind putting struct irq_chip in there is that we can use offsetof() to locate the base addresses in the irq_chip callbacks. This strategy has much in common with the recently merged intc2 code. One logic change has been made - the original ipr code enabled the interrupts by default but with this patch they are all disabled by default. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-06-15sh: rework intc2 codeMagnus Damm
The shared intc2 code currently contains cpu-specific #ifdefs. This is a tad unclean and it prevents us from using the shared code to drive board-specific irqs on the se7780 board. This patch reworks the intc2 code by moving the base addresses of the intc2 registers into struct intc2_desc. This new structure also contains the name of the controller in struct irq_chip. The idea behind putting struct irq_chip in there is that we can use offsetof() to locate the base addresses in the irq_chip callbacks. One logic change has been made - the original shared intc2 code enabled the interrupts by default but with this patch they are all disabled by default. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-10-06sh: Updates for IRQ handler changes.Paul Mundt
Trivial fixes for build breakage introduced by IRQ handler changes. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-06-29[PATCH] genirq: add ->retrigger() irq op to consolidate hw_irq_resend()Ingo Molnar
Add ->retrigger() irq op to consolidate hw_irq_resend() implementations. (Most architectures had it defined to NOP anyway.) NOTE: ia64 needs testing. i386 and x86_64 tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
