path: root/include/asm-sh64
2006-02-01[PATCH] sh/sh64: Fix bogus TIOCGICOUNT definitionsPaul Mundt
As reported by Russell King, sh and sh64 currently have bogus definitions for TIOCGICOUNT, particularly referencing a kernel only structure. Switch to using a sensible ioctl value. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] death of get_thread_info/put_thread_infoAl Viro
{get,put}_thread_info() were introduced in 2.5.4 and never had been called by anything in the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] include/asm-sh64/: "extern inline" -> "static inline"Adrian Bunk
"extern inline" doesn't make much sense. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Generic ioctl.hBrian Gerst
Most arches copied the i386 ioctl.h. Combine them into a generic header. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, add default include/asm-*/mutex.h filesArjan van de Ven
add the per-arch mutex.h files for the remaining architectures. We default to asm-generic/mutex-dec.h, because that performs quite well on most arches. Arches that do not have atomic decrement/increment instructions should switch to mutex-xchg.h instead. Arches can also provide their own implementation for the mutex fastpath primitives. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, add atomic_xchg() to all archesIngo Molnar
add atomic_xchg() to all the architectures. Needed by the new mutex code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-08[PATCH] consolidate asm/futex.hJeff Dike
Most of the architectures have the same asm/futex.h. This consolidates them into asm-generic, with the arches including it from their own asm/futex.h. In the case of UML, this reverts the old broken futex.h and goes back to using the same one as almost everyone else. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Kill L1_CACHE_SHIFT_MAXRavikiran G Thirumalai
Kill L1_CACHE_SHIFT from all arches. Since L1_CACHE_SHIFT_MAX is not used anymore with the introduction of INTERNODE_CACHE, kill L1_CACHE_SHIFT_MAX. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] atomic_long_t & include/asm-generic/atomic.h V2Christoph Lameter
Several counters already have the need to use 64 atomic variables on 64 bit platforms (see mm_counter_t in sched.h). We have to do ugly ifdefs to fall back to 32 bit atomic on 32 bit platforms. The VM statistics patch that I am working on will also make more extensive use of atomic64. This patch introduces a new type atomic_long_t by providing definitions in asm-generic/atomic.h that works similar to the c "long" type. Its 32 bits on 32 bit platforms and 64 bits on 64 bit platforms. Also cleans up the determination of the mm_counter_t in sched.h. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-13[PATCH] atomic: inc_not_zeroNick Piggin
Introduce an atomic_inc_not_zero operation. Make this a special case of atomic_add_unless because lockless pagecache actually wants atomic_inc_not_negativeone due to its offset refcount. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] atomic: cmpxchgNick Piggin
Introduce an atomic_cmpxchg operation. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] ide: move CONFIG_IDE_MAX_HWIFS into linux/ide.hBjorn Helgaas
CONFIG_IDE_MAX_HWIFS is a generic thing, no need to have it duplicated by every arch that uses it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] semaphore: Remove __MUTEX_INITIALIZER()Arthur Othieno
__MUTEX_INITIALIZER() has no users, and equates to the more commonly used DECLARE_MUTEX(), thus making it pretty much redundant. Remove it for good. Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] vm: remove unused/broken page_pte[_prot] macrosTejun Heo
This patch removes page_pte_prot and page_pte macros from all architectures. Some architectures define both, some only page_pte (broken) and others none. These macros are not used anywhere. page_pte_prot(page, prot) is identical to mk_pte(page, prot) and page_pte(page) is identical to page_pte_prot(page, __pgprot(0)). * The following architectures define both page_pte_prot and page_pte arm, arm26, ia64, sh64, sparc, sparc64 * The following architectures define only page_pte (broken) frv, i386, m32r, mips, sh, x86-64 * All other architectures define neither Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: dma-mapping (simple cases)Al Viro
2005-09-21[PATCH] Remove unused var from asm/futex.hPaolo 'Blaisorblade' Giarrusso
As recently done by Russell King for ARM, commit 4732efbeb997189d9f9b04708dc26bf8613ed721 introduces a generic asm/futex.h copied along most arches, which includes a "-ENOSYS support" to be changed if needed. However, it includes an unused var (taken from the "real" version) which GCC warns about. Remove it from all arches having that file version (i.e. same GIT id). $ git-diff-tree -r HEAD and $ git-ls-tree -r HEAD include/|grep 9feff4ce1424bc390608326240be369eb13aa648 may be more interesting than looking at the patch itself, to make sure I've just copied the arm header to all other archs having the original dummy version of this file. Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] feature removal of io_remap_page_range()Randy Dunlap
As written in Documentation/feature-removal-schedule.txt, remove the io_remap_page_range() kernel API. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Clean up struct flock64 definitionsStephen Rothwell
This patch gathers all the struct flock64 definitions (and the operations), puts them under !CONFIG_64BIT and cleans up the arch files. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove verify_area(): remove verify_area() from various uaccess.h ↵Jesper Juhl
headers Remove the deprecated (and unused) verify_area() from various uaccess.h headers. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove asm-*/hdreg.hChristoph Hellwig
unused and useless.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] auxiliary vector cleanupsH. J. Lu
The size of auxiliary vector is fixed at 42 in linux/sched.h. But it isn't very obvious when looking at linux/elf.h. This patch adds AT_VECTOR_SIZE so that we can change it if necessary when a new vector is added. Because of include file ordering problems, doing this necessitated the extraction of the AT_* symbols into a standalone header file. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] FUTEX_WAKE_OP: pthread_cond_signal() speedupJakub Jelinek
ATM pthread_cond_signal is unnecessarily slow, because it wakes one waiter (which at least on UP usually means an immediate context switch to one of the waiter threads). This waiter wakes up and after a few instructions it attempts to acquire the cv internal lock, but that lock is still held by the thread calling pthread_cond_signal. So it goes to sleep and eventually the signalling thread is scheduled in, unlocks the internal lock and wakes the waiter again. Now, before 2003-09-21 NPTL was using FUTEX_REQUEUE in pthread_cond_signal to avoid this performance issue, but it was removed when locks were redesigned to the 3 state scheme (unlocked, locked uncontended, locked contended). Following scenario shows why simply using FUTEX_REQUEUE in pthread_cond_signal together with using lll_mutex_unlock_force in place of lll_mutex_unlock is not enough and probably why it has been disabled at that time: The number is value in cv->__data.__lock. thr1 thr2 thr3 0 pthread_cond_wait 1 lll_mutex_lock (cv->__data.__lock) 0 lll_mutex_unlock (cv->__data.__lock) 0 lll_futex_wait (&cv->__data.__futex, futexval) 0 pthread_cond_signal 1 lll_mutex_lock (cv->__data.__lock) 1 pthread_cond_signal 2 lll_mutex_lock (cv->__data.__lock) 2 lll_futex_wait (&cv->__data.__lock, 2) 2 lll_futex_requeue (&cv->__data.__futex, 0, 1, &cv->__data.__lock) # FUTEX_REQUEUE, not FUTEX_CMP_REQUEUE 2 lll_mutex_unlock_force (cv->__data.__lock) 0 cv->__data.__lock = 0 0 lll_futex_wake (&cv->__data.__lock, 1) 1 lll_mutex_lock (cv->__data.__lock) 0 lll_mutex_unlock (cv->__data.__lock) # Here, lll_mutex_unlock doesn't know there are threads waiting # on the internal cv's lock Now, I believe it is possible to use FUTEX_REQUEUE in pthread_cond_signal, but it will cost us not one, but 2 extra syscalls and, what's worse, one of these extra syscalls will be done for every single waiting loop in pthread_cond_*wait. We would need to use lll_mutex_unlock_force in pthread_cond_signal after requeue and lll_mutex_cond_lock in pthread_cond_*wait after lll_futex_wait. Another alternative is to do the unlocking pthread_cond_signal needs to do (the lock can't be unlocked before lll_futex_wake, as that is racy) in the kernel. I have implemented both variants, futex-requeue-glibc.patch is the first one and futex-wake_op{,-glibc}.patch is the unlocking inside of the kernel. The kernel interface allows userland to specify how exactly an unlocking operation should look like (some atomic arithmetic operation with optional constant argument and comparison of the previous futex value with another constant). It has been implemented just for ppc*, x86_64 and i?86, for other architectures I'm including just a stub header which can be used as a starting point by maintainers to write support for their arches and ATM will just return -ENOSYS for FUTEX_WAKE_OP. The requeue patch has been (lightly) tested just on x86_64, the wake_op patch on ppc64 kernel running 32-bit and 64-bit NPTL and x86_64 kernel running 32-bit and 64-bit NPTL. With the following benchmark on UP x86-64 I get: for i in nptl-orig nptl-requeue nptl-wake_op; do echo time elf/ld.so --library-path .:$i /tmp/bench; \ for j in 1 2; do echo ( time elf/ld.so --library-path .:$i /tmp/bench ) 2>&1; done; done time elf/ld.so --library-path .:nptl-orig /tmp/bench real 0m0.655s user 0m0.253s sys 0m0.403s real 0m0.657s user 0m0.269s sys 0m0.388s time elf/ld.so --library-path .:nptl-requeue /tmp/bench real 0m0.496s user 0m0.225s sys 0m0.271s real 0m0.531s user 0m0.242s sys 0m0.288s time elf/ld.so --library-path .:nptl-wake_op /tmp/bench real 0m0.380s user 0m0.176s sys 0m0.204s real 0m0.382s user 0m0.175s sys 0m0.207s The benchmark is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00001.txt Older futex-requeue-glibc.patch version is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00002.txt Older futex-wake_op-glibc.patch version is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00003.txt Will post a new version (just x86-64 fixes so that the patch applies against pthread_cond_signal.S) to libc-hacker ml soon. Attached is the kernel FUTEX_WAKE_OP patch as well as a simple-minded testcase that will not test the atomicity of the operation, but at least check if the threads that should have been woken up are woken up and whether the arithmetic operation in the kernel gave the expected results. Acked-by: Ingo Molnar <mingo@redhat.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Jamie Lokier <jamie@shareable.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] sab: consolidate kmem_bufctl_tKyle Moffett
This is used only in slab.c and each architecture gets to define whcih underlying type is to be used. Seems a bit silly - move it to slab.c and use the same type for all architectures: unsigned int. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: consolidate get_orderStephen Rothwell
Someone mentioned that almost all the architectures used basically the same implementation of get_order. This patch consolidates them into asm-generic/page.h and includes that in the appropriate places. The exceptions are ia64 and ppc which have their own (presumably optimised) versions. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-18[PATCH] SH64: inotify and ioprio syscallsRobert Love
Add inotify and ioprio syscall stubs to SH64. Signed-off-by: Robert Love <rml@novell.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Add emergency_restart()Eric W. Biederman
When the kernel is working well and we want to restart cleanly kernel_restart is the function to use. But in many instances the kernel wants to reboot when thing are expected to be working very badly such as from panic or a software watchdog handler. This patch adds the function emergency_restart() so that callers can be clear what semantics they expect when calling restart. emergency_restart() is expected to be callable from interrupt context and possibly reliable in even more trying circumstances. This is an initial generic implementation for all architectures. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[ACPI] merge acpi-2.6.12 branch into latest Linux 2.6.13-rc...Len Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[ACPI] PNPACPI vs sound IRQDavid Shaohua Li
http://bugme.osdl.org/show_bug.cgi?id=4016 Written-by: David Shaohua Li <shaohua.li@intel.com> Acked-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-06-29[PATCH] Serial: Split 8250 port table (part 2)Russell King
Remove legacy ISA serial ports for Accent, Boca, Fourport, Hub6 and MCA from the architecture specific serial.h include. The only ports which remain in asm-*/serial.h are the platform specific entries. These should really be converted by platform maintainers to use a platform device, such as can be found in arch/arm/mach-footbridge/isa.c Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-27[PATCH] PCI: fix up errors after dma bursting patch and CONFIG_PCI=nAndrew Morton
With CONFIG_PCI=n: In file included from include/linux/pci.h:917, from lib/iomap.c:6: include/asm/pci.h:104: warning: `enum pci_dma_burst_strategy' declared inside parameter list include/asm/pci.h:104: warning: its scope is only this definition or declaration, which is probably not what you want. include/asm/pci.h: In function `pci_dma_burst_advice': include/asm/pci.h:106: dereferencing pointer to incomplete type include/asm/pci.h:106: `PCI_DMA_BURST_INFINITY' undeclared (first use in this function) include/asm/pci.h:106: (Each undeclared identifier is reported only once include/asm/pci.h:106: for each function it appears in.) make[1]: *** [lib/iomap.o] Error 1 Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] PCI: DMA bursting adviceDavid S. Miller
After seeing, at best, "guesses" as to the following kind of information in several drivers, I decided that we really need a way for platforms to specifically give advice in this area for what works best with their PCI controller implementation. Basically, this new interface gives DMA bursting advice on PCI. There are three forms of the advice: 1) Burst as much as possible, it is not necessary to end bursts on some particular boundary for best performance. 2) Burst on some byte count multiple. A DMA burst to some multiple of number of bytes may be done, but it is important to end the burst on an exact multiple for best performance. The best example of this I am aware of are the PPC64 PCI controllers, where if you end a burst mid-cacheline then chip has to refetch the data and the IOMMU translations which hurts performance a lot. 3) Burst on a single byte count multiple. Bursts shall end exactly on the next multiple boundary for best performance. Sparc64 and Alpha's PCI controllers operate this way. They disconnect any device which tries to burst across a cacheline boundary. Actually, newer sparc64 PCI controllers do not have this behavior. That is why the "pdev" is passed into the interface, so I can add code later to check which PCI controller the system is using and give advice accordingly. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-23[PATCH] streamline preempt_count type across archsJesper Juhl
The preempt_count member of struct thread_info is currently either defined as int, unsigned int or __s32 depending on arch. This patch makes the type of preempt_count an int on all archs. Having preempt_count be an unsigned type prevents the catching of preempt_count < 0 bugs, and using int on some archs and __s32 on others is not exactely "neat" - much nicer when it's just int all over. A previous version of this patch was already ACK'ed by Robert Love, and the only change in this version of the patch compared to the one he ACK'ed is that this one also makes sure the preempt_count member is consistently commented. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] Hugepage consolidationDavid Gibson
A lot of the code in arch/*/mm/hugetlbpage.c is quite similar. This patch attempts to consolidate a lot of the code across the arch's, putting the combined version in mm/hugetlb.c. There are a couple of uglyish hacks in order to covert all the hugepage archs, but the result is a very large reduction in the total amount of code. It also means things like hugepage lazy allocation could be implemented in one place, instead of six. Tested, at least a little, on ppc64, i386 and x86_64. Notes: - this patch changes the meaning of set_huge_pte() to be more analagous to set_pte() - does SH4 need s special huge_ptep_get_and_clear()?? Acked-by: William Lee Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-28[PATCH] sh: PREEMPT_ACTIVE fixPaul Mundt
Port Paulus's ppc64 fix to sh: When the generic IRQ stuff went in, it seems that HARDIRQ_BITS got bumped from 9 (for ppc64) up to 12. Consequently, the PREEMPT_ACTIVE bit is now within HARDIRQ_MASK, and I get in_interrupt() falsely returning true when PREEMPT_ACTIVE is set, and thus a BUG_ON tripping in arch/ppc64/mm/tlb.c. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04[PATCH] asm/signal.h unificationAl Viro
New file - asm-generic/signal.h. Contains declarations of __sighandler_t, __sigrestore_t, SIG_DFL, SIG_IGN, SIG_ERR and default definitions of SIG_BLOCK, SIG_UNBLOCK and SIG_SETMASK. asm-*/signal.h switched to including it. The only exception is asm-parisc/signal.h that wants its own declaration of __sighandler_t; that one is left as-is. asm-ppc64/signal.h required one more thing - unlike everybody else it used __sigrestorer_t instead of usual __sigrestore_t. PPC64 switched to common spelling. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] misc verify_area cleanupsJesper Juhl
There were still a few comments left refering to verify_area, and two functions, verify_area_skas & verify_area_tt that just wrap corresponding access_ok_skas & access_ok_tt functions, just like verify_area does for access_ok - deprecate those. There was also a few places that still used verify_area in commented-out code, fix those up to use access_ok. After applying this one there should not be anything left but finally removing verify_area completely, which will happen after a kernel release or two. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] move SA_xxx defines to linux/signal.hStas Sergeev
The attached patch moves the IRQ-related SA_xxx flags (namely, SA_PROBE, SA_SAMPLE_RANDOM and SA_SHIRQ) from all the arch-specific headers to linux/signal.h. This looks like a left-over after the irq-handling code was consolidated. The code was moved to kernel/irq/*, but the flags are still left per-arch. Right now, adding a new IRQ flag to the arch-specific header, like this patch does: http://cvs.sourceforge.net/viewcvs.py/*checkout*/alsa/alsa-driver/utils/patches/pcsp-kernel-2.6.10-03.diff?rev=1.1 no longer works, it breaks the compilation for all other arches, unless you add that flag to all the other arch-specific headers too. So I think such a clean-up makes sense. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Exterminate PAGE_BUGMatt Mackall
Remove PAGE_BUG - repalce it with BUG and BUG_ON. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: arch FIRST_USER_ADDRESS 0Hugh Dickins
Replace misleading definition of FIRST_USER_PGD_NR 0 by definition of FIRST_USER_ADDRESS 0 in all the MMU architectures beyond arm and arm26. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
