The majority of this patch was created by the following script:
ASM=arch/sparc/include/asm
mkdir -p $ASM
git mv include/asm-sparc64/ftrace.h $ASM
git rm include/asm-sparc64/*
git mv include/asm-sparc/* $ASM
sed -ie 's/asm-sparc64/asm/g' $ASM/*
sed -ie 's/asm-sparc/asm/g' $ASM/*
The rest was an update of the top-level Makefile to use sparc
for header files when sparc64 is being build.
And a small fixlet to pick up the correct unistd.h from
sparc64 code.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
With this commit all sparc64 header files are moved to asm-sparc.
The remaining files (71 files) were too different to be trivially
merged so divide them up in a _32.h and a _64.h file which
are both included from the file with no bit size.
The following script were used:
cd include
FILES=`wc -l asm-sparc64/*h | grep -v '^ 1' | cut -b 20-`
for FILE in ${FILES}; do
echo $FILE:
BASE=`echo $FILE | cut -d '.' -f 1`
FN32=${BASE}_32.h
FN64=${BASE}_64.h
GUARD=___ASM_SPARC_`echo $BASE | tr '-' '_' | tr [:lower:] [:upper:]`_H
git mv asm-sparc/$FILE asm-sparc/$FN32
git mv asm-sparc64/$FILE asm-sparc/$FN64
echo git mv done
printf "#ifndef %s\n" $GUARD > asm-sparc/$FILE
printf "#define %s\n" $GUARD >> asm-sparc/$FILE
printf "#if defined(__sparc__) && defined(__arch64__)\n" >> asm-sparc/$FILE
printf "#include <asm-sparc/%s>\n" $FN64 >> asm-sparc/$FILE
printf "#else\n" >> asm-sparc/$FILE
printf "#include <asm-sparc/%s>\n" $FN32 >> asm-sparc/$FILE
printf "#endif\n" >> asm-sparc/$FILE
git add asm-sparc/$FILE
echo new file done
printf "#include <asm-sparc/%s>\n" $FILE > asm-sparc64/$FILE
git add asm-sparc64/$FILE
echo sparc64 file done
done
The guard contains three '_' to avoid conflict with existing guards.
In additing the two Kbuild files are emptied to avoid breaking
headers_* targets.
We will reintroduce the exported header files when the necessary
kbuild changes are merged.
This patch removes the CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Current limitations:
1) On SMP single stepping has some fundamental issues,
shared with other sw single-step architectures such
as mips and arm.
2) On 32-bit sparc we don't support SMP kgdb yet. That
requires some reworking of the IPI mechanisms and
infrastructure on that platform.
As per Documentation/feature-removal-schedule.txt
infrastructure for it.
Let it rip!
