path: root/include/asm-sparc/pgalloc.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: join the remaining header filesSam Ravnborg
With this commit all sparc64 header files are moved to asm-sparc. The remaining files (71 files) were too different to be trivially merged so divide them up in a _32.h and a _64.h file which are both included from the file with no bit size. The following script were used: cd include FILES=`wc -l asm-sparc64/*h | grep -v '^ 1' | cut -b 20-` for FILE in ${FILES}; do echo $FILE: BASE=`echo $FILE | cut -d '.' -f 1` FN32=${BASE}_32.h FN64=${BASE}_64.h GUARD=___ASM_SPARC_`echo $BASE | tr '-' '_' | tr [:lower:] [:upper:]`_H git mv asm-sparc/$FILE asm-sparc/$FN32 git mv asm-sparc64/$FILE asm-sparc/$FN64 echo git mv done printf "#ifndef %s\n" $GUARD > asm-sparc/$FILE printf "#define %s\n" $GUARD >> asm-sparc/$FILE printf "#if defined(__sparc__) && defined(__arch64__)\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN64 >> asm-sparc/$FILE printf "#else\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN32 >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE git add asm-sparc/$FILE echo new file done printf "#include <asm-sparc/%s>\n" $FILE > asm-sparc64/$FILE git add asm-sparc64/$FILE echo sparc64 file done done The guard contains three '_' to avoid conflict with existing guards. In additing the two Kbuild files are emptied to avoid breaking headers_* targets. We will reintroduce the exported header files when the necessary kbuild changes are merged. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
