path: root/include/asm-sparc64/bitops.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: join the remaining header filesSam Ravnborg
With this commit all sparc64 header files are moved to asm-sparc. The remaining files (71 files) were too different to be trivially merged so divide them up in a _32.h and a _64.h file which are both included from the file with no bit size. The following script were used: cd include FILES=`wc -l asm-sparc64/*h | grep -v '^ 1' | cut -b 20-` for FILE in ${FILES}; do echo $FILE: BASE=`echo $FILE | cut -d '.' -f 1` FN32=${BASE}_32.h FN64=${BASE}_64.h GUARD=___ASM_SPARC_`echo $BASE | tr '-' '_' | tr [:lower:] [:upper:]`_H git mv asm-sparc/$FILE asm-sparc/$FN32 git mv asm-sparc64/$FILE asm-sparc/$FN64 echo git mv done printf "#ifndef %s\n" $GUARD > asm-sparc/$FILE printf "#define %s\n" $GUARD >> asm-sparc/$FILE printf "#if defined(__sparc__) && defined(__arch64__)\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN64 >> asm-sparc/$FILE printf "#else\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN32 >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE git add asm-sparc/$FILE echo new file done printf "#include <asm-sparc/%s>\n" $FILE > asm-sparc64/$FILE git add asm-sparc64/$FILE echo sparc64 file done done The guard contains three '_' to avoid conflict with existing guards. In additing the two Kbuild files are emptied to avoid breaking headers_* targets. We will reintroduce the exported header files when the necessary kbuild changes are merged. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-26generic: implement __fls on all 64-bit archsAlexander van Heukelum
Implement __fls on all 64-bit archs: alpha has an implementation of fls64. Added __fls(x) = fls64(x) - 1. ia64 has fls, but not __fls. Added __fls based on code of fls. mips and powerpc have __ilog2, which is the same as __fls. Added __fls = __ilog2. parisc, s390, sh and sparc64: Include generic __fls. x86_64 already has __fls. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-19forbid asm/bitops.h direct inclusionJiri Slaby
forbid asm/bitops.h direct inclusion Because of compile errors that may occur after bit changes if asm/bitops.h is included directly without e.g. linux/kernel.h which includes linux/bitops.h, forbid direct inclusion of asm/bitops.h. Thanks to Adrian Bunk. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18bitops: introduce lock opsNick Piggin
Introduce test_and_set_bit_lock / clear_bit_unlock bitops with lock semantics. Convert all architectures to use the generic implementation. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-By: David Howells <dhowells@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Andi Kleen <ak@muc.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-26[PATCH] bitops: sparc64: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove __ffs() - remove generic_fls() - remove generic_fls64() - remove sched_find_first_bit() - remove ffs() - unless defined(ULTRA_HAS_POPULATION_COUNT) - remove generic_hweight{64,32,16,8}() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: use non atomic operations for minix_*_bit() and ext2_*_bit()Akinobu Mita
Bitmap functions for the minix filesystem and the ext2 filesystem except ext2_set_bit_atomic() and ext2_clear_bit_atomic() do not require the atomic guarantees. But these are defined by using atomic bit operations on several architectures. (cris, frv, h8300, ia64, m32r, m68k, m68knommu, mips, s390, sh, sh64, sparc, sparc64, v850, and xtensa) This patch switches to non atomic bit operation. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SPARC64]: More fully work around Spitfire Errata 51.David S. Miller
It appears that a memory barrier soon after a mispredicted branch, not just in the delay slot, can cause the hang condition of this cpu errata. So move them out-of-line, and explicitly put them into a "branch always, predict taken" delay slot which should fully kill this problem. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-24[SPARC64]: Non-atomic bitops do not need volatile operationsDavid S. Miller
Noticed this while comparing sparc64's bitops.h to ppc64's. We can cast the volatile memory argument to be non-volatile. While we're here, __inline__ --> inline. Signed-off-by: David S. Miller <davem@davemloft.net>
