path: root/include/asm-sparc64/head.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: join the remaining header filesSam Ravnborg
With this commit all sparc64 header files are moved to asm-sparc. The remaining files (71 files) were too different to be trivially merged so divide them up in a _32.h and a _64.h file which are both included from the file with no bit size. The following script were used: cd include FILES=`wc -l asm-sparc64/*h | grep -v '^ 1' | cut -b 20-` for FILE in ${FILES}; do echo $FILE: BASE=`echo $FILE | cut -d '.' -f 1` FN32=${BASE}_32.h FN64=${BASE}_64.h GUARD=___ASM_SPARC_`echo $BASE | tr '-' '_' | tr [:lower:] [:upper:]`_H git mv asm-sparc/$FILE asm-sparc/$FN32 git mv asm-sparc64/$FILE asm-sparc/$FN64 echo git mv done printf "#ifndef %s\n" $GUARD > asm-sparc/$FILE printf "#define %s\n" $GUARD >> asm-sparc/$FILE printf "#if defined(__sparc__) && defined(__arch64__)\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN64 >> asm-sparc/$FILE printf "#else\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN32 >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE git add asm-sparc/$FILE echo new file done printf "#include <asm-sparc/%s>\n" $FILE > asm-sparc64/$FILE git add asm-sparc64/$FILE echo sparc64 file done done The guard contains three '_' to avoid conflict with existing guards. In additing the two Kbuild files are emptied to avoid breaking headers_* targets. We will reintroduce the exported header files when the necessary kbuild changes are merged. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Add GET_GL_GLOBAL() macro for SUN4V.David S. Miller
So we can read the %gl register for debugging. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Detect sun4v early in boot process.David S. Miller
We look for "SUNW,sun4v" in the 'compatible' property of the root OBP device tree node. Protect every %ver register access, to make sure it is not touched on sun4v, as %ver is hyperprivileged there. Lock kernel TLB entries using hypervisor calls instead of calls into OBP. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Add initial code to twiddle %gl on trap entry/exit.David S. Miller
Instead of setting/clearing PSTATE_AG we have to change the %gl register value on sun4v. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Refine code sequences to get the cpu id.David S. Miller
On uniprocessor, it's always zero for optimize that. On SMP, the jmpl to the stub kills the return address stack in the cpu branch prediction logic, so expand the code sequence inline and use a code patching section to fix things up. This also always better and explicit register selection, which will be taken advantage of in a future changeset. The hard_smp_processor_id() function is big, so do not inline it. Fix up tests for Jalapeno to also test for Serrano chips too. These tests want "jbus Ultra-IIIi" cases to match, so that is what we should test for. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-27[SPARC64]: Add missing IDs for newer cpus.David S. Miller
Also, the us3_cpufreq driver can work on Ultra-IV and IV+. They use the SAFARI bus register to control the clock divider just like Ultra-III and III+ do. Signed-off-by: David S. Miller <davem@davemloft.net>
