path: root/include/asm-sparc64/mmu_context.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: join the remaining header filesSam Ravnborg
With this commit all sparc64 header files are moved to asm-sparc. The remaining files (71 files) were too different to be trivially merged so divide them up in a _32.h and a _64.h file which are both included from the file with no bit size. The following script were used: cd include FILES=`wc -l asm-sparc64/*h | grep -v '^ 1' | cut -b 20-` for FILE in ${FILES}; do echo $FILE: BASE=`echo $FILE | cut -d '.' -f 1` FN32=${BASE}_32.h FN64=${BASE}_64.h GUARD=___ASM_SPARC_`echo $BASE | tr '-' '_' | tr [:lower:] [:upper:]`_H git mv asm-sparc/$FILE asm-sparc/$FN32 git mv asm-sparc64/$FILE asm-sparc/$FN64 echo git mv done printf "#ifndef %s\n" $GUARD > asm-sparc/$FILE printf "#define %s\n" $GUARD >> asm-sparc/$FILE printf "#if defined(__sparc__) && defined(__arch64__)\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN64 >> asm-sparc/$FILE printf "#else\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN32 >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE git add asm-sparc/$FILE echo new file done printf "#include <asm-sparc/%s>\n" $FILE > asm-sparc64/$FILE git add asm-sparc64/$FILE echo sparc64 file done done The guard contains three '_' to avoid conflict with existing guards. In additing the two Kbuild files are emptied to avoid breaking headers_* targets. We will reintroduce the exported header files when the necessary kbuild changes are merged. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16[SPARC64]: dr-cpu unconfigure support.David S. Miller
2007-05-02[PATCH] x86: PARAVIRT: add hooks to intercept mm creation and destructionJeremy Fitzhardinge
Add hooks to allow a paravirt implementation to track the lifetime of an mm. Paravirtualization requires three hooks, but only two are needed in common code. They are: arch_dup_mmap, which is called when a new mmap is created at fork arch_exit_mmap, which is called when the last process reference to an mm is dropped, which typically happens on exit and exec. The third hook is activate_mm, which is called from the arch-specific activate_mm() macro/function, and so doesn't need stub versions for other architectures. It's called when an mm is first used. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: linux-arch@vger.kernel.org Cc: James Bottomley <James.Bottomley@SteelEye.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2006-03-22[SPARC64]: Add a secondary TSB for hugepage mappings.David S. Miller
2006-03-20[SPARC64]: Fix and re-enable dynamic TSB sizing.David S. Miller
This is good for up to %50 performance improvement of some test cases. The problem has been the race conditions, and hopefully I've plugged them all up here. 1) There was a serious race in switch_mm() wrt. lazy TLB switching to and from kernel threads. We could erroneously skip a tsb_context_switch() and thus use a stale TSB across a TSB grow event. There is a big comment now in that function describing exactly how it can happen. 2) All code paths that do something with the TSB need to be guarded with the mm->context.lock spinlock. This makes page table flushing paths properly synchronize with both TSB growing and TLB context changes. 3) TSB growing events are moved to the end of successful fault processing. Previously it was in update_mmu_cache() but that is deadlock prone. At the end of do_sparc64_fault() we hold no spinlocks that could deadlock the TSB grow sequence. We also have dropped the address space semaphore. While we're here, add prefetching to the copy_tsb() routine and put it in assembler into the tsb.S file. This piece of code is quite time critical. There are some small negative side effects to this code which can be improved upon. In particular we grab the mm->context.lock even for the tsb insert done by update_mmu_cache() now and that's a bit excessive. We can get rid of that locking, and the same lock taking in flush_tsb_user(), by disabling PSTATE_IE around the whole operation including the capturing of the tsb pointer and tsb_nentries value. That would work because anyone growing the TSB won't free up the old TSB until all cpus respond to the TSB change cross call. I'm not quite so confident in that optimization to put it in right now, but eventually we might be able to and the description is here for reference. This code seems very solid now. It passes several parallel GCC bootstrap builds, and our favorite "nut cruncher" stress test which is a full "make -j8192" build of a "make allmodconfig" kernel. That puts about 256 processes on each cpu's run queue, makes lots of process cpu migrations occur, causes lots of page table and TLB flushing activity, incurs many context version number changes, and it swaps the machine real far out to disk even though there is 16GB of ram on this test system. :-) Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Bulletproof MMU context locking.David S. Miller
1) Always spin_lock_init() in init_context(). The caller essentially clears it out, or copies the mm info from the parent. In both cases we need to explicitly initialize the spinlock. 2) Always do explicit IRQ disabling while taking mm->context.lock and ctx_alloc_lock. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix TLB context allocation with SMT style shared TLBs.David S. Miller
The context allocation scheme we use depends upon there being a 1<-->1 mapping from cpu to physical TLB for correctness. Chips like Niagara break this assumption. So what we do is notify all cpus with a cross call when the context version number changes, and if necessary this makes them allocate a valid context for the address space they are running at the time. Stress tested with make -j1024, make -j2048, and make -j4096 kernel builds on a 32-strand, 8 core, T2000 with 16GB of ram. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Hypervisor TSB context switching.David S. Miller
2006-03-20[SPARC64]: Patch up mmu context register writes for sun4v.David S. Miller
sun4v uses ASI_MMU instead of ASI_DMMU Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Dynamically grow TSB in response to RSS growth.David S. Miller
As the RSS grows, grow the TSB in order to reduce the likelyhood of hash collisions and thus poor hit rates in the TSB. This definitely needs some serious tuning. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Add infrastructure for dynamic TSB sizing.David S. Miller
This also cleans up tsb_context_switch(). The assembler routine is now __tsb_context_switch() and the former is an inline function that picks out the bits from the mm_struct and passes it into the assembler code as arguments. setup_tsb_parms() computes the locked TLB entry to map the TSB. Later when we support using the physical address quad load instructions of Cheetah+ and later, we'll simply use the physical address for the TSB register value and set the map virtual and PTE both to zero. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: TSB refinements.David S. Miller
Move {init_new,destroy}_context() out of line. Do not put huge pages into the TSB, only base page size translations. There are some clever things we could do here, but for now let's be correct instead of fancy. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Move away from virtual page tables, part 1.David S. Miller
We now use the TSB hardware assist features of the UltraSPARC MMUs. SMP is currently knowingly broken, we need to find another place to store the per-cpu base pointers. We hid them away in the TSB base register, and that obviously will not work any more :-) Another known broken case is non-8KB base page size. Also noticed that flush_tlb_all() is not referenced anywhere, only the internal __flush_tlb_all() (local cpu only) is used by the sparc64 port, so we can get rid of flush_tlb_all(). The kernel gets it's own 8KB TSB (swapper_tsb) and each address space gets it's own private 8K TSB. Later we can add code to dynamically increase the size of per-process TSB as the RSS grows. An 8KB TSB is good enough for up to about a 4MB RSS, after which the TSB starts to incur many capacity and conflict misses. We even accumulate OBP translations into the kernel TSB. Another area for refinement is large page size support. We could use a secondary address space TSB to handle those. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-12[PATCH] sparc64: task_thread_info()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[SPARC64] mm: context switch ptlockHugh Dickins
sparc64 is unique among architectures in taking the page_table_lock in its context switch (well, cris does too, but erroneously, and it's not yet SMP anyway). This seems to be a private affair between switch_mm and activate_mm, using page_table_lock as a per-mm lock, without any relation to its uses elsewhere. That's fine, but comment it as such; and unlock sooner in switch_mm, more like in activate_mm (preemption is disabled here). There is a block of "if (0)"ed code in smp_flush_tlb_pending which would have liked to rely on the page_table_lock, in switch_mm and elsewhere; but its comment explains how dup_mmap's flush_tlb_mm defeated it. And though that could have been changed at any time over the past few years, now the chance vanishes as we push the page_table_lock downwards, and perhaps split it per page table page. Just delete that block of code. Which leaves the mysterious spin_unlock_wait(&oldmm->page_table_lock) in kernel/fork.c copy_mm. Textual analysis (supported by Nick Piggin) suggests that the comment was written by DaveM, and that it relates to the defeated approach in the sparc64 smp_flush_tlb_pending. Just delete this block too. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
