path: root/include/asm-sparc64/pstate.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: copy exported sparc64 specific header files to asm-sparcSam Ravnborg
Copy was done using the following simple script: set -e SPARC64="h display7seg.h envctrl.h psrcompat.h pstate.h uctx.h utrap.h watchdog.h" for FILE in ${SPARC64}; do if [ -f asm-sparc/$FILE ]; then echo $FILE exist in asm-sparc fi cat asm-sparc64/$FILE > asm-sparc/$FILE printf "#include <asm-sparc/$FILE>\n" > asm-sparc64/$FILE done The name of the copied files are added to asm-sparc/Kbuild to keep "make headers_check" functional. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-11sparc: Fix debugger syscall restart interactions.David S. Miller
So, forever, we've had this ptrace_signal_deliver implementation which tries to handle all of the nasties that can occur when the debugger looks at a process about to take a signal. It's meant to address all of these issues inside of the kernel so that the debugger need not be mindful of such things. Problem is, this doesn't work. The idea was that we should do the syscall restart business first, so that the debugger captures that state. Otherwise, if the debugger for example saves the child's state, makes the child execute something else, then restores the saved state, we won't handle the syscall restart properly because we lose the "we're in a syscall" state. The code here worked for most cases, but if the debugger actually passes the signal through to the child unaltered, it's possible that we would do a syscall restart when we shouldn't have. In particular this breaks the case of debugging a process under a gdb which is being debugged by yet another gdb. gdb uses sigsuspend to wait for SIGCHLD of the inferior, but if gdb itself is being debugged by a top-level gdb we get a ptrace_stop(). The top-level gdb does a PTRACE_CONT with SIGCHLD to let the inferior gdb see the signal. But ptrace_signal_deliver() assumed the debugger would cancel out the signal and therefore did a syscall restart, because the return error was ERESTARTNOHAND. Fix this by simply making ptrace_signal_deliver() a nop, and providing a way for the debugger to control system call restarting properly: 1) Report a "in syscall" software bit in regs->{tstate,psr}. It is set early on in trap entry to a system call and is fully visible to the debugger via ptrace() and regsets. 2) Test this bit right before doing a syscall restart. We have to do a final recheck right after get_signal_to_deliver() in case the debugger cleared the bit during ptrace_stop(). 3) Clear the bit in trap return so we don't accidently try to set that bit in the real register. As a result we also get a ptrace_{is,clear}_syscall() for sparc32 just like sparc64 has. M68K has this same exact bug, and is now the only other user of the ptrace_signal_deliver hook. It needs to be fixed in the same exact way as sparc. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-08consolidate asm/const.h to linux/const.hRandy Dunlap
Make a global linux/const.h header file instead of having multiple, per-arch files, and convert current users of asm/const.h to use linux/const.h. Built on x86_64 and sparc64. [akpm@linux-foundation.org: fix include/asm-x86_64/Kbuild] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-20[SPARC64]: Fixup TSTATE layout diagram in asm/pstate.hDavid S. Miller
2006-03-20[SPARC64]: Add define for "GL" field of sun4v %tstate register.David S. Miller
