path: root/include/asm-sparc64/scatterlist.h
2007-10-22Add CONFIG_DEBUG_SG sg validationJens Axboe
Add a Kconfig entry which will toggle some sanity checks on the sg entry and tables. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Change table chaining layoutJens Axboe
Change the page member of the scatterlist structure to be an unsigned long, and encode more stuff in the lower bits: - Bits 0 and 1 zero: this is a normal sg entry. Next sg entry is located at sg + 1. - Bit 0 set: this is a chain entry, the next real entry is at ->page_link with the two low bits masked off. - Bit 1 set: this is the final entry in the sg entry. sg_next() will return NULL when passed such an entry. It's thus important that sg table users use the proper accessors to get and set the page member. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-16SPARC64: sg chaining supportJens Axboe
This updates the sparc64 iommu/pci dma mappers to sg chaining. Acked-by: David S. Miller <davem@davemloft.net> Later updated to newer kernel with unified sparc64 iommu sg handling. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-02PCI: scatterlist.h needs types.hJean Delvare
Most architectures' scatterlist.h use the type dma_addr_t, but omit to include <asm/types.h> which defines it. This could lead to build failures, so let's add the missing includes. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
