path: root/include/asm-sparc64/signal.h
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-11sparc: Fix debugger syscall restart interactions.David S. Miller
So, forever, we've had this ptrace_signal_deliver implementation which tries to handle all of the nasties that can occur when the debugger looks at a process about to take a signal. It's meant to address all of these issues inside of the kernel so that the debugger need not be mindful of such things. Problem is, this doesn't work. The idea was that we should do the syscall restart business first, so that the debugger captures that state. Otherwise, if the debugger for example saves the child's state, makes the child execute something else, then restores the saved state, we won't handle the syscall restart properly because we lose the "we're in a syscall" state. The code here worked for most cases, but if the debugger actually passes the signal through to the child unaltered, it's possible that we would do a syscall restart when we shouldn't have. In particular this breaks the case of debugging a process under a gdb which is being debugged by yet another gdb. gdb uses sigsuspend to wait for SIGCHLD of the inferior, but if gdb itself is being debugged by a top-level gdb we get a ptrace_stop(). The top-level gdb does a PTRACE_CONT with SIGCHLD to let the inferior gdb see the signal. But ptrace_signal_deliver() assumed the debugger would cancel out the signal and therefore did a syscall restart, because the return error was ERESTARTNOHAND. Fix this by simply making ptrace_signal_deliver() a nop, and providing a way for the debugger to control system call restarting properly: 1) Report a "in syscall" software bit in regs->{tstate,psr}. It is set early on in trap entry to a system call and is fully visible to the debugger via ptrace() and regsets. 2) Test this bit right before doing a syscall restart. We have to do a final recheck right after get_signal_to_deliver() in case the debugger cleared the bit during ptrace_stop(). 3) Clear the bit in trap return so we don't accidently try to set that bit in the real register. As a result we also get a ptrace_{is,clear}_syscall() for sparc32 just like sparc64 has. M68K has this same exact bug, and is now the only other user of the ptrace_signal_deliver hook. It needs to be fixed in the same exact way as sparc. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-02[SPARC64]: Do not include compat.h from asm-sparc64/signal.h any more.David S. Miller
It's not needed, now that all of that stuff is now in asm/compat_signal.h, and it breaks the build too :-) Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-02[SPARC64]: Move signal compat bits to new header file.David S. Miller
Create asm-sparc64/compat_signal.h and stuff things there. This avoids the "linux/compat.h includes asm/signal.h but asm/signal.h needs compat_sigset_t which isn't defined yet" problems introduced recently. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-02[PATCH] irq-flags: SPARC64: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-07-04[SPARC64]: Add support for IRQ pre-handlers.David S. Miller
This allows a PCI controller to shim into IRQ delivery so that DMA queues can be drained, if necessary. If some bus specific code needs to run before an IRQ handler is invoked, the bus driver simply needs to setup the function pointer in bucket->irq_info->pre_handler and the two args bucket->irq_info->pre_handler_arg[12]. The Schizo PCI driver is converted over to use a pre-handler for the DMA write-sync processing it needs when a device is behind a PCI->PCI bus deeper than the top-level APB bridges. While we're here, clean up all of the action allocation and handling. Now, we allocate the irqaction as part of the bucket->irq_info area. There is an array of 4 irqaction (for PCI irq sharing) and a bitmask saying which entries are active. The bucket->irq_info is allocated at build_irq() time, not at request_irq() time. This simplifies request_irq() and free_irq() tremendously. The SMP dynamic IRQ retargetting code got removed in this change too. It was disabled for a few months now, and we can resurrect it in the future if we want. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-04[PATCH] asm/signal.h unificationAl Viro
New file - asm-generic/signal.h. Contains declarations of __sighandler_t, __sigrestore_t, SIG_DFL, SIG_IGN, SIG_ERR and default definitions of SIG_BLOCK, SIG_UNBLOCK and SIG_SETMASK. asm-*/signal.h switched to including it. The only exception is asm-parisc/signal.h that wants its own declaration of __sighandler_t; that one is left as-is. asm-ppc64/signal.h required one more thing - unlike everybody else it used __sigrestorer_t instead of usual __sigrestore_t. PPC64 switched to common spelling. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] move SA_xxx defines to linux/signal.hStas Sergeev
The attached patch moves the IRQ-related SA_xxx flags (namely, SA_PROBE, SA_SAMPLE_RANDOM and SA_SHIRQ) from all the arch-specific headers to linux/signal.h. This looks like a left-over after the irq-handling code was consolidated. The code was moved to kernel/irq/*, but the flags are still left per-arch. Right now, adding a new IRQ flag to the arch-specific header, like this patch does: http://cvs.sourceforge.net/viewcvs.py/*checkout*/alsa/alsa-driver/utils/patches/pcsp-kernel-2.6.10-03.diff?rev=1.1 no longer works, it breaks the compilation for all other arches, unless you add that flag to all the other arch-specific headers too. So I think such a clean-up makes sense. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
