path: root/include/asm-sparc64/sunbpp.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: merge header files with trivial differencesSam Ravnborg
A manual inspection revealed that the following headerfiles contained only trivial differences: hw_irq.h idprom.h kmap_types.h kvm.h spinlock_types.h sunbpp.h unaligned.h The only noteworthy change are that sparc64 had a volatile qualifer that sparc missed in spinlock_types.h. In addition a few comments were updated. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
