path: root/include/asm-sparc64/termios.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: Merge asm-sparc{,64}/termios.hSam Ravnborg
Bring the commit e55c57e0b51c68d78845549505057169c6c3cba6 ("[SPARC64]: Report any user access faults in termios accessors") over to sparc when unifying the two files. The diff was manually inspected to contain no other relevant changes. This unification therefore changes functionality of sparc. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21[SPARC]: Remove SunOS and Solaris binary support.David S. Miller
As per Documentation/feature-removal-schedule.txt Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[SPARC]: Support for new termios.David Miller
[akpm@linux-foundation.org: coding-style tweaks] Signed-off-by: David Miller <davem@davemloft.net> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-11[PATCH] consolidate line discipline number definitionsTilman Schmidt
The line discipline numbers N_* are currently defined for each architecture individually, but (except for a seeming mistake) identically, in asm/termios.h. There is no obvious reason why these numbers should be architecture specific, nor any apparent relationship with the termios structure. The total number of these, NR_LDISCS, is defined in linux/tty.h anyway. So I propose the following patch which moves the definitions of the individual line disciplines to linux/tty.h too. Three of these numbers (N_MASC, N_PROFIBUS_FDL, and N_SMSBLOCK) are unused in the current kernel, but the patch still keeps the complete set in case there are plans to use them yet. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-11-07[SPARC]: remove duplicate TIOCPKT_ definitionsStephen Rothwell
The TIOCPKT_ macros are defined by all other architectures in asm/ioctls.h and so does sparc and sparc64, so reomve the duplicates in asm/termios.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-24[SPARC64]: Report any user access faults in termios accessors.David S. Miller
