path: root/include/asm-um/mmu_context.h
2008-06-06uml: activate_mm: remove the dead PF_BORROWED_MM checktip-core-topology-2008-06-16_09.13_Montip-core-misc-2008-06-16_09.11_MonOleg Nesterov
use_mm() was changed to use switch_mm() instead of activate_mm(), since then nobody calls (and nobody should call) activate_mm() with PF_BORROWED_MM bit set. As Jeff Dike pointed out, we can also remove the "old != new" check, it is always true. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: cover stubs with a VMAJeff Dike
Give the stubs a VMA. This allows the removal of a truly nasty kludge to make sure that mm->nr_ptes was correct in exit_mmap. The underlying problem was always that the stubs, which have ptes, and thus allocated a page table, weren't covered by a VMA. This patch fixes that by using install_special_mapping in arch_dup_mmap and activate_context to create the VMA. The stubs have to be moved, since shift_arg_pages seems to assume that the stack is the only VMA present at that point during exec, and uses vma_adjust to fiddle its VMA. However, that extends the stub VMA by the amount removed from the stack VMA. To avoid this problem, the stubs were moved to a different fixed location at the start of the address space. The init_stub_pte calls were moved from init_new_context to arch_dup_mmap because I was occasionally seeing arch_dup_mmap not being called, causing exit_mmap to die. Rather than figure out what was really happening, I decided it was cleaner to just move the calls so that there's no doubt that both the pte and VMA creation happen, no matter what. arch_exit_mmap is used to clear the stub ptes at exit time. The STUB_* constants in as-layout.h no longer depend on UM_TASK_SIZE, that that definition is removed, along with the comments complaining about gcc. Because the stubs are no longer at the top of the address space, some care is needed while flushing TLBs. update_pte_range checks for addresses in the stub range and skips them. flush_thread now issues two unmaps, one for the range before STUB_START and one for the range after STUB_END. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fold mmu_context_skas into mm_contextJeff Dike
This patch folds mmu_context_skas into struct mm_context, changing all users of these structures as needed. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: style fixes pass 3Jeff Dike
Formatting changes in the files which have been changed in the course of folding foo_skas functions into their callers. These include: copyright updates header file trimming style fixes adding severity to printks These changes should be entirely non-functional. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove code made redundant by CHOOSE_MODE removalJeff Dike
This patch makes a number of simplifications enabled by the removal of CHOOSE_MODE. There were lots of functions that looked like int foo(args){ foo_skas(args); } The bodies of foo_skas are now folded into foo, and their declarations (and sometimes entire header files) are deleted. In addition, the union uml_pt_regs, which was a union between the tt and skas register formats, is now a struct, with the tt-mode arm of the union being removed. It turns out that usr2_handler was unused, so it is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: throw out CHOOSE_MODEJeff Dike
The next stage after removing code which depends on CONFIG_MODE_TT is removing the CHOOSE_MODE abstraction, which provided both compile-time and run-time branching to either tt-mode or skas-mode code. This patch removes choose-mode.h and all inclusions of it, and replaces all CHOOSE_MODE invocations with the skas branch. This leaves a number of trivial functions which will be dealt with in a later patch. There are some changes in the uaccess and tls support which go somewhat beyond this and eliminate some of the now-redundant functions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: throw out CONFIG_MODE_TTJeff Dike
This patchset throws out tt mode, which has been non-functional for a while. This is done in phases, interspersed with code cleanups on the affected files. The removal is done as follows: remove all code, config options, and files which depend on CONFIG_MODE_TT get rid of the CHOOSE_MODE macro, which decided whether to call tt-mode or skas-mode code, and replace invocations with their skas portions replace all now-trivial procedures with their skas equivalents There are now a bunch of now-redundant pieces of data structures, including mode-specific pieces of the thread structure, pt_regs, and mm_context. These are all replaced with their skas-specific contents. As part of the ongoing style compliance project, I made a style pass over all files that were changed. There are three such patches, one for each phase, covering the files affected by that phase but no later ones. I noticed that we weren't freeing the LDT state associated with a process when it exited, so that's fixed in one of the later patches. The last patch is a tidying patch which I've had for a while, but which caused inexplicable crashes under tt mode. Since that is no longer a problem, this can now go in. This patch: Start getting rid of tt mode support. This patch throws out CONFIG_MODE_TT and all config options, code, and files which depend on it. CONFIG_MODE_SKAS is gone and everything that depends on it is included unconditionally. The few changed lines are in re-written Kconfig help, lines which needed something skas-related removed from them, and a few more which weren't strictly deletions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86: PARAVIRT: add hooks to intercept mm creation and destructionJeremy Fitzhardinge
Add hooks to allow a paravirt implementation to track the lifetime of an mm. Paravirtualization requires three hooks, but only two are needed in common code. They are: arch_dup_mmap, which is called when a new mmap is created at fork arch_exit_mmap, which is called when the last process reference to an mm is dropped, which typically happens on exit and exec. The third hook is activate_mm, which is called from the arch-specific activate_mm() macro/function, and so doesn't need stub versions for other architectures. It's called when an mm is first used. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: linux-arch@vger.kernel.org Cc: James Bottomley <James.Bottomley@SteelEye.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-11-07[PATCH] uml: switch_mm fixBen Lahaise
Not quite, something along the lines of the patch below works correctly (and makes aio performance not suffer from multiple second delays), as skas0 mode correctly switches mm contexts, unlike TT (which should probably get nuked from the kernel now that skas0 seems to be working). Signed-off-by: Benjamin LaHaise <bcrl@linux.intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: fixes performance regression in activate_mm and thus exec()Paolo 'Blaisorblade' Giarrusso
Normally, activate_mm() is called from exec(), and thus it used to be a no-op because we use a completely new "MM context" on the host (for instance, a new process), and so we didn't need to flush any "TLB entries" (which for us are the set of memory mappings for the host process from the virtual "RAM" file). Kernel threads, instead, are usually handled in a different way. So, when for AIO we call use_mm(), things used to break and so Benjamin implemented activate_mm(). However, that is only needed for AIO, and could slow down exec() inside UML, so be smart: detect being called for AIO (via PF_BORROWED_MM) and do the full flush only in that situation. Comment also the caller so that people won't go breaking UML without noticing. I also rely on the caller's locks for testing current->flags. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] uml: tlb flushing fixBenjamin LaHaise
This patch fixes a fairly serious tlb flushing bug that makes aio use under uml very unreliable -- SEGVs, Oops and panic()s occur as a result of stale tlb entires being used by uml when aio switches mms due to the fact that uml does not implement the activate_mm() hook. This patch introduces a simple but correct approach (read: hammer) for implementing activate_mm() in uml by doing a force_flush_all() if the new mm is different from old. With this patch in place, uml is able to succeed at the aio test case that was randomly faulting for me before. Cc: Jeff Dike <jdike@addtoit.com> Cc: <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] uml: skas0 - separate kernel address space on stock hostsJeff Dike
UML has had two modes of operation - an insecure, slow mode (tt mode) in which the kernel is mapped into every process address space which requires no host kernel modifications, and a secure, faster mode (skas mode) in which the UML kernel is in a separate host address space, which requires a patch to the host kernel. This patch implements something very close to skas mode for hosts which don't support skas - I'm calling this skas0. It provides the security of the skas host patch, and some of the performance gains. The two main things that are provided by the skas patch, /proc/mm and PTRACE_FAULTINFO, are implemented in a way that require no host patch. For the remote address space changing stuff (mmap, munmap, and mprotect), we set aside two pages in the process above its stack, one of which contains a little bit of code which can call mmap et al. To update the address space, the system call information (system call number and arguments) are written to the stub page above the code. The %esp is set to the beginning of the data, the %eip is set the the start of the stub, and it repeatedly pops the information into its registers and makes the system call until it sees a system call number of zero. This is to amortize the cost of the context switch across multiple address space updates. When the updates are done, it SIGSTOPs itself, and the kernel process continues what it was doing. For a PTRACE_FAULTINFO replacement, we set up a SIGSEGV handler in the child, and let it handle segfaults rather than nullifying them. The handler is in the same page as the mmap stub. The second page is used as the stack. The handler reads cr2 and err from the sigcontext, sticks them at the base of the stack in a faultinfo struct, and SIGSTOPs itself. The kernel then reads the faultinfo and handles the fault. A complication on x86_64 is that this involves resetting the registers to the segfault values when the process is inside the kill system call. This breaks on x86_64 because %rcx will contain %rip because you tell SYSRET where to return to by putting the value in %rcx. So, this corrupts $rcx on return from the segfault. To work around this, I added an arch_finish_segv, which on x86 does nothing, but which on x86_64 ptraces the child back through the sigreturn. This causes %rcx to be restored by sigreturn and avoids the corruption. Ultimately, I think I will replace this with the trick of having it send itself a blocked signal which will be unblocked by the sigreturn. This will allow it to be stopped just after the sigreturn, and PTRACE_SYSCALLed without all the back-and-forth of PTRACE_SYSCALLing it through sigreturn. This runs on a stock host, so theoretically (and hopefully), tt mode isn't needed any more. We need to make sure that this is better in every way than tt mode, though. I'm concerned about the speed of address space updates and page fault handling, since they involve extra round-trips to the child. We can amortize the round-trip cost for large address space updates by writing all of the operations to the data page and having the child execute them all at the same time. This will help fork and exec, but not page faults, since they involve only one page. I can't think of any way to help page faults, except to add something like PTRACE_FAULTINFO to the host. There is PTRACE_SIGINFO, but UML doesn't use siginfo for SIGSEGV (or anything else) because there isn't enough information in the siginfo struct to handle page faults (the faulting operation type is missing). Adding that would make PTRACE_SIGINFO a usable equivalent to PTRACE_FAULTINFO. As for the code itself: - The system call stub is in arch/um/kernel/sys-$(SUBARCH)/stub.S. It is put in its own section of the binary along with stub_segv_handler in arch/um/kernel/skas/process.c. This is manipulated with run_syscall_stub in arch/um/kernel/skas/mem_user.c. syscall_stub will execute any system call at all, but it's only used for mmap, munmap, and mprotect. - The x86_64 stub calls sigreturn by hand rather than allowing the normal sigreturn to happen, because the normal sigreturn is a SA_RESTORER in UML's address space provided by libc. Needless to say, this is not available in the child's address space. Also, it does a couple of odd pops before that which restore the stack to the state it was in at the time the signal handler was called. - There is a new field in the arch mmu_context, which is now a union. This is the pid to be manipulated rather than the /proc/mm file descriptor. Code which deals with this now checks proc_mm to see whether it should use the usual skas code or the new code. - userspace_tramp is now used to create a new host process for every UML process, rather than one per UML processor. It checks proc_mm and ptrace_faultinfo to decide whether to map in the pages above its stack. - start_userspace now makes CLONE_VM conditional on proc_mm since we need separate address spaces now. - switch_mm_skas now just sets userspace_pid[0] to the new pid rather than PTRACE_SWITCH_MM. There is an addition to userspace which updates its idea of the pid being manipulated each time around the loop. This is important on exec, when the pid will change underneath userspace(). - The stub page has a pte, but it can't be mapped in using tlb_flush because it is part of tlb_flush. This is why it's required for it to be mapped in by userspace_tramp. Other random things: - The stub section in uml.lds.S is page aligned. This page is written out to the backing vm file in setup_physmem because it is mapped from there into user processes. - There's some confusion with TASK_SIZE now that there are a couple of extra pages that the process can't use. TASK_SIZE is considered by the elf code to be the usable process memory, which is reasonable, so it is decreased by two pages. This confuses the definition of USER_PGDS_IN_LAST_PML4, making it too small because of the rounding down of the uneven division. So we round it to the nearest PGDIR_SIZE rather than the lower one. - I added a missing PT_SYSCALL_ARG6_OFFSET macro. - um_mmu.h was made into a userspace-usable file. - proc_mm and ptrace_faultinfo are globals which say whether the host supports these features. - There is a bad interaction between the mm.nr_ptes check at the end of exit_mmap, stack randomization, and skas0. exit_mmap will stop freeing pages at the PGDIR_SIZE boundary after the last vma. If the stack isn't on the last page table page, the last pte page won't be freed, as it should be since the stub ptes are there, and exit_mmap will BUG because there is an unfreed page. To get around this, TASK_SIZE is set to the next lowest PGDIR_SIZE boundary and mm->nr_ptes is decremented after the calls to init_stub_pte. This ensures that we know the process stack (and all other process mappings) will be below the top page table page, and thus we know that mm->nr_ptes will be one too many, and can be decremented. Things that need fixing: - We may need better assurrences that the stub code is PIC. - The stub pte is set up in init_new_context_skas. - alloc_pgdir is probably the right place. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
