path: root/include/asm-um
2008-10-22x86, um: initial part of asm-um moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-20container freezer: add TIF_FREEZE flag to all architecturesMatt Helsley
This patch series introduces a cgroup subsystem that utilizes the swsusp freezer to freeze a group of tasks. It's immediately useful for batch job management scripts. It should also be useful in the future for implementing container checkpoint/restart. The freezer subsystem in the container filesystem defines a cgroup file named freezer.state. Reading freezer.state will return the current state of the cgroup. Writing "FROZEN" to the state file will freeze all tasks in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in the cgroup. * Examples of usage : # mkdir /containers/freezer # mount -t cgroup -ofreezer freezer /containers # mkdir /containers/0 # echo $some_pid > /containers/0/tasks to get status of the freezer subsystem : # cat /containers/0/freezer.state RUNNING to freeze all tasks in the container : # echo FROZEN > /containers/0/freezer.state # cat /containers/0/freezer.state FREEZING # cat /containers/0/freezer.state FROZEN to unfreeze all tasks in the container : # echo RUNNING > /containers/0/freezer.state # cat /containers/0/freezer.state RUNNING This patch: The first step in making the refrigerator() available to all architectures, even for those without power management. The purpose of such a change is to be able to use the refrigerator() in a new control group subsystem which will implement a control group freezer. [akpm@linux-foundation.org: fix sparc] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Pavel Machek <pavel@suse.cz> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@tuxonice.net> Tested-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16[PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITYMartin Schwidefsky
The SET_PERSONALITY macro is always called with a second argument of 0. Remove the ibcs argument and the various tests to set the PER_SVR4 personality. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-19net: Fix build with ARCH=umDavid S. Miller
If UM is going to claim that it supports DMA by setting HAS_DMA, it should provide a dma_mapping_error() implementation. Based upon a report by Julius Volz. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-26[PATCH] kill altrootAl Viro
long overdue... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-25Merge git://git.infradead.org/~dwmw2/random-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/random-2.6: remove dummy asm/kvm.h files firmware: create firmware binaries during 'make modules'.
2008-07-25remove dummy asm/kvm.h filesAdrian Bunk
This patch removes the dummy asm/kvm.h files on architectures not (yet) supporting KVM and uses the same conditional headers installation as already used for a.out.h . Also removed are superfluous install rules in the s390 and x86 Kbuild files (they are already in Kbuild.asm). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25clean up duplicated alloc/free_thread_infoFUJITA Tomonori
We duplicate alloc/free_thread_info defines on many platforms (the majority uses __get_free_pages/free_pages). This patch defines common defines and removes these duplicated defines. __HAVE_ARCH_THREAD_INFO_ALLOCATOR is introduced for platforms that do something different. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Remove __DECLARE_SEMAPHORE_GENERIC Remove asm/semaphore.h Remove use of asm/semaphore.h Add missing semaphore.h includes Remove mention of semaphores from kernel-locking
2008-07-24UML: make several more things staticWANG Cong
- Make some variables and functions static, since they don't need to be global. - Remove an unused function - arch/um/kernel/time.c::sched_clock(). - Clean the style a bit as complained by checkpatch.pl. Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24arch/um/kernel/mem.c: remove arch_validate()WANG Cong
- Remove arch_validate(), because no one uses it. - Remove useless macro HAVE_ARCH_VALIDATE. - Make the variable 'empty_bad_page' static. Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Remove asm/semaphore.hMatthew Wilcox
All users have now been converted to linux/semaphore.h and we don't need to keep these files around any longer. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-06-06uml: activate_mm: remove the dead PF_BORROWED_MM checktip-core-topology-2008-06-16_09.13_Montip-core-misc-2008-06-16_09.11_MonOleg Nesterov
use_mm() was changed to use switch_mm() instead of activate_mm(), since then nobody calls (and nobody should call) activate_mm() with PF_BORROWED_MM bit set. As Jeff Dike pointed out, we can also remove the "old != new" check, it is always true. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14asm-{alpha,h8300,um,v850,xtensa}/param.h: unbreak HZ for userspaceMike Frysinger
I noticed this because alpha was broken due to the recent commit commit bdc807871d58285737d50dc6163d0feb72cb0dc2 ("avoid overflows in kernel/time.c"). Most arches do something like this in their asm/param.h: #ifdef __KERNEL__ # define HZ CONFIG_HZ #else # define HZ 100 #endif A few arches though (namely alpha/h8300/um/v850/xtensa) either do no set HZ at all for !__KERNEL__, or they set it wrongly. This should bring all arches in line by setting up HZ for userspace. Without this currently perl 5.10 doesn't build on alpha: perl.c: In function 'perl_construct': perl.c:388: error: 'CONFIG_HZ' undeclared (first use in this function) -> http://buildd.debian.org/fetch.cgi?pkg=perl;ver=5.10.0-10;arch=alpha;stamp=1210252894 Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Cc: maximilian attems <max@stro.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ HZ on alpha is 1024 for historical reasons. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: random driver fixesJeff Dike
The random driver would essentially hang if the host's /dev/random returned -EAGAIN. There was a test of need_resched followed by a schedule inside the loop, but that didn't help and it's the wrong way to work anyway. The right way is to ask for an interrupt when there is input available from the host and handle it then rather than polling. Now, when the host's /dev/random returns -EAGAIN, the driver asks for a wakeup when there's randomness available again and sleeps. The interrupt routine just wakes up whatever processes are sleeping on host_read_wait. There is an atomic_t, host_sleep_count, which counts the number of processes waiting for randomness. When this reaches zero, the interrupt is disabled. An added complication is that async I/O notification was only recently added to /dev/random (by me), so essentially all hosts will lack it. So, we use the sigio workaround here, which is to have a separate thread poll on the descriptor and send an interrupt when there is input on it. This mechanism is activated when a process gets -EAGAIN (activating this multiple times is harmless, if a bit wasteful) and deactivated by the last process still waiting. The module name was changed from "random" to "hw_random" in order for udev to recognize it. The sigio workaround needed some changes. sigio_broken was added for cases when we know that async notification doesn't work. This is now called from maybe_sigio_broken, which deals with pts devices. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: use PAGE_SIZE in linker scriptsCyrill Gorcunov
This patch includes page.h header into linker scripts that allow us to use PAGE_SIZE macro instead of numeric constant. To be able to include page.h into linker scripts page.h is needed for some modification - i.e. we need to use __ASSEMBLY__ and _AC macro [jdike@linux.intel.com - fixed conflict with as-layout.h] Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: remove unused headerJeff Dike
From: Adrian Bunk <bunk@kernel.org> This patch removes the unused and broken (the normal asm/keyboard.h files no longer exists) include/asm-um/keyboard.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: Move arches to use common unaligned accessHarvey Harrison
Unaligned access is ok for the following arches: cris, m68k, mn10300, powerpc, s390, x86 Arches that use the memmove implementation for native endian, and the byteshifting for the opposite endianness. h8300, m32r, xtensa Packed struct for native endian, byteshifting for other endian: alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh m86knommu is generic_be for Coldfire, otherwise unaligned access is ok. frv, arm chooses endianness based on compiler settings, uses the byteshifting versions. Remove the unaligned trap handler from frv as it is now unused. v850 is le, uses the byteshifting versions for both be and le. Remove the now unused asm-generic implementation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-15uml: compile error fixWANG Cong
This patch fixes this error: In file included from /home/wangcong/projects/linux-2.6/arch/um/kernel/smp.c:9: include2/asm/tlb.h: In function `tlb_remove_page': include2/asm/tlb.h:101: error: implicit declaration of function `page_cache_release' And since including <linux/pagemap.h> in <linux/swap.h> will break sparc, we add this #include in uml's own header. Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08uml: x86_64 should copy %fs during forkJeff Dike
%fs needs to be copied from parent to child during fork. Tidied up some whitespace while I was here. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08uml: runtime host VMSPLIT detectionJeff Dike
Calculate TASK_SIZE at run-time by figuring out the host's VMSPLIT - this is needed on i386 if UML is to run on hosts with varying VMSPLITs without recompilation. TASK_SIZE is now defined in terms of a variable, task_size. This gets rid of an include of pgtable.h from processor.h, which can cause include loops. On i386, task_size is calculated early in boot by probing the address space in a binary search to figure out where the boundary between usable and non-usable memory is. This tries to make sure that a page that is considered to be in userspace is, or can be made, read-write. I'm concerned about a system-global VDSO page in kernel memory being hit and considered to be a userspace page. On x86_64, task_size is just the old value of CONFIG_TOP_ADDR. A bunch of config variable are gone now. CONFIG_TOP_ADDR is directly replaced by TASK_SIZE. NEST_LEVEL is gone since the relocation of the stubs makes it irrelevant. All the HOST_VMSPLIT stuff is gone. All references to these in arch/um/Makefile are also gone. I noticed and fixed a missing extern in os.h when adding os_get_task_size. Note: This has been revised to fix the 32-bit UML on 64-bit host bug that Miklos ran into. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: suppress A.OUT library support if !CONFIG_ARCH_SUPPORTS_AOUTDavid Howells
Suppress A.OUT library support if CONFIG_ARCH_SUPPORTS_AOUT is not set. Not all architectures support the A.OUT binfmt, so the ELF binfmt should not be permitted to go looking for A.OUT libraries to load in such a case. Not only that, but under such conditions A.OUT core dumps are not produced either. To make this work, this patch also does the following: (1) Makes the existence of the contents of linux/a.out.h contingent on CONFIG_ARCH_SUPPORTS_AOUT. (2) Renames dump_thread() to aout_dump_thread() as it's only called by A.OUT core dumping code. (3) Moves aout_dump_thread() into asm/a.out-core.h and makes it inline. This is then included only where needed. This means that this bit of arch code will be stored in the appropriate A.OUT binfmt module rather than the core kernel. (4) Drops A.OUT support for Blackfin (according to Mike Frysinger it's not needed) and FRV. This patch depends on the previous patch to move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. [jdike@addtoit.com: uml: re-remove accidentally restored code] Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: move STACK_TOP[_MAX] to asm/processor.hDavid Howells
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: LDT mutex conversionDaniel Walker
The ldt.semaphore conforms to the new struct mutex requirments, so I converted it to use the new API and changed the name. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: add back CONFIG_HZJeff Dike
avoid-overflows-in-kernel-timec.patch makes CONFIG_HZ necessary for a successful build. UML lacks a definition, so this patch adds one. It also changes the hard-wired definition of HZ to CONFIG_HZ. Note: this patch is a good idea even in the absence of hpa's time fixes. Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: get rid of syscall countersJeff Dike
Get rid of some syscall counters which haven't been useful in ages. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: customize tlb.hJeff Dike
Customize the hooks in tlb.h to optimize TLB flushing some more. Add start and end fields to tlb_gather_mmu, which are used to limit the address space range scanned when a region is unmapped. The interfaces which just free page tables, without actually changing mappings, don't need to cause a TLB flush. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: 64-bit tlb fixesJeff Dike
Some 64-bit tlb fixes - moved pmd_page_vaddr to pgtable.h since it's the same for both 2-level and 3-level page tables fixed a bogus cast on pud_page_vaddr made the address checking in update_*_range more careful Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: cover stubs with a VMAJeff Dike
Give the stubs a VMA. This allows the removal of a truly nasty kludge to make sure that mm->nr_ptes was correct in exit_mmap. The underlying problem was always that the stubs, which have ptes, and thus allocated a page table, weren't covered by a VMA. This patch fixes that by using install_special_mapping in arch_dup_mmap and activate_context to create the VMA. The stubs have to be moved, since shift_arg_pages seems to assume that the stack is the only VMA present at that point during exec, and uses vma_adjust to fiddle its VMA. However, that extends the stub VMA by the amount removed from the stack VMA. To avoid this problem, the stubs were moved to a different fixed location at the start of the address space. The init_stub_pte calls were moved from init_new_context to arch_dup_mmap because I was occasionally seeing arch_dup_mmap not being called, causing exit_mmap to die. Rather than figure out what was really happening, I decided it was cleaner to just move the calls so that there's no doubt that both the pte and VMA creation happen, no matter what. arch_exit_mmap is used to clear the stub ptes at exit time. The STUB_* constants in as-layout.h no longer depend on UM_TASK_SIZE, that that definition is removed, along with the comments complaining about gcc. Because the stubs are no longer at the top of the address space, some care is needed while flushing TLBs. update_pte_range checks for addresses in the stub range and skips them. flush_thread now issues two unmaps, one for the range before STUB_START and one for the range after STUB_END. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: clean up TASK_SIZE usageJeff Dike
Clean up the calculation and use of the usable address space size on the host. task_size is gone, replaced with TASK_SIZE, which is calculated from CONFIG_TOP_ADDR. get_kmem_end and set_task_sizes_skas are also gone. host_task_size, which refers to the entire address space usable by the UML kernel and which may be larger than the address space usable by a UML process, since that has to end on a pgdir boundary, is replaced by CONFIG_TOP_ADDR. STACK_TOP is now TASK_SIZE minus the two stub pages. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: add virt_to_pteJeff Dike
Turn um_virt_to_phys into virt_to_pte, cleaning up a horrid interface. It's also made non-static and declared in pgtable.h because it'll be needed when the stubs get a vma. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: fix page table data sizesJeff Dike
Get the sizes of various pieces of data right when using three-level page tables. pgd and pmd entries remain at 32 bits in a 32-bit compilation because page tables will remain in low memory. So, PGDIR_SHIFT, the PTRS_PER_* values, set_pud, set_pmd are conditional on 64BIT. More use of phys_t is made when there are physical memory addresses floating around. ObCheckpatchViolationJustification - the new typedef is an alternate definition of pmd_t, which I can't really live without. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: current.h cleanupJeff Dike
Tidy current-related stuff. There was a comment in current.h saying that current_thread was obsolete, so this patch turns all instances of current_thread into current_thread_info(). There's some simplifying of the result in arch/um/sys-i386/signal.c. current.h and thread_info also get style cleanups. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: style cleanupJeff Dike
Style fixes in elf-i386.h and arch/um/kernel/mem.c. update the copyright get rid of an emacs formatting comment some formatting fixes inclusion trimming whitespace fixes Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: header untanglingJeff Dike
Untangle UML headers somewhat and add some includes where they were needed explicitly, but gotten accidentally via some other header. arch/um/include/um_uaccess.h loses asm/fixmap.h because it uses no fixmap stuff and gains elf.h, because it needs FIXADDR_USER_*, and archsetjmp.h, because it needs jmp_buf. pmd_alloc_one is uninlined because it needs mm_struct, and that's inconvenient to provide in asm-um/pgtable-3level.h. elf_core_copy_fpregs is also uninlined from elf-i386.h and elf-x86_64.h, which duplicated the code anyway, to arch/um/kernel/process.c, so that the reference to current_thread doesn't pull sched.h or anything related into asm/elf.h. arch/um/sys-i386/ldt.c, arch/um/kernel/tlb.c and arch/um/kernel/skas/uaccess.c got sched.h because they dereference task_structs. Its includes of linux and asm headers got turned from "" to <>. arch/um/sys-i386/bug.c gets asm/errno.h because it needs errno constants. asm/elf-i386 gets asm/user.h because it needs user_regs_struct. asm/fixmap.h gets page.h because it needs PAGE_SIZE and PAGE_MASK and system.h for BUG_ON. asm/pgtable doesn't need sched.h. asm/processor-generic.h defined mm_segment_t, but didn't use it. So, that definition is moved to uaccess.h, which defines a bunch of mm_segment_t-related stuff. thread_info.h uses mm_segment_t, and includes uaccess.h, which causes a recursion. So, the definition is placed above the include of thread_info. in uaccess.h. thread_info.h also gets page.h because it needs PAGE_SIZE. ObCheckpatchViolationJustification - I'm not adding a typedef; I'm moving mm_segment_t from one place to another. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: move um_virt_to_physJeff Dike
This patchset makes UML build and run with three-level page tables on 32-bit hosts. This is an uncommon use case, but the code here needed fixing and cleaning up, so 32-bit three-level pages tables were tested to make sure the changes are good. Patch 1 - code movement Patch 2 - header untangling Patch 3 - style fixups in files affected so far Patch 4 - clean up use of current.h Patch 5 - fix sizes of types that are different between 2 and 3-level page tables - three-level page table support should build at this point Patch 6 - tidy (i.e. eliminate much of) the code that figures out how big the address space is Patch 7 - change um_virt_to_phys into virt_to_pte, clean its interface, and clean its (so far) one caller Patch 8 - the stub pages are covered with a VMA, allowing some nasty code to be thrown out - three-level page tables now work This patch: um_virt_to_phys only has one user, so it can be moved to the same file and made static. Its declarations in pgtable.h and ksyms.c are also gone. current_cmd was another apparent user, but it itself isn't used, so it is deleted. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05UML - Fix build in 2.6.24-rc2-mm1Jeff Dike
The earlier pgtable.h tidying patch made things a bit too tidy. Add back a header which is needed in VMALLOC_START and friend. Also add back a definition of pmd_page_vaddr, which is needed on x86_64. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: tidy pgtable.hJeff Dike
Large pieces of include/asm/pgtable.h were unused cruft. This uncovered arch/um/kernel/trap.c needing skas.h in order to get ptrace_faultinfo. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: get rid of asmlinkageJeff Dike
Get rid of asmlinkage and remove some old cruft from asm/linkage.h. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: implement get_wchanJeff Dike
Implement get_wchan - the algorithm is similar to x86. It starts with the stack pointer of the process in question and looks above that for addresses that are kernel text. The second one which isn't in the scheduler is the one that's returned. The first one is ignored because that will be UML's own context switching routine. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: remove xmm checking on x86Karol Swietlicki
This patch removes some code which ran at every boot, but does not seem to do anything anymore. Please test. It works for me but mistakes can happen. Signed-off-by: Karol Swietlicki <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30git-x86: unbreak UMLWANG Cong
Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30uml: add asm-um/asm.hJeff Dike
git-x86.patch introduces asm-x86/asm.h. UML needs to follow this with an asm/asm.h of its own. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
