path: root/include/asm-x86/i387.h
2008-06-04x86: fix broken math-emu with lazy allocation of fpu areaSuresh Siddha
Fix the math emulation that got broken with the recent lazy allocation of FPU area. init_fpu() need to be added for the math-emulation path aswell for the FPU area allocation. math emulation enabled kernel booted fine with this, in the presence of "no387 nofxsr" boot param. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: hpa@zytor.com Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-10x86: fix fpu restore from sig returnSuresh Siddha
If the task never used fpu, initialize the fpu before restoring the FP state from the signal handler context. This will allocate the fpu state, if the task never needed it before. Reported-and-bisected-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Tested-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Frederik Deweerdt <deweerdt@free.fr> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19x86: fpu xstate split cleanupSuresh Siddha
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19x86, fpu: lazy allocation of FPU area - v5Suresh Siddha
Only allocate the FPU area when the application actually uses FPU, i.e., in the first lazy FPU trap. This could save memory for non-fpu using apps. for example: on my system after boot, there are around 300 processes, with only 17 using FPU. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19x86, fpu: split FPU state from task struct - v5Suresh Siddha
Split the FPU save area from the task struct. This allows easy migration of FPU context, and it's generally cleaner. It also allows the following two optimizations: 1) only allocate when the application actually uses FPU, so in the first lazy FPU trap. This could save memory for non-fpu using apps. Next patch does this lazy allocation. 2) allocate the right size for the actual cpu rather than 512 bytes always. Patches enabling xsave/xrstor support (coming shortly) will take advantage of this. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17include/asm-x86/i387.h: checkpatch cleanups - formatting onlyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-19x86: make mxcsr_feature_mask static againAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Roland McGrath <roland@redhat.com> Cc: hpa@zytor.com Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: use _ASM_EXTABLE macro in include/asm-x86/i387.hH. Peter Anvin
Use the _ASM_EXTABLE macro from <asm/asm.h>, instead of open-coding __ex_table entires in include/asm-x86/i387.h. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86 user_regset cleanupRoland McGrath
This removes a bunch of dead code that is no longer needed now that the user_regset interfaces are being used for all these jobs. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86 i387 cleanupRoland McGrath
This removes all the old code that is no longer used after the i387 unification and cleanup. The i387_64.h is renamed to i387.h with no changes, but since it replaces the nonempty one-line stub i387.h it looks like a big diff and not a rename. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86 i387 user_regsetRoland McGrath
This revamps the i387 code to be shared across 32-bit, 64-bit, and 32-on-64. It does so by consolidating the code in one place based on the user_regset accessor interfaces. This switches 32-bit to using the i387_64.h header and 64-bit to using the i387.c that was previously i387_32.c, but that's what took the least cleanup in each file. Here i387.h is stubbed to always include i387_64.h rather than renaming the file, to keep this diff smaller and easier to read. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
