path: root/include/asm-x86/kvm_host.h
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-15KVM: Separate irq ack notification out of arch/x86/kvm/irq.cXiantao Zhang
Moving irq ack notification logic as common, and make it shared with ia64 side. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Device Assignment: Map mmio pages into VT-d page tableWeidong Han
Assigned device could DMA to mmio pages, so also need to map mmio pages into VT-d page table. Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: speed up mmu_unsync_walkMarcelo Tosatti
Cache the unsynced children information in a per-page bitmap. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: out of sync shadow coreMarcelo Tosatti
Allow guest pagetables to go out of sync. Instead of emulating write accesses to guest pagetables, or unshadowing them, we un-write-protect the page table and allow the guest to modify it at will. We rely on invlpg executions to synchronize individual ptes, and will synchronize the entire pagetable on tlb flushes. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: x86: trap invlpgMarcelo Tosatti
With pages out of sync invlpg needs to be trapped. For now simply nuke the entry. Untested on AMD. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: sync roots on mmu reloadMarcelo Tosatti
2008-10-15KVM: MMU: mode specific sync_pageMarcelo Tosatti
Examine guest pagetable and bring the shadow back in sync. Caller is responsible for local TLB flush before re-entering guest mode. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: Device Assignment with VT-dBen-Ami Yassour
Based on a patch by: Kay, Allen M <allen.m.kay@intel.com> This patch enables PCI device assignment based on VT-d support. When a device is assigned to the guest, the guest memory is pinned and the mapping is updated in the VT-d IOMMU. [Amit: Expose KVM_CAP_IOMMU so we can check if an IOMMU is present and also control enable/disable from userspace] Signed-off-by: Kay, Allen M <allen.m.kay@intel.com> Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Ben-Ami Yassour <benami@il.ibm.com> Signed-off-by: Amit Shah <amit.shah@qumranet.com> Acked-by: Mark Gross <mgross@linux.intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Add statistics for guest irq injectionsAvi Kivity
These can help show whether a guest is making progress or not. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Simplify exception entries by using __ASM_SIZE and _ASM_PTRAvi Kivity
2008-10-15KVM: remove unused field from the assigned dev structBen-Ami Yassour
Remove unused field: struct kvm_assigned_pci_dev assigned_dev from struct: struct kvm_assigned_dev_kernel Signed-off-by: Ben-Ami Yassour <benami@il.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Reduce stack usage in kvm_pv_mmu_op()Dave Hansen
We're in a hot path. We can't use kmalloc() because it might impact performance. So, we just stick the buffer that we need into the kvm_vcpu_arch structure. This is used very often, so it is not really a waste. We also have to move the buffer structure's definition to the arch-specific x86 kvm header. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: pci device assignmentBen-Ami Yassour
Based on a patch from: Amit Shah <amit.shah@qumranet.com> This patch adds support for handling PCI devices that are assigned to the guest. The device to be assigned to the guest is registered in the host kernel and interrupt delivery is handled. If a device is already assigned, or the device driver for it is still loaded on the host, the device assignment is failed by conveying a -EBUSY reply to the userspace. Devices that share their interrupt line are not supported at the moment. By itself, this patch will not make devices work within the guest. The VT-d extension is required to enable the device to perform DMA. Another alternative is PVDMA. Signed-off-by: Amit Shah <amit.shah@qumranet.com> Signed-off-by: Ben-Ami Yassour <benami@il.ibm.com> Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Add irq ack notifier listAvi Kivity
This can be used by kvm subsystems that are interested in when interrupts are acked, for example time drift compensation. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: VMX: Reinject real mode exceptionJan Kiszka
As we execute real mode guests in VM86 mode, exception have to be reinjected appropriately when the guest triggered them. For this purpose the patch adopts the real-mode injection pattern used in vmx_inject_irq to vmx_queue_exception, additionally taking care that the IP is set correctly for #BP exceptions. Furthermore it extends handle_rmode_exception to reinject all those exceptions that can be raised in real mode. This fixes the execution of himem.exe from FreeDOS and also makes its debug.com work properly. Note that guest debugging in real mode is broken now. This has to be fixed by the scheduled debugging infrastructure rework (will be done once base patches for QEMU have been accepted). Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Consolidate XX_VECTOR definesJan Kiszka
2008-10-15KVM: Add a pending interrupt queueAvi Kivity
Similar to the exception queue, this hold interrupts that have been accepted by the virtual processor core but not yet injected. Not yet used. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: VMX: Move nmi injection failure processing to vm exit pathAvi Kivity
Instead of processing nmi injection failure in the vm entry path, move it to the vm exit path (vm_complete_interrupts()). This separates nmi injection from nmi post-processing, and moves the nmi state from the VT state into vcpu state (new variable nmi_injected specifying an injection in progress). Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Move KVM TRACE DEFINITIONS to common headerHollis Blanchard
Move KVM trace definitions from x86 specific kvm headers to common kvm headers to create a cross-architecture numbering scheme for trace events. This means the kvmtrace_format userspace tool won't need to know which architecture produced the log file being processed. Signed-off-by: Jerone Young <jyoung5@us.ibm.com> Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86: accessors for guest registersMarcelo Tosatti
As suggested by Avi, introduce accessors to read/write guest registers. This simplifies the ->cache_regs/->decache_regs interface, and improves register caching which is important for VMX, where the cost of vmcs_read/vmcs_write is significant. [avi: fix warnings] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-06Merge branch 'x86/header-guards' into x86-v28-for-linus-phase1Ingo Molnar
Conflicts: include/asm-x86/dma-mapping.h include/asm-x86/gpio.h include/asm-x86/idle.h include/asm-x86/kvm_host.h include/asm-x86/namei.h include/asm-x86/uaccess.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-25KVM: Use .fixup instead of .text.fixup on __kvm_handle_fault_on_rebootEduardo Habkost
vmlinux.lds expects the fixup code to be on a section named .fixup. The .text.fixup section is not mentioned on vmlinux.lds, and is included on the resulting vmlinux (just after .text) only because of ld heuristics on placing orphan sections. However, placing .text.fixup outside .text breaks the definition of _etext, making it exclude the .text.fixup contents. That makes .text.fixup be ignored by the kernel initialization code that needs to know about section locations, such as the code setting page protection bits. Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-29KVM: Synchronize guest physical memory map to host virtual memory mapAndrea Arcangeli
Synchronize changes to host virtual addresses which are part of a KVM memory slot to the KVM shadow mmu. This allows pte operations like swapping, page migration, and madvise() to transparently work with KVM. Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-27KVM: SVM: allow enabling/disabling NPT by reloading only the architecture moduleJoerg Roedel
If NPT is enabled after loading both KVM modules on AMD and it should be disabled, both KVM modules must be reloaded. If only the architecture module is reloaded the behavior is undefined. With this patch it is possible to disable NPT only by reloading the kvm_amd module. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-22x86: consolidate header guardsVegard Nossum
This patch is the result of an automatic script that consolidates the format of all the headers in include/asm-x86/. The format: 1. No leading underscore. Names with leading underscores are reserved. 2. Pathname components are separated by two underscores. So we can distinguish between mm_types.h and mm/types.h. 3. Everything except letters and numbers are turned into single underscores. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2008-07-22x86: fix spurious '#' in kvm headerVegard Nossum
2008-07-21KVM: fix exception entry / build bug, on 64-bitIngo Molnar
-tip testing found this build bug: arch/x86/kvm/built-in.o:(.text.fixup+0x1): relocation truncated to fit: R_X86_64_32 against `.text' arch/x86/kvm/built-in.o:(.text.fixup+0xb): relocation truncated to fit: R_X86_64_32 against `.text' arch/x86/kvm/built-in.o:(.text.fixup+0x15): relocation truncated to fit: R_X86_64_32 against `.text' arch/x86/kvm/built-in.o:(.text.fixup+0x1f): relocation truncated to fit: R_X86_64_32 against `.text' arch/x86/kvm/built-in.o:(.text.fixup+0x29): relocation truncated to fit: R_X86_64_32 against `.text' Introduced by commit 4ecac3fd. The problem is that 'push' will default to 32-bit, which is not wide enough as a fixup address. (and which would crash on any real fixup event even if it was wide enough) Introduce KVM_EX_PUSH to get the proper address push width on 64-bit too. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-20KVM: Prefix some x86 low level function with kvm_, to avoid namespace issuesAvi Kivity
Fixes compilation with CONFIG_VMI enabled. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-20KVM: Add coalesced MMIO support (x86 part)Laurent Vivier
This patch enables coalesced MMIO for x86 architecture. It defines KVM_MMIO_PAGE_OFFSET and KVM_CAP_COALESCED_MMIO. It enables the compilation of coalesced_mmio.c. Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-20KVM: Prefixes segment functions that will be exported with "kvm_"Guillaume Thouvenin
Prefixes functions that will be exported with kvm_. We also prefixed set_segment() even if it still static to be coherent. signed-off-by: Guillaume Thouvenin <guillaume.thouvenin@ext.bull.net> Signed-off-by: Laurent Vivier <laurent.vivier@bull.net> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-20KVM: MTRR supportAvi Kivity
Add emulation for the memory type range registers, needed by VMware esx 3.5, and by pci device assignment. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-20KVM: Order segment register constants in the same way as cpu operand encodingAvi Kivity
This can be used to simplify the x86 instruction decoder. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-20KVM: VMX: Enable NMI with in-kernel irqchipSheng Yang
Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-20KVM: IOAPIC/LAPIC: Enable NMI supportSheng Yang
[avi: fix ia64 build breakage] Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-20KVM: Remove decache_vcpus_on_cpu() and related callbacksAvi Kivity
Obsoleted by the vmx-specific per-cpu list. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-20KVM: Handle virtualization instruction #UD faults during rebootAvi Kivity
KVM turns off hardware virtualization extensions during reboot, in order to disassociate the memory used by the virtualization extensions from the processor, and in order to have the system in a consistent state. Unfortunately virtual machines may still be running while this goes on, and once virtualization extensions are turned off, any virtulization instruction will #UD on execution. Fix by adding an exception handler to virtualization instructions; if we get an exception during reboot, we simply spin waiting for the reset to complete. If it's a true exception, BUG() so we can have our stack trace. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-20KVM: MMU: Fix false flooding when a pte points to page tableAvi Kivity
The KVM MMU tries to detect when a speculative pte update is not actually used by demand fault, by checking the accessed bit of the shadow pte. If the shadow pte has not been accessed, we deem that page table flooded and remove the shadow page table, allowing further pte updates to proceed without emulation. However, if the pte itself points at a page table and only used for write operations, the accessed bit will never be set since all access will happen through the emulator. This is exactly what happens with kscand on old (2.4.x) HIGHMEM kernels. The kernel points a kmap_atomic() pte at a page table, and then proceeds with read-modify-write operations to look at the dirty and accessed bits. We get a false flood trigger on the kmap ptes, which results in the mmu spending all its time setting up and tearing down shadows. Fix by setting the shadow accessed bit on emulated accesses. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-06-24KVM: Make kvm host use the paravirt clocksource structsGerd Hoffmann
This patch updates the kvm host code to use the pvclock structs. It also makes the paravirt clock compatible with Xen. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: avoid fx_init() schedule in atomicAndrea Arcangeli
This make sure not to schedule in atomic during fx_init. I also changed the name of fpu_init to fx_finit to avoid duplicating the name with fpu_init that is already used in the kernel, this makes grep simpler if nothing else. Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: VMX: Enable EPT feature for KVMSheng Yang
2008-05-04KVM: VMX: Prepare an identity page table for EPT in real modeSheng Yang
[aliguory: plug leak] Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: MMU: Add EPT supportSheng Yang
Enable kvm_set_spte() to generate EPT entries. Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: Add kvm_x86_ops get_tdp_level()Sheng Yang
The function get_tdp_level() provided the number of tdp level for EPT and NPT rather than the NPT specific macro. Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: add ioctls to save/store mpstateMarcelo Tosatti
So userspace can save/restore the mpstate during migration. [avi: export the #define constants describing the value] [christian: add s390 stubs] [avi: ditto for ia64] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: Rename VCPU_MP_STATE_* to KVM_MP_STATE_*Avi Kivity
We wish to export it to userspace, so move it into the kvm namespace. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: Add trace markersFeng (Eric) Liu
Trace markers allow userspace to trace execution of a virtual machine in order to monitor its performance. Signed-off-by: Feng (Eric) Liu <eric.e.liu@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: SVM: add intercept for machine check exceptionJoerg Roedel
To properly forward a MCE occured while the guest is running to the host, we have to intercept this exception and call the host handler by hand. This is implemented by this patch. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: MMU: Don't assume struct page for x86Anthony Liguori
This patch introduces a gfn_to_pfn() function and corresponding functions like kvm_release_pfn_dirty(). Using these new functions, we can modify the x86 MMU to no longer assume that it can always get a struct page for any given gfn. We don't want to eliminate gfn_to_page() entirely because a number of places assume they can do gfn_to_page() and then kmap() the results. When we support IO memory, gfn_to_page() will fail for IO pages although gfn_to_pfn() will succeed. This does not implement support for avoiding reference counting for reserved RAM or for IO memory. However, it should make those things pretty straight forward. Since we're only introducing new common symbols, I don't think it will break the non-x86 architectures but I haven't tested those. I've tested Intel, AMD, NPT, and hugetlbfs with Windows and Linux guests. [avi: fix overflow when shifting left pfns by adding casts] Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: function declaration parameter name cleanupJoerg Roedel
The kvm_host.h file for x86 declares the functions kvm_set_cr[0348]. In the header file their second parameter is named cr0 in all cases. This patch renames the parameters so that they match the function name. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
