path: root/include/asm-x86/kvm_para.h
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-07-22x86: consolidate header guardsVegard Nossum
This patch is the result of an automatic script that consolidates the format of all the headers in include/asm-x86/. The format: 1. No leading underscore. Names with leading underscores are reserved. 2. Pathname components are separated by two underscores. So we can distinguish between mm_types.h and mm/types.h. 3. Everything except letters and numbers are turned into single underscores. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2008-07-06x86: KVM guest: Add memory clobber to hypercallsAnthony Liguori
Hypercalls can modify arbitrary regions of memory. Make sure to indicate this in the clobber list. This fixes a hang when using KVM_GUEST kernel built with GCC 4.3.0. This was originally spotted and analyzed by Marcelo. Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-06-24KVM: Remove now unused structs from kvm_para.hGerd Hoffmann
The kvm_* structs are obsoleted by the pvclock_* ones. Now all users have been switched over and the old structs can be dropped. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: MMU: hypercall based pte updates and TLB flushesMarcelo Tosatti
Hypercall based pte updates are faster than faults, and also allow use of the lazy MMU mode to batch operations. Don't report the feature if two dimensional paging is enabled. [avi: - one mmu_op hypercall instead of one per op - allow 64-bit gpa on hypercall - don't pass host errors (-ENOMEM) to guest] [akpm: warning fix on i386] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: add basic paravirt supportMarcelo Tosatti
Add basic KVM paravirt support. Avoid vm-exits on IO delays. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: paravirtualized clocksource: host partGlauber de Oliveira Costa
This is the host part of kvm clocksource implementation. As it does not include clockevents, it is a fairly simple implementation. We only have to register a per-vcpu area, and start writing to it periodically. The area is binary compatible with xen, as we use the same shadow_info structure. [marcelo: fix bad_page on MSR_KVM_SYSTEM_TIME] [avi: save full value of the msr, even if enable bit is clear] [avi: clear previous value of time_page] Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Per-architecture hypercall definitionsChristian Borntraeger
Currently kvm provides hypercalls only for x86* architectures. To provide hypercall infrastructure for other kvm architectures I split kvm_para.h into a generic header file and architecture specific definitions. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
