path: root/include/asm-x86/vdso.h
2008-04-17include/asm-x86/vdso.h: checkpatch cleanups - formatting onlyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move extern declaration to vdso.hIngo Molnar
Before: total: 0 errors, 3 warnings, 685 lines checked After: total: 0 errors, 1 warnings, 678 lines checked No code changed: arch/x86/kernel/signal_32.o: text data bss dec hex filename 5333 0 4 5337 14d9 signal_32.o.before 5333 0 4 5337 14d9 signal_32.o.after md5: c279e98012a2808e90cfa2a7787e42a4 signal_32.o.before.asm c279e98012a2808e90cfa2a7787e42a4 signal_32.o.after.asm Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86 vDSO: i386 vdso32Roland McGrath
This makes the i386 kernel use the new vDSO build in arch/x86/vdso/vdso32/ to replace the old one from arch/x86/kernel/. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86 vDSO: use vdso-syms.ldsRoland McGrath
This patch changes the kernel's references to addresses in the vDSO image to be based on the symbols defined by vdso-syms.lds instead of the old vdso-syms.o symbols. This is all wrapped up in a macro defined by the new asm-x86/vdso.h header; that's the only place in the kernel source that has to know the details of the scheme for getting vDSO symbol values. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
