path: root/include/asm-x86_64/kexec.h
2006-02-03[PATCH] Compilation of kexec/kdump brokenFernando Luis Vazquez Cao
The compilation of kexec/kdump seems to be broken for x86_64. Remove the dependency of kexec on CONFIG_IA32_EMULATION. Signed-off-by: Fernando Vazquez <fernando@intellilink.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: x86_64 save cpu registers upon crashVivek Goyal
- Saving the cpu registers of all cpus before booting in to the crash kernel. - crash_setup_regs will save the registers of the cpu on which panic has occured. One of the concerns ppc64 folks raised is that after capturing the register states, one should not pop the current call frame and push new one. Hence it has been inlined. More call frames later get pushed on to stack (machine_crash_shutdown() and machine_kexec()), but one will not want to backtrace those. - Not very sure about the CFI annotations. With this patch I am getting decent backtrace with gdb. Assuming, compiler has generated enough debugging information for crash_kexec(). Coding crash_setup_regs() in pure assembly makes it tricky because then it can not be inlined and we don't want to return back after capturing register states we don't want to pop this call frame. - Saving the non-panicing cpus registers will be done in the NMI handler while shooting down them in machine_crash_shutdown. - Introducing CRASH_DUMP option in Kconfig for x86_64. Signed-off-by: Murali M Chakravarthy <muralim@in.ibm.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: dynamic per cpu allocation of memory for saving cpu registersVivek Goyal
- In case of system crash, current state of cpu registers is saved in memory in elf note format. So far memory for storing elf notes was being allocated statically for NR_CPUS. - This patch introduces dynamic allocation of memory for storing elf notes. It uses alloc_percpu() interface. This should lead to better memory usage. - Introduced based on Andi Kleen's and Eric W. Biederman's suggestions. - This patch also moves memory allocation for elf notes from architecture dependent portion to architecture independent portion. Now crash_notes is architecture independent. The whole idea is that size of memory to be allocated per cpu (MAX_NOTE_BYTES) can be architecture dependent and allocation of this memory can be architecture independent. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Kdump: Export crash notes section address through sysfsVivek Goyal
o Following patch exports kexec global variable "crash_notes" to user space through sysfs as kernel attribute in /sys/kernel. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: x86_64 kexec implementationEric W. Biederman
This is the x86_64 implementation of machine kexec. 32bit compatibility support has been implemented, and machine_kexec has been enhanced to not care about the changing internal kernel paget table structures. From: Alexander Nyberg <alexn@dsv.su.se> build fix Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
