path: root/include/asm-x86_64/swiotlb.h
2006-01-11[PATCH] x86_64: Use function pointers to call DMA mapping functionsMuli Ben-Yehuda
AK: I hacked Muli's original patch a lot and there were a lot of changes - all bugs are probably to blame on me now. There were also some changes in the fall back behaviour for swiotlb - in particular it doesn't try to use GFP_DMA now anymore. Also all DMA mapping operations use the same core dma_alloc_coherent code with proper fallbacks now. And various other changes and cleanups. Known problems: iommu=force swiotlb=force together breaks needs more testing. This patch cleans up x86_64's DMA mapping dispatching code. Right now we have three possible IOMMU types: AGP GART, swiotlb and nommu, and in the future we will also have Xen's x86_64 swiotlb and other HW IOMMUs for x86_64. In order to support all of them cleanly, this patch: - introduces a struct dma_mapping_ops with function pointers for each of the DMA mapping operations of gart (AMD HW IOMMU), swiotlb (software IOMMU) and nommu (no IOMMU). - gets rid of: if (swiotlb) return swiotlb_xxx(); - PCI_DMA_BUS_IS_PHYS is now checked against the dma_ops being set This makes swiotlb faster by avoiding double copying in some cases. Signed-Off-By: Muli Ben-Yehuda <mulix@mulix.org> Signed-Off-By: Jon D. Mason <jdmason@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-31manual update from upstream:Tony Luck
Applied Al's change 06a544971fad0992fe8b92c5647538d573089dd4 to new location of swiotlb.c Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-10-28[PATCH] gfp_t: dma-mapping (ia64)Al Viro
... and related annotations for amd64 - swiotlb code is shared, but prototypes are not. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-29[PATCH] swiotlb: support syncing sub-ranges of mappingsJohn W. Linville
This patch implements swiotlb_sync_single_range_for_{cpu,device}. This is intended to support an x86_64 implementation of dma_sync_single_range_for_{cpu,device}. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
