path: root/include/crypto
2012-12-06crypto: cast5/cast6 - move lookup tables to shared moduleJussi Kivilinna
CAST5 and CAST6 both use same lookup tables, which can be moved shared module 'cast_common'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-15crypto: vmac - Make VMAC work when blocks aren't alignedSalman Qazi
VMAC implementation, as it is, does not work with blocks that are not multiples of 128-bytes. Furthermore, this is a problem when using the implementation on scatterlists, even when the complete plain text is 128-byte multiple, as the pieces that get passed to vmac_update can be pretty much any size. I also added test cases for unaligned blocks. Signed-off-by: Salman Qazi <sqazi@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-08KEYS: Provide signature verification with an asymmetric keyDavid Howells
Provide signature verification using an asymmetric-type key to indicate the public key to be used. The API is a single function that can be found in crypto/public_key.h: int verify_signature(const struct key *key, const struct public_key_signature *sig) The first argument is the appropriate key to be used and the second argument is the parsed signature data: struct public_key_signature { u8 *digest; u16 digest_size; enum pkey_hash_algo pkey_hash_algo : 8; union { MPI mpi[2]; struct { MPI s; /* m^d mod n */ } rsa; struct { MPI r; MPI s; } dsa; }; }; This should be filled in prior to calling the function. The hash algorithm should already have been called and the hash finalised and the output should be in a buffer pointed to by the 'digest' member. Any extra data to be added to the hash by the hash format (eg. PGP) should have been added by the caller prior to finalising the hash. It is assumed that the signature is made up of a number of MPI values. If an algorithm becomes available for which this is not the case, the above structure will have to change. It is also assumed that it will have been checked that the signature algorithm matches the key algorithm. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08KEYS: Asymmetric public-key algorithm crypto key subtypeDavid Howells
Add a subtype for supporting asymmetric public-key encryption algorithms such as DSA (FIPS-186) and RSA (PKCS#1 / RFC1337). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-07crypto: cast6 - fix sparse warnings (symbol was not declared, should be static?)Jussi Kivilinna
Fix "symbol 'x' was not declared. Should it be static?" sparse warnings. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-07crypto: cast5 - fix sparse warnings (symbol was not declared, should be static?)Jussi Kivilinna
2012-08-01crypto: cast6 - prepare generic module for optimized implementationsJohannes Goetzfried
Rename cast6 module to cast6_generic to allow autoloading of optimized implementations. Generic functions and s-boxes are exported to be able to use them within optimized implementations. Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: cast5 - prepare generic module for optimized implementationsJohannes Goetzfried
Rename cast5 module to cast5_generic to allow autoloading of optimized implementations. Generic functions and s-boxes are exported to be able to use them within optimized implementations. Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: add crypto_[un]register_shashes for [un]registering multiple shash ↵Jussi Kivilinna
entries at once Add crypto_[un]register_shashes() to allow simplifying init/exit code of shash crypto modules that register multiple algorithms. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-29crypto: user - Fix lookup of algorithms with IV generatorSteffen Klassert
We lookup algorithms with crypto_alg_mod_lookup() when instantiating via crypto_add_alg(). However, algorithms that are wrapped by an IV genearator (e.g. aead or genicv type algorithms) need special care. The userspace process hangs until it gets a timeout when we use crypto_alg_mod_lookup() to lookup these algorithms. So export the lookup functions for these algorithms and use them in crypto_add_alg(). Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-20crypto: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2011-11-21crypto: serpent-sse2 - add lrw supportJussi Kivilinna
Patch adds LRW support for serpent-sse2 by using lrw_crypt(). Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmarks results (serpent-sse2/serpent_generic speed ratios): Benchmark results with tcrypt: Intel Celeron T1600 (x86_64) (fam:6, model:15, step:13): size lrw-enc lrw-dec 16B 1.00x 0.96x 64B 1.01x 1.01x 256B 3.01x 2.97x 1024B 3.39x 3.33x 8192B 3.35x 3.33x AMD Phenom II 1055T (x86_64) (fam:16, model:10): size lrw-enc lrw-dec 16B 0.98x 1.03x 64B 1.01x 1.04x 256B 2.10x 2.14x 1024B 2.28x 2.33x 8192B 2.30x 2.33x Intel Atom N270 (i586): size lrw-enc lrw-dec 16B 0.97x 0.97x 64B 1.47x 1.50x 256B 1.72x 1.69x 1024B 1.88x 1.81x 8192B 1.84x 1.79x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: Unlink and free instances when deletedSteffen Klassert
We leak the crypto instance when we unregister an instance with crypto_del_alg(). Therefore we introduce crypto_unregister_instance() to unlink the crypto instance from the template's instances list and to free the recources of the instance properly. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: xts: add interface for parallelized cipher implementationsJussi Kivilinna
Add xts_crypt() function that can be used by cipher implementations that can benefit from parallelized cipher operations. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: twofish-x86_64-3way - add lrw supportJussi Kivilinna
Patch adds LRW support for twofish-x86_64-3way by using lrw_crypt(). Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmarks results (twofish-3way/twofish-asm speed ratios): Intel Celeron T1600 (fam:6, model:15, step:13): size lrw-enc lrw-dec 16B 0.99x 1.00x 64B 1.17x 1.17x 256B 1.26x 1.27x 1024B 1.30x 1.31x 8192B 1.31x 1.32x AMD Phenom II 1055T (fam:16, model:10): size lrw-enc lrw-dec 16B 1.06x 1.01x 64B 1.08x 1.14x 256B 1.19x 1.20x 1024B 1.21x 1.22x 8192B 1.23x 1.24x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: lrw - add interface for parallelized cipher implementionsJussi Kivilinna
Export gf128mul table initialization routines and add lrw_crypt() function that can be used by cipher implementations that can benefit from parallelized cipher operations. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: serpent - export common functions for x86_64/i386-sse2 assembler ↵Jussi Kivilinna
implementations Serpent SSE2 assembler implementations only provide 4-way/8-way parallel functions and need setkey and one-block encrypt/decrypt functions. CC: Dag Arne Osvik <osvik@ii.uib.no> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Add a report function pointer to crypto_typeSteffen Klassert
We add a report function pointer to struct crypto_type. This function pointer is used from the crypto userspace configuration API to report crypto algorithms to userspace. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-09-22crypto: blowfish - split generic and common c codeJussi Kivilinna
Patch splits up the blowfish crypto routine into a common part (key setup) which will be used by blowfish crypto modules (x86_64 assembly and generic-c). Also fixes errors/warnings reported by checkpatch. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-08-16crypto: sha - Fix build error due to crypto_sha1_updateHerbert Xu
On Tue, Aug 16, 2011 at 03:22:34PM +1000, Stephen Rothwell wrote: > > After merging the final tree, today's linux-next build (powerpc > allyesconfig) produced this warning: > > In file included from security/integrity/ima/../integrity.h:16:0, > from security/integrity/ima/ima.h:27, > from security/integrity/ima/ima_policy.c:20: > include/crypto/sha.h:86:10: warning: 'struct shash_desc' declared inside parameter list > include/crypto/sha.h:86:10: warning: its scope is only this definition or declaration, which is probably not what you want > > Introduced by commit 7c390170b493 ("crypto: sha1 - export sha1_update for > reuse"). I guess you need to include crypto/hash.h in crypto/sha.h. This patch fixes this by providing a declaration for struct shash_desc. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-08-10crypto: sha1 - export sha1_update for reuseMathias Krause
Export the update function as crypto_sha1_update() to not have the need to reimplement the same algorithm for each SHA-1 implementation. This way the generic SHA-1 implementation can be used as fallback for other implementations that fail to run under certain circumstances, like the need for an FPU context while executing in IRQ context. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-06-21net: remove mm.h inclusion from netdevice.hAlexey Dobriyan
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually). To prevent mm.h inclusion via other channels also extract "enum dma_data_direction" definition into separate header. This tiny piece is what gluing netdevice.h with mm.h via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h". Removal of mm.h from scatterlist.h was tried and was found not feasible on most archs, so the link was cutoff earlier. Hope people are OK with tiny include file. Note, that mm_types.h is still dragged in, but it is a separate story. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-07crypto: padlock - Move padlock.h into include/cryptoHerbert Xu
This patch moves padlock.h from drivers/crypto into include/crypto so that it may be used by the via-rng driver. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-12-02crypto: scatterwalk - Add scatterwalk_crypto_chain helperSteffen Klassert
A lot of crypto algorithms implement their own chaining function. So add a generic one that can be used from all the algorithms that need scatterlist chaining. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-11-19crypto: af_alg - User-space interface for Crypto APIHerbert Xu
This patch creates the backbone of the user-space interface for the Crypto API, through a new socket family AF_ALG. Each session corresponds to one or more connections obtained from that socket. The number depends on the number of inputs/outputs of that particular type of operation. For most types there will be a s ingle connection/file descriptor that is used for both input and output. AEAD is one of the few that require two inputs. Each algorithm type will provide its own implementation that plugs into af_alg. They're keyed using a string such as "skcipher" or "hash". IOW this patch only contains the boring bits that is required to hold everything together. Thakns to Miloslav Trmac for reviewing this and contributing fixes and improvements. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Martin Willi <martin@strongswan.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-20crypto: cryptd - Adding the AEAD interface type support to cryptdAdrian Hoban
This patch adds AEAD support into the cryptd framework. Having AEAD support in cryptd enables crypto drivers that use the AEAD interface type (such as the patch for AEAD based RFC4106 AES-GCM implementation using Intel New Instructions) to leverage cryptd for asynchronous processing. Signed-off-by: Adrian Hoban <adrian.hoban@intel.com> Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com> Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-19crypto: skcipher - Add ablkcipher_walk interfacesDavid S. Miller
These are akin to the blkcipher_walk helpers. The main differences in the async variant are: 1) Only physical walking is supported. We can't hold on to kmap mappings across the async operation to support virtual ablkcipher_walk operations anyways. 2) Bounce buffers used for async more need to be persistent and freed at a later point in time when the async op completes. Therefore we maintain a list of writeback buffers and require that the ablkcipher_walk user call the 'complete' operation so we can copy the bounce buffers out to the real buffers and free up the bounce buffer chunks. These interfaces will be used by the new Niagara2 crypto driver. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-17crypto: md5 - Add export supportMax Vozeler
This patch adds export/import support to md5. The exported type is defined by struct md5_state. This is modeled after the equivalent change to sha1_generic. Signed-off-by: Max Vozeler <max@hinterhof.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-07crypto: pcrypt - Add pcrypt crypto parallelization wrapperSteffen Klassert
This patch adds a parallel crypto template that takes a crypto algorithm and converts it to process the crypto transforms in parallel. For the moment only aead algorithms are supported. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-19crypto: hash - Remove legacy hash/digest codeBenjamin Gilbert
6941c3a0 disabled compilation of the legacy digest code but didn't actually remove it. Rectify this. Also, remove the crypto_hash_type extern declaration from algapi.h now that the struct is gone. Signed-off-by: Benjamin Gilbert <bgilbert@cs.cmu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-19crypto: ghash - Add PCLMULQDQ accelerated implementationHuang Ying
PCLMULQDQ is used to accelerate the most time-consuming part of GHASH, carry-less multiplication. More information about PCLMULQDQ can be found at: http://software.intel.com/en-us/articles/carry-less-multiplication-and-its-usage-for-computing-the-gcm-mode/ Because PCLMULQDQ changes XMM state, its usage must be enclosed with kernel_fpu_begin/end, which can be used only in process context, the acceleration is implemented as crypto_ahash. That is, request in soft IRQ context will be defered to the cryptd kernel thread. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (102 commits) crypto: sha-s390 - Fix warnings in import function crypto: vmac - New hash algorithm for intel_txt support crypto: api - Do not displace newly registered algorithms crypto: ansi_cprng - Fix module initialization crypto: xcbc - Fix alignment calculation of xcbc_tfm_ctx crypto: fips - Depend on ansi_cprng crypto: blkcipher - Do not use eseqiv on stream ciphers crypto: ctr - Use chainiv on raw counter mode Revert crypto: fips - Select CPRNG crypto: rng - Fix typo crypto: talitos - add support for 36 bit addressing crypto: talitos - align locks on cache lines crypto: talitos - simplify hmac data size calculation crypto: mv_cesa - Add support for Orion5X crypto engine crypto: cryptd - Add support to access underlaying shash crypto: gcm - Use GHASH digest algorithm crypto: ghash - Add GHASH digest algorithm for GCM crypto: authenc - Convert to ahash crypto: api - Fix aligned ctx helper crypto: hmac - Prehash ipad/opad ...
2009-09-02crypto: vmac - New hash algorithm for intel_txt supportShane Wang
This patch adds VMAC (a fast MAC) support into crypto framework. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-29crypto: skcipher - Fix skcipher_dequeue_givcrypt NULL testHerbert Xu
As struct skcipher_givcrypt_request includes struct crypto_request at a non-zero offset, testing for NULL after converting the pointer returned by crypto_dequeue_request does not work. This can result in IPsec crashes when the queue is depleted. This patch fixes it by doing the pointer conversion only when the return value is non-NULL. In particular, we create a new function __crypto_dequeue_request that does the pointer conversion. Reported-by: Brad Bosch <bradbosch@comcast.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: cryptd - Add support to access underlaying shashHuang Ying
cryptd_alloc_ahash() will allocate a cryptd-ed ahash for specified algorithm name. The new allocated one is guaranteed to be cryptd-ed ahash, so the shash underlying can be gotten via cryptd_ahash_child(). Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-24crypto: api - Fix aligned ctx helperHerbert Xu
The aligned ctx helper was using a bogus alignment value thas was one off the correct value. Fortunately the current users do not require anything beyond the natural alignment of the platform so this hasn't caused a problem. This patch fixes that and also removes the unnecessary minimum check since if the alignment is less than the natural alignment then the subsequent ALIGN operation should be a noop. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: sha512_generic - Use 64-bit countersHerbert Xu
This patch replaces the 32-bit counters in sha512_generic with 64-bit counters. It also switches the bit count to the simpler byte count. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: sha512 - Export struct sha512_stateHerbert Xu
This patch renames struct sha512_ctx and exports it as struct sha512_state so that other sha512 implementations can use it as the reference structure for exporting their state. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: shash - Fix digest size offsetHerbert Xu
When an shash algorithm is exported as ahash, ahash will access its digest size through hash_alg_common. That's why the shash layout needs to match hash_alg_common. This wasn't the case because the alignment weren't identical. This patch fixes the problem. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: ahash - Add unaligned handling and default operationsHerbert Xu
This patch exports the finup operation where available and adds a default finup operation for ahash. The operations final, finup and digest also will now deal with unaligned result pointers by copying it. Finally export/import operations are will now be exported too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Remove old_ahash_algHerbert Xu
Now that all ahash implementations have been converted to the new ahash type, we can remove old_ahash_alg and its associated support. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: crypto4xx - Switch to new style ahashHerbert Xu
This patch changes crypto4xx to use the new style ahash type. In particular, we now use ahash_alg to define ahash algorithms instead of crypto_alg. This is achieved by introducing a union that encapsulates the new type and the existing crypto_alg structure. They're told apart through a u32 field containing the type value. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Switch to template create APIHerbert Xu
This patch changes cryptd to use the template->create function instead of alloc in anticipation for the switch to new style ahash algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: hash - Add helpers to free spawnsHerbert Xu
This patch adds the helpers crypto_drop_ahash and crypto_drop_shash so that these spawns can be dropped without ugly casts. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Add instance/spawn supportHerbert Xu
This patch adds support for creating ahash instances and using ahash as spawns. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Convert to new style algorithmsHerbert Xu
This patch converts crypto_ahash to the new style. The old ahash algorithm type is retained until the existing ahash implementations are also converted. All ahash users will automatically get the new crypto_ahash type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: api - Remove frontend argument from extsize/init_tfmHerbert Xu
As the extsize and init_tfm functions belong to the frontend the frontend argument is superfluous. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
