[ Upstream commit ef0579b64e93188710d48667cb5e014926af9f1b ]
The ahash API modifies the request's callback function in order
to clean up after itself in some corner cases (unaligned final
and missing finup).
When the request is complete ahash will restore the original
callback and everything is fine. However, when the request gets
an EBUSY on a full queue, an EINPROGRESS callback is made while
the request is still ongoing.
In this case the ahash API will incorrectly call its own callback.
This patch fixes the problem by creating a temporary request
object on the stack which is used to relay EINPROGRESS back to
the original completion function.
This patch also adds code to preserve the original flags value.
Fixes: ab6bf4e5e5e4 ("crypto: hash - Fix the pointer voodoo in...")
Cc: <stable@vger.kernel.org>
Reported-by: Sabrina Dubroca <sd@queasysnail.net>
Tested-by: Sabrina Dubroca <sd@queasysnail.net>
[ Upstream commit 6a935170a980024dd29199e9dbb5c4da4767a1b9 ]
This patch allows af_alg_release_parent to be called even for
nokey sockets.
Cc: stable@vger.kernel.org
[ Upstream commit a5596d6332787fd383b3b5427b41f94254430827 ]
This patch adds a way for ahash users to determine whether a key
is required by a crypto_ahash transform.
[ Upstream commit 37766586c965d63758ad542325a96d5384f4a8c9 ]
This patch adds a compatibility path to support old applications
that do acept(2) before setkey.
[ Upstream commit c840ac6af3f8713a71b4d2363419145760bd6044 ]
Each af_alg parent socket obtained by socket(2) corresponds to a
tfm object once bind(2) has succeeded. An accept(2) call on that
parent socket creates a context which then uses the tfm object.
Therefore as long as any child sockets created by accept(2) exist
the parent socket must not be modified or freed.
This patch guarantees this by using locks and a reference count
on the parent socket. Any attempt to modify the parent socket will
fail with EBUSY.
Pull crypto update from Herbert Xu:
"Here is the crypto update for 4.1:
New interfaces:
- user-space interface for AEAD
- user-space interface for RNG (i.e., pseudo RNG)
New hashes:
- ARMv8 SHA1/256
- ARMv8 AES
- ARMv8 GHASH
- ARM assembler and NEON SHA256
- MIPS OCTEON SHA1/256/512
- MIPS img-hash SHA1/256 and MD5
- Power 8 VMX AES/CBC/CTR/GHASH
- PPC assembler AES, SHA1/256 and MD5
- Broadcom IPROC RNG driver
Cleanups/fixes:
- prevent internal helper algos from being exposed to user-space
- merge common code from assembly/C SHA implementations
- misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (169 commits)
crypto: arm - workaround for building with old binutils
crypto: arm/sha256 - avoid sha256 code on ARMv7-M
crypto: x86/sha512_ssse3 - move SHA-384/512 SSSE3 implementation to base layer
crypto: x86/sha256_ssse3 - move SHA-224/256 SSSE3 implementation to base layer
crypto: x86/sha1_ssse3 - move SHA-1 SSSE3 implementation to base layer
crypto: arm64/sha2-ce - move SHA-224/256 ARMv8 implementation to base layer
crypto: arm64/sha1-ce - move SHA-1 ARMv8 implementation to base layer
crypto: arm/sha2-ce - move SHA-224/256 ARMv8 implementation to base layer
crypto: arm/sha256 - move SHA-224/256 ASM/NEON implementation to base layer
crypto: arm/sha1-ce - move SHA-1 ARMv8 implementation to base layer
crypto: arm/sha1_neon - move SHA-1 NEON implementation to base layer
crypto: arm/sha1 - move SHA-1 ARM asm implementation to base layer
crypto: sha512-generic - move to generic glue implementation
crypto: sha256-generic - move to generic glue implementation
crypto: sha1-generic - move to generic glue implementation
crypto: sha512 - implement base layer for SHA-512
crypto: sha256 - implement base layer for SHA-256
crypto: sha1 - implement base layer for SHA-1
crypto: api - remove instance when test failed
crypto: api - Move alg ref count init to crypto_check_alg
This updated the generic SHA-512 implementation to use the
generic shared SHA-512 glue code.
It also implements a .finup hook crypto_sha512_finup() and exports
it to other modules. The import and export() functions and the
.statesize member are dropped, since the default implementation
is perfectly suitable for this module.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
This updates the generic SHA-256 implementation to use the
new shared SHA-256 glue code.
It also implements a .finup hook crypto_sha256_finup() and exports
This updated the generic SHA-1 implementation to use the generic
shared SHA-1 glue code.
It also implements a .finup hook crypto_sha1_finup() and exports
To reduce the number of copies of boilerplate code throughout
the tree, this patch implements generic glue for the SHA-512
algorithm. This allows a specific arch or hardware implementation
to only implement the special handling that it needs.
The users need to supply an implementation of
void (sha512_block_fn)(struct sha512_state *sst, u8 const *src, int blocks)
and pass it to the SHA-512 base functions. For easy casting between the
prototype above and existing block functions that take a 'u64 state[]'
as their first argument, the 'state' member of struct sha512_state is
moved to the base of the struct.
the tree, this patch implements generic glue for the SHA-256
void (sha256_block_fn)(struct sha256_state *sst, u8 const *src, int blocks)
and pass it to the SHA-256 base functions. For easy casting between the
prototype above and existing block functions that take a 'u32 state[]'
as their first argument, the 'state' member of struct sha256_state is
the tree, this patch implements generic glue for the SHA-1
void (sha1_block_fn)(struct sha1_state *sst, u8 const *src, int blocks)
and pass it to the SHA-1 base functions. For easy casting between the
as their first argument, the 'state' member of struct sha1_state is
This patch makes crypto_unregister_instance take a crypto_instance
instead of a crypto_alg. This allows us to remove a duplicate
CRYPTO_ALG_INSTANCE check in crypto_unregister_instance.
Allow to link af_alg sgls.
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Change the RNGs to always return 0 in success case.
This patch ensures that seqiv.c works with RNGs other than krng. seqiv
expects that any return code other than 0 is an error. Without the
patch, rfc4106(gcm(aes)) will not work when using a DRBG or an ANSI
X9.31 RNG.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
"Here is the crypto update for 3.20:
- Added 192/256-bit key support to aesni GCM.
- Added MIPS OCTEON MD5 support.
- Fixed hwrng starvation and race conditions.
- Added note that memzero_explicit is not a subsitute for memset.
- Added user-space interface for crypto_rng.
- Misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (71 commits)
crypto: tcrypt - do not allocate iv on stack for aead speed tests
crypto: testmgr - limit IV copy length in aead tests
crypto: tcrypt - fix buflen reminder calculation
crypto: testmgr - mark rfc4106(gcm(aes)) as fips_allowed
crypto: caam - fix resource clean-up on error path for caam_jr_init
crypto: caam - pair irq map and dispose in the same function
crypto: ccp - terminate ccp_support array with empty element
crypto: caam - remove unused local variable
crypto: caam - remove dead code
crypto: caam - don't emit ICV check failures to dmesg
hwrng: virtio - drop extra empty line
crypto: replace scatterwalk_sg_next with sg_next
crypto: atmel - Free memory in error path
crypto: doc - remove colons in comments
crypto: seqiv - Ensure that IV size is at least 8 bytes
crypto: cts - Weed out non-CBC algorithms
MAINTAINERS: add linux-crypto to hw random
crypto: cts - Remove bogus use of seqiv
crypto: qat - don't need qat_auth_state struct
crypto: algif_rng - fix sparse non static symbol warning
With that, all ->sendmsg() instances are converted to iov_iter primitives
and are agnostic wrt the kind of iov_iter they are working with.
So's the last remaining ->recvmsg() instance that wasn't kind-agnostic yet.
All ->sendmsg() and ->recvmsg() advance ->msg_iter by the amount actually
copied and none of them modifies the underlying iovec, etc.
Cc: linux-crypto@vger.kernel.org
Modify crypto drivers to use the generic SG helper since
both of them are equivalent and the one from crypto is redundant.
See also:
468577abe37ff7b453a9ac613e0ea155349203ae reverted in
b2ab4a57b018aafbba35bff088218f5cc3d2142e
Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com>
Use setsockopt on the tfm FD to provide the authentication tag size for
an AEAD cipher. This is achieved by adding a callback function which is
intended to be used by the AEAD AF_ALG implementation.
The optlen argument of the setsockopt specifies the authentication tag
size to be used with the AEAD tfm.
AEAD requires the caller to specify the following information separate
from the data stream. This information allows the AEAD interface handler
to identify the AAD, ciphertext/plaintext and the authentication tag:
* Associated authentication data of arbitrary length and
length
* Length of authentication tag for encryption
Fix documentation typo for shash_alg->descsize.
Add documentation for initially uncovered member variables.
The API function calls exported by the kernel crypto API for SHASHes
to be used by consumers are documented.
The API function calls exported by the kernel crypto API for AHASHes
The hash data structures needed to be filled in by cipher developers are
documented.
The API function calls exported by the kernel crypto API for RNGs to
Add a macro which replaces the use of a Variable Length Array In Struct (VLAIS)
with a C99 compliant equivalent. This macro instead allocates the appropriate
amount of memory using an char array.
The new code can be compiled with both gcc and clang.
struct shash_desc contains a flexible array member member ctx declared with
CRYPTO_MINALIGN_ATTR, so sizeof(struct shash_desc) aligns the beginning
of the array declared after struct shash_desc with long long.
No trailing padding is required because it is not a struct type that can
be used in an array.
The CRYPTO_MINALIGN_ATTR is required so that desc is aligned with long long
as would be the case for a struct containing a member with
CRYPTO_MINALIGN_ATTR.
If you want to get to the ctx at the end of the shash_desc as before you can do
so using shash_desc_ctx(shash)
Signed-off-by: Behan Webster <behanw@converseincode.com>
Reviewed-by: Mark Charlebois <charlebm@gmail.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Michał Mirosław <mirqus@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris.
Mostly ima, selinux, smack and key handling updates.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits)
integrity: do zero padding of the key id
KEYS: output last portion of fingerprint in /proc/keys
KEYS: strip 'id:' from ca_keyid
KEYS: use swapped SKID for performing partial matching
KEYS: Restore partial ID matching functionality for asymmetric keys
X.509: If available, use the raw subjKeyId to form the key description
KEYS: handle error code encoded in pointer
selinux: normalize audit log formatting
selinux: cleanup error reporting in selinux_nlmsg_perm()
KEYS: Check hex2bin()'s return when generating an asymmetric key ID
ima: detect violations for mmaped files
ima: fix race condition on ima_rdwr_violation_check and process_measurement
ima: added ima_policy_flag variable
ima: return an error code from ima_add_boot_aggregate()
ima: provide 'ima_appraise=log' kernel option
ima: move keyring initialization to ima_init()
PKCS#7: Handle PKCS#7 messages that contain no X.509 certs
PKCS#7: Better handling of unsupported crypto
KEYS: Overhaul key identification when searching for asymmetric keys
KEYS: Implement binary asymmetric key ID handling
Bring back the functionality whereby an asymmetric key can be matched with a
partial match on one of its IDs.
Whilst we're at it, allow for the possibility of having an increased number of
IDs.
Reported-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Make use of the new match string preparsing to overhaul key identification
when searching for asymmetric keys. The following changes are made:
(1) Use the previously created asymmetric_key_id struct to hold the following
key IDs derived from the X.509 certificate or PKCS#7 message:
id: serial number + issuer
skid: subjKeyId + subject
authority: authKeyId + issuer
(2) Replace the hex fingerprint attached to key->type_data[1] with an
asymmetric_key_ids struct containing the id and the skid (if present).
(3) Make the asymmetric_type match data preparse select one of two searches:
(a) An iterative search for the key ID given if prefixed with "id:". The
prefix is expected to be followed by a hex string giving the ID to
search for. The criterion key ID is checked against all key IDs
recorded on the key.
(b) A direct search if the key ID is not prefixed with "id:". This will
look for an exact match on the key description.
(4) Make x509_request_asymmetric_key() take a key ID. This is then converted
into "id:<hex>" and passed into keyring_search() where match preparsing
will turn it back into a binary ID.
(5) X.509 certificate verification then takes the authority key ID and looks
up a key that matches it to find the public key for the certificate
signature.
(6) PKCS#7 certificate verification then takes the id key ID and looks up a
key that matches it to find the public key for the signed information
block signature.
Additional changes:
(1) Multiple subjKeyId and authKeyId values on an X.509 certificate cause the
cert to be rejected with -EBADMSG.
(2) The 'fingerprint' ID is gone. This was primarily intended to convey PGP
public key fingerprints. If PGP is supported in future, this should
generate a key ID that carries the fingerprint.
(3) Th ca_keyid= kernel command line option is now converted to a key ID and
used to match the authority key ID. Possibly this should only match the
actual authKeyId part and not the issuer as well.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
The maximum values for additional input string or generated blocks is
larger than 1<<32. To ensure a sensible value on 32 bit systems, return
SIZE_MAX on 32 bit systems. This value is lower than the maximum
allowed values defined in SP800-90A. The standard allow lower maximum
values, but not larger values.
SIZE_MAX - 1 is used for drbg_max_addtl to allow
drbg_healthcheck_sanity to check the enforcement of the variable
without wrapping.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
SP800-90A mandates several hard-coded values. The old drbg_cores allows
the setting of these values per DRBG implementation. However, due to the
hard requirement of SP800-90A, these values are now returned globally
for each DRBG.
The ability to set such values per DRBG is therefore removed.
This patch introduces the multi-buffer crypto daemon which is responsible
for submitting crypto jobs in a work queue to the responsible multi-buffer
crypto algorithm. The idea of the multi-buffer algorihtm is to put
data streams from multiple jobs in a wide (AVX2) register and then
take advantage of SIMD instructions to do crypto computation on several
buffers simultaneously.
The multi-buffer crypto daemon is also responsbile for flushing the
remaining buffers to complete the computation if no new buffers arrive
for a while.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Pull security subsystem updates from James Morris:
"In this release:
- PKCS#7 parser for the key management subsystem from David Howells
- appoint Kees Cook as seccomp maintainer
- bugfixes and general maintenance across the subsystem"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (94 commits)
X.509: Need to export x509_request_asymmetric_key()
netlabel: shorter names for the NetLabel catmap funcs/structs
netlabel: fix the catmap walking functions
netlabel: fix the horribly broken catmap functions
netlabel: fix a problem when setting bits below the previously lowest bit
PKCS#7: X.509 certificate issuer and subject are mandatory fields in the ASN.1
tpm: simplify code by using %*phN specifier
tpm: Provide a generic means to override the chip returned timeouts
tpm: missing tpm_chip_put in tpm_get_random()
tpm: Properly clean sysfs entries in error path
tpm: Add missing tpm_do_selftest to ST33 I2C driver
PKCS#7: Use x509_request_asymmetric_key()
Revert "selinux: fix the default socket labeling in sock_graft()"
X.509: x509_request_asymmetric_keys() doesn't need string length arguments
PKCS#7: fix sparse non static symbol warning
KEYS: revert encrypted key change
ima: add support for measuring and appraising firmware
firmware_class: perform new LSM checks
security: introduce kernel_fw_from_file hook
PKCS#7: Missing inclusion of linux/err.h
Change formal parameters to not clash with global names to
eliminate many W=2 warnings.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
pkcs7_request_asymmetric_key() and x509_request_asymmetric_key() do the same
thing, the latter being a copy of the former created by the IMA folks, so drop
the PKCS#7 version as the X.509 location is more general.
Whilst we're at it, rename the arguments of x509_request_asymmetric_key() to
better reflect what the values being passed in are intended to match on an
X.509 cert.
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
The current locking approach of the DRBG tries to keep the protected
code paths very minimal. It is therefore possible that two threads query
one DRBG instance at the same time. When thread A requests random
numbers, a shadow copy of the DRBG state is created upon which the
request for A is processed. After finishing the state for A's request is
merged back into the DRBG state. If now thread B requests random numbers
from the same DRBG after the request for thread A is received, but
before A's shadow state is merged back, the random numbers for B will be
identical to the ones for A. Please note that the time window is very
small for this scenario.
To prevent that there is even a theoretical chance for thread A and B
having the same DRBG state, the current time stamp is provided as
additional information string for each new request.
The addition of the time stamp as additional information string implies
that now all generate functions must be capable to process a linked
list with additional information strings instead of a scalar.
CC: Rafael Aquini <aquini@redhat.com>
Find the intersection between the X.509 certificate chain contained in a PKCS#7
message and a set of keys that we already know and trust.
Find the appropriate key in the PKCS#7 key list and verify the signature with
it. There may be several keys in there forming a chain. Any link in that
chain or the root of that chain may be in our keyrings.
Implement a parser for a PKCS#7 signed-data message as described in part of
RFC 2315.
The DRBG-style linked list to manage input data that is fed into the
cipher invocations is replaced with the kernel linked list
implementation.
The change is transparent to users of the interfaces offered by the
DRBG. Therefore, no changes to the testmgr code is needed.
Patch adds x86_64 assembly implementation of Triple DES EDE cipher algorithm.
Two assembly implementations are provided. First is regular 'one-block at
time' encrypt/decrypt function. Second is 'three-blocks at time' function that
gains performance increase on out-of-order CPUs.
tcrypt test results:
Intel Core i5-4570:
des3_ede-asm vs des3_ede-generic:
size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec
16B 1.21x 1.22x 1.27x 1.36x 1.25x 1.25x
64B 1.98x 1.96x 1.23x 2.04x 2.01x 2.00x
256B 2.34x 2.37x 1.21x 2.40x 2.38x 2.39x
1024B 2.50x 2.47x 1.22x 2.51x 2.52x 2.51x
8192B 2.51x 2.53x 1.21x 2.56x 2.54x 2.55x
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
The header file includes the definition of:
* DRBG data structures with
- struct drbg_state as main structure
- struct drbg_core referencing the backend ciphers
- struct drbg_state_ops callbach handlers for specific code
supporting the Hash, HMAC, CTR DRBG implementations
- struct drbg_conc defining a linked list for input data
- struct drbg_test_data holding the test "entropy" data for CAVS
testing and testmgr.c
- struct drbg_gen allowing test data, additional information
string and personalization string data to be funneled through
the kernel crypto API -- the DRBG requires additional
parameters when invoking the reset and random number
generation requests than intended by the kernel crypto API
* wrapper function to the kernel crypto API functions using struct
drbg_gen to pass through all data needed for DRBG
* wrapper functions to kernel crypto API functions usable for testing
code to inject test_data into the DRBG as needed by CAVS testing and
testmgr.c.
* DRBG flags required for the operation of the DRBG and for selecting
the particular DRBG type and backend cipher
* getter functions for data from struct drbg_core
Use skcipher_givcrypt_cast(crypto_dequeue_request(queue)) instead, which
does the same thing in much cleaner way. The skcipher_givcrypt_cast()
actually uses container_of() instead of messing around with offsetof()
too.
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
It makes no sense for crypto_yield() to be defined in scatterwalk.h ,
move it into algapi.h as it's an internal function to crypto API.
Although the existing hash walk interface has already been used
by a number of ahash crypto drivers, it turns out that none of
them were really asynchronous. They were all essentially polling
for completion.
That's why nobody has noticed until now that the walk interface
couldn't work with a real asynchronous driver since the memory
is mapped using kmap_atomic.
As we now have a use-case for a real ahash implementation on x86,
this patch creates a minimal ahash walk interface. Basically it
just calls kmap instead of kmap_atomic and does away with the
crypto_yield call. Real ahash crypto drivers don't need to yield
since by definition they won't be hogging the CPU.
These defines might be needed by crypto drivers.
Signed-off-by: Horia Geanta <horia.geanta@freescale.com>
This adds the function blkcipher_aead_walk_virt_block, which allows the caller
to use the blkcipher walk API to handle the input and output scatterlists.
In order to allow other uses of the blkcipher walk API than the blkcipher
algos themselves, this patch copies some of the transform data members to the
walk struct so the transform is only accessed at walk init time.
Now that scatterwalk_sg_chain sets the chain pointer bit the sg_page
call in scatterwalk_sg_next hits a BUG_ON when CONFIG_DEBUG_SG is
enabled. Use sg_chain_ptr instead of sg_page on a chain entry.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
The scatterwalk_crypto_chain function invokes the scatterwalk_sg_chain
function to chain two scatterlists, but the chain pointer indication
bit is not set. When the resulting scatterlist is used, for example,
by sg_nents to count the number of scatterlist entries, a segfault occurs
because sg_nents does not follow the chain pointer to the chained scatterlist.
Update scatterwalk_sg_chain to set the chain pointer indication bit as is
done by the sg_chain function.
