path: root/include/drm/drm_crtc.h
2008-12-29drm: drop DRM_IOCTL_MODE_REPLACEFB, add+remove works just as well.Kristian H�gsberg
The replace fb ioctl replaces the backing buffer object for a modesetting framebuffer object. This can be acheived by just creating a new framebuffer backed by the new buffer object, setting that for the crtcs in question and then removing the old framebuffer object. Signed-off-by: Kristian Hogsberg <krh@redhat.com> Acked-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-29drm: sanitise drm modesetting API + remove unused hotplugJakob Bornecrantz
The initially merged modesetting API has some uglies in it, this cleans up the struct members and ioctl ordering for initial submission. It also removes the unneeded hotplug infrastructure. airlied:- I've pulled this patch in from git modesetting-gem tree. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-29DRM: add mode setting supportDave Airlie
Add mode setting support to the DRM layer. This is a fairly big chunk of work that allows DRM drivers to provide full output control and configuration capabilities to userspace. It was motivated by several factors: - the fb layer's APIs aren't suited for anything but simple configurations - coordination between the fb layer, DRM layer, and various userspace drivers is poor to non-existent (radeonfb excepted) - user level mode setting drivers makes displaying panic & oops messages more difficult - suspend/resume of graphics state is possible in many more configurations with kernel level support This commit just adds the core DRM part of the mode setting APIs. Driver specific commits using these new structure and APIs will follow. Co-authors: Jesse Barnes <jbarnes@virtuousgeek.org>, Jakob Bornecrantz <jakob@tungstengraphics.com> Contributors: Alan Hourihane <alanh@tungstengraphics.com>, Maarten Maathuis <madman2003@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
