path: root/include/drm/drm_dp_helper.h
2016-09-15drm: Add DP branch device info on debugfsMika Kahola
Read DisplayPort branch device info from through debugfs interface. v2: use drm_dp_helper routines to collect data v3: cleanup to match the drm_dp_helper.c patches introduced earlier in this series v4: move DP branch device info to function 'intel_dp_branch_device_info()' v5: initial step to move debugging info from intel_dp. to drm_dp_helper.c (Daniel) v6: read hw and sw revision without using specific drm_dp_helper routines v7: indentation fixes (Jim Bride) Signed-off-by: Mika Kahola <mika.kahola@intel.com> Reviewed-by: Jim Bride <jim.bride@linux.intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1473419458-17080-12-git-send-email-mika.kahola@intel.com
2016-09-15drm/i915: Read DP branch device SW revisionMika Kahola
SW revision is mandatory field for DisplayPort branch devices. This is defined in DPCD register fields 0x50A and 0x50B. v2: move drm_dp_ds_revision structure to be part of drm_dp_link structure (Daniel) v3: remove dependency to drm_dp_helper but instead parse DPCD and print SW revision info to dmesg (Ville) v4: commit message fix (Jim Bride) Signed-off-by: Mika Kahola <mika.kahola@intel.com> Reviewed-by: Jim Bride <jim.bride@linux.intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1473419458-17080-9-git-send-email-mika.kahola@intel.com
2016-09-15drm/i915: Read DP branch device HW revisionMika Kahola
HW revision is mandatory field for DisplayPort branch devices. This is defined in DPCD register field 0x509. v2: move drm_dp_ds_revision structure to be part of drm_dp_link structure (Daniel) v3: remove dependency to drm_dp_helper but instead parse DPCD and print HW revision info to dmesg (Ville) Reviewed-by: Jim Bride <jim.bride@linux.intel.com> Signed-off-by: Mika Kahola <mika.kahola@intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1473419458-17080-8-git-send-email-mika.kahola@intel.com
2016-09-15drm: Read DP branch device idMika Kahola
Read DisplayPort branch device id string. Reviewed-by: Jim Bride <jim.bride@linux.intel.com> Signed-off-by: Mika Kahola <mika.kahola@intel.com> Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1473419458-17080-6-git-send-email-mika.kahola@intel.com
2016-09-15drm: Helper to read max bits per componentMika Kahola
Helper routine to read out maximum supported bits per component for DisplayPort legay converters. v2: Return early if detailed port cap info is not available. Replace if-else ladder with switch-case (Ville) Reviewed-by: Jim Bride <jim.bride@linux.intel.com> Signed-off-by: Mika Kahola <mika.kahola@intel.com> Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1473419458-17080-5-git-send-email-mika.kahola@intel.com
2016-09-15drm: Helper to read max clock rateMika Kahola
Helper routine to read out maximum supported pixel rate for DisplayPort legay VGA converter or TMDS clock rate for other digital legacy converters. The helper returns clock rate in kHz. v2: Return early if detailed port cap info is not available. Replace if-else ladder with switch-case (Ville) Reviewed-by: Jim Bride <jim.bride@linux.intel.com> Signed-off-by: Mika Kahola <mika.kahola@intel.com> Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1473419458-17080-4-git-send-email-mika.kahola@intel.com
2016-09-15drm: Drop VGA from bpc definitionsMika Kahola
Drop "VGA" from bits per component definitions as these are also used by other standards such as DVI, HDMI, DP++. Reviewed-by: Jim Bride <jim.bride@linux.intel.com> Signed-off-by: Mika Kahola <mika.kahola@intel.com> Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1473419458-17080-3-git-send-email-mika.kahola@intel.com
2016-09-15drm: Add missing DP downstream port typesMika Kahola
Add missing DisplayPort downstream port types. The introduced new port types are DP++ and Wireless. Reviewed-by: Jim Bride <jim.bride@linux.intel.com> Signed-off-by: Mika Kahola <mika.kahola@intel.com> Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1473419458-17080-2-git-send-email-mika.kahola@intel.com
2016-08-03drm/dp: Add drm_dp_psr_setup_time()Ville Syrjälä
Add a small helper to parse the PSR setup time from the DPCD PSR capabilities and return the value in microseconds. v2: Don't waste so many bytes on the psr_setup_time_us[] table Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2016-07-19drm/doc: Fix missing kerneldoc for drm_dp_helper.cDaniel Vetter
Never added when the DP validation code was added. Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1468612088-9721-5-git-send-email-daniel.vetter@ffwll.ch
2016-06-17drm: Minimally initialise drm_dp_auxChris Wilson
When trying to split up the initialisation phase and the registration phase, one immediate problem encountered is trying to use our own i2c devices before registration with userspace (to read EDID during device discovery). drm_dp_aux in particular only offers an interface for setting up the device *after* we have exposed the connector via sysfs. In order to break the chicken-and-egg problem, export drm_dp_aux_init() to minimally prepare the i2c device for internal use before drm_connector_register(). Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Dave Airlie <airlied@redhat.com> Cc: Rafael Antognolli <rafael.antognolli@intel.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: dri-devel@lists.freedesktop.org [danvet: Amend kerneldoc slightly.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1466152398-20157-3-git-send-email-chris@chris-wilson.co.uk
2016-05-17Merge remote-tracking branch 'airlied/drm-next' into drm-intel-next-queuedDaniel Vetter
Backmerge request by Jani to get at commit 249c4f538b1aae55d41699f8bafc6cb762a7f48f Author: Deepak M <m.deepak@intel.com> Date: Wed Mar 30 17:03:39 2016 +0300 drm: Add new DCS commands in the enum list Some simple conflicts in intel_dp.c. Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2016-05-12drm/dp: Add define to set 0.5% down-spread in MAX_DOWNSPREAD registerEnric Balletbo i Serra
Support of 0.5% down-spread is required for DisplayPort Specification Version 1.1 Sink. Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com> [treding@nvidia.com: rename to DP_MAX_DOWNSPREAD_0_5] Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-04-26drm/dp: Add definition for Display Control DPCD Registers capability sizeYetunde Adebisi
This is used when reading Display Control capability Registers on the sink device. cc: dri-devel@lists.freedesktop.org Signed-off-by: Yetunde Adebisi <yetundex.adebisi@intel.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1459865452-9138-2-git-send-email-yetundex.adebisi@intel.com
2015-11-24drm/dp: add eDP DPCD backlight control bit definitionsJani Nikula
Cc: Yetunde Adebisi <yetundex.adebisi@intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Ander Conselvan de Oliveira <conselvan2@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-10-16Merge commit '06d1ee32a4d25356a710b49d5e95dbdd68bdf505' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux into drm-next Backmerge the drm-fixes pull from Linus's tree into drm-next. This is to fix some conflicts and make future pulls cleaner
2015-10-02Merge tag 'drm-intel-next-2015-09-11' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next - initialize backlight from VBT as fallback (Jani) - hpd A support from Ville - various atomic polish all over (mostly from Maarten) - first parts of virtualize gpu guest support on bdw from Zhiyuan Lv - GuC fixes from Alex - polish for the chv clocks code (Ville) - various things all over, as usual * tag 'drm-intel-next-2015-09-11' of git://anongit.freedesktop.org/drm-intel: (145 commits) drm/i915: Update DRIVER_DATE to 20150911 drm/i915: Remove one very outdated comment drm/i915: Use crtc->state for duplication. drm/i915: Do not handle a null plane state. drm/i915: Remove legacy plane updates for cursor and sprite planes. drm/i915: Use atomic state when changing cursor visibility. drm/i915: Use the atomic state in intel_update_primary_planes. drm/i915: Use the plane state in intel_crtc_info. drm/i915: Use atomic plane state in the primary plane update. drm/i915: add attached connector to hdmi container drm/i915: don't hard code vlv backlight frequency if unset drm/i915: initialize backlight max from VBT drm/i915: use pch backlight override on hsw too drm/i915/bxt: Clean up bxt_init_clock_gating drm/i915: Fix cmdparser STORE/LOAD command descriptors drm/i915: Dump pfit state as hex drm/i915: access the PP_ON_DELAYS/PP_OFF_DELAYS regs only pre GEN5 drm/i915: access the PP_CONTROL reg only pre GEN5 drm/i915: Refactor common ringbuffer allocation code drm/i915: use the yesno helper for logging ...
2015-10-02drm/dp/mst: add some defines for logical/physical portsDave Airlie
This just removes the magic number. Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2015-09-08drm/dp: s/I2C_STATUS/I2C_WRITE_STATUS_UPDATE/Ville Syrjälä
Rename the I2C_STATUS request to I2C_WRITE_STATUS_UPDATE to match the spec. Acked-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2015-09-02Merge tag 'drm-intel-next-fixes-2015-09-02' into drm-intel-next-queuedDaniel Vetter
Backmerge -fixes since there's more DDI-E related cleanups on top of the pile of -fixes for skl that just landed for 4.3. Conflicts: drivers/gpu/drm/i915/intel_display.c drivers/gpu/drm/i914/intel_dp.c drivers/gpu/drm/i915/intel_lrc.c Conflicts are all fairly harmless adjacent line stuff. Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2015-09-01drm/dp: add drm_dp_tps3_supported helperJani Nikula
Cc: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-08-21drm/dp/mst: dump branch OUI in debugfs (v2)Dave Airlie
It appears some MST docks are worse than other, but the only way to know is to see the sw revisions in here, so dump the branch OUI so we can look at the sw revision. v2: Thierry made me feel guilty, so I parsed the branch OUI. Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2015-07-26drm: Fix DP_TEST_COUNT_MASKRodrigo Vivi
By Vesa's DP 1.2 Spec this counter has 4 bits [3:0]. This mask is wrong since when the counter was introduced by myself on commit ad9dc91b6e21266bfc6f466db4b95e10211f31ee Author: Rodrigo Vivi <rodrigo.vivi@gmail.com> Date: Tue Sep 16 19:18:12 2014 -0400 drm/i915: Fix Sink CRC Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Reviewed-by: Sivakumar Thulasimani <sivakumar.thulasimani@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-05-18drm/dp: Fix comment in DP helperJon Hunter
Commit 4f71d0cb76339 ("drm/dp: add a hw mutex around the transfer functions. (v2)"), renamed the functions drm_dp_aux_register_i2c_bus() and drm_dp_aux_unregister_i2c_bus() to drm_dp_aux_register() and drm_dp_aux_unregister(), respectively. However, a comment referring to the original names was not updated in the DP helper header file. Hence, correct these names. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-11drm/dp: Use large transactions for I2C over AUXSimon Farnsworth
Older DisplayPort to DVI-D Dual Link adapters designed by Bizlink have bugs in their I2C over AUX implementation (fixed in newer revisions). They work fine with Windows, but fail with Linux. It turns out that they cannot keep an I2C transaction open unless the previous read was 16 bytes; shorter reads can only be followed by a zero byte transfer ending the I2C transaction. Copy Windows's behaviour, and read 16 bytes at a time. If we get a short reply, assume that there's a hardware bottleneck, and shrink our read size to match. For this purpose, use the algorithm in the DisplayPort 1.2 spec, in the hopes that it'll be closest to what Windows does. Also provide an unsafe module parameter for testing smaller transfer sizes, in case there are sinks out there that cannot work with Windows. Note also that despite the previous comment in drm_dp_i2c_xfer, this speeds up native DP EDID reads; Ville Syrjälä <ville.syrjala@linux.intel.com> found the following changes in his testing: Device under test: old -> with this patch DP->DVI (OUI 001cf8): 40ms -> 35ms DP->VGA (OUI 0022b9): 45ms -> 38ms Zotac DP->2xHDMI: 25ms -> 4ms Asus PB278 monitor: 22ms -> 3ms A back of the envelope calculation shows that peak theoretical transfer rate for 1 byte reads is around 60 kbit/s; with 16 byte reads, this increases to around 500 kbit/s, which explains the increase in speed. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=55228 Tested-by: Aidan Marks <aidanamarks@gmail.com> (v3) Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-10drm/dp: add DPCD definitions from eDP 1.4Jani Nikula
Add a number of DPCD definitions from eDP 1.4. v2: s/DP_ALPM_LOCK_TIMEOUT_ERROR_STATUS/DP_ALPM_LOCK_TIMEOUT_ERROR/ (Sonika) Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Sonika Jindal <sonika.jindal@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-10drm/dp: add DPCD definitions from DP 1.1 and 1.2aJani Nikula
Add a number of DPCD definitions from DP 1.1 and 1.2a. v2: drop wrong DP version reference, rename DP training set macros (Sonika). Reviewed-by: Sonika Jindal <sonika.jindal@intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-10drm/dp: add DPCD definitions from eDP 1.2Jani Nikula
Mostly display control related DPCD addresses. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Sonika Jindal <sonika.jindal@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-10drm/dp: indentation and ordering cleanupsJani Nikula
Keep the DPCD macros ordered by address, and make indentation conform to the rest of the file. commit e045d20bef41707dbba676e58624b54f9f39e172 Author: Sonika Jindal <sonika.jindal@intel.com> Date: Thu Feb 19 13:16:44 2015 +0530 drm: Adding edp1.4 specific dpcd macros Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Sonika Jindal <sonika.jindal@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-02-24drm: Adding edp1.4 specific dpcd macrosSonika Jindal
Adding dpcd macros related to edp1.4 and link rates v2: Added DP_SUPPORTED_LINK_RATES macros Signed-off-by: Sonika Jindal <sonika.jindal@intel.com> Reviewed-by: Todd Previte <tprevite@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-02-01drm/dp: add drm_dp_link_power_down() helperRob Clark
We had _power_up(), but drivers also need to be able to power down. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-07Merge tag 'topic/core-stuff-2014-11-05' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next Just various stuff all over from a bunch of people. Shortlog gives a beter overview, it's really all misc drm patches. * tag 'topic/core-stuff-2014-11-05' of git://anongit.freedesktop.org/drm-intel: drm/edid: add #defines and helpers for ELD drm/dp: Add counters in the drm_dp_aux struct for I2C NACKs and DEFERs drm: Remove compiler BUG_ON() test drm: Fix DRM_FORCE_ON_DIGITAL use drm/gma500: Don't destroy DRM properties in the driver drm/i915: Don't destroy DRM properties in the driver drm: Add a note to drm_property_create() about property lifetime gpu: drm: Fix warning caused by a parameter description in drm_crtc.c drm/dp-helper: Move the legacy helpers to gma500 drm/crtc: Remove duplicated ioctl code drm/crtc: Fix two typos gpu:drm: Fix typo in Documentation/DocBook/drm.xml gpu: drm: drm_dp_mst_topology.c: Fix improper use of strncat drm: drm_err: Remove unnecessary __func__ argument drm: Implement O_NONBLOCK support on /dev/dri/cardN
2014-11-05drm/dp: Add counters in the drm_dp_aux struct for I2C NACKs and DEFERsTodd Previte
These counters are used for Displayort compliance testing to detect error conditions when executing tests 4.2.2.4 and 4.2.2.5 in the Displayport Link CTS specificaiton. They determine whether to use the preferred/requested mode or the failsafe mode during these tests. V2: - Addressed previous review feedback - Updated commit message - Changed from uint8_t to uint32_t Cc: dri-devel@lists.freedesktop.org Signed-off-by: Todd Previte <tprevite@gmail.com> [danvet: s/uint32_t/unsigned/ for clearer intent. Also drop the i915 from the subject, it's all core stuff.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-10-23drm/dp-helper: Move the legacy helpers to gma500Daniel Vetter
Except for gma500 all drivers are converted to the new style helpers, which have much better abstraction of the underlying hw protocols and already much more helper functions (including the entire mst library) on top of them. Since no one seems to work on converting gma500 let's just move the code away so that new drivers don't end up accidentally using this. Cc: Patrik Jakobsson <patrik.r.jakobsson@gmail.com> Reviewed-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com> Reviewed-by: Alan Cox <alan@linux.intel.com> [danvet: Add __deprecated as requested by Alan. Also add a short FIXME comment and drop the EXPORT_SYMBOL which is no longer needed.] Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2014-09-30drm/i915: Fix Sink CRCRodrigo Vivi
In some cases like when PSR just got enabled the panel need more vblank times to calculate CRC. I figured that out with the new PSR test cases facing some cases that I had a green screen but a blank CRC. Even with 2 vblank waits on kernel + 2 vblank waits on test case. So let's give up to 6 vblank wait time. However we now check for TEST_CRC_COUNT that shows when panel finished to calculate CRC and has it ready. v2: Jani pointed out attempts decrements was wrong and should never reach the error condition. And Daniel pointed out that EIO is more appropriated than EGAIN. Also I realized that I have to read test_crc_count after setting test_sink v3: Rebase and adding error message Cc: Todd Previte <tprevite@gmail.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Reviewed-by: Todd Previte <tprevite@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-09-03drm: Remove old defines for vswing and pre-emph valuesSonika Jindal
This is the last patch in the series, so remove old defines Signed-off-by: Sonika Jindal <sonika.jindal@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-09-03drm: Renaming DP training vswing pre emph definesSonika Jindal
Adding new defines, older one will be removed in the last patch in the series. This is to rename the defines to have levels instead of values for vswing and pre-emph levels as the values may differ in other scenarios like low vswing of eDP1.4 where the values are different. Done using following cocci patch for each define: @@ @@ # define DP_TRAIN_VOLTAGE_SWING_400 (0 << 0) + # define DP_TRAIN_VOLTAGE_SWING_LEVEL_0 (0 << 0) ... Cc: dri-devel@lists.freedesktop.org Signed-off-by: Sonika Jindal <sonika.jindal@intel.com> Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-06-05drm/dp: add a hw mutex around the transfer functions. (v2)Dave Airlie
This should avoid races between connector probing and HPD irqs in the future, currently mode_config.mutex blocks this possibility. Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-02drm/exynos: dp: Use DPCD defines of drm_dp_helper.hJingoo Han
Use DPCD defines of drm_dp_helper.h; thus, duplicated DPCD defines of exynos_dp_core.h can be removed. Also, DP_TEST_EDID_CHECKSUM define is added to drm_dp_helper.h. There is no functional change. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Inki Dae <inki.dae@samsung.com>
2014-05-27drm/dp: Add missing kernel-docThierry Reding
Commit 9dc4056026e0 (drm/dp: let drivers specify the name of the I2C- over-AUX adapter) introduced a new field but didn't add the proper kernel-doc for it. Signed-off-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-05-23drm/dp_helper: add defines for DP 1.2 and MST support. (v2)Dave Airlie
This just adds the defines from the DP 1.2 spec, which we will use later. fix some DP MST to 1.2 MST Signed-off-by: Dave Airlie <airlied@redhat.com> Reviewed-by: Todd Previte <tprevite@gmail.com> Reviewed-by: Jingoo Han <jg1.han@samsung.com>
2014-04-08drm/dp/i2c: Update comments about common i2c over dp assumptions (v3)Alex Deucher
If you are using the common dp over i2c functionality, it is asumed that the aux transfer function does not modify the any of the msg structure other than the reply field. Doing so breaks the logic in the common code. v2: update struct drm_dp_aux comments about assumptions v3 (chk): rebased on upstream changes Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Jani Nikula <jani.nikula@intel.com> Cc: Thierry Reding <treding@nvidia.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Christian König <christian.koenig@amd.com>
2014-03-18drm/dp: let drivers specify the name of the I2C-over-AUX adapterJani Nikula
Let the drivers specify the name of the I2C-over-AUX adapter to maintain backwards compatibility in the sysfs when converting to the new I2C-over-AUX helper infrastructure. The i915 driver currently uses DPDDC-A to DPDDC-D as names for the DP i2c adapters. These names show up in the i2c sysfs name attribute. We'd like to be able to maintain that when switching over to the new helpers. Due to i2c device and connector cleanup ordering issues we also recently made the drm device (instead of connector) the parent of the i2c adapters: commit 80f65de3c9b8101c1613fa82df500ba6a099a11c Author: Imre Deak <imre.deak@intel.com> Date: Tue Feb 11 17:12:49 2014 +0200 drm/i915: dp: fix order of dp aux i2c device cleanup With the name picked up from the adapter parent using dev_name(), it would be the same for all i2c adapters with the current I2C-over-AUX helpers. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Acked-by: Dave Airlie <airlied@redhat.com> Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-02-27Merge tag 'drm-intel-next-2014-02-07' of ↵Dave Airlie
ssh://git.freedesktop.org/git/drm-intel into drm-next - Yet more steps towards atomic modeset from Ville. - DP panel power sequencing improvements from Paulo. - irq code cleanups from Ville. - 5.4 GHz dp lane clock support for bdw/hsw from Todd. - Clock readout support for hsw/bdw (aka fastboot) from Jesse. - Make pipe underruns report at ERROR level (Ville). This is to check our improved watermarks code. - Full ppgtt support from Ben for gen7. - More fbc fixes and improvements from Ville all over the place, unfortunately not yet enabled by default on more platforms. - w/a cleanups from Ville. - HiZ stall optimization settings (Chia-I Wu). - Display register mmio offset refactor patch from Antti. - RPS improvements for corner-cases from Jeff McGee. * tag 'drm-intel-next-2014-02-07' of ssh://git.freedesktop.org/git/drm-intel: (166 commits) drm/i915: Update rps interrupt limits drm/i915: Restore rps/rc6 on reset drm/i915: Prevent recursion by retiring requests when the ring is full drm/i915: Generate a hang error code drm/i915: unify FLIP_DONE macro names drm/i915: vlv: s/spin_lock_irqsave/spin_lock/ in irq handler drm/i915: factor out valleyview_pipestat_irq_handler drm/i915: vlv: don't unmask IIR[DISPLAY_PIPE_A/B_VBLANK] interrupt drm/i915: Reorganize display pipe register accesses drm/i915: Treat using a purged buffer as a source of EFAULT drm/i915: Convert EFAULT into a silent SIGBUS drm/i915: release mutex in i915_gem_init()'s error path drm/i915: check for oom when allocating private_default_ctx drm/i915/vlv: WA to fix Voltage not getting dropped to Vmin when Gfx is power gated. drm/i915: Get rid of acthd based guilty batch search drm/i915: Use hangcheck score to find guilty context drm/i915: Drop WaDisablePSDDualDispatchEnable:ivb for IVB GT2 drm/i915: Fix IVB GT2 WaDisableDopClockGating and WaDisablePSDDualDispatchEnable drm/i915: Don't access snooped pages through the GTT (even for error capture) drm/i915: Only print information for filing bug reports once ... Conflicts: drivers/gpu/drm/i915/intel_dp.c
2014-02-26drm/dp: Allow registering AUX channels as I2C bussesThierry Reding
Implements an I2C-over-AUX I2C adapter on top of the generic drm_dp_aux infrastructure. It extracts the retry logic from existing drivers, which should help in porting those drivers to this new helper. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Thierry Reding <treding@nvidia.com> --- Changes in v5: - move comments partially to to header file - keep MOT set between I2C messages - return -EPROTO on short reads Changes in v4: - fix typo "bitrate" -> "bit rate" Changes in v3: - add back DRM_DEBUG_KMS and DRM_ERROR messages - embed i2c_adapter within struct drm_dp_aux - fix typo in comment
2014-02-26drm/dp: Add DisplayPort link helpersThierry Reding
Add a helper to probe a DP link (read out the supported DPCD revision, maximum rate, link count and capabilities) as well as power up the DP link and configure it accordingly. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Thierry Reding <treding@nvidia.com> --- Changes in v5: - export helpers Changes in v4: - fix a couple of typos in comments as pointed out by Alex Deucher Changes in v3: - split into drm_dp_link_power_up() and drm_dp_link_configure() - do not change sink state for DPCD versions earlier than 1.1 - sleep for 1-2 ms after setting local sink to D0 state - read and write consecutive registers where possible - read DPCD revision when link is probed - remove duplicate kerneldoc
2014-02-26drm/dp: Add drm_dp_dpcd_read_link_status()Thierry Reding
The function reads the link status (6 bytes starting at offset 0x202) from the DPCD so that it can be conveniently passed to other DPCD helpers. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-02-26drm/dp: Add AUX channel infrastructureThierry Reding
This is a superset of the current i2c_dp_aux bus functionality and can be used to transfer native AUX in addition to I2C-over-AUX messages. Helpers are provided to read and write the DPCD, either blockwise or byte-wise. Many of the existing helpers for DisplayPort take a copy of a portion of the DPCD and operate on that, without a way to write data back to the DPCD (e.g. for configuration of the link). Subsequent patches will build upon this infrastructure to provide common functionality in a generic way. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Thierry Reding <treding@nvidia.com> --- Changes in v5: - move comments partially to struct drm_dp_aux_msg in header file - return -EPROTO on short reads in DPCD helpers Changes in v4: - fix a typo in a comment Changes in v3: - reorder drm_dp_dpcd_writeb() arguments to be more intuitive - return number of bytes transferred in drm_dp_dpcd_write() - factor out drm_dp_dpcd_access() - describe error codes
2014-01-27drm: dp helper: Add DP test sink CRC definition.Rodrigo Vivi
This address will be used to verify panel CRC for test and validation purposes. Signed-off-by: Rodrigo Vivi <rodrigo.vivi@gmail.com> [danvet: Fix whitespace fail.] Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-12-18drm/dp: Clarify automated test constant and add constant for FAUX test patternTodd Previte
- DP_TEST_LINK_PATTERN is ambiguous, rename to DP_TEST_LINK_VIDEO_PATTERN to clarify - Added DP_TEST_LINK_FAUX_PATTERN to support automated testing of Fast AUX Signed-off-by: Todd Previte <tprevite@gmail.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
