path: root/include/drm
2012-02-09drm: Fix authentication kernel crashThomas Hellstrom
commit 598781d71119827b454fd75d46f84755bca6f0c6 upstream. If the master tries to authenticate a client using drm_authmagic and that client has already closed its drm file descriptor, either wilfully or because it was terminated, the call to drm_authmagic will dereference a stale pointer into kmalloc'ed memory and corrupt it. Typically this results in a hard system hang. This patch fixes that problem by removing any authentication tokens (struct drm_magic_entry) open for a file descriptor when that file descriptor is closed. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Change-Id: Icbba107e666306a34a621955458091410da3956a Reviewed-on: http://git-master/r/79654 Reviewed-by: Automatic_Commit_Validation_User
2012-01-05Linux 3.1.7Varun Wadekar
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
2011-12-21drm/radeon/kms: add some new pci idsAlex Deucher
commit cd5cfce856684e13b9b57d46b78bb827e9c4da3c upstream. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=43739 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-14Merge branch 'linux-3.1.5' into android-tegra-nv-3.1Varun Wadekar
Conflicts: arch/arm/Kconfig Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2011-12-09drm/radeon/kms: add some new pci idsAlex Deucher
commit 2ed4d9d648cbd4fb1c232a646dbdbdfdd373ca94 upstream. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09drm: integer overflow in drm_mode_dirtyfb_ioctl()Xi Wang
commit a5cd335165e31db9dbab636fd29895d41da55dd2 upstream. There is a potential integer overflow in drm_mode_dirtyfb_ioctl() if userspace passes in a large num_clips. The call to kmalloc would allocate a small buffer, and the call to fb->funcs->dirty may result in a memory corruption. Reported-by: Haogang Chen <haogangchen@gmail.com> Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-30drm_fixed: Add dfixed_fracRobert Morell
This helper macro retrieves the fractional part of a fixed20_12 20.12 fixed-point number. bug 818525 Original-Change-Id: Ia43a7bd3029a4d09ad7801099cbe2a52a4fc9c04 Signed-off-by: Robert Morell <rmorell@nvidia.com> Reviewed-on: http://git-master/r/40525 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com> Rebase-Id: R3ad51cd6fb0e1dadbc25807bf12894a9b81e94d3
2011-11-21drm/radeon: add some missing FireMV pci idsAlex Deucher
commit b872a37437e93df9d112ce674752b3b3a0a17020 upstream. Noticed by Egbert. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: Egbert Eich <eich@suse.de> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11drm/radeon/kms: properly set panel mode for eDPAlex Deucher
commit 00dfb8df5bf8c3afe4c0bb8361133156b06b7a2c upstream. This should make eDP more reliable. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-04drm: Separate EDID Header Check from EDID Block CheckThomas Reim
Provides function drm_edid_header_is_valid() for EDID header check and replaces EDID header check part of function drm_edid_block_valid() by a call of drm_edid_header_is_valid(). This is a prerequisite to extend DDC probing, e. g. in function radeon_ddc_probe() for Radeon devices, by a central EDID header check. Tested for kernel 2.6.35, 2.6.38 and 3.0 Cc: <stable@kernel.org> Signed-off-by: Thomas Reim <reimth@gmail.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Acked-by: Stephen Michaels <Stephen.Micheals@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-04Merge branch 'drm-intel-next' of ↵Dave Airlie
ssh://master.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6 into drm-fixes * 'drm-intel-next' of ssh://master.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6: (42 commits) drm/i915: allow cache sharing policy control drm/i915/hdmi: HDMI source product description infoframe support drm/i915/hdmi: split infoframe setting from infoframe type code drm: track CEA version number if present drm/i915: Try enabling RC6 by default (again) Revert "drm/i915/dp: Zero the DPCD data before connection probe" drm/i915/dp: wait for previous AUX channel activity to clear drm/i915: don't use uninitialized EDID bpc values when picking pipe bpp drm/i915/pch: Save/restore PCH_PORT_HOTPLUG across suspend drm/i915: apply phase pointer override on SNB+ too drm/i915: Add quirk to disable SSC on Sony Vaio Y2 drm/i915: provide more error output when mode sets fail drm/i915: add GPU max frequency control file i915: add Dell OptiPlex FX170 to intel_no_lvds drm/i915: Ignore GPU wedged errors while pinning scanout buffers drm/i915/hdmi: send AVI info frames on ILK+ as well drm/i915: fix CB tuning check for ILK+ drm/i915: Flush other plane register writes drm/i915: flush plane control changes on ILK+ as well drm/i915: apply timing generator bug workaround on CPT and PPT ...
2011-08-03drm: track CEA version number if presentJesse Barnes
Drivers need to know the CEA version number in addition to other display info (like whether the display is an HDMI sink) before enabling certain features. So track the CEA version number in the display info structure. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (135 commits) drm/radeon/kms: fix DP training for DPEncoderService revision bigger than 1.1 drm/radeon/kms: add missing vddci setting on NI+ drm/radeon: Add a rmb() in IH processing drm/radeon: ATOM Endian fix for atombios_crtc_program_pll() drm/radeon: Fix the definition of RADEON_BUF_SWAP_32BIT drm/radeon: Do an MMIO read on interrupts when not uisng MSIs drm/radeon: Writeback endian fixes drm/radeon: Remove a bunch of useless _iomem casts drm/gem: add support for private objects DRM: clean up and document parsing of video= parameter DRM: Radeon: Fix section mismatch. drm: really make debug levels match in edid failure code drm/radeon/kms: fix i2c map for rv250/280 drm/nouveau/gr: disable fifo access and idle before suspend ctx unload drm/nouveau: pass flag to engine fini() method on suspend drm/nouveau: replace nv04_graph_fifo_access() use with direct reg bashing drm/nv40/gr: rewrite/split context takedown functions drm/nouveau: detect disabled device in irq handler and return IRQ_NONE drm/nouveau: ignore connector type when deciding digital/analog on DVI-I drm/nouveau: Add a quirk for Gigabyte NX86T ...
2011-07-25drm/gem: add support for private objectsAlan Cox
These small changes should allow GEM to be used with non shmem objects as well as shmem objects. In the GMA500 case it allows the base framebuffer to appear as a GEM object and thus acquire a handle and work with KMS. For i915 it ought to be trivial to get back the wasted memory but putting the system fb back into stolen RAM and in general I can imagine it allowing the use of GEM and thus KMS with all the older cards that have their framebuffer firmly placed in video RAM. Signed-off-by: Alan Cox <alan@linux.intel.com> Tested-by: Rob Clark <rob@ti.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-07-22Merge branch 'drm-intel-fixes' into drm-intel-nextKeith Packard
2011-07-22drm/i915: Fix typo in DRM_I915_OVERLAY_PUT_IMAGE ioctl defineOle Henrik Jahren
Because of a typo, calling ioctl with DRM_IOCTL_I915_OVERLAY_PUT_IMAGE is broken if the macro is used directly. When using libdrm the bug is not hit, since libdrm handles the ioctl encoding internally. The typo also leads to the .cmd and .cmd_drv fields of the drm_ioctl structure for DRM_I915_OVERLAY_PUT_IMAGE having inconsistent content. Signed-off-by: Ole Henrik Jahren <olehenja@alumni.ntnu.no> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: stable@kernel.org Signed-off-by: Keith Packard <keithp@keithp.com>
2011-07-18drm/radeon/kms: add info query for backend mapAlex Deucher
The 3D driver need to get the pipe to backend map to certain things. Add a query to get the info. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-07-15drm/radeon/kms: add new NI pci idsAlex Deucher
Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-07-13DRM: remove drm_pci_device_is_pcieJon Mason
drm_pci_device_is_pcie duplicates the funcationality of pci_is_pcie. Convert callers of the former to the latter. This has the side benefit of removing an unnecessary search in the PCI configuration space due to using a saved PCIe capability offset. [airlied: update for new callsite] Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-06-21ttm: Fix spelling mistakes and remove unused #ifdefKonrad Rzeszutek Wilk
. and some comments to make it easier to understand. Ackedby: Randy Dunlap <randy.dunlap@oracle.com> [v2: Added some more updates from Randy Dunlap] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-06-21drm/gem: add hooks to notify driver when object handle is created/destroyedBen Skeggs
Nouveau is going to use these hooks to map/unmap objects from a client's private GPU address space. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-06-16drm/radeon: workaround a hw bug on some radeon chipsets with all-0 EDIDs.Dave Airlie
Some RS690 chipsets seem to end up with floating connectors, either a DVI connector isn't actually populated, or an add-in HDMI card is available but not installed. In this case we seem to get a NULL byte response for each byte of the i2c transaction, so we detect this case and if we see it we don't do anymore DDC transactions on this connector. I've tested this on my RS690 without the HDMI card installed and it seems to work fine. Signed-off-by: Dave Airlie <airlied@redhat.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
2011-06-07Merge branch 'drm-radeon-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-radeon-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon/kms/atom: fix PHY init drm/radeon/kms: add missing Evergreen texture formats to the CS parser drm/radeon/kms: viewport height has to be even drm/radeon/kms: remove duplicate reg from r600 safe regs drm/radeon/kms: add support for Llano Fusion APUs drm/radeon/kms: add llano pci ids drm/radeon/kms: fill in asic struct for llano drm/radeon/kms: add family ids for llano APUs drm/radeon: fix oops in ttm reserve when pageflipping (v2) drm/radeon/kms: clean up the radeon kms Kconfig drm/radeon/kms: fix thermal sensor reading on juniper drm/radeon/kms: add missing case for cayman thermal sensor drm/radeon/kms: add blit support for cayman (v2) drm/radeon/kms/blit: workaround some hw issues on evergreen+
2011-06-02drm/radeon/kms: add llano pci idsAlex Deucher
2011-05-24Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits) drivers/gpu/drm/radeon/atom.c: fix warning drm/radeon/kms: bump kms version number drm/radeon/kms: properly set num banks for fusion asics drm/radeon/kms/atom: move dig phy init out of modesetting drm/radeon/kms/cayman: fix typo in register mask drm/radeon/kms: fix typo in spread spectrum code drm/radeon/kms: fix tile_config value reported to userspace on cayman. drm/radeon/kms: fix incorrect comparison in cayman setup code. drm/radeon/kms: add wait idle ioctl for eg->cayman drm/radeon/cayman: setup hdp to invalidate and flush when asked drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked agp/uninorth: Fix lockups with radeon KMS and >1x. drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices drm/radeon/kms: fixup eDP connector handling drm/radeon/kms: bail early for eDP in hotplug callback drm/radeon/kms: simplify hotplug handler logic drm/radeon/kms: rewrite DP handling drm/radeon/kms/atom: add support for setting DP panel mode drm/radeon/kms: atombios.h updates for DP panel mode ...
2011-05-20drm/dp: add some new DP regs for DP 1.2Alex Deucher
2011-05-16drm: Take lock around probes for drm_fb_helper_hotplug_eventChris Wilson
We need to hold the dev->mode_config.mutex whilst detecting the output status. But we also need to drop it for the call into drm_fb_helper_single_fb_probe(), which indirectly acquires the lock when attaching the fbcon. Failure to do so exposes a race with normal output probing. Detected by adding some warnings that the mutex is held to the backend detect routines: [ 17.772456] WARNING: at drivers/gpu/drm/i915/intel_crt.c:471 intel_crt_detect+0x3e/0x373 [i915]() [ 17.772458] Hardware name: Latitude E6400 [ 17.772460] Modules linked in: .... [ 17.772582] Pid: 11, comm: kworker/0:1 Tainted: G W 2.6.38.4-custom.2 #8 [ 17.772584] Call Trace: [ 17.772591] [<ffffffff81046af5>] ? warn_slowpath_common+0x78/0x8c [ 17.772603] [<ffffffffa03f3e5c>] ? intel_crt_detect+0x3e/0x373 [i915] [ 17.772612] [<ffffffffa0355d49>] ? drm_helper_probe_single_connector_modes+0xbf/0x2af [drm_kms_helper] [ 17.772619] [<ffffffffa03534d5>] ? drm_fb_helper_probe_connector_modes+0x39/0x4d [drm_kms_helper] [ 17.772625] [<ffffffffa0354760>] ? drm_fb_helper_hotplug_event+0xa5/0xc3 [drm_kms_helper] [ 17.772633] [<ffffffffa035577f>] ? output_poll_execute+0x146/0x17c [drm_kms_helper] [ 17.772638] [<ffffffff81193c01>] ? cfq_init_queue+0x247/0x345 [ 17.772644] [<ffffffffa0355639>] ? output_poll_execute+0x0/0x17c [drm_kms_helper] [ 17.772648] [<ffffffff8105b540>] ? process_one_work+0x193/0x28e [ 17.772652] [<ffffffff8105c6bc>] ? worker_thread+0xef/0x172 [ 17.772655] [<ffffffff8105c5cd>] ? worker_thread+0x0/0x172 [ 17.772658] [<ffffffff8105c5cd>] ? worker_thread+0x0/0x172 [ 17.772663] [<ffffffff8105f767>] ? kthread+0x7a/0x82 [ 17.772668] [<ffffffff8100a724>] ? kernel_thread_helper+0x4/0x10 [ 17.772671] [<ffffffff8105f6ed>] ? kthread+0x0/0x82 [ 17.772674] [<ffffffff8100a720>] ? kernel_thread_helper+0x0/0x10 Reported-by: Frederik Himpe <fhimpe@telenet.be> References: https://bugs.freedesktop.org/show_bug.cgi?id=36394 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-16Merge remote branch 'keithp/drm-intel-next' of /ssd/git/drm-next into ↵Dave Airlie
drm-core-next * 'keithp/drm-intel-next' of /ssd/git/drm-next: (301 commits) drm/i915: split PCH clock gating init drm/i915: add Ivybridge clock gating init function drm/i915: Update the location of the ringbuffers' HWS_PGA registers for IVB. drm/i915: Add support for fence registers on Ivybridge. drm/i915: Use existing function instead of open-coding fence reg clear. drm/i915: split clock gating init into per-chipset functions drm/i915: set IBX pch type explicitly drm/i915: add Ivy Bridge PCI IDs and driver feature structs drm/i915: add PantherPoint PCH ID agp/intel: add Ivy Bridge support drm/i915: ring support for Ivy Bridge drm/i915: page flip support for Ivy Bridge drm/i915: interrupt & vblank support for Ivy Bridge drm/i915: treat Ivy Bridge watermarks like Sandy Bridge drm/i915: manual FDI training for Ivy Bridge drm/i915: add swizzle/tiling support for Ivy Bridge drm/i915: Ivy Bridge has split display and pipe control drm/i915: add IS_IVYBRIDGE macro for checks drm/i915: add IS_GEN7 macro to cover Ivy Bridge and later drm/i915: split enable/disable vblank code into chipset specific functions ...
2011-05-09drm: mm: fix debug outputDaniel Vetter
The looping helper didn't do anything due to a superficial semicolon. Furthermore one of the two dump functions suffered from copy&paste fail. While staring at the code I've also noticed that the replace helper (currently unused) is a bit broken. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-04drm/radeon/kms: fix gart setup on fusion parts (v2)Alex Deucher
Out of the entire GART/VM subsystem, the hw designers changed the location of 3 regs. v2: airlied: add parameter for userspace to work from. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Jerome Glisse <jglisse@redhat.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-04drm/radeon/kms: add some new pci idsAlex Deucher
Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-28drm: Export the command-line mode parserChris Wilson
In the absence of configuration data for providing the fixed mode for a panel, I would like to be able to pass such modes along a separate module paramenter. To do so, I then need to parse a modeline from a string, which drm is already capable of. Export that capability to the drivers. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-28drm: Verify debug message argumentsJoe Perches
Add __attribute__((format (printf, 4, 5))) to drm_ut_debug_printk and fix fallout. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-28drm: Create and use drm_errJoe Perches
Reduce drm text size ~1% by using drm_err and printf extension %pV to emit error messages. Remove unused macro DRM_MEM_ERROR. $ size drivers/gpu/drm/built-in.o* text data bss dec hex filename 361159 9663 256 371078 5a986 drivers/gpu/drm/built-in.o.new 365416 9663 256 375335 5ba27 drivers/gpu/drm/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-28drm: Take lock around probes for drm_fb_helper_hotplug_eventChris Wilson
2011-04-28drm: parse color format support for digital displaysJesse Barnes
EDID 1.4 digital displays report the color spaces they support in the features block. Add support for grabbing this data and stuffing it into the display_info struct for driver use. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-28drm: add bit depth parsingJesse Barnes
EDID 1.4 digital monitors report the bit depth supported in the input field. Add support for parsing this out and storing the info in the display_info structure for use by drivers. [airlied: tweaked to fix inter-patch dependency] Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Adam Jackson <ajax@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-27drm/i915: restore only the mode of this driver on lastclose (v2)Dave Airlie
i915 calls the panic handler function on last close to reset the modes, however this is a really bad idea for multi-gpu machines, esp shareable gpus machines. So add a new entry point for the driver to just restore its own fbcon mode. v2: move code into fb helper, fix panic code to block mode change on powered off GPUs. [airlied: this hits drm core and I wrote it and it was reviewed on intel-gfx so really I signed it off twice ;-).] Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-27drm/radeon/kms: add info query for tile pipesAlex Deucher
needed by mesa for htile setup. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-05drm: fix "persistant" typoJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-05drm/radeon/kms: add some new ontario pci idsAlex Deucher
Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc:stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-01drm: export drm_find_cea_extension to driversBen Skeggs
Nouveau needs access to this structure to build an ELD block for use by the HDA audio codec. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-24drm/vblank: update recently added vbl interface to be more future proof.Dave Airlie
This makes the interface a bit cleaner by leaving a single gap in the vblank bit space instead of creating two gaps. Suggestions from Michel on mailing list/irc. Reviewed-by: Michel Dänzer <michel@daenzer.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-21drm/kernel: vblank wait on crtc > 1Ilija Hadzic
Below is a patch against drm-next branch of 2.6.38-rc8+ kernel that adds the capability to wait on vblank events for CRTCs that are greater than 1 and thus cannot be represented with primary/secondary flags in the legacy interface. It was discussed on the dri-devel list in these two threads: http://lists.freedesktop.org/archives/dri-devel/2011-March/009009.html http://lists.freedesktop.org/archives/dri-devel/2011-March/009025.html This patch extends the interface to drm_wait_vblank ioctl so that crtc>1 can be represented. It also adds a new capability to drm_getcap ioctl so that the user space can check whether the new interface to drm_wait_vblank is supported (and fall back to the legacy interface if not) Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com> Reviewed-by: Mario Kleiner <mario.kleiner at tuebingen.mpg.de> Acked-by: Mario Kleiner <mario.kleiner at tuebingen.mpg.de> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Tested-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-14Merge remote branch 'intel/drm-intel-next' of ../drm-next into drm-core-nextDave Airlie
* 'intel/drm-intel-next' of ../drm-next: (755 commits) drm/i915: Only wait on a pending flip if we intend to write to the buffer drm/i915/dp: Sanity check eDP existence drm/i915: Rebind the buffer if its alignment constraints changes with tiling drm/i915: Disable GPU semaphores by default drm/i915: Do not overflow the MMADDR write FIFO Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing" drm/i915: Don't save/restore hardware status page address register drm/i915: don't store the reg value for HWS_PGA drm/i915: fix memory corruption with GM965 and >4GB RAM Linux 2.6.38-rc7 Revert "TPM: Long default timeout fix" drm/i915: Re-enable GPU semaphores for SandyBridge mobile drm/i915: Replace vblank PM QoS with "Interrupt-Based AGPBUSY#" Revert "drm/i915: Use PM QoS to prevent C-State starvation of gen3 GPU" drm/i915: Allow relocation deltas outside of target bo drm/i915: Silence an innocuous compiler warning for an unused variable fs/block_dev.c: fix new kernel-doc warning ACPI: Fix build for CONFIG_NET unset mm: <asm-generic/pgtable.h> must include <linux/mm_types.h> x86: Use u32 instead of long to set reset vector back to 0 ... Conflicts: drivers/gpu/drm/i915/i915_gem.c
2011-03-04drm: add cap bit to denote if dumb ioctl is available or not.Dave Airlie
This allows libkms to make an easier decision. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-04drm/core: add ioctl to query device/driver capabilitiesBen Skeggs
We're coming to see a need to have a set of generic capability checks in the core DRM, in addition to the driver-specific ioctls that already exist. This patch defines an ioctl to do as such, but does not yet define any capabilities. [airlied: drop the driver callback for now.] Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
