path: root/include/drm
2014-01-09drm/radeon: 0x9649 is SUMO2 not SUMOAlex Deucher
commit d00adcc8ae9e22eca9d8af5f66c59ad9a74c90ec upstream. Fixes rendering corruption due to incorrect gfx configuration. bug: https://bugs.freedesktop.org/show_bug.cgi?id=63599 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-21Merge branch 'drm-radeon-sun-hainan' of ↵Linus Torvalds
git://people.freedesktop.org/~airlied/linux Pull radeon sun/hainan support from Dave Airlie: "Since I know its outside the merge window, but since this is new hw I thought I'd try and provoke the new hw exception, it just fills in the blanks in the driver for the new AMD sun and hainan chipsets." * 'drm-radeon-sun-hainan' of git://people.freedesktop.org/~airlied/linux: drm/radeon: add Hainan pci ids drm/radeon: add golden register settings for Hainan (v2) drm/radeon: sun/hainan chips do not have UVD (v2) drm/radeon: track which asics have UVD drm/radeon: radeon-asic updates for Hainan drm/radeon: fill in ucode loading support for Hainan drm/radeon: don't touch DCE or VGA regs on Hainan (v3) drm/radeon: fill in GPU init for Hainan (v2) drm/radeon: add chip family for Hainan
2013-05-20drm/radeon: add Hainan pci idsAlex Deucher
Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com>
2013-05-16Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Fix for radeon nomodeset regression, old radeon interface cliprects fix, 2 qxl crasher fixes, and a couple of minor cleanups. I may have a new AMD hw support branch next week, its one of those doesn't affect anything existing just adds new support, I'll see how it shapes up and I might ask you to take it, just thought I'd warn in advance." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: drm/radeon: restore nomodeset operation (v2) qxl: fix bug with object eviction and update area drm/qxl: drop active_user_framebuffer as its unneeded qxl: drop unused variable. drm/qxl: fix ioport interactions for kernel submitted commands. drm: remove unused wrapper macros drm/radeon: check incoming cliprects pointer
2013-05-13Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Just a few straggling fixes I hoovered up, and an intel fixes pull from Daniel which fixes some regressions, and some mgag200 fixes from Matrox." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: drm/mgag200: Fix framebuffer base address programming drm/mgag200: Convert counter delays to jiffies drm/mgag200: Fix writes into MGA1064_PIX_CLK_CTL register drm/mgag200: Don't change unrelated registers during modeset drm: Only print a debug message when the polled connector has changed drm: Make the HPD status updates debug logs more readable drm: Use names of ioctls in debug traces drm: Remove pointless '-' characters from drm_fb_helper documentation drm: Add kernel-doc for drm_fb_helper_funcs->initial_config drm: refactor call to request_module drm: Don't prune modes loudly when a connector is disconnected drm: Add missing break in the command line mode parsing code drm/i915: clear the stolen fb before resuming Revert "drm/i915: Calculate correct stolen size for GEN7+" drm/i915: hsw: fix link training for eDP on port-A Revert "drm/i915: revert eDP bpp clamping code changes" drm: don't check modeset locks in panic handler drm/i915: Fix pipe enabled mask for pipe C in WM calculations drm/mm: fix dump table BUG drm/i915: Always normalize return timeout for wait_timeout_ioctl
2013-05-13drm: remove unused wrapper macrosDave Airlie
We don't use these anymore so nuke them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-05-10drm: Use names of ioctls in debug tracesChris Cummins
The intention here is to make the output of dmesg with full verbosity a bit easier for a human to parse. This commit transforms: [drm:drm_ioctl], pid=699, cmd=0x6458, nr=0x58, dev 0xe200, auth=1 [drm:drm_ioctl], pid=699, cmd=0xc010645b, nr=0x5b, dev 0xe200, auth=1 [drm:drm_ioctl], pid=699, cmd=0xc0106461, nr=0x61, dev 0xe200, auth=1 [drm:drm_ioctl], pid=699, cmd=0xc01c64ae, nr=0xae, dev 0xe200, auth=1 [drm:drm_mode_addfb], [FB:32] [drm:drm_ioctl], pid=699, cmd=0xc0106464, nr=0x64, dev 0xe200, auth=1 [drm:drm_vm_open_locked], 0x7fd9302fe000,0x00a00000 [drm:drm_ioctl], pid=699, cmd=0x400c645f, nr=0x5f, dev 0xe200, auth=1 [drm:drm_ioctl], pid=699, cmd=0xc00464af, nr=0xaf, dev 0xe200, auth=1 [drm:intel_crtc_set_config], [CRTC:3] [NOFB] into: [drm:drm_ioctl], pid=699, dev=0xe200, auth=1, I915_GEM_THROTTLE [drm:drm_ioctl], pid=699, dev=0xe200, auth=1, I915_GEM_CREATE [drm:drm_ioctl], pid=699, dev=0xe200, auth=1, I915_GEM_SET_TILING [drm:drm_ioctl], pid=699, dev=0xe200, auth=1, IOCTL_MODE_ADDFB [drm:drm_mode_addfb], [FB:32] [drm:drm_ioctl], pid=699, dev=0xe200, auth=1, I915_GEM_MMAP_GTT [drm:drm_vm_open_locked], 0x7fd9302fe000,0x00a00000 [drm:drm_ioctl], pid=699, dev=0xe200, auth=1, I915_GEM_SET_DOMAIN [drm:drm_ioctl], pid=699, dev=0xe200, auth=1, DRM_IOCTL_MODE_RMFB [drm:intel_crtc_set_config], [CRTC:3] [NOFB] v2: drm_ioctls is now a constant (Ville Syrjälä) Signed-off-by: Chris Cummins <christopher.e.cummins@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-05-10drm: Remove pointless '-' characters from drm_fb_helper documentationVille Syrjälä
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-05-10drm: Add kernel-doc for drm_fb_helper_funcs->initial_configVille Syrjälä
2013-05-02Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm pull request for 3.10. Wierd bits: - OMAP drm changes required OMAP dss changes, in drivers/video, so I took them in here. - one more fbcon fix for font handover - VT switch avoidance in pm code - scatterlist helpers for gpu drivers - have acks from akpm Highlights: - qxl kms driver - driver for the spice qxl virtual GPU Nouveau: - fermi/kepler VRAM compression - GK110/nvf0 modesetting support. Tegra: - host1x core merged with 2D engine support i915: - vt switchless resume - more valleyview support - vblank fixes - modesetting pipe config rework radeon: - UVD engine support - SI chip tiling support - GPU registers initialisation from golden values. exynos: - device tree changes - fimc block support Otherwise: - bunches of fixes all over the place." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (513 commits) qxl: update to new idr interfaces. drm/nouveau: fix build with nv50->nvc0 drm/radeon: fix handling of v6 power tables drm/radeon: clarify family checks in pm table parsing drm/radeon: consolidate UVD clock programming drm/radeon: fix UPLL_REF_DIV_MASK definition radeon: add bo tracking debugfs drm/radeon: add new richland pci ids drm/radeon: add some new SI PCI ids drm/radeon: fix scratch reg handling for UVD fence drm/radeon: allocate SA bo in the requested domain drm/radeon: fix possible segfault when parsing pm tables drm/radeon: fix endian bugs in atom_allocate_fb_scratch() OMAPDSS: TFP410: return EPROBE_DEFER if the i2c adapter not found OMAPDSS: VENC: Add error handling for venc_probe_pdata OMAPDSS: HDMI: Add error handling for hdmi_probe_pdata OMAPDSS: RFBI: Add error handling for rfbi_probe_pdata OMAPDSS: DSI: Add error handling for dsi_probe_pdata OMAPDSS: SDI: Add error handling for sdi_probe_pdata OMAPDSS: DPI: Add error handling for dpi_probe_pdata ...
2013-05-02drm/radeon: add new richland pci idsAlex Deucher
Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-05-02drm/radeon: add some new SI PCI idsAlex Deucher
2013-05-01drm: proc: Use minor->index to label things, not PDE->nameDavid Howells
Use minor->index to label things, not the name field from the proc_dir_entry of the /proc/dwm/<minor>/ directory. Also, use "%u" not "%d" to render the value and use a 12-byte buffer in which to render the integer, not a 16-byte buffer. The longest string an unsigned int can give you is 10 chars (4294967295) plus a NUL, so round up to 12 as the stack is likely to be 4- or 8-byte aligned. Signed-off-by: David Howells <dhowells@redhat.com> cc: dri-devel@lists.freedesktop.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01drm: Constify drm_proc_list[]David Howells
Constify drm_proc_list[] and related pointers. Signed-off-by: David Howells <dhowells@redhat.com> cc: dri-devel@lists.freedesktop.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01drm/prime: keep a reference from the handle to exported dma-buf (v6)Dave Airlie
Currently we have a problem with this: 1. i915: create gem object 2. i915: export gem object to prime 3. radeon: import gem object 4. close prime fd 5. radeon: unref object 6. i915: unref object i915 has an imported object reference in its file priv, that isn't cleaned up properly until fd close. The reference gets added at step 2, but at step 6 we don't have enough info to clean it up. The solution is to take a reference on the dma-buf when we export it, and drop the reference when the gem handle goes away. So when we export a dma_buf from a gem object, we keep track of it with the handle, we take a reference to the dma_buf. When we close the handle (i.e. userspace is finished with the buffer), we drop the reference to the dma_buf, and it gets collected. This patch isn't meant to fix any other problem or bikesheds, and it doesn't fix any races with other scenarios. v1.1: move export symbol line back up. v2: okay I had to do a bit more, as the first patch showed a leak on one of my tests, that I found using the dma-buf debugfs support, the problem case is exporting a buffer twice with the same handle, we'd add another export handle for it unnecessarily, however we now fail if we try to export the same object with a different gem handle, however I'm not sure if that is a case I want to support, and I've gotten the code to WARN_ON if we hit something like that. v2.1: rebase this patch, write better commit msg. v3: cleanup error handling, track import vs export in linked list, these two patches were separate previously, but seem to work better like this. v4: danvet is correct, this code is no longer useful, since the buffer better exist, so remove it. v5: always take a reference to the dma buf object, import or export. (Imre Deak contributed this originally) v6: square the circle, remove import vs export tracking now that there is no difference Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-04-30drm: Kill user_modes list and the associated ioctlsVille Syrjälä
There is no way to use modes added to the user_modes list. We never look at the contents of said list in the kernel, and the only operations userspace can do are attach and detach. So the only "benefit" of this interface is wasting kernel memory. Fortunately it seems no real user space application ever used these ioctls. So just kill them. Also remove the prototypes for the non-existing drm_mode_addmode_ioctl() and drm_mode_rmmode_ioctl() functions. v2: Use drm_noop instead of completely removing the ioctls Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-04-30drm: Silence some sparse warningsVille Syrjälä
drivers/gpu/drm/drm_pci.c:155:5: warning: symbol 'drm_pci_set_busid' was not declared. Should it be static? drivers/gpu/drm/drm_pci.c:197:5: warning: symbol 'drm_pci_set_unique' was not declared. Should it be static? drivers/gpu/drm/drm_pci.c:269:5: warning: symbol 'drm_pci_agp_init' was not declared. Should it be static? drivers/gpu/drm/drm_crtc.c:181:1: warning: symbol 'drm_get_dirty_info_name' was not declared. Should it be static? drivers/gpu/drm/drm_crtc.c:1123:5: warning: symbol 'drm_mode_group_init' was not declared. Should it be static? drivers/gpu/drm/drm_modes.c:918:6: warning: symbol 'drm_mode_validate_clocks' was not declared. Should it be static? Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-04-26drm: Add drm_mode_equal_no_clocks()Ville Syrjälä
drm_mode_equal_no_clocks() is like drm_mode_equal() except it doesn't compare the clock or vrefresh values. drm_mode_equal() is now implemented by first doing the clock checks, and then calling drm_mode_equal_no_clocks(). v2: Add missing EXPORT_SYMBOL() Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-04-26drm: Remove explicit vrefresh initialization from DRM_MODE()Ville Syrjälä
No need to zero initialize .vrefresh in DRM_MODE() since it's using desgignated initializers. This will also avoid some duplicate initialization warnings later. Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-04-23drm: add drm_edid_to_eld helper extracting SADs from EDID (v2)Rafał Miłecki
Some devices (ATI/AMD cards) don't support passing ELD struct to the hardware but just require filling specific registers and then the hardware/firmware does the rest. In such cases we need to read the info from SAD blocks and put them in the correct registers. agd5f: note that the returned pointer needs to be kfreed as per Christian's suggestion. v2: fix warning Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-04-16Merge tag 'drm-intel-next-2013-04-06' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-next Daniel writes: Since I expect Linus to open the merge window in about a week I guess this is the last i915 feature pull for 3.10. Highlights: Updated testing tree for -next. Highlights: - Corner case fixes discovered with static analyzers (Damien). - More fixes to combat unclaimed register errors on Haswell (Paulo). - Some small fixes to the gpu turbo code (Rodrigo+Ben), Ben has more fixes for overclocking support pending. - More prep work for fastboot from Chris. - VT-switchless suspend/resume from Jesse. - The prep work of Egbert Eich's hpd irq storm handling. Hopefully we can squeeze in the actual storm handling code for 3.10 ... - More convenience helpers for Imre's sg iterator. Core parts acked by Andrew Morton. - A bit of backlight code cleanup from Jani. - Fixed ilk gpu reset (Jesse). - Reduced color range handling fixes for VLV (Ville). The big item here is though the introduction of pipe_config to properly pre-compute the desired modeset state before touching the hw. Together with some very basic support to read out the current config from the hw and compare the state with the sw tracking. This is all prep work for more reliable fastboot, atomic modesets and other cool features. Stuff converted to the new world includes: - Most simple pipe attributes (reduce color range, pixel multiplier). - Pipe bpp/dither handling. - Some convenience flags like ->has_pch_encoder to simplify the code flow. - (Almost) DP clock handling, had to be reverted since part of a prep patch was lost in rebasing ... Expect a lot of patches for this throughout 3.11, there's tons of work till we have all state properly tracked for fastbooting to woExpect a lot of patches for this throughout 3.11, there's tons of work till we have all state properly tracked for fastbooting to work. For 3.10 I have a bunch of fixes queued up and I plan to send them all out at the end of this week. I need to shuffle patches in my -next queue a bit so that we don't but feature-y stuff in there, too. The main thing I'd like to sneak in is Egbert's hpd irq storm handling, which should be pretty low-risk since all the infrastructure work has landed already. I also have the oops fix pending, but that only mustered review before the w/e and giving how hairy that part of our modeset code is, I want to give it some more testing before forwarding. Note: annarchy.fd.o seems to run out of disk space, so couldn't push the usual for-airlied branch. Tag should work though. Note 2: I've had to do a backmerge since conflicts grew too ugly, but the upstream -rc I've backmerged is already in your drm-next. * tag 'drm-intel-next-2013-04-06' of git://people.freedesktop.org/~danvet/drm-intel: (75 commits) drm/i915: info level for simulated gpu hang dmesg notice drm/i915: revert eDP bpp clamping code changes Revert "drm/i915: fix DP get_hw_state return value" drm/i915: Don't use the HDMI port color range bit on Valleyview drm/i915: Set PIPECONF color range bit on Valleyview drm/i915: extract i9xx_set_pipeconf drm/i915: Add no-lvds quirk for Fujitsu Esprimo Q900 drm/i915: create pipe_config->dpll for clock state drm/i915: hw readout support for ->has_pch_encoders drm/i915: add hw state readout/checking for pipe_config drm/i915: rip out superflous is_dp&is_cpu_edp tracking drm/i915: remove leaky eDP functions drm/i915: track dp target_clock in pipe_config drm/i915: move dp_m_n computation to dp_encoder->compute_config drm/i915: clear up the fdi/dp set_m_n confusion drm/i915: Fix sdvo connector get_hw_state function drm/i915: drop DPFLIPSTAT enables on VLV v3 drm/i915: add Punit read/write routines for VLV v2 drm/i915: panel power sequencing for VLV eDP v2 drm/i915/dp: fix up VLV DP handling v2 ...
2013-04-12drm: Misc comment cleanupChristopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-04-12ttm: export functions to allow qxl do its own iomappingDave Airlie
qxl wants to use io mapping like i915 gem does, for now just export the symbols so the driver can implement atomic page maps using io mapping. Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-04-12include/drm/drm_fb_helper.h: remove left over function declarationAlon Levy
Signed-off-by: Alon Levy <alevy@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-04-03Merge tag 'v3.9-rc5' into drm-intel-next-queuedDaniel Vetter
Backmerge Linux 3.9-rc5 since I want to merge a few dp clock cleanups for -next, but they will conflict all over the place with commit 9d1a455b0ca1c2c956b4d9ab212864a8695270f1 Author: Takashi Iwai <tiwai@suse.de> Date: Mon Mar 18 11:25:36 2013 +0100 drm/i915: Use the fixed pixel clock for eDP in intel_dp_set_m_n() from -fixes. Conflicts: drivers/gpu/drm/i915/intel_dp.c: Simply adjacent lines changed. drivers/gpu/drm/i915/intel_panel.c: A field rename in -next conflicts with a bugfix in -fixes. Take the version from -fixes and apply the rename. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-03-26drm: add initial_config function to fb helperJesse Barnes
Rather than building a config which may or may not work, let the driver build an initial fb config. This allows the driver to use the BIOS boot configuration for example, displaying kernel messages and the initial fb console on the same outputs the BIOS lit up at boot time. If that fails, the driver can still fall back the same way as the core. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: dri-devel@lists.freedesktop.org Acked-by: Dave Airlie <airlied@gmail.com> Reviewed-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-03-15drm/radeon: add Richland pci idsAlex Deucher
Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-03-08drm: Documentation typo fixesChristopher Harvey
2013-02-22drm: Add HDMI infoframe helpersThierry Reding
Add a generic helper to fill in an HDMI AVI infoframe with data extracted from a DRM display mode. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
2013-02-22drm: Add some missing forward declarationsThierry Reding
The drm_file and drm_clip_rect structures are used throughout the file but they are never declared nor pulled in through an include. Add forward declarations to make them available. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
2013-02-22drm: Remove duplicate drm_mode_cea_vic()Thierry Reding
The same function had already been merged with a different name. Remove the duplicate one but reuse some of its kerneldoc fragments for the existing implementation. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
2013-02-21Merge branch 'tilcdc-next' of git://people.freedesktop.org/~robclark/linux ↵Dave Airlie
into drm-next KMS driver for TI LCD controller * 'tilcdc-next' of git://people.freedesktop.org/~robclark/linux: drm/tilcdc: add support for LCD panels (v5) drm/tilcdc: add encoder slave (v2) drm/i2c: nxp-tda998x (v3) drm/tilcdc: add TI LCD Controller DRM driver (v4) drm/nouveau: use i2c encoder helper wrappers drm: i2c encoder helper wrappers drm/cma: add debugfs helpers drm: small fix in drm_send_vblank_event() drm: Don't set the plane->fb to NULL on successfull set_plane drm/cma-helper: fixup compilation Conflicts: drivers/gpu/drm/Kconfig drivers/gpu/drm/Makefile drivers/gpu/drm/drm_fb_cma_helper.c
2013-02-20Merge branch 'drm-intel-fixes' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-next So here's my promised pile of fixes for 3.9. I've dropped the core prep patches for vt-switchless suspend/resume as discussed on irc. Highlights: - Fix dmar on g4x. Not really gfx related, but I'm fed up with getting blamed for dmar crapouts. - Disable wc ptes updates on ilk when dmar is enabled (Chris). So again, dmar, but this time gfx related :( - Reduced range support for hsw, using the pipe CSC (Ville). - Fixup pll limits for gen3/4 (Patrick Jakobsson). The sdvo patch is already confirmed to fix 2 bug reports, so added cc: stable on that one. - Regression fix for 8bit fb console (Ville). - Preserve lane reversal bits on DDI/FDI ports (Damien). - Page flip vs. gpu hang fixes (Ville). Unfortuntely not quite all of them, need to decide what to do with the currently still in-flight ones. - Panel fitter regression fix from Mika Kuoppala (was accidentally left on on some pipes with the new modset code since 3.7). This also improves the modeset sequence and might help a few other unrelated issues with lvds. - Write backlight regs even harder ... another installement in our eternal fight against the BIOS and backlights. - Fixup lid notifier vs. suspend/resume races (Zhang Rui). Prep work for new ACPI stuff, but closing the race itself seems worthwile on its own. - A few other small fixes and tiny cleanups all over. Lots of the patches are cc: stable since I've stalled on a few not-so-important fixes for 3.8 due to the grumpy noise Linus made. * 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel: (33 commits) intel/iommu: force writebuffer-flush quirk on Gen 4 Chipsets drm/i915: Disable WC PTE updates to w/a buggy IOMMU on ILK drm/i915: Implement pipe CSC based limited range RGB output drm/i915: inverted brightness quirk for Acer Aspire 4736Z drm/i915: Print the hw context status is debugfs drm/i915: Use HAS_L3_GPU_CACHE in i915_gem_l3_remap drm/i915: Fix PIPE_CONTROL DW/QW write through global GTT on IVB+ drm/i915: Set i9xx sdvo clock limits according to specifications drm/i915: Set i9xx lvds clock limits according to specifications drm/i915: Preserve the DDI link reversal configuration drm/i915: Preserve the FDI line reversal override bit on CPT drm/i915: add missing \n to UTS_RELEASE in the error_state drm: Use C8 instead of RGB332 when determining the format from depth/bpp drm: Fill depth/bits_per_pixel for C8 format drm/i915: don't clflush gem objects in stolen memory drm/i915: Don't wait for page flips if there was GPU reset drm/i915: Kill obj->pending_flip drm/i915: Fix a typo in a intel_modeset_stage_output_state() comment drm/i915: remove bogus mutex_unlock from error-path drm/i915: Print the pipe control page GTT address ...
2013-02-17drm: i2c encoder helper wrappersRob Clark
Simplify life for drivers using an encoder-slave, so that they can make their drm_encoder_helper_funcs const, rather than needing to dynamically allocate and populate them. Signed-off-by: Rob Clark <robdclark@gmail.com>
2013-02-17drm/cma: add debugfs helpersRob Clark
Add helper to display fb's which can be used directly in drm_info_list: static struct drm_info_list foo_debugfs_list[] = { ... { "fb", drm_fb_cma_debugfs_show, 0 }, }; to display information about CMA fb objects, as well as a drm_gem_cma_describe() which can be used if the driver bothers to keep a list of CMA GEM objects. Signed-off-by: Rob Clark <robdclark@gmail.com>
2013-02-15drm/i915: Fix gen2 mappable calculationsBen Widawsky
When I refactored the code initially, I forgot that gen2 uses a different bar for the CPU mappable aperture. The agp-less code knows nothing of generations less than 5, so we have to expand the gtt_probe function to include the mappable base and end. It was originally broken by me: commit baa09f5fd8a6d033ec075355dda99a65b7f6a0f3 Author: Ben Widawsky <ben@bwidawsk.net> Date: Thu Jan 24 13:49:57 2013 -0800 drm/i915: Add probe and remove to the gtt ops Reported-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-14drm/fb-helper: remove unused members of struct drm_fb_helperDaniel Vetter
Spotted by Rob Clark. Reviewed-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-14drm/fb-helper: improve kerneldocDaniel Vetter
Now that the fbdev helper interface for drivers is trimmed down, update the kerneldoc for all the remaining exported functions. I've tried to beat the DocBook a bit by reordering the function references a bit into a more sensible ordering. But that didn't work out at all. Hence just extend the in-code DOC: section a bit. Also remove the LOCKING: sections - especially for the setup functions they're totally bogus. But that's not a documentation problem, but simply an artifact of the current rather hazardous locking around drm init and even more so around fbdev setup ... v2: Some further improvements: - Also add documentation for drm_fb_helper_single_add_all_connectors, Dave Airlie didn't want me to kill this one from the fb helper interface. - Update docs for drm_fb_helper_fill_var/fix - they should be used from the driver's ->fb_probe callback to setup the fbdev info structure. - Clarify what the ->fb_probe callback should all do - it needs to setup both the fbdev info and allocate the drm framebuffer used as backing storage. - Add basic documentaation for the drm_fb_helper_funcs driver callback vfunc. v3: Implement clarifications Laurent Pinchart suggested in his review. v4: Fix another mispelling Laurent spotted. Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-14drm/fb-helper: unexport drm_fb_helper_single_fb_probeDaniel Vetter
Not called by anyone, and really, shouldn't be. Drivers are supposed either drm_fb_helper_initial_config or drm_fb_helper_hotplug_event. Originally this was done differently, but is now consolidated in the helper functions and no longer done by drivers directly. Reviewed-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-14drm/fb-helper: kill drm_fb_helper_restoreDaniel Vetter
It's only used internally for the sysrq and panic handlers provided by the drm fb helper implementation. Hence just inline it, kill the export and remove the confusing kerneldoc. Driver's are supposed to call drm_fb_helper_restore_fbdev_mode on lastclose. Note that locking is totally fubar - the sysrq case doesn't take any locks at all. The panic handler probably shouldn't take any locks since it'll only make things worse. Otoh it's probably better to switch things over to the atomic modeset callbacks (and disable the panic handler for those drivers which don't implement it). But that's both better done in separate patches. Reviewed-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-14drm: review locking for drm_fb_helper_restore_fbdev_modeDaniel Vetter
... it's required. Fix up exynos and the cma helper, and add a corresponding WARN_ON to drm_fb_helper_restore_fbdev_mode. Note that tegra calls the fbdev cma helper restore function also from it's driver-load callback. Which is a bit against current practice, since usually the call is only from ->lastclose, and initial setup is done by drm_fb_helper_initial_config. Also add the relevant drm DocBook entry. v2: Add promised WARN to restore_fbdev_mode. Reviewed-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-08Merge branch 'for-airlied' of git://people.freedesktop.org/~mlankhorst/linux ↵Dave Airlie
into drm-next TTM reservations changes, preparing for new reservation mutex system. * 'for-airlied' of git://people.freedesktop.org/~mlankhorst/linux: drm/ttm: unexport ttm_bo_wait_unreserved drm/nouveau: use ttm_bo_reserve_slowpath in validate_init, v2 drm/ttm: use ttm_bo_reserve_slowpath_nolru in ttm_eu_reserve_buffers, v2 drm/ttm: add ttm_bo_reserve_slowpath drm/ttm: cleanup ttm_eu_reserve_buffers handling drm/ttm: remove lru_lock around ttm_bo_reserve drm/nouveau: increase reservation sequence every retry drm/vmwgfx: always use ttm_bo_is_reserved
2013-02-08drm: add prime helpersAaron Plattner
Instead of reimplementing all of the dma_buf functionality in every driver, create helpers drm_prime_import and drm_prime_export that implement them in terms of new, lower-level hook functions: gem_prime_pin: callback when a buffer is created, used to pin buffers into GTT gem_prime_get_sg_table: convert a drm_gem_object to an sg_table for export gem_prime_import_sg_table: convert an sg_table into a drm_gem_object gem_prime_vmap, gem_prime_vunmap: map and unmap an object These hooks are optional; drivers can opt in by using drm_gem_prime_import and drm_gem_prime_export as the .gem_prime_import and .gem_prime_export fields of struct drm_driver. v2: - Drop .begin_cpu_access. None of the drivers this code replaces implemented it. Having it here was a leftover from when I was trying to include i915 in this rework. - Use mutex_lock instead of mutex_lock_interruptible, as these three drivers did. This patch series shouldn't change that behavior. - Rename helpers to gem_prime_get_sg_table and gem_prime_import_sg_table. Rename struct sg_table* variables to 'sgt' for clarity. - Update drm.tmpl for these new hooks. v3: - Pass the vaddr down to the driver. This lets drivers that just call vunmap on the pointer avoid having to store the pointer in their GEM private structures. - Move documentation into a /** DOC */ comment in drm_prime.c and include it in drm.tmpl with a !P line. I tried to use !F lines to include documentation of the individual functions from drmP.h, but the docproc / kernel-doc scripts barf on that file, so hopefully this is good enough for now. - apply refcount fix from commit be8a42ae60addd8b6092535c11b42d099d6470ec ("drm/prime: drop reference on imported dma-buf come from gem") Signed-off-by: Aaron Plattner <aplattner@nvidia.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: David Airlie <airlied@linux.ie> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-02-08Merge branch 'drm-next-3.9' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-next Alex writes: - CS ioctl cleanup and unification. Unification of a lot of functionality that was duplicated across multiple generates of hardware. - Add support for Oland GPUs - Deprecate UMS support. Mesa and the ddx dropped support for UMS and apparently very few people still use it since the UMS CS ioctl was broken for several kernels and no one reported it. It was fixed in 3.8/stable. - Rework GPU reset. Use the status registers to determine what blocks to reset. This better matches the recommended reset programming model. This also allows us to properly reset blocks besides GFX and DMA. - Switch the VM set page code to use an IB rather than the ring. This fixes overflow issues when doing large page table updates using a small ring like DMA. - Several small cleanups and bug fixes. * 'drm-next-3.9' of git://people.freedesktop.org/~agd5f/linux: (38 commits) drm/radeon/dce6: fix display powergating drm/radeon: add Oland pci ids drm/radeon: radeon-asic updates for Oland drm/radeon: add ucode loading support for Oland drm/radeon: fill in gpu init for Oland drm/radeon: add Oland chip family drm/radeon: switch back to using the DMA ring for VM PT updates drm/radeon: use IBs for VM page table updates v2 drm/radeon: don't reset the MC on IGPs/APUs drm/radeon: use the reset mask to determine if rings are hung drm/radeon: halt engines before disabling MC (si) drm/radeon: halt engines before disabling MC (cayman/TN) drm/radeon: halt engines before disabling MC (evergreen) drm/radeon: halt engines before disabling MC (6xx/7xx) drm/radeon: use status regs to determine what to reset (si) drm/radeon: use status regs to determine what to reset (cayman) drm/radeon: use status regs to determine what to reset (evergreen) drm/radeon: use status regs to determine what to reset (6xx/7xx) drm/radeon: rework GPU reset on cayman/TN drm/radeon: rework GPU reset on cayman/TN ...
2013-02-08Merge tag 'of_videomode_helper' of git://git.pengutronix.de/git/str/linux ↵Dave Airlie
into drm-next videomode helpers for of + devicetree stuff, required for new kms drivers (not the fbdev maintainer). * tag 'of_videomode_helper' of git://git.pengutronix.de/git/str/linux: drm_modes: add of_videomode helpers drm_modes: add videomode helpers fbmon: add of_videomode helpers fbmon: add videomode helpers video: add of helper for display timings/videomode video: add display_timing and videomode viafb: rename display_timing to via_display_timing
2013-02-08Merge tag 'drm-intel-next-2013-02-01' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-next Daniel writes: "Probably the last feature pull for 3.9, there's some fixes outstanding thought that I'd like to sneak in. And maybe 3.8 takes a bit longer ... Anyway, highlights of this pull: - Kill the horrible IS_DISPLAYREG hack to handle the mmio offset movements on vlv, big thanks to Ville. - Dynamic power well support for Haswell, shaves away a bit when only using the eDP port on pipe A (Paulo). Plus unclaimed register fixes uncovered by this. - Clarifications of the gpu hang/reset state transitions, hopefully fixing a few spurious -EIO deaths in userspace. - Haswell ELD fixes. - Some more (pp)gtt cleanups from Ben. - A few smaller things all over. Plus all the stuff from the previous rather small pull request: - Broadcast RBG improvements and reduced color range fixes from Ville. - Ben is on a "kill legacy gtt code for good" spree, first pile of patches included. - No-relocs and bo lut improvements for faster execbuf from Chris. - Some refactorings from Imre." * tag 'drm-intel-next-2013-02-01' of git://people.freedesktop.org/~danvet/drm-intel: (101 commits) GPU/i915: Fix acpi_bus_get_device() check in drivers/gpu/drm/i915/intel_opregion.c drm/i915: Set the SR01 "screen off" bit in i915_redisable_vga() too drm/i915: Kill IS_DISPLAYREG() drm/i915: Introduce i915_vgacntrl_reg() drm/i915: gen6_gmch_remove can be static drm/i915: dynamic Haswell display power well support drm/i915: check the power down well on assert_pipe() drm/i915: don't send DP "idle" pattern before "normal" on HSW PORT_A drm/i915: don't run hsw power well code on !hsw drm/i915: kill cargo-culted locking from power well code drm/i915: Only run idle processing from i915_gem_retire_requests_worker drm/i915: Fix CAGF for HSW drm/i915: Reclaim GTT space for failed PPGTT drm/i915: remove intel_gtt structure drm/i915: Add probe and remove to the gtt ops drm/i915: extract hw ppgtt setup/cleanup code drm/i915: pte_encode is gen6+ drm/i915: vfuncs for ppgtt drm/i915: vfuncs for gtt_clear_range/insert_entries drm/i915: Error state should print /sys/kernel/debug ...
2013-02-01drm/radeon: add Oland pci idsAlex Deucher
2013-01-31drm/i915: remove intel_gtt structureBen Widawsky
With the probe call in our dispatch table, we can now cut away the last three remaining members in the intel_gtt shared struct and so remove it completely. v2: Rebased on top of Daniel's series Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Reviewed-by: Damien Lespiau <damien.lespiau@intel.com> [danvet: bikeshed commit message a bit.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-24drm_modes: add of_videomode helpersSteffen Trumtrar
Add helper to get drm_display_mode from devicetree. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Philipp Zabel <p.zabel@pengutronix.de> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Tested-by: Afzal Mohammed <Afzal@ti.com> Tested-by: Rob Clark <robclark@gmail.com> Tested-by: Leela Krishna Amudala <leelakrishna.a@gmail.com>
2013-01-24drm_modes: add videomode helpersSteffen Trumtrar
Add conversion from videomode to drm_display_mode Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Philipp Zabel <p.zabel@pengutronix.de> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Tested-by: Afzal Mohammed <Afzal@ti.com> Tested-by: Rob Clark <robclark@gmail.com> Tested-by: Leela Krishna Amudala <leelakrishna.a@gmail.com>
