path: root/include/dt-bindings/input
2015-10-16devicetree: bindings: Use linux-event-codes.h for evdev codesHans de Goede
Add a symlink to uapi/linux/linux-event-codes.h, and include that instead of (re)defining all the evdev type and code values in dt-bindings/input/input.h. This way we do not need to keep all the event codes synced manually. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-08-19Input: drv260x - add TI drv260x haptics driverDan Murphy
Add the TI drv260x haptics/vibrator driver. This device uses the input force feedback to produce a wave form to driver an ERM or LRA actuator device. The initial driver supports the devices real time playback mode. But the device has additional wave patterns in ROM. This functionality will be added in future patchsets. Product data sheet is located here: http://www.ti.com/product/drv2605 Signed-off-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-08-19include: dt-binding: input: create a DT header defining key codes.Laxman Dewangan
Many of Key device tree bindings uses the constant number as key code which matches with kernel header key code and then comment as follows for reference/better readability: linux,code = <102>; /* KEY_HOME */ Create a DT header which defines all the key code so that DT key bindings can use it as follows: linux,code = <KEY_HOME>; Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
