path: root/include/dt-bindings/pinctrl
2016-09-16pinctrl: dt-bindings: samsung: Add header with values used for configurationKrzysztof Kozlowski
Hard-coded pinctrl configuration values are scattered through DTS files. The numbers are difficult to decode by human, especially without the datasheet. Additionally the drive strength differs between S3C64xx, S5PV210 and Exynos SoC families increasing the confusion. The header will help making this more readable and maintainable. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2016-08-01Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "Device tree contents continue to be the largest branches we submit. This time around, some of the contents worth pointing out is: New SoC platforms: - Freescale i.MX 7Solo - Broadcom BCM23550 - Cirrus Logic EP7209 and EP7211 (clps711x platforms)_ - Hisilicon HI3519 - Renesas R8A7792 Some of the other delta that is sticking out, line-count wise: - Exynos moves of IP blocks under an SoC bus, which causes a large delta due to indentation changes - a new Tegra K1 board: Apalis - a bunch of small updates to many Allwinner platforms; new hardware support, some cleanup, etc" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits) ARM: dts: sun8i: Add dts file for inet86dz board ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04 ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts ARM: dts: sun5i: reference-design-tablet: Remove mention of q8 ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi ARM: dts: at91: Don't build unnecessary dtbs ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions ARM: dts: at91: at91sam9g25ek: fix isi endpoint node ARM: dts: at91: move isi definition to at91sam9g25ek ARM: dts: at91: fix i2c-gpio node name ARM: dts: at91: vinco: fix regulator name ARM: dts: at91: ariag25 : fix onewire node ...
2016-07-05includes: dt-bindings: Add STM32F746 pinctrl DT bindingsAlexandre TORGUE
Signed-off-by: Maxime Coquelin <mcoquelin.stm32@gmail.com> Signed-off-by: Alexandre TORGUE <alexandre.torgue@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-06-09ARM: dts: keystone: Header file for pinctrl constantsLokesh Vutla
The pinctrl IP used in some of the Keystone 2 devices differ vs other TI SoCs. Therefore, create a Keystone specific pinctrl header. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2016-04-15arm64: dts: add Hi6220 pinctrl configuration nodesZhong Kaihua
Add Hi6220 pinctrl configuration nodes Signed-off-by: Zhong Kaihua <zhongkaihua@huawei.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Haojian Zhuang <haojian.zhuang@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
2016-03-20Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Arnd Bergmann: "These are all the updates to device tree files for 32-bit platforms, plus a couple of related 64-bit updates: New SoC support: - Allwinner A83T - Axis Artpec-6 SoC - Mediatek MT7623 SoC - TI Keystone K2G SoC - ST Microelectronics stm32f469 New board or machine support: - ARM Juno R2 - Buffalo Linkstation LS-QVL and LS-GL - Cubietruck plus - D-Link DIR-885L - DT support for ARM RealView PB1176 and PB11MPCore - Google Nexus 7 - Homlet v2 - Itead Ibox - Lamobo R1 - LG Optimus Black - Logicpd dm3730 - Raspberry Pi Model A Other changes include - Lots of updates for Qualcomm APQ8064, MSM8974 and others - Improved support for Nokia N900 and other OMAP machines - Common clk support for lpc32xx - HDLCD display on ARM - Improved stm32f429 support - Improved Renesas device support, r8a779x and others - Lots of Rockchip updates - Samsung cleanups - ADC support for Atmel SAMA5D2 - BCM2835 (Raspberry Pi) improvements - Broadcom Northstar Plus enhancements - OMAP GPMC rework - Several improvements for Atmel SAMA5D2 / Xplained - Global change to remove inofficial "arm,amba-bus" compatible string" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (350 commits) ARM, ARM64: dts: drop "arm,amba-bus" in favor of "simple-bus" ARM: dts: artpec: dual-license on artpec6.dtsi ARM: dts: ux500: add synaptics RMI4 for Ux500 TVK DT arm64: dts: juno/vexpress: fix node name unit-address presence warnings arm64: dts: foundation-v8: add SBSA Generic Watchdog device node ARM: dts: at91: sama5d2 Xplained: add leds node ARM: dts: at91: sama5d2 Xplained: add user push button ARM: dts: at91: sama5d2 Xplained: set pin muxing for usb gadget and usb host ARM: dts: stm32f429: Enable Ethernet on Eval board ARM: dts: omap3-sniper: TWL4030 keypad support Revert "ARM: dts: DRA7: Add dt nodes for PWMSS" ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND ARM: dts: dm814x: dra62x: Fix NAND device nodes ARM: dts: stm32f429: Add Ethernet support ARM: dts: stm32f429: Add system config bank node ARM: dts: at91: sama5d2: add nand0 and nfc0 nodes ARM: dts: at91: sama5d2: add dma properties to UART nodes ARM: dts: at91: sama5d2 Xplained: Correct the macb irq pinctrl node ARM: dts: exynos: Don't overheat the Odroid XU3-Lite on high load ARM: dts: exynos: Add cooling levels for Exynos5422/5800 CPUs ...
2016-02-19pinctrl: mediatek: Modify pinctrl bindings for mt7623John Crispin
Signed-off-by: John Crispin <blogic@openwrt.org> Cc: devicetree@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-11includes: dt-bindings: Add STM32F429 pinctrl DT bindingsMaxime Coquelin
Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Maxime Coquelin <mcoquelin.stm32@gmail.com>
2015-12-31Merge tag 'omap-for-v4.5/81xx-dts-signed' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt Pull "reworked dts changes for ti81xx devices and minimal dra62x j5ec-evm support" from Tony Lindgren: Add minimal device tree support for dra62x also known j5eco. It is related to dm814x, just the clocks are a bit different and it has a different set of integrated devices. And let's get some basic dm814x and dra62x devices working as many of the devices are like on am33xx:: - pinctrl using the pinctrl defines as for am33xx - Updated EDMA bindings with support for using exma_xbar - MMC support for dm814x-evm, t410 and dra62x-j5eco-evm - USB support for dm814x-evm, t410 and dra62x-j5eco-evm This branch depends on an earlier omap-for-v4.5/81xx-fixes-signed branch that has dm814x dts fixes interlaced with SoC related fixes to keep things booting. The interlaced SoC and dts fixes were needed because of issues with the device tree defined clocks that just happened to work on bootloader timings for t410 earlier. * tag 'omap-for-v4.5/81xx-dts-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (21 commits) ARM: dts: Add usb support for j5-eco evm ARM: dts: Add usb support for hp t410 ARM: dts: Add usb support for dm814x-evm ARM: dts: Add usb support for dm814x and dra62x ARM: dts: Enable emmc on hp t410 ARM: dts: Add mmc support for dra62x j5-eco evm ARM: dts: Add mmc support for dm8148-evm ARM: dts: Add mmc device entries for dm814x ARM: dts: Update edma bindings on dm814x to use edma_xbar ARM: dts: Add pinctrl macros for dm814x ARM: dts: Add minimal dra62x j5-eco evm support ARM: dts: Add basic support for dra62x j5-eco SoC ARM: OMAP2+: Remove useless check for legacy booting for dm814x ARM: OMAP2+: Enable GPIO for dm814x ARM: dts: Fix dm814x pinctrl address and mask ARM: dts: Fix dm8148 control modules ranges ARM: OMAP2+: Fix timer entries for dm814x ARM: dts: Fix some mux and divider clocks to get dm814x-evm booting ARM: OMAP2+: Add DPPLS clock manager for dm814x clk: ti: Add few dm814x clock aliases ...
2015-12-22ARM: dts: Add pinctrl macros for dm814xTony Lindgren
Let's add the DM814X_IOPAD macro the same way as we have for dm816x and am33xx as this allows comparing the registers with the documentation easily. The pinctrl bits are yet again different on dm814x. Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-11-30pinctrl: Move am4372 and dra7 macros to the the SoC header filesJavier Martinez Canillas
The <dt-bindings/pinctrl/omap.h> header file defines a set of macros for different SoCs families that falls under the OMAP sub-arch, that allow to define the padconf register physical address instead of the register offset from the padconf base. But the am43xx and dra7xx SoCs families have their own pinctrl header file so the DTS using these SoCs aren't able to use the AM4372_IOPAD() and DRA7XX_CORE_IOPAD() macros since <dt-bindings/pinctrl/omap.h> is not included. Move the macros to the correct header files so can be used by the DTS. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-09-04Merge tag 'pinctrl-v4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "This is the bulk of pin control changes for the v4.3 development cycle. Like with GPIO it's a lot of stuff. If my subsystems are any sign of the overall tempo of the kernel v4.3 will be a gigantic diff. [ It looks like 4.3 is calmer than 4.2 in most other subsystems, but we'll see - Linus ] Core changes: - It is possible configure groups in debugfs. - Consolidation of chained IRQ handler install/remove replacing all call sites where irq_set_handler_data() and irq_set_chained_handler() were done in succession with a combined call to irq_set_chained_handler_and_data(). This series was created by Thomas Gleixner after the problem was observed by Russell King. - Tglx also made another series of patches switching __irq_set_handler_locked() for irq_set_handler_locked() which is way cleaner. - Tglx also wrote a good bunch of patches to make use of irq_desc_get_xxx() accessors and avoid looking up irq_descs from IRQ numbers. The goal is to get rid of the irq number from the handlers in the IRQ flow which is nice. Driver feature enhancements: - Power management support for the SiRF SoC Atlas 7. - Power down support for the Qualcomm driver. - Intel Cherryview and Baytrail: switch drivers to use raw spinlocks in IRQ handlers to play nice with the realtime patch set. - Rework and new modes handling for Qualcomm SPMI-MPP. - Pinconf power source config for SH PFC. New drivers and subdrivers: - A new driver for Conexant Digicolor CX92755. - A new driver for UniPhier PH1-LD4, PH1-Pro4, PH1-sLD8, PH1-Pro5, ProXtream2 and PH1-LD6b SoC pin control support. - Reverse-egineered the S/PDIF settings for the Allwinner sun4i driver. - Support for Qualcomm Technologies QDF2xxx ARM64 SoCs - A new Freescale i.mx6ul subdriver. Cleanup: - Remove platform data support in a number of SH PFC subdrivers" * tag 'pinctrl-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (95 commits) pinctrl: at91: fix null pointer dereference pinctrl: mediatek: Implement wake handler and suspend resume pinctrl: mediatek: Fix multiple registration issue. pinctrl: sh-pfc: r8a7794: add USB pin groups pinctrl: at91: Use generic irq_{request,release}_resources() pinctrl: cherryview: Use raw_spinlock for locking pinctrl: baytrail: Use raw_spinlock for locking pinctrl: imx6ul: Remove .owner field pinctrl: zynq: Fix typos in smc0_nand_grp and smc0_nor_grp pinctrl: sh-pfc: Implement pinconf power-source param for voltage switching clk: rockchip: add pclk_pd_pmu to the list of rk3288 critical clocks pinctrl: sun4i: add spdif to pin description. pinctrl: atlas7: clear ugly branch statements for pull and drivestrength pinctrl: baytrail: Serialize all register access pinctrl: baytrail: Drop FSF mailing address pinctrl: rockchip: only enable gpio clock when it setting pinctrl/mediatek: fix spelling mistake in dev_err error message pinctrl: cherryview: Serialize all register access pinctrl: UniPhier: PH1-Pro5: add I2C ch6 pin-mux setting pinctrl: nomadik: reflect current input value ...
2015-08-05ARM: dts: am43xx: Introduce MUX_MODE9 for pinctrlDave Gerlach
Some pins on AM43XX support MODE9 for the pinctrl settings so add a binding to describe this. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-07-17pinctrl: qcom: ssbi: Family A gpio & mpp driversBjorn Andersson
This introduces pinctrl drivers for gpio and mpp blocks found in family A PMICs. Tested-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-14pinctrl: dra: dt-bindings: Add virtual mode configuration optionNishanth Menon
In addition to the regular mux configuration such as mux mode 1, 2 etc, certain pins of DRA7 require to have "virtual mode" also programmed. This allows for predefined delay characteristics to be used by the SoC to meet timing characterstics needed for the interface. Provide easy to use macro to do the same. It is important to note that the official TI guidelines recommend to do as minimal pin reconfiguration beyond the bootloader given the design of the hardware involved which can result in substantial glitches which may impair functionality of certain peripherals. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-06-26Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Kevin Hilman: "As usual, quite a few device-tree updates in ARM land. There was one minor churn in DTs due to relicensing under a dual-license, and lots of little additions of new peripherals, features etc, but nothing really exciting to call to your attention. Some higlights, focsuing on support for new SoCs and boards: - AT91: new boards: Overkiz, Acme Systems' Arietta G25 - tegra: HDA support - bcm: new platforms: Buffalo WXR-1900DHP, SmartRG SR400ac, ASUS RT-AC87U - mvebu: new platforms: Compulab CM-A510, Armada 385-based Linksys boards, DLink DNS-327L - OMAP: new platforms: Baltos IR5221, LogicPD Torpedo, Toby-Churchill SL50 - ARM: added support for Juno r1 board - sunxi: A33 SoC support; new boards: A23 EVB, SinA33, GA10H-A33, Mele A1000G - imx: i.MX7D SoC support; new boards: Armadeus Systems APF6, Gateworks GW5510, and aristainetos2 boards - hisilicon: hi6220 SoC support; new boards: 96boards hikey" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (462 commits) ARM: hisi: revert changes from hisi/hip04-dt branch ARM: nomadik: set proper compatible for accelerometer ARM64: juno: add GPIO keys ARM: at91/dt: sama5d4: fix dma conf for aes, sha and tdes nodes ARM: dts: Introduce STM32F429 MCU ARM: socfpga: dts: enable ethernet for Arria10 devkit ARM: dts: k2l: fix the netcp range size ARM: dts: k2e: fix the netcp range size ARM: dts: k2hk: fix the netcp range size ARM: dts: k2l-evm: Add device bindings for netcp driver ARM: dts: k2e-evm: Add device bindings for netcp driver ARM: dts: k2hk-evm: Add device bindings for netcp driver ARM: BCM5301X: Add DT for Asus RT-AC87U ARM: BCM5301X: add IRQ numbers for PCIe controller ARM: BCM5301X: add NAND flash chip description arm64: dts: Add dts files for Hisilicon Hi6220 SoC clk: hi6220: Document devicetree bindings for hi6220 clock arm64: hi6220: Document devicetree bindings for Hisilicon hi6220 SoC ARM: at91/dt: sama5d4ek: mci0 uses slot 0 ARM: at91/dt: kizbox: fix mismatch LED PWM device ...
2015-05-28Merge tag 'omap-for-v4.2/dt-pt1' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt Merge "Device tree related changes for omaps" from Tony Lindgren: - Configure MMC data lines 4..8 for 1.8V IO on boards that are using them as GPIOs instead of MMC data lines - Add support for Baltos IR5221 - Add device tree support for LogicPD Torpedo devkit - Add 3717 core pinctrl region - Add gta04 1w and GSM audio support - Add wilink and ov2659 support for am437x-gp-evm - Add am335x-evm bluetooth and mmc3 support - Enable omap5-uevm uart wakeup interrupt - Enable I2C2 on BeagleBone as it's used for the capes - Use defines for LDP GPIO keys * tag 'omap-for-v4.2/dt-pt1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: dts: am335x-evm: add mmc3 and wlan definitions to dts ARM: dts: Enable SDIO card interrupt for 37xx-evm ARM: dts: Fix ldp gpio keys to use defines ARM: dts: Beaglebone i2c definitions ARM: dts: am437x-gp-evm: add DT nodes for ov2659 sensor ARM: dts: add DTS for Baltos IR5221 ARM: dts: omap5-uevm: Add Uart wakeup interrupt ARM: dts: omap3-gta04: Add GSM audio support ARM: dts: am335x-evm: add bluetooth support ARM: dts: am437x-gp-evm: add wilink8 support ARM: dts: omap3-gta04: Add hdqw1 support ARM: dts: add core2 padconf region for am3517 ARM: dts: Add minimal support for LogicPD Torpedo DM3730 devkit ARM: OMAP3: Add support for configuring MMC pins as GPIO pins
2015-05-20ARM: dts: am437x-gp-evm: add wilink8 supportEyal Reizer
enable mmc3 used for wlan and uart3 used for bluetooth configure the gpios used for wlan and bluetooth controls add fixed voltage regulator used for wlan power control Signed-off-by: Eyal Reizer <eyalr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-05-19pinctrl: mt6397: Add pinfunc header file for mt6397.Hongzhou Yang
Add pinfunc header file, mt8135/mt8173 relate dts will include it. Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-14ARM: bcm2835: dt: Add header file for pinctrl constantsStefan Wahren
This new header file defines pincontrol constants to use from bcm2835 DTS files for pincontrol properties option. Reviewed-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-04-14Merge tag 'pinctrl-v4.1-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pincontrol updates from Linus Walleij: "This is the bulk of pin control changes for the v4.1 development cycle. Nothing really exciting this time: we basically added a few new drivers and subdrivers and stabilized them in linux-next. Some cleanups too. With sunrisepoint Intel has a real fine fully featured pin control driver for contemporary hardware, and the AMD driver is also for large deployments. Most of the others are ARM devices. New drivers: - Intel Sunrisepoint - AMD KERNCZ GPIO - Broadcom Cygnus IOMUX New subdrivers: - Marvell MVEBU Armada 39x SoCs - Samsung Exynos 5433 - nVidia Tegra 210 - Mediatek MT8135 - Mediatek MT8173 - AMLogic Meson8b - Qualcomm PM8916 On top of this cleanups and development history for the above drivers as issues were fixed after merging" * tag 'pinctrl-v4.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (71 commits) pinctrl: sirf: move sgpio lock into state container pinctrl: Add support for PM8916 GPIO's and MPP's pinctrl: bcm2835: Fix support for threaded level triggered IRQs sh-pfc: r8a7790: add EtherAVB pin groups pinctrl: Document "function" + "pins" pinmux binding pinctrl: intel: Add Intel Sunrisepoint pin controller and GPIO support pinctrl: fsl: imx: Check for 0 config register pinctrl: Add support for Meson8b documentation: Extend pinctrl docs for Meson8b pinctrl: Cleanup Meson8 driver Fix inconsistent spinlock of AMD GPIO driver which can be recognized by static analysis tool smatch. Declare constant Variables with Sparse's suggestion. pinctrl: at91: convert __raw to endian agnostic IO pinctrl: constify of_device_id array pinctrl: pinconf-generic: add dt node names to error messages pinctrl: pinconf-generic: scan also referenced phandle node pinctrl: mvebu: add suspend/resume support to Armada XP pinctrl driver pinctrl: st: Display pin's function when printing pinctrl debug information pinctrl: st: Show correct pin direction also in GPIO mode pinctrl: st: Supply a GPIO get_direction() call-back pinctrl: st: Move st_get_pio_control() further up the source file ...
2015-04-08pinctrl: Add support for PM8916 GPIO's and MPP'sIvan T. Ivanov
Add compatible string definitions and supported pin functions. Signed-off-by: Ivan T. Ivanov <ivan.ivanov@linaro.org> Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-18pinctrl: mediatek: Add Pinctrl/GPIO driver for mt8135.Hongzhou Yang
The mediatek SoCs have GPIO controller that handle both the muxing and GPIOs. The GPIO controller have pinmux, pull enable, pull select, direction and output high/low control. This driver include common driver and mt8135 part. The common driver include the pinctrl driver and GPIO driver. The mt8135 part contain its special device data. Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-06ARM: dts: am43xx: fix SLEWCTRL_FAST pinctrl bindingDave Gerlach
According to AM437x TRM, Document SPRUHL7B, Revised December 2014, Section 7.2.1 Pad Control Registers, setting bit 19 of the pad control registers actually sets the SLEWCTRL value to slow rather than fast as the current macro indicates. Introduce a new macro, SLEWCTRL_SLOW, that sets the bit, and modify SLEWCTRL_FAST to 0 but keep it for completeness. Current users of the macro (i2c, mdio, and uart) are left unmodified as SLEWCTRL_FAST was the macro used and actual desired state. Tested on am437x-gp-evm with no difference in software performance seen. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-06ARM: dts: am33xx: fix SLEWCTRL_FAST pinctrl bindingDave Gerlach
According to AM335x TRM, Document spruh73l, Revised February 2015, Section 9.2.2 Pad Control Registers, setting bit 6 of the pad control registers actually sets the SLEWCTRL value to slow rather than fast as the current macro indicates. Introduce a new macro, SLEWCTRL_SLOW, that sets the bit, and modify SLEWCTRL_FAST to 0 but keep it for completeness. Current users of the macro (i2c and mdio) are left unmodified as SLEWCTRL_FAST was the macro used and actual desired state. Tested on am335x-gp-evm with no difference in software performance seen. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-01-26Merge tag 'sunxi-dt-for-3.20' of ↵Olof Johansson
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into next/dt Merge "Allwinner device tree changes for 3.20" from Maxime Ripard: A lot of changes to the device tree for the 3.20 merge window, mostly with: - More DT license convertions, only two DTS and two DTSI are still uncertain and have not been converted yet - Use the C-preprocessor includes in the device trees. - Add support for the A31s SoC and improve the A80 support - Add IR receiver, lradc, PS/2 support - Add cpufreq support for all SoCs but the A23 and A80. - And a lot of new boards * tag 'sunxi-dt-for-3.20' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux: (64 commits) ARM: dts: sun5i: Enable axp209 support on A13-OLinuxIno ARM: sunxi: dts: Add A10/A20 PS2 pin muxing options ARM: sunxi: dts: Add PS2 nodes to dtsi for A10,A20 ARM: dts: sun6i: Add resistive touchscreen controller node to dtsi ARM: dts: sun4i: Add Hyundau A7HD board ARM: dts: sun4i: Add Marsboard A10 board ARM: dts: sun9i: Enable mmc2 on A80 Optimus Board ARM: dts: sun9i: Add 8 bit mmc pinmux setting for mmc2 ARM: dts: sun9i: Enable mmc0 on A80 Optimus Board ARM: dts: sun9i: Convert a80 optimus board dts to label referencing ARM: dts: sun9i: Add mmc controller nodes to the A80 dtsi ARM: dts: sun9i: Add mmc config clock nodes ARM: dts: sunxi: Add missing mdio label ARM: dts: sun5i: Add mk802_a10s board ARM: dts: sun4i: Add mk802ii board ARM: dts: sun4i: Add mk802 board ARM: dts: sun4i: Add dts file for Chuwi V7 CW0825 tablet ARM: dts: sun7i: Add dts file for Bananapro board ARM: sun6i: Enable ARM arch timers ARM: dts: sun6i: Convert hummingbird a31 dts to label references ... Signed-off-by: Olof Johansson <olof@lixom.net>
2015-01-21ARM: sunxi: DT: Convert the DTs to use a header for the pinctrl nodesMaxime Ripard
The pinctrl nodes require some extra opaque arguments for the pull up and drive strength values. Introduce a new header file and convert the device trees to replace these opaque numbers by defines. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-19ARM: dts: Add minimal support for dm8168-evmTony Lindgren
This allows booting the device with basic functionality. Note that at least on my revision c board the DDR3 does not seem to work properly and only some of the memory can be reliably used. Also, the mainline u-boot does not seem to properly initialize the ethernet, so I've been using the old TI u-boot at: http://arago-project.org/git/projects/?p=u-boot-omap3.git;a=summary Cc: Brian Hutchinson <b.hutchman@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-12-11Merge tag 'pinctrl-v3.19-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control changes from Linus Walleij: "Here is a stash of pin control changes I have collected for the v3.19 series. Mainly new hardware support, with Intels new embedded SoC as the especially interesting thing standing out, fully using the subsystem. - Force conversion of the ux500 pin control device trees and parsers to use the generic pin control bindings. - New driver and device tree bindings for the Qualcomm PMIC MPP pin controller and GPIO. - Some ACPI infrastructure for pin controllers. - New driver for the Intel CherryView/Braswell pin controller, the first Intel pin controller to fully take advantage of the pin control subsystem. - Support the Freescale i.MX VF610 variant. - Support the sunxi A80 variant. - Support the Samsung Exynos 4415 and Exynos 7 variants. - Split out Intel pin controllers to their own subdirectory. - A large slew of rockchip pin control updates, including suspend/resume support. - A large slew of Samsung Exynos pin controller updates. - Various minor updates and fixes" * tag 'pinctrl-v3.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (49 commits) pinctrl: at91: enhance (debugfs) at91_gpio_dbg_show pinctrl: meson: add device tree bindings documentation gpio: tz1090: Fix error handling of irq_of_parse_and_map pinctrl: tz1090-pinctrl.txt: Fix typo in binding pinctrl: pinconf-generic: Declare dt_params/conf_items const pinctrl: exynos: Add support for Exynos4415 pinctrl: exynos: Add initial driver data for Exynos7 pinctrl: exynos: Add irq_chip instance for Exynos7 wakeup interrupts pinctrl: exynos: Consolidate irq domain callbacks pinctrl: exynos: Generalize the eint16_31 demux code pinctrl: samsung: Separate per-bank init and runtime data pinctrl: samsung: Constify samsung_pin_ctrl struct pinctrl: samsung: Constify samsung_pin_bank_type struct pinctrl: samsung: Drop unused label field in samsung_pin_ctrl struct pinctrl: samsung: Make samsung_pinctrl_get_soc_data use ERR_PTR() pinctrl: Add Intel Cherryview/Braswell pin controller support gpio / ACPI: Add knowledge about pin controllers to acpi_get_gpiod() pinctrl: Fix path error in documentation pinctrl: rockchip: save and restore gpio6_c6 pinmux in suspend/resume pinctrl: rockchip: add suspend/resume functions ...
2014-11-10pinctrl: dra: dt-bindings: Fix output pull up/downRoger Quadros
For PIN_OUTPUT_PULLUP and PIN_OUTPUT_PULLDOWN we must not set the PULL_DIS bit which disables the PULLs. PULL_ENA is a 0 and using it in an OR operation is a NOP, so don't use it in the PIN_OUTPUT_PULLUP/DOWN macros. Fixes: 23d9cec07c58 ("pinctrl: dra: dt-bindings: Fix pull enable/disable") Signed-off-by: Roger Quadros <rogerq@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-10-29pinctrl: Device tree bindings for Qualcomm PMIC MPP blockIvan T. Ivanov
DeviceTree binding documentation for Qualcomm SPMI PMIC MPP pinctrl drivers. Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com> Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-29pinctrl: Device tree bindings for Qualcomm PMIC GPIO blockBjorn Andersson
This introduced the device tree bindings for the GPIO block found in PMIC's from Qualcomm. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-05pinctrl: at91: add drive strength configurationMarek Roszko
The SAMA5 and SAM9x5 series both have drive strength options for the PIOs. This patch adds the ability to set one of three hardware options for drive strengths of low, medium or high for the each pin. The actual current output of the chip based on the setting is defined in the datasheets and varies per pins separate from banks and with supply voltage. This patch adds three new dt-bindings that allow setting the strength when configuring pins. By default, no change will be made to the drive strength of a pin from its reset value. Due to the difference between the register addresses of the SAMA5 and SAM9x5 series, a new sama5d3-pinctrl id was added. Signed-off-by: Marek Roszko <mark.roszko@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-28pinctrl: Add mux options 3 and 4 for rockchip pinctrlDoug Anderson
Newer Rockchip SoCs have more muxing slots. Add slots 3 and 4 since the rk3288 table goes all the way up to 4. Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-08Merge tag 'dt-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device-tree changes from Olof Johansson: "Unlike the board branch, this keeps having large sets of changes for every release, but that's quite expected and is so far working well. Most of this is plumbing for various device bindings and new platforms, but there's also a bit of cleanup and code removal for things that are moved from platform code to DT contents (some OMAP clock code in particular). There's also a pinctrl driver for tegra here (appropriately acked), that's introduced this way to make it more bisectable. I'm happy to say that there were no conflicts at all with this branch this release, which means that changes are flowing through our tree as expected instead of merged through driver maintainers (or at least not done with conflicts). There are several new boards added, and a couple of SoCs. In no particular order: - Rockchip RK3288 SoC support, including DTS for a dev board that they have seeded with some community developers. - Better support for Hardkernel Exynos4-based ODROID boards. - CCF conversions (and dtsi contents) for several Renesas platforms. - Gumstix Pepper (TI AM335x) board support - TI eval board support for AM437x - Allwinner A23 SoC, very similar to existing ones which mostly has resulted in DT changes for support. Also includes support for an Ippo tablet with the chipset. - Allwinner A31 Hummingbird board support, not to be confused with the SolidRun i.MX-based Hummingboard. - Tegra30 Apalis board support" * tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits) ARM: dts: Enable USB host0 (EHCI) on rk3288-evb ARM: dts: add rk3288 ehci usb devices ARM: dts: Turn on USB host vbus on rk3288-evb ARM: tegra: apalis t30: fix device tree compatible node ARM: tegra: paz00: Fix some indentation inconsistencies ARM: zynq: DT: Clarify Xilinx Zynq platform ARM: dts: rockchip: add watchdog node ARM: dts: rockchip: remove pinctrl setting from radxarock uart2 ARM: dts: Add missing pinctrl for uart0/1 for exynos3250 ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250 ARM: dts: Add TMU dt node to monitor the temperature for exynos3250 ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250 ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only ARM: dts: max77686 is exynos5250-snow only ARM: zynq: DT: Remove DMA from board DTs ARM: zynq: DT: Add CAN node ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table ARM: dts: Add PMU DT node for exynos5260 SoC ARM: EXYNOS: Add support for Exynos5410 PMU ARM: dts: Add PMU to exynos5410 ...
2014-07-23pinctrl: dra: dt-bindings: Fix pull enable/disableNishanth Menon
The DRA74/72 control module pins have a weak pull up and pull down. This is configured by bit offset 17. if BIT(17) is 1, a pull up is selected, else a pull down is selected. However, this pull resisstor is applied based on BIT(16) - PULLUDENABLE - if BIT(18) is *0*, then pull as defined in BIT(17) is applied, else no weak pulls are applied. We defined this in reverse. Reference: Table 18-5 (Description of the pad configuration register bits) in Technical Reference Manual Revision (DRA74x revision Q: SPRUHI2Q Revised June 2014 and DRA72x revision F: SPRUHP2F - Revised June 2014) Fixes: 6e58b8f1daaf1a ("ARM: dts: DRA7: Add the dts files for dra7 SoC and dra7-evm board") Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Felipe Balbi <balbi@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-11of: Add NVIDIA Tegra XUSB pad controller bindingThierry Reding
This patch adds the device tree binding documentation for the XUSB pad controller found on NVIDIA Tegra SoCs. It exposes both pinmuxing and PHY capabilities. Tested-by: Mikko Perttunen <mperttunen@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-06-02Merge tag 'dt-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC devicetree updates from Olof Johansson: "As with previous release, this continues to be among the largest branches we merge, with lots of new contents. New things for this release are among other things: - DTSI contents for the new SoCs supported in 3.16 (see SoC pull request) - Qualcomm APQ8064 and APQ8084 SoCs and eval boards - Nvidia Jetson TK1 development board (Tegra T124-based) Two new SoCs that didn't need enough new platform code to stand out enough for me to notice when writing the SoC tag, but that adds new DT contents are: - TI DRA72 - Marvell Berlin 2Q" * tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits) ARM: dts: add secure firmware support for exynos5420-arndale-octa ARM: dts: add pmu sysreg node to exynos3250 ARM: dts: correct the usb phy node in exynos5800-peach-pi ARM: dts: correct the usb phy node in exynos5420-peach-pit ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410 ARM: dts: add dts files for exynos3250 SoC ARM: dts: add mfc node for exynos5800 ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi ARM: dts: enable fimd for exynos5800-peach-pi ARM: dts: enable display controller for exynos5800-peach-pi ARM: dts: enable hdmi for exynos5800-peach-pi ARM: dts: add dts file for exynos5800-peach-pi board ARM: dts: add dts file for exynos5800 SoC ARM: dts: add dts file for exynos5260-xyref5260 board ARM: dts: add dts files for exynos5260 SoC ARM: dts: update watchdog node name in exynos5440 ARM: dts: use key code macros on Origen and Arndale boards ARM: dts: enable RTC and WDT nodes on Origen boards ARM: dts: qcom: Add APQ8084-MTP board support ARM: dts: qcom: Add APQ8084 SoC support ...
2014-05-19ARM: dts: Change IOPAD macro's for OMAP4/5Joachim Eastwood
The OMAP4/5 TRMs primarily list address offsets from the padconf physical address (which is not driver base address) and not always the absolute physical address for padconf registers like some other OMAP TRMs. So create a new macro to use this offset and to avoid confusion between different OMAP parts. For more information, see the tables in TRM for named something like "Device Core Control Module Pad Configuration Register Fields" and "Device Wake-Up Control Module Pad Configuration Register Fields" Note that we now also have to update cm-t54 for the fixed up offsets. Signed-off-by: Joachim Eastwood <manabian@gmail.com> [tony@atomide.com: updated comments, updated cm-t54] Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-06ARM: dts: Fix omap serial wake-up when booted with device treeTony Lindgren
We've had deeper idle states working on omaps for few years now, but only in the legacy mode. When booted with device tree, the wake-up events did not have a chance to work until commit 3e6cee1786a1 (pinctrl: single: Add support for wake-up interrupts) that recently got merged. In addition to that we also needed commit 79d9701559a9 (of/irq: create interrupts-extended property) and 9ec36cafe43b (of/irq: do irq resolution in platform_get_irq) that are now also merged. So let's fix the wake-up events for some selected omaps so devices booted in device tree mode won't just hang if deeper power states are enabled, and so systems can wake up from suspend to the serial port event. Note that there's no longer need to specify the wake-up bit in the pinctrl settings, the request_irq on the wake-up pin takes care of that. Cc: devicetree@vger.kernel.org Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Nishanth Menon <nm@ti.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Tero Kristo <t-kristo@ti.com> [tony@atomide.com: updated comments, added board LDP] Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-02pinctrl: am43xx: dt-bindings: add MUX_MODE8Darren Etheridge
AM43xx devices have an extra MUX_MODE for certain pins. Updating dt include to have MUX_MODE8 which maps to 0x8. Signed-off-by: Darren Etheridge <detheridge@ti.com> Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
2014-01-23Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "This branch is reducing in size for every release since most board-related changes have started happening in devicetrees now. Still, we have some things going on here. * Renesas platforms are still adding a bit more legacy device support, something that should trail off shortly as they move to full DT * We group most defconfig updates into this branch out of old habits * Removal of legacy OMAP2 platforms over to DT continues, and a handful of old code is being removed here" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: dts: OMAP2: fix interrupt number for rng ARM: dts: Split omap3 pinmux core device ARM: dts: Add omap specific pinctrl defines to use padconf addresses ARM: bcm2835: bcm2835_defconfig updates ARM: msm_defconfig: Enable restart driver defconfig: msm_defconfig: Enable CONFIG_ARCH_MSM8974 ARM: msm: Add support for APQ8074 Dragonboard ARM: exynos_defconfig: Enable S2MPS11 voltage regulator ARM: tegra: Enable DRM panel support ARM: shmobile: mackerel: Fix USBHS pinconf entry ARM: shmobile: Let Koelsch multiplatform boot with Koelsch DTB ARM: shmobile: Let Lager multiplatform boot with Lager DTB ARM: shmobile: Remove non-multiplatform Koelsch reference support ARM: shmobile: Remove non-multiplatform Lager reference support ARM: shmobile: koelsch-reference: Instantiate clkdevs for SCIF and CMT ARM: shmobile: lager-reference: Instantiate clkdevs for SCIF and CMT ARM: shmobile: koelsch-reference: Remove duplicate CCF initialization ARM: shmobile: lager-reference: Enable multiplaform kernel support ARM: shmobile: armadillo: Set backlight enable GPIO ARM: shmobile: Koelsch: add Ether support ... Conflicts: arch/arm/mach-omap2/omap_hwmod_2xxx_ipblock_data.c
2014-01-07ARM: dts: Add omap specific pinctrl defines to use padconf addressesTony Lindgren
As we have one to three pinctrl-single instances for each SoC it is a bit confusing to configure the padconf register offset from the base of the padconf register base. Let's add macros that allow using the physical address of the padconf register directly, or in most cases, just the last 16-bits of the address as they are shown in the documentation. Note that most documentation shows two padconf registers for each 32-bit address, so adding 2 to the documentation address is needed for the second padconf register as we treat them as 16-bit registers for omap3+. For example, omap36xx documentation shows sdmmc2_clk at 0x48002158, so we can just use the last 16-bits of that value: pinctrl-single,pins = < OMAP3_CORE1_IOPAD(0x2158, PIN_INPUT_PULLUP | MUX_MODE0) ... >; And we don't need to separately calculate the offset from the 0x2030 base: pinctrl-single,pins = < 0x128 (PIN_INPUT_PULLUP | MUX_MODE0) ... >; Naturally both ways of defining the registers can be used, and I'm not saying we should replace all the existing defines. But it may be handy to use these macros for new entries and when doing other related .dts file clean-up. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> [tony@atomide.com: updated for 3430 vs 3630 core2 range] Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-12-16ARM: tegra: Add header file for pinctrl constantsLaxman Dewangan
This new header file defines pincontrol constants for Tegra to use from Tegra's DTS file for pincontrol properties option. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-11-12Merge tag 'pinctrl-for-v3.13-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "Main pin control pull request for the v3.13 cycle. The changes hitting arch/blackfin are ACKed by the Blackfin maintainer, and the device tree bindings are ACKed to the extent possible by someone from the device tree maintainers group. - Blackfin ADI pin control driver, we move yet another architecture under this subsystem umbrella. - Incremental updates to the Renesas Super-H PFC pin control driver. New subdriver for the r8a7791 SoC. - Non-linear GPIO ranges from the gpiolib side of things, this enabled simplified device tree bindings by referring entire groups of pins on some pin controller to act as back-end for a certain GPIO-chip driver. - Add the Abilis TB10x pin control driver used on the ARC architecture. Also the corresponding GPIO driver is merged through this tree, so the ARC has full support for pins and GPIOs after this. - Subdrivers for Freescale i.MX1, i.MX27 and i.MX50 pin controller instances. The i.MX1 and i.MX27 is an entirely new family (silicon) of controllers whereas i.MX50 is a variant of the previous supported controller. - Then the usual slew of fixes, cleanups and incremental updates" The ARC DT changes are apparently still pending, that hopefully gets sorted out in a timely manner. * tag 'pinctrl-for-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (48 commits) pinctrl: imx50: add pinctrl support code for the IMX50 SoC pinctrl: at91: copy define to driver pinctrl: remove minor dead code pinctrl: imx: fix using pin->input_val wrongly pinctrl: imx1: fix return value check in imx1_pinctrl_core_probe() gpio: tb10x: fix return value check in tb10x_gpio_probe() gpio: tb10x: use module_platform_driver to simplify the code pinctrl: imx27: imx27 pincontrol driver pinctrl: imx1 core driver pinctrl: sh-pfc: r8a7791 PFC support sh-pfc: r8a7778: Add CAN pin groups gpio: add TB10x GPIO driver pinctrl: at91: correct a few typos pinctrl: mvebu: remove redundant of_match_ptr pinctrl: tb10x: use module_platform_driver to simplify the code pinctrl: tb10x: fix the error handling in tb10x_pinctrl_probe() pinctrl: add documentation for pinctrl_get_group_pins() pinctrl: rockchip: emulate both edge triggered interrupts pinctrl: rockchip: add rk3188 specifics pinctrl: rockchip: remove redundant check ...
2013-10-28Merge tag 'omap-for-v3.13/dt-late' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt Some more dts changes from Benoit Cousson <bcousson@baylibre.com> via Tony Lindgren: - Add a lot of N900 nodes - Add OPP table to OMAP5/DRA7 - Add support for Newflow NanoBone board - Add i2c aliases - Add McASP and audio support - Add reset/idle on init bindings for OMAP - Add more nodes for AM4272 * tag 'omap-for-v3.13/dt-late' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (42 commits) ARM: dts: omap5-uevm: Remove pinmux for dmic pins ARM: dts: omap5-uevm: Correct twl6040 reset GPIO pinmux ARM: dts: TWL4030: Add power button support ARM: dts: omap3-n900: Add LP5523 support ARM: dts: omap3-n900: Add TLV320AIC3X support ARM: dts: omap3-n900:: Mux RX51_LCD_RESET_GPIO in DTS ARM: dts: omap3-n900: Add NAND support ARM: dts: omap3-n900: Specify regulator info ARM: dts: TWL4030: Add missing regulators ARM: dts: omap3-n900: Add LP5523 support ARM: dts: omap3-n900: Add vibrator device ARM: dts: omap3-n900: GPIO key definitions ARM: dts: omap3-n900: Add support for SD cards ARM: dts: omap3-n900: Add UART support ARM: dts: omap3-n900: Fix i2c bus speed ARM: dts: omap3-n900: Add pinctrl for i2c devices ARM: dts: DRA7: Add CPU OPP table ARM: dts: OMAP5: Add CPU OPP table ARM: dts: dra7-evm: add smps123 supply for CPU ARM: dts: omap5-uevm: add smps123 supply for CPU ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-10-20ARM: dts: AM4372: Update Support for EPOS EVMMugunthan V N
-> Adding pinmux for cpsw, i2c0. -> Enabling the modules that are present in AM4372 EPOS EVM These modules are tested on AM4372 EPOS EVM. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
2013-10-14Merge branches 'omap-for-v3.13/dt' and 'omap-for-v3.13/quirk' into ↵Tony Lindgren
omap-for-v3.13/board-removal We need the fixes in v3.12-rc5, dts changes in omap-for-v3.13/dt, and the platform data quirk changes in omap-for-v3.13/quirk to start removing omap3 board files without breaking things.
2013-10-08ARM: dts: Fix pinctrl mask for omap3Tony Lindgren
The wake-up interrupt bit is available on omap3/4/5 processors unlike what we claim. Without fixing it we cannot use it on omap3 and the system configured for wake-up events will just hang on wake-up. Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Benoît Cousson <bcousson@baylibre.com> Cc: devicetree@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-10-08ARM: dts: DRA7: Add the dts files for dra7 SoC and dra7-evm boardR Sricharan
Add minimal device tree source needed for DRA7 based SoCs. Also add a board dts file for the dra7-evm (based on dra752) which contains 1.5G of memory with 1G interleaved and 512MB non-interleaved. Also added in the board file are pin configuration details for i2c, mcspi and uart devices on board. Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
