Strip some trailing spaces.
commit 339412841d7 (RxRPC: Allow key payloads to be passed in XDR form)
broke klog for me. I notice the v1 key struct had a kif_version field
added:
-struct rxkad_key {
- u16 security_index; /* RxRPC header security index */
- u16 ticket_len; /* length of ticket[] */
- u32 expiry; /* time at which expires */
- u32 kvno; /* key version number */
- u8 session_key[8]; /* DES session key */
- u8 ticket[0]; /* the encrypted ticket */
+struct rxrpc_key_data_v1 {
+ u32 kif_version; /* 1 */
+ u16 security_index;
+ u16 ticket_length;
+ u32 expiry; /* time_t */
+ u32 kvno;
+ u8 session_key[8];
+ u8 ticket[0];
However the code in rxrpc_instantiate strips it away:
data += sizeof(kver);
datalen -= sizeof(kver);
Removing kif_version fixes my problem.
Use uX rather than uintX_t types for consistency.
Parse RxRPC security index 5 type keys (Kerberos 5 tokens).
Allow add_key() and KEYCTL_INSTANTIATE to accept key payloads in XDR form as
described by openafs-1.4.10/src/auth/afs_token.xg. This provides a way of
passing kaserver, Kerberos 4, Kerberos 5 and GSSAPI keys from userspace, and
allows for future expansion.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Make request_key() and co fundamentally asynchronous to make it easier for
NFS to make use of them. There are now accessor functions that do
asynchronous constructions, a wait function to wait for construction to
complete, and a completion function for the key type to indicate completion
of construction.
Note that the construction queue is now gone. Instead, keys under
construction are linked in to the appropriate keyring in advance, and that
anyone encountering one must wait for it to be complete before they can use
it. This is done automatically for userspace.
The following auxiliary changes are also made:
(1) Key type implementation stuff is split from linux/key.h into
linux/key-type.h.
(2) AF_RXRPC provides a way to allocate null rxrpc-type keys so that AFS does
not need to call key_instantiate_and_link() directly.
(3) Adjust the debugging macros so that they're -Wformat checked even if
they are disabled, and make it so they can be enabled simply by defining
__KDEBUG to be consistent with other code of mine.
(3) Documentation.
[alan@lxorguk.ukuu.org.uk: keys: missing word in documentation]
Signed-off-by: Alan Cox <alan@redhat.com>
Provide AF_RXRPC sockets that can be used to talk to AFS servers, or serve
answers to AFS clients. KerberosIV security is fully supported. The patches
and some example test programs can be found in:
http://people.redhat.com/~dhowells/rxrpc/
This will eventually replace the old implementation of kernel-only RxRPC
currently resident in net/rxrpc/.
