Some devices have multiple bands enables in the EEPROM data, even though
they are only calibrated for one. Allow platform data to disable
unsupported bands.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
On some devices (especially little-endian ones), the flash EEPROM data
has a different endian, which needs to be detected.
Add a flag to the platform data to allow overriding that behavior
Add a new platform data flag "use_eeprom" that indicates that the eeprom
found on the card itself should be used instead of the one present in
the platform data.
This allows to override the MAC address of a PCI card while preserving
the eeprom data from the card itself.
The default behavior is preserved.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
The Buffalo device WZR-HP-G450H uses the index 3 for TX gain,
which is set to the high_power table currently. Later variants
of the router use the same index, but instead refer to the
low_ob_db gain table. This is not handled in the driver since
there is no way to distinguish board revisions and the high_power
table is used (incorrectly) for the newer variants.
By default, devices based on AR9300 using the TX gain index 3 have
to use the high_power table. To make sure that WZR-HP-G450H is not
broken when the high_power table is updated, use a separate array
based on information obtained from the platform data.
The current situation where only the original variant of WZR-HP-G450H
works properly stays unchanged.
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
The calibration data for devices w/o a separate
EEPROM chip can be specified via the 'eeprom_data'
field of 'ath9k_platform_data'. The 'eeprom_data'
is usually filled from board specific setup
functions. It is easy if the EEPROM data is mapped
to the memory, but it can be complicated if it is
stored elsewhere.
The patch adds support for loading of the EEPROM
data via the firmware API to avoid this limitation.
The patch adds a callback to ath9k_platform_data. If the
callback is provided by the platform code, then it can be
used to hard reset the WMAC device.
The callback is required for doing a hard reset of the AR9330
chips to get them working again after a hang.
The AR9330 1.0 and 1.1 are using the same revision,
thus it is not possible to distinguish the two chips.
The platform setup code can distinguish the chips based
on the SoC revision.
Add a callback function to ath9k_platform_data in order
to allow getting the revision number from the platform code.
Add a bool in ath9k_platform_data to pass AHB clock speed information.
Driver needs this to configure PLL on some SOCs.
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
On some devices the correct MAC address is not in the EEPROM data, but
stored somewhere else.
On the AR913x SOCs we have to provide EEPROM contents via platform_data,
because accessing the flash via MMIO is not safe. Additionally different
boards may store the radio calibration data at different locations.
Changes-licensed-under: ISC
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
Tested-by: Pavel Roskin <proski@gnu.org>
