path: root/include/linux/atm_tcp.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2008-05-14atm: Cleanup atm_tcp.h and atm.h for userspace.Mike Frysinger
The atm_tcp.h uses types from linux/atm.h, but does not include it. It should also use the standard __u## types from linux/types.h rather than the uint##_t types since the former can be found with the kernel already. Same goes for linux/atm.h. The linux/socket.h include there also gets dropped as atm.h does not actually use anything from socket.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
