path: root/include/linux/atmdev.h
2012-03-24Merge tag 'device-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/device.h> avoidance patches from Paul Gortmaker: "Nearly every subsystem has some kind of header with a proto like: void foo(struct device *dev); and yet there is no reason for most of these guys to care about the sub fields within the device struct. This allows us to significantly reduce the scope of headers including headers. For this instance, a reduction of about 40% is achieved by replacing the include with the simple fact that the device is some kind of a struct. Unlike the much larger module.h cleanup, this one is simply two commits. One to fix the implicit <linux/device.h> users, and then one to delete the device.h includes from the linux/include/ dir wherever possible." * tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: device.h: audit and cleanup users in main include dir device.h: cleanup users outside of linux/include (C files)
2012-03-16device.h: audit and cleanup users in main include dirPaul Gortmaker
The <linux/device.h> header includes a lot of stuff, and it in turn gets a lot of use just for the basic "struct device" which appears so often. Clean up the users as follows: 1) For those headers only needing "struct device" as a pointer in fcn args, replace the include with exactly that. 2) For headers not really using anything from device.h, simply delete the include altogether. 3) For headers relying on getting device.h implicitly before being included themselves, now explicitly include device.h 4) For files in which doing #1 or #2 uncovers an implicit dependency on some other header, fix by explicitly adding the required header(s). Any C files that were implicitly relying on device.h to be present have already been dealt with in advance. Total removals from #1 and #2: 51. Total additions coming from #3: 9. Total other implicit dependencies from #4: 7. As of 3.3-rc1, there were 110, so a net removal of 42 gives about a 38% reduction in device.h presence in include/* Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-03-04BUG: headers with BUG/BUG_ON etc. need linux/bug.hPaul Gortmaker
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any other BUG variant in a static inline (i.e. not in a #define) then that header really should be including <linux/bug.h> and not just expecting it to be implicitly present. We can make this change risk-free, since if the files using these headers didn't have exposure to linux/bug.h already, they would have been causing compile failures/warnings. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-11-26atm: eliminate atm_guess_pdu2truesize()chas williams - CONTRACTOR
Signed-off-by: Chas Williams - CONTRACTOR <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22atm: use SKB_TRUESIZE() in atm_guess_pdu2truesize()Eric Dumazet
SKB_TRUESIZE() provides a better approximation of expected skb truesize. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-30atm/solos-pci: Don't flap VCs when carrier state changesPhilip A. Prindeville
Don't flap VCs when carrier state changes; higher-level protocols can detect loss of connectivity and act accordingly. This is more consistent with how other network interfaces work. We no longer use release_vccs() so we can delete it. release_vccs() was duplicated from net/atm/common.c; make the corresponding function exported, since other code duplicates it and could leverage it if it were public. Signed-off-by: Philip A. Prindeville <philipp@redfish-solutions.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10atm: correct sysfs 'device' link creation and parent relationshipsDan Williams
The ATM subsystem was incorrectly creating the 'device' link for ATM nodes in sysfs. This led to incorrect device/parent relationships exposed by sysfs and udev. Instead of rolling the 'device' link by hand in the generic ATM code, pass each ATM driver's bus device down to the sysfs code and let sysfs do this stuff correctly. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-09atm: propagate signal changes via notifierKarl Hiramoto
Add notifier chain for changes in atm_dev. Clients like br2684 will call register_atmdevice_notifier() to be notified of changes. Drivers will call atm_dev_signal_change() to notify clients like br2684 of the change. On DSL and ATM devices it's usefull to have a know if you have a carrier signal. netdevice LOWER_UP changes can be propagated to userspace via netlink monitor. Signed-off-by: Karl Hiramoto <karl@hiramoto.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03atm: 32-bit ioctl compatibilityDavid Woodhouse
We lack compat ioctl support through most of the ATM code. This patch deals with most of it, and I can now at least use BR2684 and PPPoATM with 32-bit userspace. I haven't added a .compat_ioctl method to struct atm_ioctl, because AFAICT none of the current users need any conversion -- so we can just call the ->ioctl() method in every case. I looked at br2684, clip, lec, mpc, pppoatm and atmtcp. In svc_compat_ioctl() the only mangling which is needed is to change COMPAT_ATM_ADDPARTY to ATM_ADDPARTY. Although it's defined as _IOW('a', ATMIOC_SPECIAL+4,struct atm_iobuf) it doesn't actually _take_ a struct atm_iobuf as an argument -- it takes a struct sockaddr_atmsvc, which _is_ the same between 32-bit and 64-bit code, so doesn't need conversion. Almost all of vcc_ioctl() would have been identical, so I converted that into a core do_vcc_ioctl() function with an 'int compat' argument. I've done the same with atm_dev_ioctl(), where there _are_ a few differences, but still it's relatively contained and there would otherwise have been a lot of duplication. I haven't done any of the actual device-specific ioctls, although I've added a compat_ioctl method to struct atmdev_ops. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[ATM]: Convert struct class_device to struct deviceKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
2006-09-06[PATCH] Move linux/device.h include in linux/atmdev.h to #ifdef __KERNEL__ ↵Ismail Donmez
section linux/device.h header is not included in the David Woodhouse's kernel-headers git tree which is used for userspace kernel headers. Which results in compile errors when building iproute2. Attached patch moves linux/device.h include under the #ifdef __KERNEL__ section. Signed-off-by: Ismail Donmez <ismail@pardus.org.tr> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[ATM]: basic sysfs support for ATM devicesRoman Kagan
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-11-29[ATM]: deregistration removes device from atm_devs list immediatelyStanislaw Gruszka
atm_dev_deregister() removes device from atm_dev list immediately to prevent operations on a phantom device. Decision to free device based only on ->refcnt now. Remove shutdown_atm_dev() use atm_dev_deregister() instead. atm_dev_deregister() also asynchronously releases all vccs related to device. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[ATM]: linux/config.h only needed for #ifdef __KERNEL__ sectionChas Williams
2005-11-29[ATM]: atm_pcr_goal() doesn't modify its argument's contents -- mark it as constMitchell Blank Jr
Signed-off-by: Mitchell Blank Jr <mitch@sfgoth.com> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-06[ATM]: add support for LECS addresses learned from networkEric Kinzie
From: Eric Kinzie <ekinzie@cmf.nrl.navy.mil> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-04[ATM]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in atm code: net/atm/atm_misc.c:35:44: warning: implicit cast to nocast type drivers/atm/fore200e.c:183:33: warning: implicit cast to nocast type Also use kzalloc() instead of kmalloc(). Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
