[ Upstream commit 74843787158e9dff249f0528e7d4806102cc2c26 ]
Commit ecb89f2f5f3e7 ("mmc: atmel-mci: remove compat for non DT board
when requesting dma chan") broke dma on AVR32 and any other boards not
using DT. This restores a fallback mechanism for such cases.
Signed-off-by: Mans Rullgard <mans@mansr.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Add support for non-removable slots which have no card detection GPIO
and which should not be polled for a card change.
Signed-off-by: Timo Kokkonen <timo.kokkonen@offcode.fi>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
This patch adds an include of linux/types.h to make sure bool is defined
before utilized in this header file.
Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Homogenize namespace to atmci.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
Allow the use of another DMA controller driver in atmel-mci sd/mmc driver.
This adds a generic dma_slave pointer to the mci platform structure where
we can store DMA controller information. In atmel-mci we use information
provided by this structure to initialize the driver (with new helper
functions that are architecture dependant).
This also adds at32/avr32 chip modifications to cope with this new access
method.
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: <linux-mmc@vger.kernel.org>
Same patch as before, modified to use bool. Also adds description of
the new field in struct atmel_mci that I missed in the first patch.
This patch adds Atmel MCI support for inverted detect pins.
Signed-off-by: Jonas Larsson <jonas.larsson@martinsson.se>
Acked-by: Pierre Ossman <pierre@ossman.eu>
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (22 commits)
ioat: fix self test for multi-channel case
dmaengine: bump initcall level to arch_initcall
dmaengine: advertise all channels on a device to dma_filter_fn
dmaengine: use idr for registering dma device numbers
dmaengine: add a release for dma class devices and dependent infrastructure
ioat: do not perform removal actions at shutdown
iop-adma: enable module removal
iop-adma: kill debug BUG_ON
iop-adma: let devm do its job, don't duplicate free
dmaengine: kill enum dma_state_client
dmaengine: remove 'bigref' infrastructure
dmaengine: kill struct dma_client and supporting infrastructure
dmaengine: replace dma_async_client_register with dmaengine_get
atmel-mci: convert to dma_request_channel and down-level dma_slave
dmatest: convert to dma_request_channel
dmaengine: introduce dma_request_channel and private channels
net_dma: convert to dma_find_channel
dmaengine: provide a common 'issue_pending_all' implementation
dmaengine: centralize channel allocation, introduce dma_find_channel
dmaengine: up-level reference counting to the module level
Needed to use the atmel-mci driver in an architecture
independant maner.
