path: root/include/linux/atmel-pwm-bl.h
2008-07-24fbdev: LCD backlight driver using Atmel PWM driverHans-Christian Egtvedt
This patch adds a platform driver using the ATMEL PWM driver to control a backlight which requires a PWM signal and optional GPIO signal for discrete on/off signal. It has been tested on Favr-32 board from EarthLCD. The driver is configurable by supplying a struct with the platform data. See the include/linux/atmel-pwm-bl.h for details. The board code for Favr-32 will be submitted to the AVR32 kernel list. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
