path: root/include/linux/bcd.h
2012-09-10usb/core: use bin2bcd() for bcdDevice in RHSebastian Andrzej Siewior
The kernel's version number is used as decimal in the bcdDevice field of the RH descriptor. For kernel version v3.12 we would see 3.0c in lsusb. I am not sure how important it is to stick with bcd values since this is this way since we started git history and nobody complained (however back then we reported only 2.6). Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2008-10-20include/linux/bcd.h: remove commentsAdrian Bunk
- the macros are gone - there's no more code in this file, LGPL + GPL = GPL, and the code that was moved to lib/bcd.c is anyway trivial Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20remove the obsolete BCD*BIN/BIN*BCD macrosAdrian Bunk
Remove the following obsolete macros: - BCD2BIN - BIN2BCD - BCD_TO_BIN - BIN_TO_BCD Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: BCD codeshrinkDavid Brownell
This updates <linux/bcd.h> to define the key routines as constant functions, which the macros will then call. Newer code can now call bcd2bin() instead of SCREAMING BCD2BIN() TO THE FOUR WINDS. This lets each driver shrink their codespace by using N function calls to a single (global) copy of those routines, instead of N inlined copies of these functions per driver. These routines aren't used in speed-critical code. Almost all callers are in the RTC framework. Typical per-driver savings is near 300 bytes. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Adrian Bunk <bunk@kernel.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
