path: root/include/linux/bitmap.h
2009-08-21Make bitmask 'and' operators return a result codeLinus Torvalds
When 'and'ing two bitmasks (where 'andnot' is a variation on it), some cases want to know whether the result is the empty set or not. In particular, the TLB IPI sending code wants to do cpumask operations and determine if there are any CPU's left in the final set. So this just makes the bitmask (and cpumask) functions return a boolean for whether the result has any bits set. Cc: stable@kernel.org (2.6.30, needed by TLB shootdown fix) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-30bitmap: test for constant as well as small size for inline versionsRusty Russell
Impact: reduce text size bitmap_zero et al have a fastpath for nbits <= BITS_PER_LONG, but this should really only apply where the nbits is known at compile time. This only saves about 1200 bytes on an allyesconfig kernel, but with cpumasks going variable that number will increase. text data bss dec hex filename 35327852 5035607 6782976 47146435 2cf65c3 vmlinux-before 35326640 5035607 6782976 47145223 2cf6107 vmlinux-after Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-10-23Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: (47 commits) uwb: wrong sizeof argument in mac address compare uwb: don't use printk_ratelimit() so often uwb: use kcalloc where appropriate uwb: use time_after() when purging stale beacons uwb: add credits for the original developers of the UWB/WUSB/WLP subsystems uwb: add entries in the MAINTAINERS file uwb: depend on EXPERIMENTAL wusb: wusb-cbaf (CBA driver) sysfs ABI simplification uwb: document UWB and WUSB sysfs files uwb: add symlinks in sysfs between radio controllers and PALs uwb: dont tranmit identification IEs uwb: i1480/GUWA100U: fix firmware download issues uwb: i1480: remove MAC/PHY information checking function uwb: add Intel i1480 HWA to the UWB RC quirk table uwb: disable command/event filtering for D-Link DUB-1210 uwb: initialize the debug sub-system uwb: Fix handling IEs with empty IE data in uwb_est_get_size() wusb: fix bmRequestType for Abort RPipe request wusb: fix error path for wusb_set_dev_addr() wusb: add HWA host controller driver ...
2008-10-20bitmask: remove bitmap_scnprintf_len()Lai Jiangshan
bitmap_scnprintf_len() is not used now, so we remove it. Otherwise we have to maintain it and make its return value always equal to bitmap_scnprintf()'s return value. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-17bitmap: add bitmap_copy_le()David Vrabel
bitmap_copy_le() copies a bitmap, putting the bits into little-endian order (i.e., each unsigned long word in the bitmap is put into little-endian order). The UWB stack used bitmaps to manage Medium Access Slot availability, and these bitmaps need to be written to the hardware in LE order. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-08-12seq_file: add seq_cpumask(), seq_nodemask()Alexey Dobriyan
Short enough reads from /proc/irq/*/smp_affinity return -EINVAL for no good reason. This became noticed with NR_CPUS=4096 patches, when length of printed representation of cpumask becase 1152, but cat(1) continued to read with 1024-byte chunks. bitmap_scnprintf() in good faith fills buffer, returns 1023, check returns -EINVAL. Fix it by switching to seq_file, so handler will just fill buffer and doesn't care about offsets, length, filling EOF and all this crap. For that add seq_bitmap(), and wrappers around it -- seq_cpumask() and seq_nodemask(). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Reviewed-by: Paul Jackson <pj@sgi.com> Cc: Mike Travis <travis@sgi.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13cpumask: remove bitmap_scnprintf_len and cpumask_scnprintf_lenPaul Jackson
They aren't used. They were briefly used as part of some other patches to provide an alternative format for displaying some /proc and /sys cpumasks. They probably should have been removed when those other patches were dropped, in favor of a different solution. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: "Mike Travis" <travis@sgi.com> Cc: "Bert Wesarg" <bert.wesarg@googlemail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: add bitmap_onto() and bitmap_fold() operationsPaul Jackson
The following adds two more bitmap operators, bitmap_onto() and bitmap_fold(), with the usual cpumask and nodemask wrappers. The bitmap_onto() operator computes one bitmap relative to another. If the n-th bit in the origin mask is set, then the m-th bit of the destination mask will be set, where m is the position of the n-th set bit in the relative mask. The bitmap_fold() operator folds a bitmap into a second that has bit m set iff the input bitmap has some bit n set, where m == n mod sz, for the specified sz value. There are two substantive changes between this patch and its predecessor bitmap_relative: 1) Renamed bitmap_relative() to be bitmap_onto(). 2) Added bitmap_fold(). The essential motivation for bitmap_onto() is to provide a mechanism for converting a cpuset-relative CPU or Node mask to an absolute mask. Cpuset relative masks are written as if the current task were in a cpuset whose CPUs or Nodes were just the consecutive ones numbered 0..N-1, for some N. The bitmap_onto() operator is provided in anticipation of adding support for the first such cpuset relative mask, by the mbind() and set_mempolicy() system calls, using a planned flag of MPOL_F_RELATIVE_NODES. These bitmap operators (and their nodemask wrappers, in particular) will be used in code that converts the user specified cpuset relative memory policy to a specific system node numbered policy, given the current mems_allowed of the tasks cpuset. Such cpuset relative mempolicies will address two deficiencies of the existing interface between cpusets and mempolicies: 1) A task cannot at present reliably establish a cpuset relative mempolicy because there is an essential race condition, in that the tasks cpuset may be changed in between the time the task can query its cpuset placement, and the time the task can issue the applicable mbind or set_memplicy system call. 2) A task cannot at present establish what cpuset relative mempolicy it would like to have, if it is in a smaller cpuset than it might have mempolicy preferences for, because the existing interface only allows specifying mempolicies for nodes currently allowed by the cpuset. Cpuset relative mempolicies are useful for tasks that don't distinguish particularly between one CPU or Node and another, but only between how many of each are allowed, and the proper placement of threads and memory pages on the various CPUs and Nodes available. The motivation for the added bitmap_fold() can be seen in the following example. Let's say an application has specified some mempolicies that presume 16 memory nodes, including say a mempolicy that specified MPOL_F_RELATIVE_NODES (cpuset relative) nodes 12-15. Then lets say that application is crammed into a cpuset that only has 8 memory nodes, 0-7. If one just uses bitmap_onto(), this mempolicy, mapped to that cpuset, would ignore the requested relative nodes above 7, leaving it empty of nodes. That's not good; better to fold the higher nodes down, so that some nodes are included in the resulting mapped mempolicy. In this case, the mempolicy nodes 12-15 are taken modulo 8 (the weight of the mems_allowed of the confining cpuset), resulting in a mempolicy specifying nodes 4-7. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: <kosaki.motohiro@jp.fujitsu.com> Cc: <ray-lk@madrabbit.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19cpumask: add cpumask_scnprintf_len functionMike Travis
Add a new function cpumask_scnprintf_len() to return the number of characters needed to display "len" cpumask bits. The current method of allocating NR_CPUS bytes is incorrect as what's really needed is 9 characters per 32-bit word of cpumask bits (8 hex digits plus the seperator [','] or the terminating NULL.) This function provides the caller the means to allocate the correct string length. Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-19remove BITS_TO_TYPE macroJiri Slaby
remove BITS_TO_TYPE macro I realized, that it is actually the same as DIV_ROUND_UP, use it instead. [akpm@linux-foundation.org: build fix] Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-11[PATCH] bitmap: parse input from kernel and user buffersReinette Chatre
lib/bitmap.c:bitmap_parse() is a library function that received as input a user buffer. This seemed to have originated from the way the write_proc function of the /proc filesystem operates. This has been reworked to not use kmalloc and eliminates a lot of get_user() overhead by performing one access_ok before using __get_user(). We need to test if we are in kernel or user space (is_user) and access the buffer differently. We cannot use __get_user() to access kernel addresses in all cases, for example in architectures with separate address space for kernel and user. This function will be useful for other uses as well; for example, taking input for /sysfs instead of /proc, so it was changed to accept kernel buffers. We have this use for the Linux UWB project, as part as the upcoming bandwidth allocator code. Only a few routines used this function and they were changed too. Signed-off-by: Reinette Chatre <reinette.chatre@linux.intel.com> Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Cc: Paul Jackson <pj@sgi.com> Cc: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: Optimize bitmap_weight for small bitmapsAndi Kleen
Use inline code bitmaps <= BITS_PER_LONG in bitmap_weight. This gives _much_ better code. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] bitmap: region cleanupPaul Jackson
Paul Mundt <lethal@linux-sh.org> says: This patch set implements a number of patches to clean up and restructure the bitmap region code, in addition to extending the interface to support multiword spanning allocations. The current implementation (before this patch set) is limited by only being able to allocate pages <= BITS_PER_LONG, as noted by the strategically positioned BUG_ON() at lib/bitmap.c:752: /* We don't do regions of pages > BITS_PER_LONG. The * algorithm would be a simple look for multiple zeros in the * array, but there's no driver today that needs this. If you * trip this BUG(), you get to code it... */ BUG_ON(pages > BITS_PER_LONG); As I seem to have been the first person to trigger this, the result ends up being the following patch set with the help of Paul Jackson. The final patch in the series eliminates quite a bit of code duplication, so the bitmap code size ends up being smaller than the current implementation as an added bonus. After these are applied, it should already be possible to do multiword allocations with dma_alloc_coherent() out of ranges established by dma_declare_coherent_memory() on x86 without having to change any of the code, and the SH store queue API will follow up on this as the other user that needs support for this. This patch: Some code cleanup on the lib/bitmap.c bitmap_*_region() routines: * spacing * variable names * comments Has no change to code function. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] cpusets: bitmap and mask remap operatorsPaul Jackson
In the forthcoming task migration support, a key calculation will be mapping cpu and node numbers from the old set to the new set while preserving cpuset-relative offset. For example, if a task and its pages on nodes 8-11 are being migrated to nodes 24-27, then pages on node 9 (the 2nd node in the old set) should be moved to node 25 (the 2nd node in the new set.) As with other bitmap operations, the proper way to code this is to provide the underlying calculation in lib/bitmap.c, and then to provide the usual cpumask and nodemask wrappers. This patch provides that. These operations are termed 'remap' operations. Both remapping a single bit and a set of bits is supported. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
