path: root/include/linux/blk_types.h
2011-10-24block: Remove the control of complete cpu from bio.Tao Ma
bio originally has the functionality to set the complete cpu, but it is broken. Chirstoph said that "This code is unused, and from the all the discussions lately pretty obviously broken. The only thing keeping it serves is creating more confusion and possibly more bugs." And Jens replied with "We can kill bio_set_completion_cpu(). I'm fine with leaving cpu control to the request based drivers, they are the only ones that can toggle the setting anyway". So this patch tries to remove all the work of controling complete cpu from a bio. Cc: Shaohua Li <shaohua.li@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-08-23block: separate priority boosting from REQ_METAChristoph Hellwig
Add a new REQ_PRIO to let requests preempt others in the cfq I/O schedule, and lave REQ_META purely for marking requests as metadata in blktrace. All existing callers of REQ_META except for XFS are updated to also set REQ_PRIO for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-11Move some REQ flags to the common bio/request areaMatthew Wilcox
REQ_SECURE, REQ_FLUSH and REQ_FUA may all be set on a bio as well as on a request, so relocate them to the shared part of the enum. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Namhyung Kim <namhyung@gmail.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-20block: add REQ_SECURE to REQ_COMMON_MASKNamhyung Kim
Add REQ_SECURE flag to REQ_COMMON_MASK so that init_request_from_bio() can pass it to @req->cmd_flags. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@kernel.org # 2.6.36 and newer Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-20block: get rid of on-stack plugging debug checksJens Axboe
We don't need them anymore, so kill: - REQ_ON_PLUG checks in various places - !rq_mergeable() check in plug merging Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: initial patch for on-stack per-task pluggingJens Axboe
This patch adds support for creating a queuing context outside of the queue itself. This enables us to batch up pieces of IO before grabbing the block device queue lock and submitting them to the IO scheduler. The context is created on the stack of the process and assigned in the task structure, so that we can auto-unplug it if we hit a schedule event. The current queue plugging happens implicitly if IO is submitted to an empty device, yet callers have to remember to unplug that IO when they are going to wait for it. This is an ugly API and has caused bugs in the past. Additionally, it requires hacks in the vm (->sync_page() callback) to handle that logic. By switching to an explicit plugging scheme we make the API a lot nicer and can get rid of the ->sync_page() hack in the vm. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-25block: add REQ_FLUSH_SEQTejun Heo
rq == &q->flush_rq was used to determine whether a rq is part of a flush sequence, which worked because all requests in a flush sequence were sequenced using the single dedicated request. This is about to change, so introduce REQ_FLUSH_SEQ flag to distinguish flush sequence requests. This patch doesn't cause any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: remove REQ_HARDBARRIERChristoph Hellwig
REQ_HARDBARRIER is dead now, so remove the leftovers. What's left at this point is: - various checks inside the block layer. - sanity checks in bio based drivers. - now unused bio_empty_barrier helper. - Xen blockfront use of BLKIF_OP_WRITE_BARRIER - it's dead for a while, but Xen really needs to sort out it's barrier situaton. - setting of ordered tags in uas - dead code copied from old scsi drivers. - scsi different retry for barriers - it's dead and should have been removed when flushes were converted to FS requests. - blktrace handling of barriers - removed. Someone who knows blktrace better should add support for REQ_FLUSH and REQ_FUA, though. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-15block: Make the integrity mapped property a bio flagMartin K. Petersen
Previously we tracked whether the integrity metadata had been remapped using a request flag. This was fine for low-level retries. However, if an I/O was redriven by upper layers we would end up remapping again, causing the retry to fail. Deprecate the REQ_INTEGRITY flag and introduce BIO_MAPPED_INTEGRITY which enables filesystems to notify lower layers that the bio in question has already been remapped. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16blkio: Core implementation of throttle policyVivek Goyal
o Actual implementation of throttling policy in block layer. Currently it implements READ and WRITE bytes per second throttling logic. IOPS throttling comes in later patches. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: make __blk_rq_prep_clone() copy most command flagsTejun Heo
Currently __blk_rq_prep_clone() copies only REQ_WRITE and REQ_DISCARD. There's no reason to omit other command flags and REQ_FUA needs to be copied to implement FUA support in request-based dm. REQ_COMMON_MASK which specifies flags to be copied from bio to request already identifies all the command flags. Define REQ_CLONE_MASK to be the same as REQ_COMMON_MASK for clarity and make __blk_rq_prep_clone() copy all flags in the mask. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: implement REQ_FLUSH/FUA based interface for FLUSH/FUA requestsTejun Heo
Now that the backend conversion is complete, export sequenced FLUSH/FUA capability through REQ_FLUSH/FUA flags. REQ_FLUSH means the device cache should be flushed before executing the request. REQ_FUA means that the data in the request should be on non-volatile media on completion. Block layer will choose the correct way of implementing the semantics and execute it. The request may be passed to the device directly if the device can handle it; otherwise, it will be sequenced using one or more proxy requests. Devices will never see REQ_FLUSH and/or FUA which it doesn't support. Also, unlike the original REQ_HARDBARRIER, REQ_FLUSH/FUA requests are never failed with -EOPNOTSUPP. If the underlying device doesn't support FLUSH/FUA, the block layer simply make those noop. IOW, it no longer distinguishes between writeback cache which doesn't support cache flush and writethrough/no cache. Devices which have WB cache w/o flush are very difficult to come by these days and there's nothing much we can do anyway, so it doesn't make sense to require everyone to implement -EOPNOTSUPP handling. This will simplify filesystems and block drivers as they can drop -EOPNOTSUPP retry logic for barriers. * QUEUE_ORDERED_* are removed and QUEUE_FSEQ_* are moved into blk-flush.c. * REQ_FLUSH w/o data can also be directly passed to drivers without sequencing but some drivers assume that zero length requests don't have rq->bio which isn't true for these requests requiring the use of proxy requests. * REQ_COMMON_MASK now includes REQ_FLUSH | REQ_FUA so that they are copied from bio to request. * WRITE_BARRIER is marked deprecated and WRITE_FLUSH, WRITE_FUA and WRITE_FLUSH_FUA are added. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: drop barrier ordering by queue drainingTejun Heo
Filesystems will take all the responsibilities for ordering requests around commit writes and will only indicate how the commit writes themselves should be handled by block layers. This patch drops barrier ordering by queue draining from block layer. Ordering by draining implementation was somewhat invasive to request handling. List of notable changes follow. * Each queue has 1 bit color which is flipped on each barrier issue. This is used to track whether a given request is issued before the current barrier or not. REQ_ORDERED_COLOR flag and coloring implementation in __elv_add_request() are removed. * Requests which shouldn't be processed yet for draining were stalled by returning -EAGAIN from blk_do_ordered() according to the test result between blk_ordered_req_seq() and blk_blk_ordered_cur_seq(). This logic is removed. * Draining completion logic in elv_completed_request() removed. * All barrier sequence requests were queued to request queue and then trckled to lower layer according to progress and thus maintaining request orders during requeue was necessary. This is replaced by queueing the next request in the barrier sequence only after the current one is complete from blk_ordered_complete_seq(), which removes the need for multiple proxy requests in struct request_queue and the request sorting logic in the ELEVATOR_INSERT_REQUEUE path of elv_insert(). * As barriers no longer have ordering constraints, there's no need to dump the whole elevator onto the dispatch queue on each barrier. Insert barriers at the front instead. * If other barrier requests come to the front of the dispatch queue while one is already in progress, they are stored in q->pending_barriers and restored to dispatch queue one-by-one after each barrier completion from blk_ordered_complete_seq(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-12block: add secure discardAdrian Hunter
Secure discard is the same as discard except that all copies of the discarded sectors (perhaps created by garbage collection) must also be erased. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: Kyungmin Park <kmpark@infradead.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10block: make sure that REQ_* types are seen even with CONFIG_BLOCK=nJens Axboe
These form the basis of the basic WRITE etc primitives, so we need them to be always visible. Otherwise we see errors like: mm/filemap.c:2164: error: 'REQ_WRITE' undeclared fs/read_write.c:362: error: 'REQ_WRITE' undeclared fs/splice.c:1108: error: 'REQ_WRITE' undeclared fs/aio.c:1496: error: 'REQ_WRITE' undeclared Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07bio, fs: separate out bio_types.h and define READ/WRITE constants in terms ↵Tejun Heo
of BIO_RW_* flags linux/fs.h hard coded READ/WRITE constants which should match BIO_RW_* flags. This is fragile and caused breakage during BIO_RW_* flag rearrangement. The hardcoding is to avoid include dependency hell. Create linux/bio_types.h which contatins definitions for bio data structures and flags and include it from bio.h and fs.h, and make fs.h define all READ/WRITE related constants in terms of BIO_RW_* flags. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
