commit 5151412dd4338b273afdb107c3772528e9e67d92 upstream.
struct request_queue is allocated with __GFP_ZERO so its "node" field is
zero before initialization. This causes an oops if node 0 is offline in
the page allocator because its zonelists are not initialized. From Dave
Young's dmesg:
SRAT: Node 1 PXM 2 0-d0000000
SRAT: Node 1 PXM 2 100000000-330000000
SRAT: Node 0 PXM 1 330000000-630000000
Initmem setup node 1 0000000000000000-000000000affb000
Built 1 zonelists in Node order, mobility grouping on.
BUG: unable to handle kernel paging request at 0000000000001c08
IP: [<ffffffff8111c355>] __alloc_pages_nodemask+0xb5/0x870
and __alloc_pages_nodemask+0xb5 translates to a NULL pointer on
zonelist->_zonerefs.
The fix is to initialize q->node at the time of allocation so the correct
node is passed to the slab allocator later.
Since blk_init_allocated_queue_node() is no longer needed, merge it with
blk_init_allocated_queue().
[rientjes@google.com: changelog, initializing q->node]
Reported-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Tested-by: Dave Young <dyoung@redhat.com>
Change-Id: I24b14588aef6226f3bcdf37e78af61cbe9a31fd2
Reviewed-on: http://git-master/r/74168
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Cleaning up the code a little bit. attempt_plug_merge() traverses the plug
list anyway, we can do the request counting there, so stack size is reduced
a little bit.
The motivation here is I suspect if we should count the requests for each
queue (task could handle multiple disks in the meantime), but my test doesn't
show it's worthy doing. If somebody proves we should do it, below change
will make that more easier.
Signed-off-by: Shaohua Li <shli@kernel.org>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Commit ae1b1539622fb46e51b4d13b3f9e5f4c713f86ae, block: reimplement
FLUSH/FUA to support merge, introduced a performance regression when
running any sort of fsyncing workload using dm-multipath and certain
storage (in our case, an HP EVA). The test I ran was fs_mark, and it
dropped from ~800 files/sec on ext4 to ~100 files/sec. It turns out
that dm-multipath always advertised flush+fua support, and passed
commands on down the stack, where those flags used to get stripped off.
The above commit changed that behavior:
static inline struct request *__elv_next_request(struct request_queue *q)
struct request *rq;
while (1) {
- while (!list_empty(&q->queue_head)) {
+ if (!list_empty(&q->queue_head)) {
rq = list_entry_rq(q->queue_head.next);
- if (!(rq->cmd_flags & (REQ_FLUSH | REQ_FUA)) ||
- (rq->cmd_flags & REQ_FLUSH_SEQ))
- return rq;
- rq = blk_do_flush(q, rq);
- if (rq)
- return rq;
+ return rq;
Note that previously, a command would come in here, have
REQ_FLUSH|REQ_FUA set, and then get handed off to blk_do_flush:
struct request *blk_do_flush(struct request_queue *q, struct request *rq)
unsigned int fflags = q->flush_flags; /* may change, cache it */
bool has_flush = fflags & REQ_FLUSH, has_fua = fflags & REQ_FUA;
bool do_preflush = has_flush && (rq->cmd_flags & REQ_FLUSH);
bool do_postflush = has_flush && !has_fua && (rq->cmd_flags &
REQ_FUA);
unsigned skip = 0;
if (blk_rq_sectors(rq) && !do_preflush && !do_postflush) {
rq->cmd_flags &= ~REQ_FLUSH;
if (!has_fua)
rq->cmd_flags &= ~REQ_FUA;
return rq;
So, the flush machinery was bypassed in such cases (q->flush_flags == 0
&& rq->cmd_flags & (REQ_FLUSH|REQ_FUA)).
Now, however, we don't get into the flush machinery at all. Instead,
__elv_next_request just hands a request with flush and fua bits set to
the scsi_request_fn, even if the underlying request_queue does not
support flush or fua.
The agreed upon approach is to fix the flush machinery to allow
stacking. While this isn't used in practice (since there is only one
request-based dm target, and that target will now reflect the flush
flags of the underlying device), it does future-proof the solution, and
make it function as designed.
In order to make this work, I had to add a field to the struct request,
inside the flush structure (to store the original req->end_io). Shaohua
had suggested overloading the union with rb_node and completion_data,
but the completion data is used by device mapper and can also be used by
other drivers. So, I didn't see a way around the additional field.
I tested this patch on an HP EVA with both ext4 and xfs, and it recovers
the lost performance. Comments and other testers, as always, are
appreciated.
Cheers,
Jeff
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
This moves the FC classes bsg code to the block layer and
makes it a lib so that other classes like iscsi and SAS can use it.
It is helpful because working with the request queue, bios,
creating scatterlists, etc are a pain that the LLD does not
have to worry about with normal IOs and should not have to
worry about for bsg requests.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Some systems benefit from completions always being steered to the strict
requester cpu rather than the looser "per-socket" steering that
blk_cpu_to_group() attempts by default. This is because the first
CPU in the group mask ends up being completely overloaded with work,
while the others (including the original submitter) has power left
to spare.
Allow the strict mode to be set by writing '2' to the sysfs control
file. This is identical to the scheme used for the nomerges file,
where '2' is a more aggressive setting than just being turned on.
echo 2 > /sys/block/<bdev>/queue/rq_affinity
Cc: Roland Dreier <roland@purestorage.com>
Tested-by: Dave Jiang <dave.jiang@intel.com>
Reorder request_queue to remove 16 bytes of alignment padding in 64 bit
builds.
On my config this shrinks the size of this structure from 1608 to 1592
bytes and therefore needs one fewer cachelines.
Also trivially move the open bracket { to be on the same line as the
structure name to make it easier to grep.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
I'm often confused why not disable preempt when changing blk_plug list. It
would be better to add comments here in case others have the similar concerns.
When I test fio script with big I/O depth, I found the total throughput drops
compared to some relative small I/O depth. The reason is the thread accumulates
big requests in its plug list and causes some delays (surely this depends
on CPU speed).
I thought we'd better have a threshold for requests. When a threshold reaches,
this means there is no request merge and queue lock contention isn't severe
when pushing per-task requests to queue, so the main advantages of blk plug
don't exist. We can force a plug list flush in this case.
With this, my test throughput actually increases and almost equals to small
I/O depth. Another side effect is irq off time decreases in blk_flush_plug_list()
for big I/O depth.
The BLK_MAX_REQUEST_COUNT is choosen arbitarily, but 16 is efficiently to
reduce lock contention to me. But I'm open here, 32 is ok in my test too.
block/blk-throttle.c
block/cfq-iosched.c
There is not a function rq_init but blk_rq_init in block/blk-core.c.
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
Since those defined functions require additional semicolon
from the caller, they could cause potential syntax errors
when used in if-else statements.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Since for-2.6.40/core was forked off the 2.6.39 devel tree, we've
had churn in the core area that makes it difficult to handle
patches for eg cfq or blk-throttle. Instead of requiring that they
be based in older versions with bugs that have been fixed later
in the rc cycle, merge in 2.6.39 final.
Also fixes up conflicts in the below files.
drivers/block/paride/pcd.c
drivers/cdrom/viocd.c
drivers/ide/ide-cd.c
In some cases we would end up stacking discard_zeroes_data incorrectly.
Fix this by enabling the feature by default for stacking drivers and
clearing it for low-level drivers. Incorporating a device that does not
support dzd will then cause the feature to be disabled in the stacking
driver.
Also ensure that the maximum discard value does not overflow when
exported in sysfs and return 0 in the alignment and dzd fields for
devices that don't support discard.
Reported-by: Lukas Czerner <lczerner@redhat.com>
Acked-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@kernel.org
In some drives, flush requests are non-queueable. When flush request is
running, normal read/write requests can't run. If block layer dispatches
such request, driver can't handle it and requeue it. Tejun suggested we
can hold the queue when flush is running. This can avoid unnecessary
requeue. Also this can improve performance. For example, we have
request flush1, write1, flush 2. flush1 is dispatched, then queue is
hold, write1 isn't inserted to queue. After flush1 is finished, flush2
will be dispatched. Since disk cache is already clean, flush2 will be
finished very soon, so looks like flush2 is folded to flush1.
In my test, the queue holding completely solves a regression introduced by
commit 53d63e6b0dfb95882ec0219ba6bbd50cde423794:
block: make the flush insertion use the tail of the dispatch list
It's not a preempt type request, in fact we have to insert it
behind requests that do specify INSERT_FRONT.
which causes about 20% regression running a sysbench fileio
workload.
Stable: 2.6.39 only
flush request isn't queueable in some drives. Add a flag to let driver
notify block layer about this. We can optimize flush performance with the
knowledge.
Stable: 2.6.39 only
We are currently using this flag to check whether it's safe
to call into ->request_fn(). If it is set, we punt to kblockd.
But we get a lot of false positives and excessive punts to
kblockd, which hurts performance.
The only real abuser of this infrastructure is SCSI. So export
the async queue run and convert SCSI over to use that. There's
room for improvement in that SCSI need not always use the async
call, but this fixes our performance issue and they can fix that
up in due time.
Instead of overloading __blk_run_queue to force an offload to kblockd
add a new blk_run_queue_async helper to do it explicitly. I've kept
the blk_queue_stopped check for now, but I suspect it's not needed
as the check we do when the workqueue items runs should be enough.
MD can't use this since it really requires us to be able to
keep more than a single piece of state for the unplug. Commit
048c9374 added the required support for MD, so get rid of this
now unused code.
This reverts commit f75664570d8b75469cc468f23c2b27220984983b.
block/blk-core.c
md/raid requires an unplug callback, but as it does not uses
requests the current code cannot provide one.
So allow arbitrary callbacks to be attached to the blk_plug.
Signed-off-by: NeilBrown <neilb@suse.de>
Linus correctly observes that the most important dispatch cases
are now done from kblockd, this isn't ideal for latency reasons.
The original reason for switching dispatches out-of-line was to
avoid too deep a stack, so by _only_ letting the "accidental"
flush directly in schedule() be guarded by offload to kblockd,
we should be able to get the best of both worlds.
So add a blk_schedule_flush_plug() that offloads to kblockd,
and only use that from the schedule() path.
For the explicit unplugging, we'd prefer to kick things off
immediately and not pay the penalty of the latency to switch
to kblockd. So let blk_finish_plug() do the run inline, while
the implicit-on-schedule-out unplug will punt to kblockd.
It's a bit of a mess currently. task->plug is being cleared
and reset in __blk_finish_plug(), and blk_finish_plug() is
testing for a NULL plug which cannot happen even from schedule()
anymore since it uses blk_needs_flush_plug() to determine
whether to call into this function at all.
So get rid of some of the cruft.
MD would like to know when a queue is unplugged, so it can flush
it's bitmap writes. Add such a callback.
The current block integrity (DIF/DIX) support in DM is verifying that
all devices' integrity profiles match during DM device resume (which
is past the point of no return). To some degree that is unavoidable
(stacked DM devices force this late checking). But for most DM
devices (which aren't stacking on other DM devices) the ideal time to
verify all integrity profiles match is during table load.
Introduce the notion of an "initialized" integrity profile: a profile
that was blk_integrity_register()'d with a non-NULL 'blk_integrity'
template. Add blk_integrity_is_initialized() to allow checking if a
profile was initialized.
Update DM integrity support to:
- check all devices with _initialized_ integrity profiles match
during table load; uninitialized profiles (e.g. for underlying DM
device(s) of a stacked DM device) are ignored.
- disallow a table load that would result in an integrity profile that
conflicts with a DM device's existing (in-use) integrity profile
- avoid clearing an existing integrity profile
- validate all integrity profiles match during resume; but if they
don't all we can do is report the mismatch (during resume we're past
Cc: Martin K. Petersen <martin.petersen@oracle.com>
They used an older prototype, fix it up.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
block/blk-core.c
block/blk-flush.c
drivers/md/raid1.c
drivers/md/raid10.c
drivers/md/raid5.c
fs/nilfs2/btnode.c
fs/nilfs2/mdt.c
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
This patch adds support for creating a queuing context outside
of the queue itself. This enables us to batch up pieces of IO
before grabbing the block device queue lock and submitting them to
the IO scheduler.
The context is created on the stack of the process and assigned in
the task structure, so that we can auto-unplug it if we hit a schedule
event.
The current queue plugging happens implicitly if IO is submitted to
an empty device, yet callers have to remember to unplug that IO when
they are going to wait for it. This is an ugly API and has caused bugs
in the past. Additionally, it requires hacks in the vm (->sync_page()
callback) to handle that logic. By switching to an explicit plugging
scheme we make the API a lot nicer and can get rid of the ->sync_page()
hack in the vm.
Currently we use plugging for that, but as plugging is going away,
we need an alternative mechanism.
This merge creates two set of conflicts. One is simple context
conflicts caused by removal of throtl_scheduled_delayed_work() in
for-linus and removal of throtl_shutdown_timer_wq() in
for-2.6.39/core.
The other is caused by commit 255bb490c8 (block: blk-flush shouldn't
call directly into q->request_fn() __blk_run_queue()) in for-linus
crashing with FLUSH reimplementation in for-2.6.39/core. The conflict
isn't trivial but the resolution is straight-forward.
* __blk_run_queue() calls in flush_end_io() and flush_data_end_io()
should be called with @force_kblockd set to %true.
* elv_insert() in blk_kick_flush() should use
%ELEVATOR_INSERT_REQUEUE.
Both changes are to avoid invoking ->request_fn() directly from
request completion path and closely match the changes in the commit
255bb490c8.
Move blk_throtl_exit() in blk_cleanup_queue() as blk_throtl_exit() is
written in such a way that it needs queue lock. In blk_release_queue()
there is no gurantee that ->queue_lock is still around.
Initially blk_throtl_exit() was in blk_cleanup_queue() but Ingo reported
one problem.
https://lkml.org/lkml/2010/10/23/86
And a quick fix moved blk_throtl_exit() to blk_release_queue().
commit 7ad58c028652753814054f4e3ac58f925e7343f4
Author: Jens Axboe <jaxboe@fusionio.com>
Date: Sat Oct 23 20:40:26 2010 +0200
block: fix use-after-free bug in blk throttle code
This patch reverts above change and does not try to shutdown the
throtl work in blk_sync_queue(). By avoiding call to
throtl_shutdown_timer_wq() from blk_sync_queue(), we should also avoid
the problem reported by Ingo.
blk_sync_queue() seems to be used only by md driver and it seems to be
using it to make sure q->unplug_fn is not called as md registers its
own unplug functions and it is about to free up the data structures
used by unplug_fn(). Block throttle does not call back into unplug_fn()
or into md. So there is no need to cancel blk throttle work.
In fact I think cancelling block throttle work is bad because it might
happen that some bios are throttled and scheduled to be dispatched later
with the help of pending work and if work is cancelled, these bios might
never be dispatched.
Block layer also uses blk_sync_queue() during blk_cleanup_queue() and
blk_release_queue() time. That should be safe as we are also calling
blk_throtl_exit() which should make sure all the throttling related
data structures are cleaned up.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
__blk_run_queue() automatically either calls q->request_fn() directly
or schedules kblockd depending on whether the function is recursed.
blk-flush implementation needs to be able to explicitly choose
kblockd. Add @force_kblockd.
All the current users are converted to specify %false for the
parameter and this patch doesn't introduce any behavior change.
stable: This is prerequisite for fixing ide oops caused by the new
blk-flush implementation.
Cc: Jan Beulich <JBeulich@novell.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
block/cfq-iosched.c
o Dominik Klein reported a system hang issue while doing some blkio
throttling testing.
https://lkml.org/lkml/2011/2/24/173
o Some tracing revealed that CFQ was not dispatching any more jobs as
queue unplug was not happening. And queue unplug was not happening
because unplug work was not being called as there was one throttling
work on same cpu which as not finished yet. And throttling work had not
finished as it was tyring to dispatch a bio to CFQ but all the request
descriptors were consume to it was put to sleep.
o So basically it is a cyclic dependecny between CFQ unplug work and
throtl dispatch work. Tejun suggested that use separate workqueue for
such cases.
o This patch uses a separate workqueue for throttle related work and
does not rely on kblockd workqueue anymore.
Reported-by: Dominik Klein <dk@in-telegence.net>
Flush requests are never put on the IO scheduler. Convert request
structure's elevator_private* into an array and have the flush fields
share a union with it.
Reclaim the space lost in 'struct request' by moving 'completion_data'
back in the union with 'rb_node'.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
The current FLUSH/FUA support has evolved from the implementation
which had to perform queue draining. As such, sequencing is done
queue-wide one flush request after another. However, with the
draining requirement gone, there's no reason to keep the queue-wide
sequential approach.
This patch reimplements FLUSH/FUA support such that each FLUSH/FUA
request is sequenced individually. The actual FLUSH execution is
double buffered and whenever a request wants to execute one for either
PRE or POSTFLUSH, it queues on the pending queue. Once certain
conditions are met, a flush request is issued and on its completion
all pending requests proceed to the next sequence.
This allows arbitrary merging of different type of flushes. How they
are merged can be primarily controlled and tuned by adjusting the
above said 'conditions' used to determine when to issue the next
flush.
This is inspired by Darrick's patches to merge multiple zero-data
flushes which helps workloads with highly concurrent fsync requests.
* As flush requests are never put on the IO scheduler, request fields
used for flush share space with rq->rb_node. rq->completion_data is
moved out of the union. This increases the request size by one
pointer.
As rq->elevator_private* are used only by the iosched too, it is
possible to reduce the request size further. However, to do that,
we need to modify request allocation path such that iosched data is
not allocated for flush requests.
* FLUSH/FUA processing happens on insertion now instead of dispatch.
- Comments updated as per Vivek and Mike.
Cc: "Darrick J. Wong" <djwong@us.ibm.com>
Cc: Shaohua Li <shli@kernel.org>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Mike Snitzer <snitzer@redhat.com>
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits)
block: ensure that completion error gets properly traced
blktrace: add missing probe argument to block_bio_complete
block cfq: don't use atomic_t for cfq_group
block cfq: don't use atomic_t for cfq_queue
block: trace event block fix unassigned field
block: add internal hd part table references
block: fix accounting bug on cross partition merges
kref: add kref_test_and_get
bio-integrity: mark kintegrityd_wq highpri and CPU intensive
block: make kblockd_workqueue smarter
Revert "sd: implement sd_check_events()"
block: Clean up exit_io_context() source code.
Fix compile warnings due to missing removal of a 'ret' variable
fs/block: type signature of major_to_index(int) to major_to_index(unsigned)
block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p)
cfq-iosched: don't check cfqg in choose_service_tree()
fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors
cdrom: export cdrom_check_events()
sr: implement sr_check_events()
/proc/diskstats would display a strange output as follows.
$ cat /proc/diskstats |grep sda
8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089
8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691
8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390
8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92
8 4 sda4 4 0 8 0 0 0 0 0 0 0 0
8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137
Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is
merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE.
The detailed root cause is as follows.
Assuming that there are two partition, sda1 and sda2.
1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight
is 0 and sda2's one is 1.
sda1 | 0
sda2 | 1
2. A bio belongs to sda1 is issued and is merged into the request mentioned on
step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed
from sda2 region to sda1 region. However the two partition's
hd_struct->in_flight are not changed.
sda1 | 0
sda2 | 1
3. The request is finished and blk_account_io_done() is called. In this case,
sda2's hd_struct->in_flight, not a sda1's one, is decremented.
sda1 | -1
sda2 | 1
The patch fixes the problem by caching the partition lookup
inside the request structure, hence making sure that the increment
and decrement will always happen on the same partition struct. This
also speeds up IO with accounting enabled, since it cuts down on
the number of lookups we have to do.
Also add a refcount to struct hd_struct to keep the partition in
memory as long as users exist. We use kref_test_and_get() to ensure
we don't add a reference to a partition which is going away.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Implement blk_limits_max_hw_sectors() and make
blk_queue_max_hw_sectors() a wrapper around it.
DM needs this to avoid setting queue_limits' max_hw_sectors and
max_sectors directly. dm_set_device_limits() now leverages
blk_limits_max_hw_sectors() logic to establish the appropriate
max_hw_sectors minimum (PAGE_SIZE). Fixes issue where DM was
incorrectly setting max_sectors rather than max_hw_sectors (which
caused dm_merge_bvec()'s max_hw_sectors check to be ineffective).
When stacking devices, a request_queue is not always available. This
forced us to have a no_cluster flag in the queue_limits that could be
used as a carrier until the request_queue had been set up for a
metadevice.
There were several problems with that approach. First of all it was up
to the stacking device to remember to set queue flag after stacking had
completed. Also, the queue flag and the queue limits had to be kept in
sync at all times. We got that wrong, which could lead to us issuing
commands that went beyond the max scatterlist limit set by the driver.
The proper fix is to avoid having two flags for tracking the same thing.
We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the
block layer merging functions. The queue_limit 'no_cluster' is turned
into 'cluster' to avoid double negatives and to ease stacking.
Clustering defaults to being enabled as before. The queue flag logic is
removed from the stacking function, and explicitly setting the cluster
flag is no longer necessary in DM and MD.
Reported-by: Ed Lin <ed.lin@promise.com>
Currently, media presence polling for removeable block devices is done
from userland. There are several issues with this.
* Polling is done by periodically opening the device. For SCSI
devices, the command sequence generated by such action involves a
few different commands including TEST_UNIT_READY. This behavior,
while perfectly legal, is different from Windows which only issues
single command, GET_EVENT_STATUS_NOTIFICATION. Unfortunately, some
ATAPI devices lock up after being periodically queried such command
sequences.
* There is no reliable and unintrusive way for a userland program to
tell whether the target device is safe for media presence polling.
For example, polling for media presence during an on-going burning
session can make it fail. The polling program can avoid this by
opening the device with O_EXCL but then it risks making a valid
exclusive user of the device fail w/ -EBUSY.
* Userland polling is unnecessarily heavy and in-kernel implementation
is lighter and better coordinated (workqueue, timer slack).
This patch implements framework for in-kernel disk event handling,
which includes media presence polling.
* bdops->check_events() is added, which supercedes ->media_changed().
It should check whether there's any pending event and return if so.
Currently, two events are defined - DISK_EVENT_MEDIA_CHANGE and
DISK_EVENT_EJECT_REQUEST. ->check_events() is guaranteed not to be
called parallelly.
* gendisk->events and ->async_events are added. These should be
initialized by block driver before passing the device to add_disk().
The former contains the mask of all supported events and the latter
the mask of all events which the device can report without polling.
/sys/block/*/events[_async] export these to userland.
* Kernel parameter block.events_dfl_poll_msecs controls the system
polling interval (default is 0 which means disable) and
/sys/block/*/events_poll_msecs control polling intervals for
individual devices (default is -1 meaning use system setting). Note
that if a device can report all supported events asynchronously and
its polling interval isn't explicitly set, the device won't be
polled regardless of the system polling interval.
* If a device is opened exclusively with write access, event checking
is automatically disabled until all write exclusive accesses are
released.
* There are event 'clearing' events. For example, both of currently
defined events are cleared after the device has been successfully
opened. This information is passed to ->check_events() callback
using @clearing argument as a hint.
* Event checking is always performed from system_nrt_wq and timer
slack is set to 25% for polling.
* Nothing changes for drivers which implement ->media_changed() but
not ->check_events(). Going forward, all drivers will be converted
to ->check_events() and ->media_change() will be dropped.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Jan Kara <jack@suse.cz>
There's no reason for register_disk() and del_gendisk() to be in
fs/partitions/check.c. Move both to genhd.c. While at it, collapse
unlink_gendisk(), which was artificially in a separate function due to
genhd.c / check.c split, into del_gendisk().
REQ_HARDBARRIER is dead now, so remove the leftovers. What's left
at this point is:
- various checks inside the block layer.
- sanity checks in bio based drivers.
- now unused bio_empty_barrier helper.
- Xen blockfront use of BLKIF_OP_WRITE_BARRIER - it's dead for a while,
but Xen really needs to sort out it's barrier situaton.
- setting of ordered tags in uas - dead code copied from old scsi
drivers.
- scsi different retry for barriers - it's dead and should have been
removed when flushes were converted to FS requests.
- blktrace handling of barriers - removed. Someone who knows blktrace
better should add support for REQ_FLUSH and REQ_FUA, though.
fs/ext4/inode.c
fs/ext4/mballoc.c
include/trace/events/ext4.h
This is done the same way as helper sb_issue_discard for
blkdev_issue_discard.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
This reverts commit 7681bfeeccff5efa9eb29bf09249a3c400b15327.
include/linux/genhd.h
It has numerous issues with the cleanup path and non-elevator
devices. Revert it for now so we can come up with a clean
version without rushing things.
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits)
xen-blkfront: disable barrier/flush write support
Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c
block: remove BLKDEV_IFL_WAIT
aic7xxx_old: removed unused 'req' variable
block: remove the BH_Eopnotsupp flag
block: remove the BLKDEV_IFL_BARRIER flag
block: remove the WRITE_BARRIER flag
swap: do not send discards as barriers
fat: do not send discards as barriers
ext4: do not send discards as barriers
jbd2: replace barriers with explicit flush / FUA usage
jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier
jbd: replace barriers with explicit flush / FUA usage
nilfs2: replace barriers with explicit flush / FUA usage
reiserfs: replace barriers with explicit flush / FUA usage
gfs2: replace barriers with explicit flush / FUA usage
btrfs: replace barriers with explicit flush / FUA usage
xfs: replace barriers with explicit flush / FUA usage
block: pass gfp_mask and flags to sb_issue_discard
dm: convey that all flushes are processed as empty
sda1 | 0
sda2 | 1
sda1 | 0
sda2 | 1
sda1 | -1
sda2 | 1
When reloading partition tables, quiesce IO to ensure that no
request references to the partition struct exists. When it is safe
to free the partition table, the IO for that device is restarted
again.
Physical block size was declared unsigned int to accomodate the maximum
size reported by READ CAPACITY(16). Make sure we use the right type in
the related functions.
