path: root/include/linux/brcmphy.h
2010-06-24broadcom: Add 5241 supportDmitry Baryshkov
This patch adds the 5241 PHY ID to the broadcom module. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24broadcom: move all PHY_ID's to headerDmitry Baryshkov
Move all PHY IDs to brcmphy.h header for completeness and unification of code. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17tg3: Push phylib definitions to phylibMatt Carlson
This patch pushes phylib definitions out to phylib headers. For phy IDs, this removes some code duplication. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Optionally disable TXC if no linkMatt Carlson
This patch adds code to disable the TXC and RXC reference clocks if link is not available. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Add code to disable rxc refclkMatt Carlson
The 5785 does not use the RXC reference clock. Turning it off is desirable as it saves power. By default, the 50610 enables the RXC reference clock and the 50610M disables it. Presumably this is one of the reasons why the hardware architect chose one over the other. Adding a "rx reference clock disable" flag is not the ideal way to describe the option, as it would force the MAC using a 50610M to set the flag. Ideally we want the flags to represent opt-in behavior that deviates from hardware defaults. Furthermore, the lack of a "disable" flag implies that the requester wants the rx reference clock enabled, which doesn't necessarily follow. By presenting the option as a passive statement (rx reference clock unused) rather than a command, I hope to convey an opt-in option to disable the rx reference clock that falls back to hardware defaults if not set. A secondary benefit of this is that it keeps the intelligence about phy defaults in the broadcom module where it belongs and allows the broadcom module more latitude should a bug arise. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Add PHY_BRCM_CLEAR_RGMII_MODE flagMatt Carlson
Broadcom 50610M parts changed the default definitions of the RGMII mode shadow register. The 5785 needs the RGMII mode selection bits [4:3] cleared. The default value of the remaining bits in this register are zero. Rather than unnecessarily burn an extra bit in the dev_flags member in an attempt to enumerate all possible combinations, this patch take a more course grained approach and labels the option as "clear all bits". Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02broadcom: Consolidate dev_flags definitionsMatt Carlson
This patch moves all the dev_flags enumerations outside the broadcom.c file to include/linux/brcmphy.h. The existing flags were not used yet and have been re-enumerated to avoid conflicts. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-29tg3: Add shmem options.Matt Carlson
This patch adds some options obtained through shared memory. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
