Pull ARM SoC late changes from Olof Johansson:
"We were expecting to sit on this branch through most of the merge
window since the contents was merged into our tree late, but we ended
up sitting on all of our contents so it can go in with the rest.
The contents here is:
- a large branch of cleanups of the CM/PRM blocks on OMAP.
- a couple of patches plumbing up CM/PRM on OMAP5 and DRA7.
- a branch with DT updates for Freescale i.MX. including some
shuffling from .dts to .dtsi (include) files that causes a little
churn"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (78 commits)
ARM: OMAP2+: Fix booting with configs that don't have MFD_SYSCON
ARM: OMAP4+: control: add support for initializing control module via DT
ARM: dts: dra7: add minimal l4 bus layout with control module support
ARM: dts: omap5: add minimal l4 bus layout with control module support
ARM: OMAP4+: control: remove support for legacy pad read/write
ARM: OMAP4: display: convert display to use syscon for dsi muxing
ARM: dts: omap4: add minimal l4 bus layout with control module support
ARM: dts: am4372: add minimal l4 bus layout with control module support
ARM: dts: am43xx-epos-evm: fix pinmux node layout
ARM: dts: am33xx: add minimal l4 bus layout with control module support
ARM: dts: omap3: add minimal l4 bus layout with control module support
ARM: dts: omap24xx: add minimal l4 bus layout with control module support
ARM: OMAP2+: control: add syscon support for register accesses
ARM: OMAP2+: id: cache omap_type value
ARM: OMAP2+: control: remove API for getting control module base address
ARM: OMAP2+: clock: add low-level support for regmap
ARM: OMAP4+: PRM: get rid of cpu_is_omap44xx calls from interrupt init
ARM: OMAP4+: PRM: setup prm_features from the PRM init time flags
ARM: OMAP2+: CM: move SoC specific init calls within a generic API
ARM: OMAP4+: PRM: determine prm_device_inst based on DT compatibility
Pull ARM SoC multiplatform code changes from Olof Johansson:
"The changes here belong to two main platforms:
- Atmel At91 is flipping the bit and going multiplatform. This
includes some cleanups and removal of code, and the final flip of
config dependencies
- Shmobile has several platforms that are going multiplatform, but
this branch also contains a bunch of cleanups that they weren't
able to keep separate in a good way. THere's also a removal of one
of their SoCs and the corresponding boards (sh7372 and mackerel)"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
ARM: at91/pm: move AT91_MEMCTRL_* to pm.h
ARM: at91/pm: move the standby functions to pm.c
ARM: at91: fix pm_suspend.S compilation when ARMv6 is selected
ARM: at91: add a Kconfig dependency on multi-platform
ARM: at91: drop AT91_TIMER_HZ
ARM: at91: remove hardware.h
ARM: at91: remove SoC headers
ARM: at91: remove useless mach/cpu.h
ARM: at91: remove unused headers
ARM: at91: switch at91_dt_defconfig to multiplatform
ARM: at91: switch to multiplatform
ARM: shmobile: r8a7778: enable multiplatform target
ARM: shmobile: bockw: add sound to DT
ARM: shmobile: r8a7778: add sound to DT
ARM: shmobile: bockw: add devices hooked up to i2c0 to DT
DT: i2c: add trivial binding for OKI ML86V7667 video decoder
ARM: shmobile: r8a7778: common clock framework CPG driver
ARM: shmobile: bockw dts: set extal clock frequency
ARM: shmobile: bockw dts: Move Ethernet node to BSC
ARM: shmobile: r8a73a4: Remove legacy code
Change to using endian agnostic _relaxed IO accessors instead of __raw
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
CC: Andrew Victor <linux@maxim.org.za>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
CC: Mike Turquette <mturquette@linaro.org> (maintainer:COMMON CLK FRAMEWORK)
CC: Stephen Boyd <sboyd@codeaurora.org> (maintainer:COMMON CLK FRAMEWORK)
CC: linux-kernel@vger.kernel.org (open list:COMMON CLK FRAMEWORK)
Signed-off-by: Michael Turquette <mturquette@linaro.org>
Splits the clock related provider module inits under their own driver files.
Previously this was done for all modules under the common PRM driver.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
All clock provider related drivers will now register their iomaps
with a static index. This makes it easier to split up the individual
drivers to their own files in subsequent patches.
Driver for the r8a7778's clocks that depend on the mode bits.
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Michael Turquette <mturquette@linaro.org>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
The 'ARM: OMAP3: legacy clock data move under clk driver' patch series
causes build errors when CONFIG_OMAP3 is not set:
drivers/clk/ti/dpll.c: In function 'ti_clk_register_dpll':
drivers/clk/ti/dpll.c:199:31: error: 'omap3_dpll_ck_ops' undeclared (first use in this function)
const struct clk_ops *ops = &omap3_dpll_ck_ops;
drivers/clk/ti/dpll.c:199:31: note: each undeclared identifier is reported only once for each function it appears in
drivers/clk/ti/dpll.c:259:10: error: 'omap3_dpll_per_ck_ops' undeclared (first use in this function)
ops = &omap3_dpll_per_ck_ops;
drivers/built-in.o: In function `ti_clk_register_gate':
drivers/clk/ti/gate.c:179: undefined reference to `clkhwops_omap3430es2_dss_usbhost_wait'
drivers/clk/ti/gate.c:179: undefined reference to `clkhwops_am35xx_ipss_module_wait'
-in.o: In function `ti_clk_register_interface':
drivers/clk/ti/interface.c:100: undefined reference to `clkhwops_omap3430es2_iclk_hsotgusb_wait'
drivers/clk/ti/interface.c:100: undefined reference to `clkhwops_omap3430es2_iclk_dss_usbhost_wait'
drivers/clk/ti/interface.c:100: undefined reference to `clkhwops_omap3430es2_iclk_ssi_wait'
drivers/clk/ti/interface.c:100: undefined reference to `clkhwops_am35xx_ipss_wait'
drivers/built-in.o: In function `ti_clk_register_composite':
:(.text+0x3da768): undefined reference to `ti_clk_build_component_gate'
In order to fix that problem, this patch makes the omap3 legacy code
compiled only when both CONFIG_OMAP3 and CONFIG_ATAGS are set.
git://nv-tegra.nvidia.com/user/pdeschrijver/linux into clk-next
Tegra clock fixes for 3.20
Adds a way for clock consumers to set maximum and minimum rates. This
can be used for thermal drivers to set minimum rates, or by misc.
drivers to set maximum rates to assure a minimum performance level.
Changes the signature of the determine_rate callback by adding the
parameters min_rate and max_rate.
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[sboyd@codeaurora.org: set req_rate in __clk_init]
[mturquette@linaro.org: min/max rate for sun6i_ahb1_clk_determine_rate
migrated clk-private.h changes to clk.c]
arch/arm/mach-omap2/cclock3xxx_data.c
tegra_clocks_apply_init_table() needs to be called after the udelay
loop has been calibrated (see commit
441f199a37cfd66c5dd8dd45490bd3ea6971117d ("clk: tegra: defer
application of init table") for why that is). On existing Tegra SoCs
this was done by calling tegra_clocks_apply_init_table() from
tegra_dt_init(). To make this also work on ARM64, we need to change
this into an initcall. tegra_dt_init() is called from
customize_machine which is an arch_initcall. Therefore this should
also work on existing 32bit Tegra SoCs.
Tested on Tegra20 (ventana), Tegra30 (beaverboard), Tegra124 (jetson TK1) and
Tegra132.
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
[paul@pwsan.com: tweaked the commit message]
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Paul Walmsley <pwalmsley@nvidia.com>
Cc: Thierry Reding <treding@nvidia.com>
Cc: Prashant Gaikwad <pgaikwad@nvidia.com>
Cc: Mike Turquette <mturquette@linaro.org>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Alexandre Courbot <gnurou@gmail.com>
Introduces omap3 legacy clock data under clock driver. The clock data
is also in new format, which makes it possible to get rid of the
clk-private.h header. This patch also introduces SoC specific init
functions that shall be called from the low level init.
The data format used in this file has two possible evolution paths;
it can either be removed completely once no longer needed, or it will
be possible to retain the format and modify the TI clock driver to be
a loadable module at some point. The actual path to be followed
will be decided later.
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into clk-next
Allwinner clock changes for 3.20
The set of clock changes for the 3.20 merge window, with mostly:
- Some PLL fixes for the A80 and A31
- The MMC custom phase functions are removed, and moved over to the generic
phase API.
- Add the A80 MMC clocks
Some DT changes slipped here as well, to preserve bisectability.
These modules don't need to include clk-private.h. Replace the
include with clk.h because these modules are clock consumers and
also include clk-provider.h in clk/ti.h because struct
clk_hw_omap has a struct clk_hw embedded in it.
Cc: Tero Kristo <t-kristo@ti.com>
Cc: Tony Lindgren <tony@atomide.com>
Reviewed-by: Paul Walmsley <paul@pwsan.com>
Now that we don't have any user left for our custom phase function, we can
safely remove this hack from the code.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
Tested-by: Chen-Yu Tsai <wens@csie.org>
While the change for determine_rate clock operation was merged,
the OMAP counterpart using these calls was overlooked for some reason,
and caused boot failures on at least OMAP4 platforms. Fixed by updating
the DPLL API calls to use the new parameters.
Fixes: 646cafc6aa ("clk: Change clk_ops->determine_rate")
Cc: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Acked-by: Paul Walmsley <paul@pwsan.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
Reported-by: Kevin Hilman <khilman@linaro.org>
Expand the support of omap4 per-dpll to provide set_rate_and_parent.
This is required for proper behavior of clk_change_rate with
determine_rate support.
Similarly to OMAP3 noncore DPLL, the implementation of this DPLL clock
type is wrong. This patch adds basic functionality for determine_rate
for this clock type which will be taken into use in the patches following
later.
Currently, DPLL code hides the re-parenting within its internals, which
is wrong. This needs to be exposed to the common clock code via
determine_rate and set_rate_and_parent APIs. This patch adds support
for these, which will be taken into use in the following patches.
git://git.linaro.org/people/mike.turquette/linux
Pull clock tree updates from Mike Turquette:
"The clk tree changes for 3.18 are dominated by clock drivers. Mostly
fixes and enhancements to existing drivers as well as new drivers.
This tag contains a bit more arch code than I usually take due to some
OMAP2+ changes. Additionally it contains the restart notifier
handlers which are merged as a dependency into several trees.
The PXA changes are the only messy part. Due to having a stable tree
I had to revert one patch and follow up with one more fix near the tip
of this tag. Some dead code is introduced but it will soon become
live code after 3.18-rc1 is released as the rest of the PXA family is
converted over to the common clock framework.
Another trend in this tag is that multiple vendors have started to
push the complexity of changing their CPU frequency into the clock
driver, whereas this used to be done in CPUfreq drivers.
Changes to the clk core include a generic gpio-clock type and a
clk_set_phase() function added to the top-level clk.h api. Due to
some confusion on the fbdev mailing list the kernel boot parameters
documentation was updated to further explain the clk_ignore_unused
parameter, which is often required by users of the simplefb driver.
Finally some fixes to the locking around the clock debugfs stuff was
done to prevent deadlocks when interacting with other subsystems."
* tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits)
clk: pxa clocks build system fix
Revert "arm: pxa: Transition pxa27x to clk framework"
clk: samsung: register restart handlers for s3c2412 and s3c2443
clk: rockchip: add restart handler
clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate
doc/kernel-parameters.txt: clarify clk_ignore_unused
dts: add devicetree bindings for pxa27x clocks
clk: add pxa27x clock drivers
arm: pxa: add clock pll selection bits
clk: dts: document pxa clock binding
clk: add pxa clocks infrastructure
clk: gpio-gate: Ensure gpiod_ APIs are prototyped
clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe
clk: ti: LLVMLinux: Move __init outside of type definition
clk: ti: consider the fact that of_clk_get() might return an error
clk: ti: dra7-atl-clock: fix a memory leak
clk: ti: change clock init to use generic of_clk_init
clk: hix5hd2: add I2C clocks
clk: hix5hd2: add watchdog0 clocks
Previously, the TI clock driver initialized all the clocks hierarchically
under each separate clock provider node. Now, each clock that requires
IO access will instead check their parent node to find out which IO range
to use.
This patch allows the TI clock driver to use a few new features provided
by the generic of_clk_init, and also allows registration of clock nodes
outside the clock hierarchy (for example, any external clocks.)
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jyri Sarha <jsarha@ti.com>
Cc: Stefan Assmann <sassmann@kpanic.de>
Newer SoCs have two different AHB interconnect. The AHB 32 bits Matrix
interconnect (h32mx) has a clock that can be setup at the half of the h64mx
clock (which is mck). The h32mx clock can not exceed 90 MHz.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This patch adds helper functions to configure clock parents and rates
as specified through 'assigned-clock-parents', 'assigned-clock-rates'
DT properties for a clock provider or clock consumer device.
The helpers are now being called by the bus code for the platform, I2C
and SPI busses, before the driver probing and also in the clock core
after registration of a clock provider.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
clk-next
git://git.linaro.org/people/mike.turquette/linux into next
Pull clock framework updates from Mike Turquette:
"The clock framework changes for 3.16 are pretty typical: mostly clock
driver additions and fixes. There are additions to the clock core
code for some of the basic types (e.g. the common divider type has
some fixes and featured added to it).
One minor annoyance is a last-minute dependency that wasn't handled
quite right. Commit ba0fae3b06a6 ("clk: berlin: add core clock driver
for BG2/BG2CD") in this pull request depends on
include/dt-bindings/clock/berlin2.h, which is already in your tree via
the arm-soc pull request. Building for the berlin platform will break
when the clk tree is built on it's own, but merged into your master
branch everything should be fine"
* tag 'clk-for-linus-3.16' of git://git.linaro.org/people/mike.turquette/linux: (75 commits)
mmc: sunxi: Add driver for SD/MMC hosts found on Allwinner sunxi SoCs
clk: export __clk_round_rate for providers
clk: versatile: free icst on error return
clk: qcom: Return error pointers for unimplemented clocks
clk: qcom: Support msm8974pro global clock control hardware
clk: qcom: Properly support display clocks on msm8974
clk: qcom: Support display RCG clocks
clk: qcom: Return highest rate when round_rate() exceeds plan
clk: qcom: Fix mmcc-8974's PLL configurations
clk: qcom: Fix clk_rcg2_is_enabled() check
clk: berlin: add core clock driver for BG2Q
clk: berlin: add core clock driver for BG2/BG2CD
clk: berlin: add driver for BG2x complex divider cells
clk: berlin: add driver for BG2x simple PLLs
clk: berlin: add driver for BG2x audio/video PLL
clk: st: Terminate of match table
clk/exynos4: Fix compilation warning
ARM: shmobile: r8a7779: Add clock index macros for DT sources
clk: divider: Fix overflow in clk_divider_bestdiv
clk: u300: Terminate of match table
Duty Cycle Correction(DCC) needs to be enabled if the MPU is to run at
frequencies beyond 1.4GHz for OMAP5, DRA75x, DRA72x.
MPU DPLL has a limitation on the maximum frequency it can be locked
at. Duty Cycle Correction circuit is used to recover a correct duty
cycle for achieving higher frequencies (hardware internally switches
output to M3 output(CLKOUTHIF) from M2 output (CLKOUT)).
For further information, See the note on OMAP5432 Technical Reference
Manual(SWPU282U) chapter 3.6.3.3.1 "DPLLs Output Clocks Parameters",
and also the "OMAP543x ES2.0 DM Operating Conditions Addendum v0.5"
chapter 2.1 "Micro Processor Unit (MPU)". Equivalent information is
present in relevant DRA75x, 72x documentation(SPRUHP2E, SPRUHI2P).
Signed-off-by: Andrii Tseglytskyi <andrii.tseglytskyi@ti.com>
Signed-off-by: Taras Kondratiuk <taras@ti.com>
Signed-off-by: J Keerthy <j-keerthy@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
[t-kristo@ti.com: added TRM / DM references for DCC clock rate]
The clock and clkdev for this are added manually.
Adds support for registering the alias clocks, boot time clock-enable list
and disabling autoidle of clocks.
OMAP2430 I2CHS modules require specific hardware ops to be used, so added
a new compatible string for this.
This patch adds support for omap2 type aplls, which have gating and
autoidle functionality.
OMAP2 has slightly different DPLL compared to later OMAP generations.
This patch adds support for the ti,omap2-dpll-core-clock and also adds
the bindings documentation.
__clk_get_hw is supposed to be used by clk providers, not clk consumers.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
The R8A7779 SoC has several clocks that are too custom to be supported in a
generic driver. Those clocks are all fixed rate clocks with multiplier and
divisor set according to boot mode configuration.
Based on work for R-Car Gen2 SoCs by Laurent Pinchart.
Cc: devicetree@vger.kernel.org
AT91 slow clk is a clk multiplexer.
In some SoCs (sam9x5, sama5, sam9g45 families) this multiplexer can
choose among 2 sources: an internal RC oscillator circuit and an oscillator
using an external crystal.
In other Socs (sam9260 family) the multiplexer source is hardcoded with
the OSCSEL signal.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
HdG: add header exporting clk_sunxi_mmc_phase_control
Signed-off-by: Emilio López <emilio@elopez.com.ar>
Pull ARM SoC late cleanups from Arnd Bergmann:
"These could not be part of the first cleanup branch, because they
either came too late in the cycle, or they have dependencies on other
branches. Important changes are:
- The integrator platform is almost multiplatform capable after some
reorganization (Linus Walleij)
- Minor cleanups on Zynq (Michal Simek)
- Lots of changes for Exynos and other Samsung platforms, including
further preparations for multiplatform support and the clocks
bindings are rearranged"
* tag 'tags/cleanup2-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
devicetree: fix newly added exynos sata bindings
ARM: EXYNOS: Fix compilation error in cpuidle.c
ARM: S5P64X0: Explicitly include linux/serial_s3c.h in mach/pm-core.h
ARM: EXYNOS: Remove hardware.h file
ARM: SAMSUNG: Remove hardware.h inclusion
ARM: S3C24XX: Remove invalid code from hardware.h
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Keep some essential LDOs enabled for arndale-octa board
ARM: dts: Disable MDMA1 node for arndale-octa board
ARM: S3C64XX: Fix build for implicit serial_s3c.h inclusion
serial: s3c: Fix build of header without serial_core.h preinclusion
ARM: EXYNOS: Allow wake-up using GIC interrupts
ARM: EXYNOS: Stop using legacy Samsung PM code
ARM: EXYNOS: Remove PM initcalls and useless indirection
ARM: EXYNOS: Fix abuse of CONFIG_PM
ARM: SAMSUNG: Move s3c_pm_check_* prototypes to plat/pm-common.h
ARM: SAMSUNG: Move common save/restore helpers to separate file
ARM: SAMSUNG: Move Samsung PM debug code into separate file
ARM: SAMSUNG: Consolidate PM debug functions
ARM: SAMSUNG: Use debug_ll_addr() to get UART base address
If CLK_SET_RATE_PARENT is set for a clkoutx2 clock, calling
clk_set_rate() on the clock "skips" the x2 multiplier as there are no
set_rate and round_rate functions defined for the clkoutx2.
This results in getting double the requested clock rates, breaking the
display on omap3430 based devices. This got broken when
d0f58bd3bba3877fb1af4664c4e33273d36f00e4 and related patches were merged
for v3.14, as omapdss driver now relies more on the clk-framework and
CLK_SET_RATE_PARENT.
This patch implements set_rate and round_rate for clkoutx2.
Tested on OMAP3430, OMAP3630, OMAP4460.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-by: Tero Kristo <t-kristo@ti.com>
The clkc has its registers in the range of the slcr.
Instead of passing around the slcr base address pointer, let the clkc get the
address from the DT.
This prepares the slcr to be a real driver with multiple memory ranges
(slcr, clocks, pinctrl,...)
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Pull more clock framework changes from Mike Turquette:
"The second half of the clock framework pull requeust for 3.14 is
dominated by platform support for Qualcomm's MSM SoCs, DT binding
updates for TI's OMAP-ish processors and additional support for
Samsung chips.
Additionally there are other smaller clock driver changes and several
last minute fixes. This pull request also includes the HiSilicon
support that depends on the already-merged arm-soc pull request"
[ Fix up stupid compile error in the source tree with evil merge - Grumpy Linus ]
* tag 'clk-for-linus-3.14-part2' of git://git.linaro.org/people/mike.turquette/linux: (49 commits)
clk: sort Makefile
clk: sunxi: fix overflow when setting up divided factors
clk: Export more clk-provider functions
dt-bindings: qcom: Fix warning with duplicate dt define
clk: si5351: remove variant from platform_data
clk: samsung: Remove unneeded semicolon
clk: qcom: Fix modular build
ARM: OMAP3: use DT clock init if DT data is available
ARM: AM33xx: remove old clock data and link in new clock init code
ARM: AM43xx: Enable clock init
ARM: OMAP: DRA7: Enable clock init
ARM: OMAP4: remove old clock data and link in new clock init code
ARM: OMAP2+: io: use new clock init API
ARM: OMAP2+: PRM: add support for initializing PRCM clock modules from DT
ARM: OMAP3: hwmod: initialize clkdm from clkdm_name
ARM: OMAP: hwmod: fix an incorrect clk type cast with _get_clkdm
ARM: OMAP2+: clock: use driver API instead of direct memory read/write
ARM: OMAP2+: clock: add support for indexed memmaps
ARM: dts: am43xx clock data
ARM: dts: AM35xx: use DT clock data
clk-43xx.c now contains the clock init functionality for am43xx, including
DT clock registration and adding of static clkdev entries.
Tested-by: Nishanth Menon <nm@ti.com>
clk-3xxx.c now contains the clock init functionality for omap3, including
OMAP3 has interface clocks in addition to functional clocks, which
require special handling for the autoidle and idle status register
offsets mainly.
clk-33xx.c now contains the clock init functionality for am33xx, including
This patch also moves the omap2_clk_enable_init_clocks declaration to
the driver include, as this is needed by the am33xx clock init code.
clk-7xx.c now contains the clock init functionality for dra7, including
clk-54xx.c now contains the clock init functionality for omap5, including
clk-44xx.c now contains the clock init functionality for omap4, including
ti,mux-clock provides now a binding for basic mux support. This is just
using the basic clock type.
Some OMAP clocks require knowledge about their parent clockdomain for
book keeping purposes. This patch creates a new DT binding for TI
clockdomains, which act as a collection of device clocks. Clockdomain
itself is rather misleading name for the hardware functionality, as at
least on OMAP4 / OMAP5 / DRA7 the clockdomains can be collections of either
clocks and/or IP blocks, thus idle-domain or such might be more appropriate.
For most cases on these SoCs, the kernel doesn't even need the information
and the mappings can be ignored.
This patch adds support for TI specific gate clocks. These behave as basic
gate-clock, but have different ops / hw-ops for controlling the actual
gate, for example waiting until the clock is ready. Several sub-types
are supported:
- ti,gate-clock: basic gate clock with default ops/hwops
- ti,clkdm-gate-clock: clockdomain level gate control
- ti,dss-gate-clock: gate clock with DSS specific hardware handling
- ti,am35xx-gate-clock: gate clock with AM35xx specific hardware handling
- ti,hsdiv-gate-clock: gate clock with OMAP36xx hardware errata handling
This patch adds support for TI divider clock binding, which simply uses
the basic clock divider to provide the features needed.
