commit 6575820221f7a4dd6eadecf7bf83cdd154335eda upstream.
Currently, all workqueue cpu hotplug operations run off
CPU_PRI_WORKQUEUE which is higher than normal notifiers. This is to
ensure that workqueue is up and running while bringing up a CPU before
other notifiers try to use workqueue on the CPU.
Per-cpu workqueues are supposed to remain working and bound to the CPU
for normal CPU_DOWN_PREPARE notifiers. This holds mostly true even
with workqueue offlining running with higher priority because
workqueue CPU_DOWN_PREPARE only creates a bound trustee thread which
runs the per-cpu workqueue without concurrency management without
explicitly detaching the existing workers.
However, if the trustee needs to create new workers, it creates
unbound workers which may wander off to other CPUs while
CPU_DOWN_PREPARE notifiers are in progress. Furthermore, if the CPU
down is cancelled, the per-CPU workqueue may end up with workers which
aren't bound to the CPU.
While reliably reproducible with a convoluted artificial test-case
involving scheduling and flushing CPU burning work items from CPU down
notifiers, this isn't very likely to happen in the wild, and, even
when it happens, the effects are likely to be hidden by the following
successful CPU down.
Fix it by using different priorities for up and down notifiers - high
priority for up operations and low priority for down operations.
Workqueue cpu hotplug operations will soon go through further cleanup.
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/device.h> avoidance patches from Paul Gortmaker:
"Nearly every subsystem has some kind of header with a proto like:
void foo(struct device *dev);
and yet there is no reason for most of these guys to care about the
sub fields within the device struct. This allows us to significantly
reduce the scope of headers including headers. For this instance, a
reduction of about 40% is achieved by replacing the include with the
simple fact that the device is some kind of a struct.
Unlike the much larger module.h cleanup, this one is simply two
commits. One to fix the implicit <linux/device.h> users, and then one
to delete the device.h includes from the linux/include/ dir wherever
possible."
* tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
device.h: audit and cleanup users in main include dir
device.h: cleanup users outside of linux/include (C files)
The <linux/device.h> header includes a lot of stuff, and
it in turn gets a lot of use just for the basic "struct device"
which appears so often.
Clean up the users as follows:
1) For those headers only needing "struct device" as a pointer
in fcn args, replace the include with exactly that.
2) For headers not really using anything from device.h, simply
delete the include altogether.
3) For headers relying on getting device.h implicitly before
being included themselves, now explicitly include device.h
4) For files in which doing #1 or #2 uncovers an implicit
dependency on some other header, fix by explicitly adding
the required header(s).
Any C files that were implicitly relying on device.h to be
present have already been dealt with in advance.
Total removals from #1 and #2: 51. Total additions coming
from #3: 9. Total other implicit dependencies from #4: 7.
As of 3.3-rc1, there were 110, so a net removal of 42 gives
about a 38% reduction in device.h presence in include/*
This patch is based on Andi Kleen's work:
Implement autoprobing/loading of modules serving CPU
specific features (x86cpu autoloading).
And Kay Siever's work to get rid of sysdev cpu structures
and making use of struct device instead.
Before, the cpuid driver had to be loaded to get the x86cpu
autoloading feature. With this patch autoloading works through
the /sys/devices/system/cpu object
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Dave Jones <davej@redhat.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Acked-by: Andi Kleen <ak@linux.intel.com>
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits)
arm: fix up some samsung merge sysdev conversion problems
firmware: Fix an oops on reading fw_priv->fw in sysfs loading file
Drivers:hv: Fix a bug in vmbus_driver_unregister()
driver core: remove __must_check from device_create_file
debugfs: add missing #ifdef HAS_IOMEM
arm: time.h: remove device.h #include
driver-core: remove sysdev.h usage.
clockevents: remove sysdev.h
arm: convert sysdev_class to a regular subsystem
arm: leds: convert sysdev_class to a regular subsystem
kobject: remove kset_find_obj_hinted()
m86k: gpio - convert sysdev_class to a regular subsystem
mips: txx9_sram - convert sysdev_class to a regular subsystem
mips: 7segled - convert sysdev_class to a regular subsystem
sh: dma - convert sysdev_class to a regular subsystem
sh: intc - convert sysdev_class to a regular subsystem
power: suspend - convert sysdev_class to a regular subsystem
power: qe_ic - convert sysdev_class to a regular subsystem
power: cmm - convert sysdev_class to a regular subsystem
s390: time - convert sysdev_class to a regular subsystem
Fix up conflicts with 'struct sysdev' removal from various platform
drivers that got changed:
- arch/arm/mach-exynos/cpu.c
- arch/arm/mach-exynos/irq-eint.c
- arch/arm/mach-s3c64xx/common.c
- arch/arm/mach-s3c64xx/cpu.c
- arch/arm/mach-s5p64x0/cpu.c
- arch/arm/mach-s5pv210/common.c
- arch/arm/plat-samsung/include/plat/cpu.h
- arch/powerpc/kernel/sysfs.c
and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
This moves the 'cpu sysdev_class' over to a regular 'cpu' subsystem
and converts the devices to regular devices. The sysdev drivers are
implemented as subsystem interfaces now.
After all sysdev classes are ported to regular driver core entities, the
sysdev implementation will be entirely removed from the kernel.
Userspace relies on events and generic sysfs subsystem infrastructure
from sysdev devices, which are made available with this conversion.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Borislav Petkov <bp@amd64.org>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
When architectures register CPUs, they indicate whether the CPU allows
hotplugging; notably, x86 and ARM don't allow hotplugging CPU 0.
Userspace can easily query the hotpluggability of a CPU via sysfs;
however, the kernel has no convenient way of accessing that property in
an architecture-independent way. While the kernel can simply try it and
see, some code needs to distinguish between "hotplug failed" and
"hotplug has no hope of working on this CPU"; for example, rcutorture's
CPU hotplug tests want to avoid drowning out real hotplug failures with
expected failures.
Expose this property via a new cpu_is_hotpluggable function, so that the
rest of the kernel can access it in an architecture-independent way.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Remove the suspend_cpu_hotplug declaration, which doesn't correspond
to an existing variable.
[rjw: Added the changelog.]
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
We presently define all kinds of notifiers in notifier.h. This is not
necessary at all, since different subsystems use different notifiers, they
are almost non-related with each other.
This can also save much build time. Suppose I add a new netdevice event,
really I don't have to recompile all the source, just network related.
Without this patch, all the source will be recompiled.
I move the notify events near to their subsystem notifier registers, so
that they can be found more easily.
This patch:
It is not necessary to share the same notifier.h.
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Greg KH <greg@kroah.com>
drivers/base/intf.c was removed before the beginning of (git) time but
its Documentation stuck around. Remove it.
Signed-off-by: Brandon Philips <brandon@ifup.org>
Reimplement CPU hotplugging support using trustee thread. On CPU
down, a trustee thread is created and each step of CPU down is
executed by the trustee and workqueue_cpu_callback() simply drives and
waits for trustee state transitions.
CPU down operation no longer waits for works to be drained but trustee
sticks around till all pending works have been completed. If CPU is
brought back up while works are still draining,
workqueue_cpu_callback() tells trustee to step down and tell workers
to rebind to the cpu.
As it's difficult to tell whether cwqs are empty if it's freezing or
frozen, trustee doesn't consider draining to be complete while a gcwq
is freezing or frozen (tracked by new GCWQ_FREEZING flag). Also,
workers which get unbound from their cpu are marked with WORKER_ROGUE.
Trustee based implementation doesn't bring any new feature at this
point but it will be used to manage worker pool when dynamic shared
worker pool is implemented.
cpu on/offlining
Currently, when a cpu goes down, cpu_active is cleared before
CPU_DOWN_PREPARE starts and cpuset configuration is updated from a
default priority cpu notifier. When a cpu is coming up, it's set
before CPU_ONLINE but cpuset configuration again is updated from the
same cpu notifier.
For cpu notifiers, this presents an inconsistent state. Threads which
a CPU_DOWN_PREPARE notifier expects to be bound to the CPU can be
migrated to other cpus because the cpu is no more inactive.
Fix it by updating cpu_active in the highest priority cpu notifier and
cpuset configuration in the second highest when a cpu is coming up.
Down path is updated similarly. This guarantees that all other cpu
notifiers see consistent cpu_active and cpuset configuration.
cpuset_track_online_cpus() notifier is converted to
cpuset_update_active_cpus() which just updates the configuration and
now called from cpuset_cpu_[in]active() notifiers registered from
sched_init_smp(). If cpuset is disabled, cpuset_update_active_cpus()
degenerates into partition_sched_domains() making separate notifier
for !CONFIG_CPUSETS unnecessary.
This problem is triggered by cmwq. During CPU_DOWN_PREPARE, hotplug
callback creates a kthread and kthread_bind()s it to the target cpu,
and the thread is expected to run on that cpu.
* Ingo's test discovered __cpuinit/exit markups were incorrect.
Fixed.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Paul Menage <menage@google.com>
Instead of hardcoding priority 10 and 20 in sched and perf, collect
them into CPU_PRI_* enums.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
deallocate
Currently the cpu-allocation/deallocation process comprises of two steps:
- Set the indicators and to update the device tree with DLPAR node
information.
- Online/offline the allocated/deallocated CPU.
This is achieved by writing to the sysfs tunables "probe" during allocation
and "release" during deallocation.
At the sametime, the userspace can independently online/offline the CPUs of
the system using the sysfs tunable "online".
It is quite possible that when a userspace tool offlines a CPU
for the purpose of deallocation and is in the process of updating the device
tree, some other userspace tool could bring the CPU back online by writing to
the "online" sysfs tunable thereby causing the deallocate process to fail.
The solution to this is to serialize writes to the "probe/release" sysfs
tunable with the writes to the "online" sysfs tunable.
This patch employs a mutex to provide this serialization, which is a no-op on
all architectures except PPC_PSERIES
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Acked-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Version 3 of this patch is updated with documentation added to
Documentation/ABI. There are no changes to any of the C code from v2
of the patch.
In order to support kernel DLPAR of CPU resources we need to provide an
interface to add (probe) and remove (release) the resource from the system.
This patch Creates new generic probe and release sysfs files to facilitate
cpu probe/release. The probe/release interface provides for allowing each
arch to supply their own routines for implementing the backend of adding
and removing cpus to/from the system.
This also creates the powerpc specific stubs to handle the arch callouts
from writes to the sysfs files.
The creation and use of these files is regulated by the
CONFIG_ARCH_CPU_PROBE_RELEASE option so that only architectures that need the
capability will have the files created.
Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com>
This patch introduces a new cpu_notifier() API that is similar
to hotcpu_notifier(), but which also notifies of CPUs coming
online during boot in the !HOTPLUG_CPU case.
Reported-by: Ingo Molnar <mingo@elte.hu>
Reported-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Tested-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: josht@linux.vnet.ibm.com
Cc: akpm@linux-foundation.org
Cc: mathieu.desnoyers@polymtl.ca
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: benh@kernel.crashing.org
LKML-Reference: <12503552312611-git-send-email->
SLAB uses get/put_online_cpus() which use a mutex which is itself only
initialized when cpu_hotplug_init() is called. Currently we hang suring
boot in SLAB due to doing that too late.
Reported by James Bottomley and Sachin Sant (and possibly others).
Debugged by Benjamin Herrenschmidt.
This just removes the dynamic initialization of the data structures, and
replaces it with a static one, avoiding this dependency entirely, and
removing one unnecessary special initcall.
Tested-by: Sachin Sant <sachinp@in.ibm.com>
Tested-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
cpuhotplug_mutex_lock() is not used, remove it.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Gautham R Shenoy <ego@in.ibm.com>
Right now, there is no notifier that is called on a new cpu, before the new
cpu begins processing interrupts/softirqs.
Various kernel function would need that notification, e.g. kvm works around
by calling smp_call_function_single(), rcu polls cpu_online_map.
The patch adds a CPU_STARTING notification. It also adds a helper function
that sends the message to all cpu_chain handlers.
Tested on x86-64.
All other archs are untested. Especially on sparc, I'm not sure if I got
it right.
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
workqueue_cpu_callback(CPU_DEAD) flushes cwq->thread under
cpu_maps_update_begin(). This means that the multithreaded workqueues
can't use get_online_cpus() due to the possible deadlock, very bad and
very old problem.
Introduce the new state, CPU_POST_DEAD, which is called after
cpu_hotplug_done() but before cpu_maps_update_done().
Change workqueue_cpu_callback() to use CPU_POST_DEAD instead of CPU_DEAD.
This means that create/destroy functions can't rely on get_online_cpus()
any longer and should take cpu_add_remove_lock instead.
[akpm@linux-foundation.org: fix CONFIG_SMP=n]
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Max Krasnyansky <maxk@qualcomm.com>
Cc: Paul Jackson <pj@sgi.com>
Cc: Vegard Nossum <vegard.nossum@gmail.com>
Fix following warnings:
WARNING: vmlinux.o(.data+0x5020): Section mismatch in reference from the variable cpu_vsyscall_notifier_nb.12876 to the function .cpuinit.text:cpu_vsyscall_notifier()
WARNING: vmlinux.o(.data+0x9ce0): Section mismatch in reference from the variable profile_cpu_callback_nb.17654 to the function .devinit.text:profile_cpu_callback()
WARNING: vmlinux.o(.data+0xd380): Section mismatch in reference from the variable workqueue_cpu_callback_nb.15004 to the function .devinit.text:workqueue_cpu_callback()
WARNING: vmlinux.o(.data+0x11d00): Section mismatch in reference from the variable relay_hotcpu_callback_nb.19626 to the function .cpuinit.text:relay_hotcpu_callback()
WARNING: vmlinux.o(.data+0x12970): Section mismatch in reference from the variable cpu_callback_nb.24694 to the function .devinit.text:cpu_callback()
WARNING: vmlinux.o(.data+0x3fee0): Section mismatch in reference from the variable percpu_counter_hotcpu_callback_nb.10903 to the function .cpuinit.text:percpu_counter_hotcpu_callback()
WARNING: vmlinux.o(.data+0x74ce0): Section mismatch in reference from the variable topology_cpu_callback_nb.12506 to the function .cpuinit.text:topology_cpu_callback()
Functions used as argument are by definition only used in HOTPLUG_CPU
situations so thay are annotated __cpuinit. Annotate the static variable used
by hotcpu_register with __cpuinitdata to match this definition.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Gautham R Shenoy <ego@in.ibm.com>
None of these files use any of the functionality promised by
asm/semaphore.h. It's possible that they (or some user of them) rely
on it dragging in some unrelated header file, but I can't build all
these files, so we'll have to fix any build failures as they come up.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
fix build on !CONFIG_SMP.
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use
get_online_cpus and put_online_cpus instead as it highlights the
refcount semantics in these operations.
The new API guarantees protection against the cpu-hotplug operation, but
it doesn't guarantee serialized access to any of the local data
structures. Hence the changes needs to be reviewed.
In case of pseries_add_processor/pseries_remove_processor, use
cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the
cpu_present_map there.
This patch implements a Refcount + Waitqueue based model for
cpu-hotplug.
Now, a thread which wants to prevent cpu-hotplug, will bump up a global
refcount and the thread which wants to perform a cpu-hotplug operation
will block till the global refcount goes to zero.
The readers, if any, during an ongoing cpu-hotplug operation are blocked
until the cpu-hotplug operation is over.
Signed-off-by: Paul Jackson <pj@sgi.com> [For !CONFIG_HOTPLUG_CPU ]
make randconfig bootup testing found that the cpufreq code
crashes on bootup, if the powernow-k8 driver is enabled and
if maxcpus=1 passed on the boot line to a !CONFIG_HOTPLUG_CPU
kernel.
First lockdep found out that there's an inconsistent unlock
sequence:
[ BUG: bad unlock balance detected! ]
swapper/1 is trying to release lock (&per_cpu(cpu_policy_rwsem, cpu)) at:
[<ffffffff806ffd8e>] unlock_policy_rwsem_write+0x3c/0x42
but there are no more locks to release!
Call Trace:
[<ffffffff80251c29>] print_unlock_inbalance_bug+0x104/0x12c
[<ffffffff80252f3a>] mark_held_locks+0x56/0x94
[<ffffffff807008b6>] cpufreq_add_dev+0x2a8/0x5c4
then shortly afterwards the cpufreq code crashed on an assert:
kernel BUG at drivers/cpufreq/cpufreq.c:1068!
invalid opcode: 0000 [1] SMP
Call Trace:
[<ffffffff805145d6>] sysdev_driver_unregister+0x5b/0x91
[<ffffffff806ff520>] cpufreq_register_driver+0x15d/0x1a2
[<ffffffff80cc0596>] powernowk8_init+0x86/0x94
---[ end trace 1e9219be2b4431de ]---
the bug was caused by maxcpus=1 bootup, which brought up the
secondary core as !cpu_online() but !cpu_is_offline() either,
which on on !CONFIG_HOTPLUG_CPU is always 0 (include/linux/cpu.h):
/* CPUs don't go offline once they're online w/o CONFIG_HOTPLUG_CPU */
static inline int cpu_is_offline(int cpu) { return 0; }
but the cpufreq code uses cpu_online() and cpu_is_offline() in
a mixed way - the low-level drivers use cpu_online(), while
the cpufreq core uses cpu_is_offline(). This opened up the
possibility to add the non-initialized sysdev device of the
secondary core:
cpufreq-core: trying to register driver powernow-k8
cpufreq-core: adding CPU 0
powernow-k8: BIOS error - no PSB or ACPI _PSS objects
cpufreq-core: initialization failed
cpufreq-core: adding CPU 1
which then blew up. The fix is to make cpu_is_offline() always
the negation of cpu_online(). With that fix applied the kernel
boots up fine without crashing:
Calling initcall 0xffffffff80cc0510: powernowk8_init+0x0/0x94()
powernow-k8: Found 1 AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ processors (1 cpu cores) (version 2.20.00)
initcall 0xffffffff80cc0510: powernowk8_init+0x0/0x94() returned -19.
initcall 0xffffffff80cc0510 ran for 19 msecs: powernowk8_init+0x0/0x94()
Calling initcall 0xffffffff80cc328f: init_lapic_nmi_sysfs+0x0/0x39()
We could fix this by making CPU enumeration aware of max_cpus, but that
would be more fragile IMO, and the cpu_online(cpu) != cpu_is_offline(cpu)
possibility was quite confusing and a continuous source of bugs too.
Most distributions have kernels with CPU hotplug enabled, so this bug
remained hidden for a long time.
Bug forensics:
The broken cpu_is_offline() API variant was introduced via:
commit a59d2e4e6977e7b94e003c96a41f07e96cddc340
Author: Rusty Russell <rusty@rustcorp.com.au>
Date: Mon Mar 8 06:06:03 2004 -0800
[PATCH] minor cleanups for hotplug CPUs
( this predates linux-2.6.git, this commit is available from Thomas's
historic git tree. )
Then 1.5 years later the cpufreq code made use of it:
commit c32b6b8e524d2c337767d312814484d9289550cf
Author: Ashok Raj <ashok.raj@intel.com>
Date: Sun Oct 30 14:59:54 2005 -0800
[PATCH] create and destroy cpufreq sysfs entries based on cpu notifiers
+ if (cpu_is_offline(cpu))
+ return 0;
which is a correct use of the subtly broken new API. v2.6.15 then
shipped with this bug included.
then it took two more years for random-kernel qa to hit it.
The return of the present "do {} while" based stub definition of
register_hotcpu_notifier() cannot be checked. This makes the stub
asymmetric w.r.t. the real HOTPLUG_CPU=y implementation that is
int-returning. So let us redefine this to be consistent with the full
version. Also do the same for unregister_hotcpu_notifier().
We cannot define these as static inline functions due to an existing GCC
bug (#33172). So define as macros that return appropriately instead (int
'0' for the register_hotcpu_notifier case and void for
unregister_hotcpu_notifier).
Signed-off-by: Satyam Sharma <satyam@infradead.org>
Dependencies of CONFIG_SUSPEND and CONFIG_HIBERNATION introduced by commit
296699de6bdc717189a331ab6bbe90e05c94db06 "Introduce CONFIG_SUSPEND for
suspend-to-Ram and standby" are incorrect, as they don't cover the facts that
(1) not all architectures support suspend and (2) SMP hibernation is only
possible on X86 and PPC64 (if CONFIG_PPC64_SWSUSP is set).
This patch makes the following needlessly global code static:
- arch_reinit_sched_domains()
- struct attr_sched_mc_power_savings
- struct attr_sched_smt_power_savings
aa95387774039096c11803c04011f1aa42d85758 removed the implementation of
lock_cpu_hotplug_interruptible and all users of it. This stub definition
for !CONFIG_HOTPLUG_CPU was left over -- kill it now.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
sysdev.h uses THIS_MODULE so should include <linux/module.h>.
[akpm@linux-foundation.org: couple of fixes]
Cc: Andi Kleen <ak@suse.de>
Fix the regression resulting from the recent change of suspend code
ordering that causes systems based on Intel x86 CPUs using the microcode
driver to hang during the resume.
The problem occurs since the microcode driver uses request_firmware() in
its CPU hotplug notifier, which is called after tasks has been frozen and
hangs. It can be fixed by telling the microcode driver to use the
microcode stored in memory during the resume instead of trying to load it
from disk.
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Maxim <maximlevitsky@gmail.com>
!CONFIG_HOTPLUG_CPU
The following patchset allows a host with running virtual machines to be
suspended and, on at least a subset of the machines tested, resumed. Note
that this is orthogonal to suspending and resuming an individual guest to a
file.
A side effect of implementing suspend/resume is that cpu hotplug is now
supported. This should please the owners of big iron.
This patch:
KVM wants the cpu hotplug notifications, both for cpu hotplug itself, but more
commonly for host suspend/resume.
In order to avoid extensive #ifdefs, provide stubs when CONFIG_CPU_HOTPLUG is
not defined.
In all, we have four cases:
- UP: register and unregister stubbed out
- SMP+hotplug: full register and unregister
- SMP, no hotplug, core: register as __init, unregister stubbed
(cpus are brought up during core initialization)
- SMP, no hotplug, module: register and unregister stubbed out
(cpus cannot be brought up during module lifetime)
Signed-off-by: Avi Kivity <avi@qumranet.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits)
[PATCH] x86-64: Export smp_call_function_single
[PATCH] i386: Clean up smp_tune_scheduling()
[PATCH] unwinder: move .eh_frame to RODATA
[PATCH] unwinder: fully support linker generated .eh_frame_hdr section
[PATCH] x86-64: don't use set_irq_regs()
[PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq
[PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM
[PATCH] i386: replace kmalloc+memset with kzalloc
[PATCH] x86-64: remove remaining pc98 code
[PATCH] x86-64: remove unused variable
[PATCH] x86-64: Fix constraints in atomic_add_return()
[PATCH] x86-64: fix asm constraints in i386 atomic_add_return
[PATCH] x86-64: Correct documentation for bzImage protocol v2.05
[PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code
[PATCH] x86-64: Fix numaq build error
[PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header
[PATCH] unwinder: Add debugging output to the Dwarf2 unwinder
[PATCH] x86-64: Clarify error message in GART code
[PATCH] x86-64: Fix interrupt race in idle callback (3rd try)
[PATCH] x86-64: Remove unwind stack pointer alignment forcing again
Fixed conflict in include/linux/uaccess.h manually
Provide a common interface for all the subsystems to lock and unlock their
per-subsystem hotcpu mutexes.
When CONFIG_HOTPLUG_CPU is not set, these operations would be no-ops.
[akpm@osdl.org: macros -> inlines]
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn,
prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus
generating compiler warnings of unused symbols, hence forcing people to add
#ifdefs.
the compiler can skip truly unused functions just fine:
1624412 728710 3674856 6027978 5bfaca vmlinux.before
1624412 728710 3674856 6027978 5bfaca vmlinux.after
[akpm@osdl.org: topology.c fix]
Change the 'no_control' field in the cpu struct to a more positive
and better term 'hotpluggable'. And change(/cleanup) the logic accordingly.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Cc: "Li, Shaohua" <shaohua.li@intel.com>
This patch adds two functions to create and remove sysfs attributes and
attribute_group to all cpus. That allows to register sysfs attributes in
a subdirectory like: /sys/devices/system/cpu/cpuX/group_name/what_ever
This will be used by cbe_thermal to group all attributes dealing with
thermal support in one directory.
Signed-of-by: Christian Krafft <krafft@de.ibm.com>
The current suspend code has to be run on one CPU, so we use the CPU
hotplug to take the non-boot CPUs offline on SMP machines. However, we
should also make sure that these CPUs will not be enabled by someone else
after we have disabled them.
The functions disable_nonboot_cpus() and enable_nonboot_cpus() are moved to
kernel/cpu.c, because they now refer to some stuff in there that should
better be static. Also it's better if disable_nonboot_cpus() returns an
error instead of panicking if something goes wrong, and
enable_nonboot_cpus() has no reason to panic(), because the CPUs may have
been enabled by the userland before it tries to take them online.
Acked-by: Pavel Machek <pavel@ucw.cz>
The CPU hotplug locking was quite messy, with a recursive lock to
handle the fact that both the actual up/down sequence wanted to
protect itself from being re-entered, but the callbacks that it
called also tended to want to protect themselves from CPU events.
This splits the lock into two (one to serialize the whole hotplug
sequence, the other to protect against the CPU present bitmaps
changing). The latter still allows recursive usage because some
subsystems (ondemand policy for cpufreq at least) had already gotten
too used to the lax locking, but the locking mistakes are hopefully
now less fundamental, and we now warn about recursive lock usage
when we see it, in the hope that it can be fixed.
Always use do {} while (0). Failing to do so can cause subtle compile
failures or bugs.
Cc: Chandra Seetharaman <sekharan@us.ibm.com>
Define new macros register_hotcpu_notifier() and unregister_hotcpu_notifier()
that redefines register_cpu_notifier() and unregister_cpu_notifier() for use
only when HOTPLUG_CPU is defined.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Cc: Ashok Raj <ashok.raj@intel.com>
CPUs come online only at init time (unless CONFIG_HOTPLUG_CPU is defined).
So, cpu_notifier functionality need to be available only at init time.
This patch makes register_cpu_notifier() available only at init time, unless
CONFIG_HOTPLUG_CPU is defined.
This patch exports register_cpu_notifier() and unregister_cpu_notifier() only
if CONFIG_HOTPLUG_CPU is defined.
With Goto-san's patch, we can add new pgdat/node at runtime. I'm now
considering node-hot-add with cpu + memory on ACPI.
I found acpi container, which describes node, could evaluate cpu before
memory. This means cpu-hot-add occurs before memory hot add.
In most part, cpu-hot-add doesn't depend on node hot add. But register_cpu(),
which creates symbolic link from node to cpu, requires that node should be
onlined before register_cpu(). When a node is onlined, its pgdat should be
there.
This patch-set holds off creating symbolic link from node to cpu
until node is onlined.
This removes node arguments from register_cpu().
Now, register_cpu() requires 'struct node' as its argument. But the array of
struct node is now unified in driver/base/node.c now (By Goto's node hotplug
patch). We can get struct node in generic way. So, this argument is not
necessary now.
This patch also guarantees add cpu under node only when node is onlined. It
is necessary for node-hot-add vs. cpu-hot-add patch following this.
Moreover, register_cpu calculates cpu->node_id by cpu_to_node() without regard
to its 'struct node *root' argument. This patch removes it.
Also modify callers of register_cpu()/unregister_cpu, whose args are changed
by register-cpu-remove-node-struct patch.
[Brice.Goglin@ens-lyon.org: fix it]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org>
- Moved check for online cpu out of smp_prepare_cpu()
- Moved default declaration of smp_prepare_cpu() to kernel/cpu.c
- Removed lock_cpu_hotplug() from smp_prepare_cpu() to around it, since
its called from cpu_up() as well now.
- Removed clearing from cpu_present_map during cpu_offline as it breaks
using cpu_up() directly during a subsequent online operation.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com>
Doing (int < NR_CPUS) doesn't dtrt if it's negative..
There are some callers in cpufreq hotplug notify path that the lowest
function calls lock_cpu_hotplug(). The lock is already held during
cpu_up() and cpu_down() calls when the notify calls are broadcast to
registered clients.
Ideally if possible, we could disable_preempt() at the highest caller and
make sure we dont sleep in the path down in cpufreq->driver_target() calls
but the calls are so intertwined and cumbersome to cleanup.
Hence we consistently use lock_cpu_hotplug() and unlock_cpu_hotplug() in
all places.
- Removed export of cpucontrol semaphore and made it static.
- removed explicit uses of up/down with lock_cpu_hotplug()
so we can keep track of the the callers in same thread context and
just keep refcounts without calling a down() that causes a deadlock.
- Removed current_in_hotplug() uses
- Removed PF_HOTPLUG_CPU in sched.h introduced for the current_in_hotplug()
temporary workaround.
Tested with insmod of cpufreq_stat.ko, and logical online/offline
to make sure we dont have any hang situations.
Cc: Zwane Mwaikambo <zwane@linuxpower.ca>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
When calling target drivers to set frequency, we take cpucontrol lock.
When we modified the code to accomodate CPU hotplug, there was an attempt
to take a double lock of cpucontrol leading to a deadlock. Since the
current thread context is already holding the cpucontrol lock, we dont need
to make another attempt to acquire it.
Now we leave a trace in current->flags indicating current thread already is
under cpucontrol lock held, so we dont attempt to do this another time.
Thanks to Andrew Morton for the beating:-)
Build fix
(akpm: this patch is still unpleasant. Ashok continues to look for a cleaner
solution, doesn't he? ;))
Some modules creating sysfs entries under /sys/devices/system/cpu/cpuX/
need to know the parent sysfs entry to make devices under them. This will
just return the sysfs entry for a given cpu.
sysfs entries showing under each cpu sysfs can be easily created if such
entries can be created by registering a sysfs driver for cpuclass. The
issue is when the entry is created the CPU may not be online, hence we
would need to defer the creation until the online notification comes.
Current users: cache entries for Intel CPU's and cpufreq subsystem.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Zwane Mwaikambo <zwane@holomorphy.com>
net/sunrpc/rpc_pipe.c
This patch is against 2.6.10, but still applies cleanly. It's just
s/driverfs/sysfs/ in these two files.
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
